Help with extended access list
danilo-mugosa04
Frequent Visitor
Frequent Visitor
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've written
ip access-list extended VLAN10-PING
permit icmp 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
deny icmp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
permit ip any any
ip access-list extended VLAN20-PING
permit icmp 192.168.20.0 0.0.0.255 192.168.20.0 0.0.0.255
deny icmp 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip any any
Here is the zip file.. Please help
as @Joseph W. Doherty said, you need to apply the access lists (which look almost correct in your first post) to the relevant subinterfaces. So:
permit ip any any
interface GigabitEthernet0/0.10
description VLAN 10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip access-group VLAN10-PING in
permit ip any any
interface GigabitEthernet0/0.20
description VLAN 20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip access-group VLAN20-PING in
8 Replies 8
Joseph W. Doherty
Well, for starters, you have the ACL applied on the main interface.  Try applying in on the router's relevant subinterface(s).
Next, at the IP level, same network traffic shouldn't be going to gateway, so your permit ICMP ACEs aren't needed.
Next, if you want to deny all ICMP between VLANs, your ACE can be much simpler.
Lastly, do you really want to block all ICMP, or just ping?
Just ping
Is this something that I should do ?
ip access-list extended DENY-ICMP-BETWEEN-VLANS
deny icmp any any
description VLAN 10
ip access-group DENY-ICMP-BETWEEN-VLANS in
permit ip any any
description VLAN 10
permit ip any any
description VLAN 20
Is this also valid solution ?
! Define ACLs to deny all ICMP traffic between VLANs
deny icmp any any
! Apply ACLs on subinterfaces
description VLAN 10
description VLAN 20
Because here I dont need to use this  deny icmp 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 for every single VLAN
this will almost work. Keep in mind that every access list has an implicit 'deny all' at the end. So you need to add 'permit ip any any' at the bottom, otherwise everything will be blocked.
Joseph W. Doherty
Almost there!
Between your and @Georg Pauwen replies, if you want to limit this blocking to pings you only now need to limit the ACE to just pings.  So, hint, consider ALL the options on your deny ACE.
Lastly, consider will a single deny ACE, for blocking pings be sufficient?  Hint, this last question, and its correct answer, is important to understanding how to solve this network requirement.
A similar question of ACL usage would be should ACL be used in, out or both?
Hint, last two questions are for understanding, because might there be multiple "correct" answers or is there truly one "right" answer?
Again, above questions might help you much in future ACL issues but are not needed to solve your OP.
I think I solved a problem now I've got the new one with routing can you guys help me with it ?
https://community.cisco.com/t5/routing/help-with-dynamic-routing/td-p/5076169
