09-30-2020 05:12 AM
I know that using Cisco Cloud OnRamp for IaaS I can spin up virtual vEdges on AWS or Azure but that would be tied to the selected location. Does Cloud OnRamp offers a feature you can set up more than one location?
Let's say, I want to spin my vEdges on US-EAST but for whatever reason US-EAST has a problem the connections could seamlessly go to US-WEST?
The basic idea here is to not be tied to a specif AWS / Azure location
Thank you.
Solved! Go to Solution.
09-30-2020 09:58 PM
Yes you can. This all depends on which Resource Group you allow to connect to OnRamp, East/West or both. Currently we are only using US-West to tie in with Azure and OnRamp.
I believe you need 2 vEdge licenses for each region you want to connect to.
09-30-2020 09:58 PM
