Filter routes
anitachoi3
Level 6
Level 6
Hi expert,
I would like to filter a route which is exactly match the condition. Below is the requirement:
A.
1. allow 192.168.30.0/30
2. not allow 192.168.30.0/29 or other
3. not allow 192.168.30.0/31 or other.
B.
1. not allow 192.168.30.0/30
2. allow 192.168.30.0/29 or other
3. allow 192.168.30.0/31 or other.
It seems that ACL cannot do it. please advise.
rdgs
Anita
yes it will deny everything else except 192.168.30.0/30
Regards.
Alain.
10 Replies 10
smitesh kharecha
Level 10
Level 10
Hi Anita,
Use prefix-list
A. permit 192.168.30.0 ge /30 will block all other which has subnet less than /30
B. You need to add permit statement for just 192.168.30.0/30 only.
Smitesh
Latchum Naidu
Hi Anita,
I would suggest you to use route-map in order to get your required routes filter.
A.
ip access ex 100
permit ip 192.168.30.0 0.0.0.3
deny any any
route-map Route_filter1 permit 10
match ip address 100
B.
ip access ex 200
permit ip 192.168.30.0 0.0.0.7
permit ip 192.168.30.0 0.0.0.2
deny any any
match ip address 200
Please rate the helpfull posts.
Naidu.
Dear Naidu,
For A, if there is a route 192.168.30.0 255.255.255.254 (192.168.30.0/31), it should be cover by ACL 100 becasue 0.0.0.3 should include it. Not sure that I am right or wrong. please advise.
How to allow the route "/30" but not accept "/31", "/32"?
rdgs
Anita
Hi Anita,
You can use the below one..
ip access ex 200
deny any any
Naidu.
Hi Naidu,
If the route is 192.168.30.0 0.0.0.1, the ACL 200 should pernit it. Is it correct?
rdge
Anita
the only way to filter prefixes and prefix-length is with a prefix-list.
It may be configure with a special  extended ACL but I don't know if it will work in every routing protocols( I know it's possible with BGP).In this case you match the prefix-length with the destination part, it should be something like this:
for permitting only 192.168.1.0/24: access-list 100 permit 192.168.1.0 0.0.0.255 255.255.255.0 0.0.0.255
But the prefix-list is the tool to use for such cases as it is easier to implement.
Regards.
Alain
Dear Alain,
Please see if it is working or not.
For A:
ip prefix-list abc seq 5 deny 192.168.30.0 gt 30
ip prefix-list abc seq 10 deny 192.168.30.0 le 30
ip prefix-list abc seq 15 permit any
For B:
ip prefix-list abc seq 5 permit 192.168.30.0 gt 30
ip prefix-list abc seq 10 premit 192.168.30.0 le 30
rdgs
Anita
for A: denying /29 and /31 but permitting anything else included /30
ip prefix-list abc seq 5 deny 192.168.30.0/29
ip prefix-list abc seq 10 deny 192.168.30.0/31
ip prefix-list abc seq 15 permit 0.0.0.0/0 le 32
for B: denying /30 but permitting anything else included /29 and /31
ip prefix-list abc seq 5 deny 192.168.30.0/30
ip prefix-list abc seq 10 permit  0.0.0.0/0 le 32
Regards.
Alain
Hi Alain,
Does it work for A:
ip prefix-list abc seq 5 permit 192.168.30.0/30
could it block 192.168.30.0/32, /31, /29, /28.....
rdgs
Anita
Regards.
Alain.
