cisco ISR 11000 Stuck after image validated Please HELP!
IT SOLUTIONS
Community Member
Rom image verified correctly
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
C1111-4P platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located throughput_monitor_params
Unsupported package header version (-1347440721)
Located c1100-universalk9_ias.16.09.02.SPA.bin
Package header rev 3 structure detected
IsoSize = 416391168
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 3247276D:E1CAC3CB:E6327294:86F39D2D:155D7289
expected 3247276D:E1CAC3CB:E6327294:86F39D2D:155D7289
RSA Signed RELEASE Image Signature Verification Successful
Image validated
17 Replies 17
Leo Laohoo
Use a different firmware version, like 16.9.8.
Sorry I'm clueless about cisco routers, which one of the two? and how would load it into the router?
Break the boot into ROMMON.
Download the firmware into a USB flash drive.
Insert the flash drive into the router and use the command "boot usbflash0:filename.bin"
I'm sorry Leo I cannot download  it it says that I need to have a "Valid Service Contract" I need to get it wit CISCO if I bought it directly; but since this Router was here an the previous IT guy left without any information about this router I'm stuk!!
Any advice?
Any advice?
Read this:  Cisco IOS and IOS XE Software DHCP Remote Code Execution Vulnerability
Pay attention to the Customers Without Service Contracts section:
Customers who purchase directly from Cisco but do not hold a Cisco service contract and customers who make purchases through third-party vendors but are unsuccessful in obtaining fixed software through their point of sale should obtain upgrades by contacting the Cisco TAC.
Customers should have the product serial number available and be prepared to provide the URL of this advisory as evidence of entitlement to a free upgrade.
Email TAC and provide the serial number of the router.  Request TAC to publish 16.9.8 and provide TAC the filename.
If the solution works, please take the time to mark this thread as "Answered".
confreg01
Level 2
Level 2
Same issue, used 16.09.08.bin
rommon 4 > boot usb0:1100-universalk9_ias.16.09.08.SPA.bin
Located c1100-universalk9_ias.16.09.08.SPA.bin
but the unit is stuck at the below prompt:
rommon 4 > boot usb0:c1100-universalk9_ias.16.09.08.SPA.bin
IsoSize = 419405824
calculated B750CE21:8A08A447:D2561455:367908BB:B2DF867B
expected B750CE21:8A08A447:D2561455:367908BB:B2DF867B
Image validated
PHY reset timed out
PHY reset timed out
Last reset cause: Unrecoverable Error
C1117-4PLTEEAWE platform with 4194304 Kbytes of main memory
IsoSize = 416391168
Image validated
This issue remains, unfortunately.
confreg01
Level 2
Level 2
Issue Remains even with 16.09.08.bin immage
rommon 1 > set
PS1=rommon ! >
THRPUT=
LICENSE_SUITE=
LICENSE_BOOT_LEVEL=
MCP_STARTUP_TRACEFLAGS=00000000:00000000
ETHER_PORT=0
TFTP_RETRY_COUNT=20
RET_2_RTS=14:50:08 BST Wed Apr 21 2021
BSI=0
RET_2_RCALTS=
RANDOM_NUM=1340303014
CRASHINFO=webui:crashinfo_20210503-145135-BST
BOOT=usb0:c1100-universalk9_ias.16.09.03.SPA.bin
rommon 2 > BOOT=usb0:c1100-universalk9_ias.16.09.08.SPA.bin
rommon 3 > sync
rommon 4 > set
PS1=rommon ! >
THRPUT=
LICENSE_SUITE=
LICENSE_BOOT_LEVEL=
ETHER_PORT=0
TFTP_RETRY_COUNT=20
BSI=0
RET_2_RCALTS=
rommon 5 > boot usb0:c1100-universalk9_ias.16.09.08.SPA.bin
Froze at this point:
IsoSize = 419405824
Booting from usb0: not working.
Setting usb0: boot variable not working.
Use a different firmware version.  Try 17.9.4a.
fabiofariasff
Visitor
Hello guys, someone found solutions for this problem? I have the same problem with cisco asr 1001-x. I tried various images but the problem persist
Console into the router and reboot the router.
Post the entire boot-up process.
Hi Leo, Thanks so much for your reply!
In 16 version the reboot show:
Initializing Hardware ...
System integrity status: 00000610
U
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
ASR1001-X platform with 8388608 Kbytes of main memory
File size is 0x2a530e45
Located asr1001x-universalk9.16.06.02.SPA.bin
Image size 710086213 inode num 12, bks cnt 173361 blk size 8*512
Boot image size = 710086213 (0x2a530e45) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated cdc97600:ad24c658:e667d433:cedb6e17:8e52b5c8
expected cdc97600:ad24c658:e667d433:cedb6e17:8e52b5c8
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
ÿ
U
Image validated
ÿ
And in 17 version is a little different, it is bellow:
Receiving asr1001x-universalk9.17.06.01a.SPA.bin from 192.0.2.250 !!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
Boot image size = 725957510 (0x2b453b86) bytes
calculated b8a7af7d:ddd5981c:3a792ea2:57ac5d38:a59516e2
expected b8a7af7d:ddd5981c:3a792ea2:57ac5d38:a59516e2
Image validated
ÿ* localhost
State: initializing
Jobs: 11 queued
Failed: 0 units
Since: Wed 2014-01-01 20:19:40 Universal; 1min 30s ago
CGroup: /
|-init.scope
| `-1 /init
`-system.slice
|-system-systemd\x2dfsck.slice
| `-systemd-fsck@dev-usb0.service
| |-246 /bin/bash /sbin/fsck_or_mkfs.sh /dev/usb0
| `-266 /sbin/fsck -y -T /dev/usb0
|-systemd-udevd.service
| `-210 /usr/lib/systemd/systemd-udevd
|-report_fails.service
| `-245 systemctl status -l -n 100 -o short-monotonic --no-pager
|-systemd-tmpfiles-setup.service
| `-247 /usr/bin/systemd-tmpfiles --create --remove --boot --exclud
`-systemd-journald.service
`-135 /usr/lib/systemd/systemd-journald
>>> Rebooting
you need to set up the boot variable,.   can you go into rommon mode and check to see what files are there?  Then boot from any of the files. or previous image.     can you take screenshot of files that are there?
