09-29-2012 10:47 AM - edited 03-04-2019 05:42 PM
Dear concern,
Our Router 7606 is in a problem with high CPU Utilization. We are using one EBGP and one IBGP session. We are also running OSPF with area 0 between two IBGP router to exchange few local networks. When bandwidth cross 100 MB than only CPU use become 100%. when bandwidth consumption is 80MB CPU use become 80% end so on.
Pls find the bellow out put and assist us.
Out put is when bandwidth consumption is 34MB
CPU utilization for five seconds: 44%/43%; one minute: 42%; five minutes: 30%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
78 44 9625 4 0.39% 0.03% 0.00% 2 Virtual Exec
13 40 375 106 0.07% 0.00% 0.00% 0 ARP Input
30 116 1098 105 0.07% 0.01% 0.00% 0 IPC Seat Manager
164 524 42660 12 0.07% 0.04% 0.05% 1 Virtual Exec
186 0 22945 0 0.07% 0.03% 0.02% 0 ACE Tunnel Task
259 12 89401 0 0.07% 0.10% 0.08% 0 Ethernet Msec Ti
1 0 8 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 4 156 25 0.00% 0.01% 0.00% 0 Load Meter
4 0 47 0 0.00% 0.00% 0.00% 0 SCP async: Draco
5 0 173 0 0.00% 0.00% 0.00% 0 Retransmission o
6 0 3 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
7 0 1 0 0.00% 0.00% 0.00% 0 PF Redun ICC Req
8 8684 466 18635 0.00% 0.86% 0.81% 0 Check heaps
9 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
10 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
11 0 2 0 0.00% 0.00% 0.00% 0 Timers
12 4 226 17 0.00% 0.00% 0.00% 0 WATCH_AFS
14 8 853 9 0.00% 0.00% 0.00% 0 ARP Background
15 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
16 0 1 0 0.00% 0.00% 0.00% 0 ATM ASYNC PROC
End = e Freeze = f
Enter Command:
RTLSGR1#sh memory statistics
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 1322CA94 1692218732 522133152 1170085580 1168835904 1169364236
I/O 78000000 134217728 50319772 83897956 83897956 83896252
RTLSGR1#sh cef drop
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [feature]'
IPv4 CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 0 0 422 10 4 0
5/0 0 0 0 0 0 0
3/0 0 0 0 0 0 0
RTLSGR1#
SUP
RSP720-3C-GE
IOS
c7600rsp72043_rp-ADVENTERPRISEK9-M
Solved! Go to Solution.
10-02-2012 05:06 AM
Please don't forget to mark the query as answered if you are satisfied with the answer
09-29-2012 11:33 PM
The reason for high cpu is interrupts here (44%/43%)
When did you start seeing this issue? Did you make any change prior to this issue
Can you upload the following output
1. Show tech
2. Show interfaces | inc up|rate|drop
09-30-2012 12:37 AM
The router was configured one month back and was running well.One week back customer complain with dropping the packet through ICMP/Ping. After issuing sh proc cpu moni we found CPU uses increase parallal to bandwidth consumption.
RTLSGR1#
RTLSGR1#Show interfaces | inc up|rate|drop
GigabitEthernet5/1 is up, line protocol is up (connected)
Full-duplex, 1000Mb/s, media type is LH
Input queue: 0/75/4426/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
5 minute input rate 117567000 bits/sec, 151845 packets/sec
5 minute output rate 113281000 bits/sec, 144974 packets/sec
0 unknown protocol drops
GigabitEthernet5/2 is up, line protocol is up (connected)
5 minute input rate 43863000 bits/sec, 68152 packets/sec
5 minute output rate 48144000 bits/sec, 75019 packets/sec
Loopback0 is up, line protocol is up
Keepalive not supported
RTLSGR1#sh tech-support
------------------ show clock ------------------
*07:10:26.950 UTC Sun Sep 30 2012
------------------ show version ------------------
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 15-Mar-12 05:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
RTLSGR1 uptime is 21 hours, 10 minutes
Uptime for this control processor is 21 hours, 10 minutes
System returned to ROM by reload (SP by reload)
System image file is "bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO7606-S (M8500) processor (revision 1.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX1249G0P1
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
2 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
------------------ show running-config ------------------
Building configuration...
Current configuration : 3282 bytes
! Last configuration change at 20:13:17 UTC Sat Sep 29 2012 by rtl
version 12.2
service password-encryption
service counters max age 10
hostname RTLSGR1
boot-start-marker
boot system flash sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin
boot-end-marker
enable secret 5
enable password 7
no aaa new-model
no ip source-route
no ip domain lookup
vtp mode transparent
mls rp ip
no mls flow ip
no mls flow ipv6
no mls rate-limit multicast ipv4 fib-miss
no mls rate-limit multicast ipv4 partial
no mls rate-limit unicast acl vacl-log
no mls rate-limit unicast ip rpf-failure
no mls rate-limit unicast ip icmp unreachable no-route
no mls rate-limit unicast ip icmp unreachable acl-drop
no mls rate-limit unicast ip errors
no mls rate-limit all ttl-failure
no mls rate-limit all mtu-failure
mls cef error action reset
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
username das privilege 15 secret 5
username rtl privilege 15 secret 5
redundancy
main-cpu
auto-sync running-config
mode sso
vlan internal allocation policy ascending
ip ssh version 2
class-map match-all icmp
match protocol icmp
policy-map icmp-policy
class icmp
priority 100
class class-default
fair-queue
interface Loopback0
ip address 192.168.18.3 255.255.255.240
interface GigabitEthernet5/1
description Internet With NetroNext
ip address 103.14.80.19 255.255.255.240
speed nonegotiate
interface GigabitEthernet5/2
ip address 103.12.212.130 255.255.255.252
speed nonegotiate
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
redistribute static subnets route-map rtl
network 103.14.80.16 0.0.0.15 area 0
network 192.168.18.0 0.0.0.15 area 0
router bgp 58636
no synchronization
bgp router-id 103.12.212.130
bgp log-neighbor-changes
network 103.12.212.128 mask 255.255.255.252
network 103.14.80.0 mask 255.255.252.0
network 103.14.80.16 mask 255.255.255.240
neighbor 103.12.212.129 remote-as 132337
neighbor 192.168.18.1 remote-as 58636
neighbor 192.168.18.1 update-source Loopback0
neighbor 192.168.18.1 soft-reconfiguration inbound
no auto-summary
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip http server
no ip http secure-server
ip route 103.14.80.0 255.255.252.0 Null0
ip route 103.14.80.48 255.255.255.240 103.14.80.20
ip route 192.168.100.0 255.255.255.0 103.14.80.49
ip route 192.168.101.0 255.255.255.0 103.14.80.49
ip route 192.168.102.0 255.255.255.0 103.14.80.49
ip prefix-list netronext-out seq 5 permit 103.14.80.0/24
ip prefix-list netronext-out seq 10 deny 0.0.0.0/0 le 32
access-list 10 permit 192.168.100.0
access-list 10 permit 192.168.101.0
access-list 10 permit 192.168.102.0
no cdp run
route-map rtl permit 10
match ip address 10
snmp-server community
control-plane
line con 0
line vty 0 4
login local
length 0
international
transport input telnet
exception crashinfo buffersize 80
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
5548/6000 OIR IOS Process
5532/6000 ISSU Infra API Delayed Registration Process
4488/6000 IPC ISSU Versioning Process
3508/6000 IPC ISSU Receive Process
5444/6000 IPC Zone Manager
5544/6000 ICC Retry Q
3236/6000 IPC Split Init
4284/6000 RTTY Client Registration
3856/6000 PF ISSU PRST media read proc
5552/6000 CDP BLOB
5508/6000 FM HA Sync
5508/6000 L3 Manager HA
2144/6000 c6k ivrfs
11068/12000 MRIB IPv4 Init Process
11480/12000 MRIB IPv6 Init Process
11076/12000 MFIB RP IPC
5116/6000 ICC Slave Comp. Up
3396/6000 eobc_init_process
4912/6000 DRMI Master Reg. Slave Process
5552/6000 PM MP Process
4940/6000 EARL INFO CAPABILITY process
5552/6000 Low Batt Process
5492/6000 C6K ENV RP init
5000/6000 SPAN Subsystem
5364/6000 PostOfficeNet
5548/6000 SASL MAIN
11052/12000 Router Init
10892/12000 CDP Protocol
53996/60000 EEM TCL Proc
53796/60000 EEM Auto Registration Proc
11536/12000 cdp init process
6320/12000 Init
5032/6000 Draco DFS Port Registation Proc
4840/6000 IPC LC Port Opener
5548/6000 MPLS ACL RP CFG Background
5340/6000 RADIUS INITCONFIG
4780/6000 LCC Configure
9504/12000 draco-oir:slot 5
4028/6000 BGP Open
4832/6000 SLB RF Active Proc
10512/12000 draco-oir:slot 3
5496/6000 URPF stats
2552/3000 Rom Random Update Process
33720/36000 TCP Command
10816/12000 Exec
5516/6000 Link Status process
5940/12000 Virtual Exec
5528/6000 FCP Router
5536/6000 moduleTrap Generation Process
19912/24000 show techsupport huge_stack
Interrupt level stacks:
Level Called Unused/Size Name
1 253516503 6364/9000 dma Intr handler
2 1192726 6476/9000 eobc etsec1 tx interrupt
3 0 9000/9000 Low Battery Interrupt
4 18402 8916/9000 16550 Con/Aux Interrupt
5 0 9000/9000 SP to RP Interrupt
6 3538172 8924/9000 Timebase Reference Interrupt
7 19127678 8812/9000 M8500_TIMER_INTERRUPT
******* Information of Last System Crash **********
Using bootdisk:crashinfo.
%Error opening bootdisk:crashinfo (File not found)
****** Information of Last System Crash - SP ******
The last crashinfo failed to be written.
Please verify the exception crashinfo configuration
the filesytem devices, and the free space on the
filesystem devices.
Using crashinfo_FAILED.
%Error opening disk0:crashinfo_FAILED (File not found)
------------------ show interfaces ------------------
Hardware is C7600 1Gb 802.3, address is 0021.a00b.1f80 (bia 0021.a00b.1f80)
Description: Internet With NetroNext
Internet address is 103.14.80.19/28
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 35/255, rxload 36/255
Keepalive set (10 sec)
input flow-control is off, output flow-control is on
Clock mode is auto
Last input 00:00:00, output 00:00:00, output hang never
Output queue: 0/40 (size/max)
5 minute input rate 145078000 bits/sec, 187358 packets/sec
5 minute output rate 140346000 bits/sec, 179956 packets/sec
L2 Switched: ucast: 21922 pkt, 1587633 bytes - mcast: 28897 pkt, 3332971 bytes
L3 in Switched: ucast: 1945640473 pkt, 284679948179 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 7186984243 pkt, 630745022136 bytes mcast: 0 pkt, 0 bytes
5385099034 packets input, 561321660323 bytes, 0 no buffer
Received 62921 broadcasts (0 IP multicasts)
0 runts, 0 giants, 3 throttles
0 watchdog, 0 multicast, 0 pause input
7186568266 packets output, 630714825156 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier, 0 pause output
Internet address is 103.12.212.130/30
reliability 255/255, txload 15/255, rxload 13/255
Media-type configured as SFP connector
Clock mode is auto
5 minute input rate 54458000 bits/sec, 85172 packets/sec
5 minute output rate 59194000 bits/sec, 92575 packets/sec
L2 Switched: ucast: 798508 pkt, 74558632 bytes - mcast: 1 pkt, 64 bytes
L3 in Switched: ucast: 4478303555 pkt, 361957334907 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 473908163 pkt, 38519838944 bytes mcast: 0 pkt, 0 bytes
4479526586 packets input, 362293052779 bytes, 0 no buffer
Received 3 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 126 overrun, 0 ignored
4938216931 packets output, 398118007574 bytes, 0 underruns
0 lost carrier, 0 no carrier, 4 pause output
Hardware is Loopback
Internet address is 192.168.18.3/28
MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
Encapsulation LOOPBACK, loopback not set
Last input 11:13:25, output never, output hang never
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
473 packets output, 89549 bytes, 0 underruns
Vlan1 is administratively down, line protocol is down
Hardware is EtherSVI, address is 0021.a00b.1f80 (bia 0021.a00b.1f80)
Last input never, output never, output hang never
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Hardware is RSP720 EOBC
Interface information:
Interface EOBC0/0(idb 0x17CCC6D0)
108696 packets input, 27128580 bytes
4 broadcasts received
126939 packets output, 45936031 bytes
4300 broadcasts sent
Dev_Instance=0x183C6B98 406612888
Receive/Transmit Buffer Descriptors
RingSz Shadow StartBD LastBD Head Tail Pend
Rx0 512 183C7534 79C43CC0 79C44CB8 152 0 0
Tx0 512 0 79C44D00 79C45CF8 475 475 0
Rx Drop On Busy Disabled
Hash match table for multicast (in use 1, maximum 64 entries):
Entry 0 MAC Addr = 0100.8300.0000
ETSEC counters in Hardware
64b = 685 64b-127b = 227 128b-255b = 51
256b-511b = 609 512b-1023b = 565 1024b-1518b = 937
1519b-1522b = 0 RxBytes = 0 RxPkt = 49
RxFCSErr = 0 RxMCast = 27 RxBCast = 4
RxCntrlFr = 0 RxPauseFR = 0 RxUnkop = 0
RxAlignErr = 0 RxLenErr = 0 RxCodeErr = 0
RxSenseErr = 0 RxUnder = 0 RxOver = 0
RxFrag = 10 RxJab = 0 RxDrop = 0
RxFilerRej = 0 Txbytes = 0 TxPkt = 987
TxMCast = 202 TxBCast = 0 TxPause = 0
TxDef = 205 TxCol = 29 TxMCol = 3
TxLateCol = 0 TxExCol = 0 TxTotCol = 38
TxDrop = 0 TxJab = 0 TxFCS = 0
TxOver = 0 TxUnder = 0 TxFrg = 0
------------------ show user ------------------
Line User Host(s) Idle Location
1 vty 0 rtl idle 00:03:48 203.76.109.154
* 2 vty 1 rtl idle 00:00:01 203.76.109.154
Interface User Mode Idle Peer Address
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
Processor 1322CA94 1692218732 522457996 1169760736 1167289628 1168873196
I/O 78000000 134217728 50320188 83897540 83838016 83831612
------------------ show process memory ------------------
Processor Pool Total: 1692218732 Used: 522444180 Free: 1169774552
I/O Pool Total: 134217728 Used: 50320144 Free: 83897584
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 263483816 13296604 238688968 7490 171325823 *Init*
0 0 14068 4875544 14068 11 11 *Sched*
0 0 159652980 162595780 1497596 193 155 *Dead*
0 0 0 0 677692 0 0 *MallocLite*
1 0 517920 0 525148 0 0 Chunk Manager
2 0 236 236 4228 0 0 Load Meter
3 0 0 0 7092 0 0 FCP Router
4 0 293812 293812 7092 3617 4797 SCP async: Draco
5 0 0 0 7228 0 0 Retransmission o
6 0 15056 0 7228 0 0 IPC ISSU Dispatc
7 0 0 0 7228 0 0 PF Redun ICC Req
8 0 3360 236 10352 0 0 Check heaps
9 0 82936 212216 90164 5560 0 Pool Manager
10 0 0 16160 7228 0 0 DiscardQ Backgro
11 0 236 236 7228 0 0 Timers
12 0 0 0 4228 0 0 WATCH_AFS
13 0 66120 35624 37724 15618 15618 ARP Input
14 0 987328 962224 32332 21 21 ARP Background
15 0 236 236 7228 0 0 ATM Idle Timer
16 0 0 0 7228 0 0 ATM ASYNC PROC
17 0 0 0 7228 0 0 AAA_SERVER_DEADT
18 0 0 0 13228 0 0 Policy Manager
19 0 35392 10336 33488 124 124 Entity MIB API
20 0 598996 0 609224 176 144 EEM ED Syslog
21 0 0 0 7228 0 0 IFS Agent Manage
22 0 80 1604 7228 0 0 IPC Event Notifi
23 0 0 0 7228 0 0 IPC Mcast Pendin
24 0 0 0 7228 0 0 IPC Dynamic Cach
25 0 0 0 7228 0 0 IPC Service NonC
26 0 122128 115760 13516 104 104 PF_Split Sync Pr
27 0 0 0 7228 138630 138630 IPC Periodic Tim
28 0 24460 0 8572 0 0 IPC Deferred Por
29 0 0 0 7228 0 0 IPC Process leve
30 0 350760 213028 167956 113119 113119 IPC Seat Manager
31 0 0 0 7228 0 0 IPC Check Queue
32 0 216344 0 19248 566 552 IPC Seat RX Cont
33 0 12516 5384 18372 0 0 IPC Seat TX Cont
34 0 19184 496 16536 11275 11275 IPC Keep Alive M
35 0 0 0 7228 0 0 IPC Loadometer
36 0 0 0 7228 0 0 Compute SRP rate
37 0 0 0 7228 0 0 RO Notify Timers
38 0 0 0 4228 0 0 RMI RM Notify Wa
39 0 0 0 7228 0 0 CEF MIB API
40 0 236 236 7228 0 0 DDR Timers
41 0 0 0 7228 0 0 ifIndex Receive
42 0 0 0 7228 0 0 SENSOR-MGR event
43 0 236 236 7228 0 0 Serial Backgroun
44 0 0 0 25228 0 0 Crash writer
45 0 304 0 7532 0 0 Exception contro
46 0 3416 2984 7228 22 22 RPC pf-split-rp
47 0 4882872 4882872 7228 39746 39746 EnvMon
48 0 236 236 7228 0 0 GraphIt
49 0 310092 132988 160812 1091 1091 rf proxy rp agen
50 0 236 236 7228 0 0 rf proxy message
51 0 15760 2276 20200 187 187 Entity MIB C6k P
52 0 5484 236 7228 2 2 client_entity_se
53 0 0 0 7228 0 0 SERIAL A'detect
54 0 0 0 7228 0 0 Snmp ICC Process
55 0 134844 6636 8228 44 44 Cat6k SNMP
56 0 236 1032 7228 0 0 Cat6k SNMP Trap
57 0 8820 2892 12704 6 6 RPC idprom-MP
58 0 0 0 7228 0 0 Dynamic ARP Insp
59 0 0 0 7228 0 0 Critical Bkgnd
60 0 34916 708 15524 2 2 Net Background
61 0 2472 2156 13544 0 0 IDB Work
62 0 236 236 13228 320 320 Logger
63 0 13664 3196 7228 0 0 TTY Background
64 0 2268 1720 7776 10 10 IF-MGR control p
65 0 0 0 7228 0 0 IF-MGR event pro
66 0 472 604 7228 0 0 RPC rf_rfmib_not
67 0 80432 61164 26496 352 352 Env action
68 0 0 0 7228 0 0 EOBC ETSEC FREEZ
69 0 236 236 7228 0 0 Flash ICC Server
70 0 0 0 7228 0 0 ICC Nego
71 0 224 0 7452 0 0 itasca
72 0 0 0 7228 7060 7060 Net Input
73 0 46548 130276 15188 0 0 draco-oir-proces
75 0 696 700 7452 4 4 svclc
76 0 0 0 7228 0 0 IPC ISSU Version
77 0 0 0 7228 0 0 IPC ISSU Version
78 1 2606832 2579140 14712 13299 13303 Virtual Exec
79 0 0 0 7228 0 0 IPC ISSU Version
80 0 0 0 7228 0 0 IPC ISSU Version
81 0 0 0 7228 0 0 IPC ISSU Version
82 0 0 0 7228 0 0 IPC ISSU Version
83 0 0 0 7228 0 0 IPC ISSU Version
84 0 0 0 7228 0 0 IPC ISSU Version
85 0 0 0 7228 0 0 IPC ISSU Version
86 0 0 0 7228 0 0 IPC ISSU Version
87 0 0 0 7228 0 0 IPC ISSU Version
88 0 0 0 7228 0 0 IPC ISSU Version
89 0 0 0 7228 0 0 IPC ISSU Version
90 0 4728 0 11956 0 0 IPC ISSU Version
91 0 0 0 7228 0 0 IPC ISSU Version
92 0 0 0 7228 0 0 IPC ISSU Version
93 0 0 0 7228 0 0 IPC ISSU Version
94 0 0 0 7228 0 0 IPC ISSU Version
95 0 0 0 7228 0 0 IPC ISSU Version
96 0 0 0 7228 0 0 IPC ISSU Version
97 0 0 0 7228 0 0 IPC ISSU Version
98 0 0 0 7228 0 0 IPC ISSU Version
99 0 0 0 7228 0 0 IPC ISSU Version
100 0 0 0 7228 0 0 IPC ISSU Version
101 0 0 0 7228 0 0 IPC ISSU Version
102 0 0 0 7228 0 0 IPC ISSU Version
103 0 0 0 7228 0 0 IPC ISSU Version
104 0 0 0 7228 0 0 IPC ISSU Version
105 0 0 0 7228 0 0 IPC ISSU Version
106 0 0 0 7228 0 0 IPC ISSU Version
107 0 0 0 7228 0 0 IPC ISSU Version
108 0 0 0 7228 0 0 IPC ISSU Version
109 0 0 0 7228 0 0 IPC ISSU Version
110 0 0 0 7228 0 0 IPC ISSU Version
111 0 0 0 7228 0 0 IPC ISSU Version
112 0 0 0 7228 0 0 IPC ISSU Version
113 0 0 0 7228 0 0 IPC ISSU Version
114 0 944 944 7228 39 39 RPC Sync
115 0 472 604 7228 0 0 RPC rpc-slave-15
116 0 0 148 7228 0 0 SCP Multicast
117 0 224 0 7452 0 0 simba
118 0 0 0 7228 0 0 MWAM CONFIG ON S
119 0 0 0 7228 0 0 SAMI CONFIG ON S
120 0 0 0 7228 0 0 cpf_msg_holdq_pr
121 0 0 0 7228 0 0 cpf_msg_rcvq_pro
122 0 0 0 7228 0 0 CHKPT Test clien
123 0 0 0 7228 0 0 DHCPC HA
124 0 0 0 7228 0 0 DHCPD HA
125 0 0 0 7228 0 0 DHCPv6 Relay HA
126 0 0 0 7228 0 0 Network-rf Notif
127 0 0 0 7228 0 0 ARP HA
128 0 0 0 7228 0 0 MDR SM Proxy Sla
129 0 0 0 7228 0 0 RF CWAN HA Proce
130 0 0 0 7228 0 0 CWAN HA VLAN SYN
131 0 0 0 7228 0 0 CWAN IF EVENT HA
132 0 0 0 7228 0 0 CWAN APS HA Proc
133 0 0 0 7228 0 0 CWAN SRP HA Proc
134 0 0 0 4228 0 0 Inode Table Dest
135 0 800 208 7228 76018 76018 Heartbeat Proces
136 0 76 0 7228 0 0 Const ICC reques
137 0 0 0 7228 0 0 Const ICC event
138 0 0 0 7228 0 0 Const ICC except
139 0 0 0 7228 0 0 ICC Local Reques
140 0 0 1168 7228 0 0 ICC Async mcast
141 0 0 1710624 7228 0 0 ICC Async true m
142 0 1064 864 7428 1 1 ICC Mcast IPC Ev
143 0 0 0 7228 0 0 ICC_REQ Debug Pr
144 0 0 0 7228 0 0 ICC FC Process
145 0 0 0 7228 0 0 ICC FC Test Send
146 0 0 0 7228 0 0 ICC FC Test Low
147 0 0 0 7228 0 0 PF Sync process
148 0 0 0 7228 0 0 QoS HA CHKPT
149 0 0 0 7228 0 0 CWRP SPA TSM HA
150 0 236 236 10228 0 0 Switch IP Host T
151 0 0 0 7156 0 0 EM Action CNS
152 0 4728 0 11956 0 0 IKE HA Mgr
153 0 0 0 7228 0 0 IPSEC HA Mgr
154 0 154076 9256 94388 20 20 PF_Init Process
155 0 0 0 7228 0 0 Transport Port A
156 0 3052 2648 7380 605 605 RTTYS Process
157 0 0 0 13228 0 0 RFS server proce
158 0 0 0 7228 0 0 BACK CHECK
159 0 236 236 7228 0 0 Compute load avg
160 0 4968 1196 12196 0 0 Per-minute Jobs
161 0 6396 5972 10652 16 16 Per-Second Jobs
162 0 0 0 7228 0 0 cpf_process_tpQ
163 0 0 0 7228 0 0 IPC Apps Task
164 2 1628868 1627492 14508 438 429 Virtual Exec
165 0 0 0 7228 0 0 AggMgr Process
166 0 236 236 7228 0 0 CWAN ICC
167 0 0 0 7228 0 0 SFF8472
168 0 236 236 7228 0 0 Service Group PC
169 0 0 0 7228 0 0 LSM Vlan alloc p
170 0 145440 0 7228 21154 21154 Remote Console P
171 0 0 0 7228 0 0 CCB SEND RETRY A
172 0 0 0 7228 0 0 POS APS Event Pr
173 0 88384 31164 59528 1036 1036 CWAN OIR Handler
174 0 236 236 7228 0 0 CWAN Egress SACL
175 0 0 0 7228 0 0 DSX3MIB ll handl
176 0 0 0 7228 0 0 EI RP
177 0 3592 3592 7228 8 8 FPD Management P
178 0 0 0 7228 0 0 FPD Action Proce
179 0 236 236 7228 0 0 const FPD ICC pr
180 0 0 0 7228 0 0 dwdm RPC RP proc
181 0 236 236 7228 0 0 netclk_process
182 0 0 0 7228 0 0 netclk_ha_proces
183 0 472 472 7228 7 8 SCP async: LCP#5
184 0 236 236 7228 0 0 CWAN ACD tasks
185 0 1884 472 8640 1 1 ACE_REQUESTS han
186 0 16668 0 41896 0 0 ACE Tunnel Task
187 0 0 0 25228 0 0 ACE VRF Task
188 0 472 472 7228 2 2 CMFI RP process
189 0 0 0 7228 0 0 CWAN CHOCX PROCE
190 0 0 0 7228 0 0 HAL Mailbox
191 0 0 0 7228 0 0 CWAN CHDSX PROCE
192 0 0 0 7228 0 0 CT3 Mailbox
193 0 0 0 7228 0 0 CE3 Mailbox
194 0 236 236 7228 0 0 MIP Mailbox
195 0 0 0 7228 0 0 Earl NDE Task
196 0 1873932 1873932 7228 15216 15216 esw_vlan_stat_pr
197 0 388 236 7380 0 0 Gemini L3 forwar
198 0 0 0 7228 0 0 CWRP SPA ATM OIR
199 0 0 0 7228 0 0 ACE event
200 0 0 0 7228 0 0 ACE HAPI
201 0 0 0 7228 0 0 ACE policy loade
202 0 236 0 4464 0 0 Async write proc
203 0 236 0 4464 0 0 Async write proc
204 0 236 0 4464 0 0 Async write proc
205 0 236 0 4464 0 0 Async write proc
206 0 0 0 4228 0 0 DFS flush period
207 0 236 236 7228 0 0 AAA Server
208 0 0 0 7228 0 0 AAA ACCT Proc
209 0 49384 0 56612 0 0 ACCT Periodic Pr
210 0 0 0 7228 0 0 AAA System Acct
211 0 0 0 7228 0 0 Auth-proxy AAA B
212 0 0 0 7228 0 0 IP Admin SM Proc
213 0 6576 13112 13452 0 0 Collection proce
214 0 224 0 13452 0 0 CEF switching ba
215 0 224 0 4452 0 0 ADJ NSF process
216 0 940704 940476 13456 8546 8546 ADJ resolve proc
217 0 0 0 7228 0 0 PPCP RP Stats Ba
218 0 236 236 7228 0 0 AAA Dictionary R
219 0 0 0 7228 0 0 DHCP Snooping cl
220 0 0 0 7228 0 0 DHCP Snooping
221 0 18372 1424 21124 1 6 IP ARP Adjacency
222 0 49384 0 56612 0 0 IP ARP Retry Age
223 0 1997100 1934388 36440 759858 759857 IP Input
224 0 0 0 7228 0 0 ICMP event handl
225 0 236 236 7228 0 0 PIM register asy
226 0 0 0 7228 0 0 IPv6 ping proces
227 0 236 236 7228 360 360 MOP Protocols
228 0 236 236 7228 0 0 PPP SIP
229 0 236 236 7228 0 0 PPP Bind
230 0 236 236 13228 0 0 PPP IP Route
231 0 584 584 7740 229 229 IFCOM Msg Hdlr
232 0 0 0 7228 0 0 HDLC HA
233 0 68868 236 81860 0 0 SSM connection m
234 0 472 236 7464 54699 54699 Spanning Tree
235 0 68100 2512 10228 6 6 EAPoUDP Process
236 0 0 0 13228 0 0 SSS Manager
237 0 0 0 13228 0 0 SSS Policy Manag
238 0 0 0 7228 0 0 SSS Feature Mana
239 0 0 0 7228 0 0 SSS Feature Time
240 0 0 0 7228 0 0 SG DPM
241 0 0 0 7228 0 0 Timer handler fo
242 0 0 0 7228 0 0 Prepaid response
243 0 0 0 7228 0 0 Timed Policy act
244 0 0 0 7228 0 0 AAA response han
245 0 0 0 7228 0 0 AAA EPD HANDLER
246 0 0 0 7228 0 0 PM EPD API
247 0 236 236 13228 0 0 KRB5 AAA
248 0 236 236 7228 0 0 cv6 per prefix a
249 0 236 236 7228 0 0 Const MGRE Proce
250 0 0 0 7228 0 0 CCM
251 0 0 0 7228 0 0 CCM IPC flow con
252 0 0 0 13228 0 0 DMLP Counter
253 0 236 236 10228 0 0 802.1x Accountin
254 0 236 236 7228 0 0 Dot1x Mgr Proces
255 0 0 0 7228 0 0 EAP Framework
256 0 0 0 7228 0 0 EAP Test
257 0 236 236 13228 0 0 Ethernet CFM
258 0 236 236 13228 0 0 Ethernet Timer C
259 0 236 236 13228 0 0 Ethernet Msec Ti
260 0 236 236 13228 0 0 Ethernet LMI
261 0 3052 0 16280 0 0 IMA PROC
262 0 236 236 7228 0 0 IPAM/ODAP Events
263 0 49384 0 62612 0 0 IPAM Manager
264 0 236 236 13228 0 0 IPAM Events
265 0 307568 44204 270592 0 0 EEM Server
266 0 8060 6848 8968 52 52 SW VLAN RP
267 0 1820 0 9048 0 0 const ipfib per-
268 0 472 236 7464 0 0 CFMPAL-RP Proces
269 0 472 236 7464 0 0 ECFMPAL RPC Proc
270 0 236 236 7228 0 0 ACR platform pro
271 0 9780 472 7136 2 2 OBFL Cfg Dispatc
272 0 236 236 10228 0 0 Ethernet OAM Pro
273 0 10224 0 11428 0 0 CEF RP IPC Backg
274 0 26656 13524 75076 106 106 HWIF QoS Process
275 0 33644 33996 9228 0 0 crypto sw pk pro
276 0 2624 0 9852 0 0 MLS FIB RP
277 0 0 0 7228 0 0 mcast_rp_icc Pro
278 0 86112 236 93104 0 0 MIRP-RP Process
279 0 1580 236 8572 0 0 const-mfib-rp Pr
280 0 236 236 7228 0 0 QOS Stats Export
281 0 236 236 7228 0 0 QOS Stats Gather
282 0 0 0 7228 0 0 Switch IP Admiss
283 0 236 236 10228 0 0 Switch IP Host T
284 0 0 0 7228 0 0 TCAM API Process
285 0 236 236 7228 0 0 REP Topology cha
286 0 0 0 13228 0 0 TC SIP
287 0 236 236 7228 0 0 IP PORTBUNDLE
288 0 0 0 7228 0 0 SG CMD HANDLER
289 0 236 236 13228 0 0 IP Static Sessio
290 0 0 0 7228 0 0 RADIUS Proxy
291 0 0 0 7228 0 0 vaccess_lock_pro
292 0 0 0 7228 0 0 va_lock_ha_proce
293 0 4728 0 11956 0 0 AC Switch
294 0 236 236 7228 0 0 OCE punted Pkts
295 0 0 0 7228 0 0 LSP Tunnel FRR
296 0 0 0 10228 0 0 MPLS Auto-Tunnel
297 0 0 0 7228 0 0 O-UNI Client Msg
298 0 0 0 7228 0 0 IP Traceroute
299 0 0 0 7228 0 0 FRR Background P
300 0 22608 6604 34940 0 0 CEF background p
301 0 224 0 13452 0 0 fib_fib_bfd_sb e
302 0 0 0 10228 0 0 IP IRDP
303 0 224 688 7452 0 0 XDR background p
304 0 8627048 8019932 725092 81393 81391 XDR mcast
305 0 6448 0 13676 0 0 LSD HA Proc
306 0 14900 0 7228 0 0 IPC LC Message H
307 0 0 0 7228 0 0 XDR RP Ping Back
308 0 134268 166340 7228 1879 1879 XDR RP backgroun
309 0 0 0 7228 0 0 XDR RP Test Back
310 0 7736 7680 11004 0 0 IP Background
311 0 8564 3192 16680 5 5 IP Connected Rou
312 0 72679268 49024 72432552 0 0 IP RIB Update
313 0 0 0 7228 0 0 ACR HA
314 0 0 0 7228 0 0 ACR HA IPC flow
315 0 32820 0 46048 0 0 ATM HA
316 0 0 0 7228 0 0 ATM HA IPC flow
317 0 0 0 7228 0 0 ATM HA ACR
318 0 0 0 7244 0 0 SNMP Timers
319 0 3052 0 10280 0 0 CEM PROC
320 0 0 0 7228 0 0 CEM HA
321 0 0 0 7228 0 0 BFD HA
322 0 0 655880 10092 12 12 BGP Scheduler
323 0 0 0 7100 0 0 IPC ISSU Version
324 0 43688 2584 32964 0 0 CEF: IPv4 proces
325 0 516 0 7452 0 0 ADJ background
326 0 0 0 7228 0 0 RETRY_REPOPULATE
327 0 0 0 7228 0 0 Socket Timers
328 0 0 0 7228 0 0 FR HA
329 0 0 37920 13228 8578 8578 TCP Timer
330 0 2170956 0 13228 0 0 TCP Protocols
331 0 940 0 11168 0 0 HTTP CORE
332 0 0 0 7228 0 0 HSRP HA
333 0 0 0 7228 0 0 IDS Timer
334 0 0 0 7228 0 0 Inspect Timer
335 0 11264 1740 16752 0 0 EEM Policy Direc
336 0 224 0 13452 0 0 MFIB Master back
337 0 3700 0 13928 0 0 EEM ED CLI
338 0 472 236 10464 0 0 Multicast Offloa
339 0 95132 236 36536 0 0 SCTP Main Proces
340 0 0 0 7228 0 0 IPv6 ACL RP Proc
341 0 751484 751484 7228 0 0 QoS stats proces
342 0 0 0 7228 0 0 SLB CF process
343 0 0 0 7228 0 0 SLB Replicate IP
344 0 0 0 7228 0 0 VRRP HA
345 0 0 0 7228 0 0 MFI Comm RP Proc
346 0 0 0 13228 0 0 Path set broker
347 0 0 0 7228 0 0 LDP HA
348 0 236 236 7228 0 0 MPLS VPN HA Clie
349 0 0 0 7228 0 0 RSVP HA Services
350 0 236 236 7228 0 0 TSPTUN HA
351 0 0 0 7228 0 0 ac_atm_state_eve
352 0 0 0 7228 0 0 ATM HA AC
353 0 236 236 7228 0 0 BD MACSEC HA
354 0 236 236 7228 0 0 BD MACSEC HA
355 0 0 0 7228 0 0 CEM HA AC
356 0 0 0 7228 0 0 VTEMPLATE IPC fl
357 0 0 0 7228 0 0 XC RIB MGR
358 0 0 0 7228 0 0 CMFI VPN HA Proc
359 0 236 236 4228 0 0 L2X Switching Ev
360 0 0 0 7228 0 0 AAA HA
361 0 236 236 7228 0 0 ATIP_UDP_TSK
362 0 236 236 7228 0 0 PPP NBF
363 0 0 0 7228 0 0 Cv6 RP Process
364 0 224 0 7452 0 0 XDR FOF process
365 0 0 0 7228 0 0 HQF MSFC Event P
366 0 236 236 7228 0 0 PPP Compress Inp
367 0 236 236 7228 0 0 PPP Compress Res
368 0 0 0 25228 0 0 COPS
369 0 0 0 7228 0 0 802.1x Critical
370 0 0 0 7228 0 0 MAB Framework
371 0 0 0 7228 0 0 ECFM HA IPC flow
372 0 236 236 7228 0 0 EFP Errd
373 0 1758368 8255248 19528 8441 8441 L3 Manager
374 0 0 0 7228 0 0 L3 Manager Commo
375 0 825592 64140 874052 112 163 FM core
376 0 0 0 7228 0 0 GLBP HA
377 0 0 0 7228 0 0 Probe Input
378 0 0 0 7228 0 0 IMA HA
379 0 224 0 13452 0 0 MRIB RP Proxy
380 0 0 0 7228 0 0 RARP Input
381 0 236 236 10228 0 0 static
382 0 472 236 4464 0 0 PfR BR Learn
383 0 0 0 7228 0 0 PAD InCall
384 0 236 236 13228 0 0 X.25 Background
385 0 0 0 7228 0 0 X.25 Encaps Mana
386 0 0 0 7228 0 0 CFIB RP process
387 0 10264 3600 13588 24 24 Const Rate Limit
388 0 6576 1484 13360 40 40 HIDDEN VLAN Proc
389 0 0 0 7228 0 0 FR XDR manager
390 0 0 0 7228 0 0 CWAN LTL manager
391 0 0 0 7228 1216 1216 CWAN-RP SCP Proc
392 0 88512 1748 72048 15 17 CWAN-RP SCP Inpu
393 0 0 0 7228 0 0 DHCP Snooping HA
394 0 3700 0 13964 0 0 EEM ED Counter
395 0 340 236 7332 0 0 IPHC RP Process
396 0 1824 236 11816 0 0 L2TRACE SERVER
397 0 236 236 7228 0 0 CWPA QoS
398 0 312 236 7304 0 0 Const TCAM Mgr R
399 0 236 236 7228 0 0 MWAM_CONSOLE Tim
400 0 0 0 7228 0 0 Container Proces
401 0 236 236 13228 0 0 IP SIP Process
402 0 236 236 13228 0 0 IP Inband Sessio
403 0 0 0 7228 0 0 Crypto PAS Proc
404 0 0 0 7228 0 0 Crypto HW Proc
405 0 236 336 7228 0 0 Inter Chassis Pr
406 0 188328 0 173872 0 0 LSD Main Proc
407 0 1728 236 8720 0 0 LFDp Input Proc
408 0 236 236 7228 0 0 AAA Cached Serve
409 0 4728 0 11956 0 0 EM Background Pr
410 0 236 236 7228 0 0 LOCAL AAA
411 0 236 236 7228 0 0 ENABLE AAA
412 0 236 236 7228 0 0 LINE AAA
413 0 13183188 12088236 10092 37225 37225 BGP I/O
414 0 1012 236 8004 0 0 TPLUS
415 0 0 0 7228 0 0 IDMGR CORE
416 0 0 0 7228 0 0 MPLS Auto Mesh P
417 0 236 236 7228 0 0 Crypto Support
418 0 12096 1836 7908 0 0 crypto engine pr
419 0 0 0 7228 0 0 encrypt proc
420 0 2312 1512 10028 4 4 Crypto CA
421 0 0 0 9228 0 0 Crypto PKI-CRL
422 0 0 0 9228 0 0 Crypto SSL
423 0 0 0 10228 0 0 QOS PERUSER
424 0 472 236 7464 0 0 PIM HA
425 0 0 0 7228 0 0 Laminar Icc Eve
426 0 236 236 13228 0 0 SLB Main CPU pro
427 0 236 236 7228 0 0 CRYPTO MAP FREE
428 0 45488 3336 67380 0 0 Crypto ACL
429 0 0 0 7228 0 0 Crypto INT
430 0 5404 236 18396 1 1 Crypto IKMP
431 0 104832 4372 48100 10 10 IPSEC key engine
432 0 0 0 7228 0 0 IPSEC manual key
433 0 0 0 9228 0 0 Key Proc
434 0 460 236 7452 0 0 Lawful Intercept
435 0 484 236 7476 0 0 LI messaging
436 0 0 0 7228 0 0 LI C6K
437 0 0 0 7228 0 0 LI C6K PROV
438 0 224 0 7452 0 0 DATA Transfer Pr
439 0 224 0 7452 0 0 DATA Collector
440 0 236 22992 7228 0 0 AAA SEND STOP EV
441 0 3700 0 13928 0 0 EEM ED Routing
442 0 3700 0 13928 0 0 EEM ED Track
443 0 3956 0 14184 0 0 EEM ED Resource
444 0 0 0 7228 0 0 L3MM Process
445 0 0 0 7228 0 0 Syslog Traps
446 0 236 368 7228 0 0 RPC aapi_rp
447 0 2660 2792 7228 22 22 RPC capi_rp
448 0 236 368 7228 0 0 RPC chapi_rp
449 0 236 368 7228 0 0 RPC dot1x_aaa_rp
450 0 236 368 7228 0 0 RPC ether_oam_sp
451 0 236 368 7276 0 0 RPC epld_sp2rp
452 0 236 368 7228 0 0 RPC gvrp_sp2rp
453 0 236 368 7228 0 0 RPC idbman_sp2mp
454 0 224 0 7452 0 0 LC Registry Expo
455 0 1159560 1158732 8188 9406 9406 RPC online_diag_
456 0 520 652 7228 2 2 RPC online_wan_d
457 0 236 368 7228 0 0 RPC pagp_switch_
458 0 236 368 7228 0 0 RPC pm_switch_sp
459 0 236 368 7228 0 0 RPC psecure_rp
460 0 236 368 7228 0 0 RPC pt_switch_sp
461 0 236 368 7228 0 0 RPC qnq_switch_s
462 0 236 368 7228 0 0 RPC rf_cli_sp2rp
463 0 0 0 7228 0 0 SONET Traps
465 0 236 236 7228 0 0 VTPMIB EDIT BUFF
466 0 236 368 7228 0 0 RPC snmp_notify
467 0 236 368 7228 0 0 RPC snmp_stackli
468 0 236 368 7228 0 0 RPC span_switch_
469 0 236 368 7228 0 0 RPC stp_sp2mp_ap
470 0 23508 5036 17592 418 418 OSPF-1 Router
471 0 236 236 7228 0 0 Module enable-di
472 0 3784 3916 7228 36 36 RPC c6k_power_rp
473 0 4488 4620 7228 36 36 RPC c6k_rp_envir
474 0 236 368 7228 0 0 RPC ecfmpal_rpc_
475 0 0 0 7248 0 0 CONST AFL
476 0 236 368 7228 0 0 RPC cwan_ltl_sp2
477 0 236 236 7228 0 0 RP Error Detecti
478 0 236 368 7228 0 0 RPC error_detect
479 0 0 0 7256 0 0 HW Capacity ICC
480 0 236 368 7228 0 0 RPC itasca_rp
481 0 224 0 7452 0 0 RP L2 Applicatio
482 0 0 0 7228 0 0 LACP-MP Process
483 0 93728 93504 7452 15 15 Online Diag EEM
484 0 0 0 7228 0 0 PAgP-MP Process
485 0 236 368 7228 0 0 RPC pclc_g2_agsm
486 0 236 368 7228 0 0 RPC pclc_g2_fw_r
487 0 236 236 7228 64 64 Logger ICC Proce
488 0 236 368 7228 0 0 RPC pf_issu_sp2r
489 0 236 368 7228 0 0 RPC pikachu_rp
491 0 2124 2256 7228 16 16 RPC pm-mp
492 0 0 0 7228 0 0 PM Callback
493 0 17273652 17270048 10832 208900 278016 Port manager per
494 0 0 0 7228 0 0 Max CPU utilizat
495 0 15496 840 7228 4 4 RPC lcc_sp
496 0 2656 2788 7228 6 6 RPC fabman_sp
497 0 236 236 7228 21 21 rp to lc clock u
498 0 716220 716220 7228 3037 3037 SPA ENTITY Proce
499 0 261911580 16746680 249624548 29 29 BGP Router
500 0 236 236 7228 0 0 SPAN Capture
501 0 0 0 7228 0 0 EC-Card-Cfg
502 0 236 368 7228 0 0 RPC sw_backup_in
503 0 3124 2728 7228 20 20 RPC sw_vlan_rp
504 0 472 604 7228 2 2 RPC udld_rp
505 0 2448 1784 7228 12 12 RPC vtp_const_ap
506 0 236 368 7228 0 0 RPC rep_sp2rp_ap
507 0 236 368 7228 0 0 RPC dot1ad_sp2mp
508 0 236 236 7228 0 0 Rommon upgrade p
509 0 236 368 7228 0 0 RPC mlacp_sp2mp
510 0 236 236 7228 0 0 ICRM
511 0 236 368 7228 0 0 RPC icrm_sp2rp
512 0 4728 0 11956 0 0 ACR RP PROC
513 0 3700 0 13928 0 0 EEM ED Interface
514 0 120312 236 133304 0 0 MRIB Process
515 0 0 88 7228 0 0 CWAN OIR IPC Rea
516 0 0 0 7228 0 0 MFI LFD Stats Pr
517 0 0 0 13228 0 0 MFI LFD Timer Pr
518 0 4952 0 12180 0 0 MFI LFD Main Pro
519 0 0 0 7228 0 0 PF Clock Process
520 0 3700 0 13928 0 0 EEM ED IOSWD
521 0 3700 0 13964 0 0 EEM ED None
522 0 3700 0 13928 0 0 EEM ED OIR
523 0 3804 320 14032 0 0 EEM ED RF
524 0 3700 0 13928 0 0 EEM ED SNMP
525 0 3700 0 13928 0 0 EEM ED SNMP Noti
526 0 3700 0 13928 0 0 EEM ED Timer
527 0 3700 0 13928 0 0 EEM ED Ipsla
528 0 96588 42512 92252 0 0 Call Home proces
529 0 0 0 7228 0 0 IP SLAs Ethernet
530 0 0 0 7228 0 0 IP SLA AutoEther
531 0 3700 0 13956 0 0 EEM ED RPC
532 0 0 0 7228 0 0 DRMI Config Disp
533 0 40956 40956 13228 170 170 Syslog
534 0 236 236 7228 0 0 CWAN Bridge task
535 0 236 236 13228 0 0 QM MRM Process o
536 0 472 472 61228 19 19 QM Process on RP
537 0 236 236 61228 0 0 QM Reply Process
538 0 236 236 61228 0 0 QM Timer ACL Pro
539 0 236 236 7228 0 0 DHCP Snooping Sw
540 0 0 0 7280 0 0 Call Home Timer
541 0 236 236 7228 0 0 CONST PC POLICYM
542 0 228 0 7456 0 0 Online Diag CNS
543 0 224 0 7452 1 1 Online Diag CNS
544 0 3700 0 13928 0 0 EM ED GOLD
545 0 3700 0 13928 0 0 EEM ED Test
546 0 3700 0 13928 0 0 EEM ED Config
547 0 3700 0 13928 0 0 EEM ED Env
548 0 0 0 7228 0 0 VACL Logger
549 0 472 472 7228 2 2 REP RP Proc
550 0 236 236 61228 0 0 SIP10G QM Proces
551 0 0 0 7228 0 0 IP SLA MPLSLM Pr
552 0 0 0 10120 0 0 BGP Scanner
553 0 12940880 131176 7296 0 0 BGP Task
554 0 0 0 7232 0 0 TCP Listener
555 0 29160932 29156288 14176 269296 269296 IP SNMP
556 0 2114456 0 13228 0 0 PDU DISPATCHER
557 0 1712745824 1714860372 16832 66357 66362 SNMP ENGINE
558 0 1184 236 14176 0 0 IP SNMPV6
559 0 0 0 13228 0 0 SNMP ConfCopyPro
560 0 236 236 13228 0 0 SNMP Traps
561 0 0 0 7092 0 0 BGP Event
562 0 9852 7692 11172 8150 8150 OSPF-1 Hello
572598004 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 51%/48%; one minute: 51%; five minutes: 54%
1 0 9 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 4088 15239 268 0.00% 0.01% 0.00% 0 Load Meter
3 0 1 0 0.00% 0.00% 0.00% 0 FCP Router
4 20 2433 8 0.00% 0.00% 0.00% 0 SCP async: Draco
8 1345764 70348 19130 0.00% 1.17% 0.95% 0 Check heaps
9 4 16 250 0.00% 0.00% 0.00% 0 Pool Manager
10 0 2 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
12 156 5708 27 0.07% 0.00% 0.00% 0 WATCH_AFS
13 1380 14314 96 0.00% 0.00% 0.00% 0 ARP Input
14 124 79056 1 0.00% 0.00% 0.00% 0 ARP Background
17 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
18 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
19 0 24 0 0.00% 0.00% 0.00% 0 Entity MIB API
20 8 156 51 0.00% 0.00% 0.00% 0 EEM ED Syslog
21 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
22 8 15228 0 0.00% 0.00% 0.00% 0 IPC Event Notifi
23 44 73996 0 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
24 0 1271 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
25 8 15222 0 0.00% 0.00% 0.00% 0 IPC Service NonC
26 0 107 0 0.00% 0.00% 0.00% 0 PF_Split Sync Pr
27 268 73995 3 0.00% 0.00% 0.00% 0 IPC Periodic Tim
28 76 74001 1 0.00% 0.00% 0.00% 0 IPC Deferred Por
29 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
30 13464 68870 195 0.00% 0.00% 0.00% 0 IPC Seat Manager
31 0 1386 0 0.00% 0.00% 0.00% 0 IPC Check Queue
32 12 190 63 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
33 0 9 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
34 104 7628 13 0.00% 0.00% 0.00% 0 IPC Keep Alive M
35 28 15225 1 0.00% 0.00% 0.00% 0 IPC Loadometer
36 0 7622 0 0.00% 0.00% 0.00% 0 Compute SRP rate
37 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
38 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
39 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
40 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
41 0 1 0 0.00% 0.00% 0.00% 0 ifIndex Receive
42 0 1 0 0.00% 0.00% 0.00% 0 SENSOR-MGR event
43 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
44 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
45 0 1 0 0.00% 0.00% 0.00% 0 Exception contro
46 0 22 0 0.00% 0.00% 0.00% 0 RPC pf-split-rp
47 3104 20479 151 0.00% 0.00% 0.00% 0 EnvMon
48 36 76172 0 0.00% 0.00% 0.00% 0 GraphIt
49 60 1088 55 0.00% 0.00% 0.00% 0 rf proxy rp agen
50 0 3 0 0.00% 0.00% 0.00% 0 rf proxy message
51 8 16 500 0.00% 0.00% 0.00% 0 Entity MIB C6k P
52 4 3 1333 0.00% 0.00% 0.00% 0 client_entity_se
53 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
54 0 1 0 0.00% 0.00% 0.00% 0 Snmp ICC Process
55 0 39 0 0.00% 0.00% 0.00% 0 Cat6k SNMP
56 0 8 0 0.00% 0.00% 0.00% 0 Cat6k SNMP Trap
57 0 17 0 0.00% 0.00% 0.00% 0 RPC idprom-MP
58 64 75811 0 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
59 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
60 16 9148 1 0.00% 0.00% 0.00% 0 Net Background
61 0 3 0 0.00% 0.00% 0.00% 0 IDB Work
62 0 271 0 0.00% 0.00% 0.00% 0 Logger
63 32 75789 0 0.00% 0.00% 0.00% 0 TTY Background
64 0 17 0 0.00% 0.00% 0.00% 0 IF-MGR control p
65 0 23 0 0.00% 0.00% 0.00% 0 IF-MGR event pro
66 0 5 0 0.00% 0.00% 0.00% 0 RPC rf_rfmib_not
67 20 352 56 0.00% 0.00% 0.00% 0 Env action
68 40 75810 0 0.00% 0.00% 0.00% 0 EOBC ETSEC FREEZ
69 0 2 0 0.00% 0.00% 0.00% 0 Flash ICC Server
70 0 1 0 0.00% 0.00% 0.00% 0 ICC Nego
71 0 130 0 0.00% 0.00% 0.00% 0 itasca
72 124 6686 18 0.00% 0.00% 0.00% 0 Net Input
73 4 10 400 0.00% 0.00% 0.00% 0 draco-oir-proces
75 0 58 0 0.00% 0.00% 0.00% 0 svclc
76 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
77 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
78 80952 15522694 5 0.00% 0.09% 3.01% 1 Virtual Exec
79 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
80 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
81 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
82 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
83 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
84 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
85 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
86 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
87 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
88 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
89 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
90 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
91 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
92 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
93 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
94 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
95 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
96 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
97 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
98 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
99 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
100 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
101 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
102 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
103 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
104 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
105 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
106 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
107 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
108 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
109 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
110 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
111 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
112 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
113 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
114 0 11 0 0.00% 0.00% 0.00% 0 RPC Sync
115 0 3 0 0.00% 0.00% 0.00% 0 RPC rpc-slave-15
116 0 3 0 0.00% 0.00% 0.00% 0 SCP Multicast
117 0 128 0 0.00% 0.00% 0.00% 0 simba
118 0 3 0 0.00% 0.00% 0.00% 0 MWAM CONFIG ON S
119 0 1 0 0.00% 0.00% 0.00% 0 SAMI CONFIG ON S
120 0 2 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
121 0 1 0 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
122 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
123 0 1 0 0.00% 0.00% 0.00% 0 DHCPC HA
124 0 1 0 0.00% 0.00% 0.00% 0 DHCPD HA
125 0 1 0 0.00% 0.00% 0.00% 0 DHCPv6 Relay HA
126 0 1 0 0.00% 0.00% 0.00% 0 Network-rf Notif
127 0 4 0 0.00% 0.00% 0.00% 0 ARP HA
128 0 1 0 0.00% 0.00% 0.00% 0 MDR SM Proxy Sla
129 40 1271 31 0.00% 0.00% 0.00% 0 RF CWAN HA Proce
130 0 1 0 0.00% 0.00% 0.00% 0 CWAN HA VLAN SYN
131 0 1 0 0.00% 0.00% 0.00% 0 CWAN IF EVENT HA
132 0 1 0 0.00% 0.00% 0.00% 0 CWAN APS HA Proc
133 0 1 0 0.00% 0.00% 0.00% 0 CWAN SRP HA Proc
134 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
135 768 75868 10 0.00% 0.00% 0.00% 0 Heartbeat Proces
136 0 2 0 0.00% 0.00% 0.00% 0 Const ICC reques
137 0 1 0 0.00% 0.00% 0.00% 0 Const ICC event
138 0 1 0 0.00% 0.00% 0.00% 0 Const ICC except
139 0 1 0 0.00% 0.00% 0.00% 0 ICC Local Reques
140 0 7 0 0.00% 0.00% 0.00% 0 ICC Async mcast
141 244 4235 57 0.00% 0.00% 0.00% 0 ICC Async true m
142 0 3 0 0.00% 0.00% 0.00% 0 ICC Mcast IPC Ev
143 0 1 0 0.00% 0.00% 0.00% 0 ICC_REQ Debug Pr
144 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Process
145 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Test Send
146 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Test Low
147 0 1 0 0.00% 0.00% 0.00% 0 PF Sync process
148 0 1 0 0.00% 0.00% 0.00% 0 QoS HA CHKPT
149 0 1 0 0.00% 0.00% 0.00% 0 CWRP SPA TSM HA
150 0 2 0 0.00% 0.00% 0.00% 0 Switch IP Host T
151 0 1 0 0.00% 0.00% 0.00% 0 EM Action CNS
152 0 1 0 0.00% 0.00% 0.00% 0 IKE HA Mgr
153 0 1 0 0.00% 0.00% 0.00% 0 IPSEC HA Mgr
154 8 26 307 0.00% 0.00% 0.00% 0 PF_Init Process
155 0 1290 0 0.00% 0.00% 0.00% 0 Transport Port A
156 1896 376787 5 0.00% 0.00% 0.00% 0 RTTYS Process
157 0 1 0 0.00% 0.00% 0.00% 0 RFS server proce
158 0 1 0 0.00% 0.00% 0.00% 0 BACK CHECK
159 120 15241 7 0.00% 0.00% 0.00% 0 Compute load avg
160 30688 1303 23551 0.00% 0.02% 0.00% 0 Per-minute Jobs
161 712 76223 9 0.00% 0.00% 0.00% 0 Per-Second Jobs
162 0 1 0 0.00% 0.00% 0.00% 0 cpf_process_tpQ
163 0 1 0 0.00% 0.00% 0.00% 0 IPC Apps Task
164 636 382 1664 3.83% 0.50% 0.10% 2 Virtual Exec
165 0 2 0 0.00% 0.00% 0.00% 0 AggMgr Process
166 0 2 0 0.00% 0.00% 0.00% 0 CWAN ICC
167 0 1 0 0.00% 0.00% 0.00% 0 SFF8472
168 0 2 0 0.00% 0.00% 0.00% 0 Service Group PC
169 0 1 0 0.00% 0.00% 0.00% 0 LSM Vlan alloc p
170 584 17174 34 0.00% 0.00% 0.00% 0 Remote Console P
171 0 1 0 0.00% 0.00% 0.00% 0 CCB SEND RETRY A
172 0 1 0 0.00% 0.00% 0.00% 0 POS APS Event Pr
173 180 1326 135 0.00% 0.00% 0.00% 0 CWAN OIR Handler
174 0 2 0 0.00% 0.00% 0.00% 0 CWAN Egress SACL
175 0 1 0 0.00% 0.00% 0.00% 0 DSX3MIB ll handl
176 0 1 0 0.00% 0.00% 0.00% 0 EI RP
177 0 7 0 0.00% 0.00% 0.00% 0 FPD Management P
178 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
179 0 2 0 0.00% 0.00% 0.00% 0 const FPD ICC pr
180 0 1 0 0.00% 0.00% 0.00% 0 dwdm RPC RP proc
181 0 2 0 0.00% 0.00% 0.00% 0 netclk_process
182 0 1 0 0.00% 0.00% 0.00% 0 netclk_ha_proces
183 0 7 0 0.00% 0.00% 0.00% 0 SCP async: LCP#5
184 0 2 0 0.00% 0.00% 0.00% 0 CWAN ACD tasks
185 0 3 0 0.00% 0.00% 0.00% 0 ACE_REQUESTS han
186 380 2292756 0 0.00% 0.01% 0.00% 0 ACE Tunnel Task
187 0 1 0 0.00% 0.00% 0.00% 0 ACE VRF Task
188 8 16 500 0.00% 0.00% 0.00% 0 CMFI RP process
189 48 75806 0 0.00% 0.00% 0.00% 0 CWAN CHOCX PROCE
190 0 1 0 0.00% 0.00% 0.00% 0 HAL Mailbox
191 28 75807 0 0.00% 0.00% 0.00% 0 CWAN CHDSX PROCE
192 0 1 0 0.00% 0.00% 0.00% 0 CT3 Mailbox
193 0 1 0 0.00% 0.00% 0.00% 0 CE3 Mailbox
194 0 2 0 0.00% 0.00% 0.00% 0 MIP Mailbox
195 0 1 0 0.00% 0.00% 0.00% 0 Earl NDE Task
196 1440 15032 95 0.00% 0.00% 0.00% 0 esw_vlan_stat_pr
197 0 3 0 0.00% 0.00% 0.00% 0 Gemini L3 forwar
198 0 1 0 0.00% 0.00% 0.00% 0 CWRP SPA ATM OIR
199 0 1 0 0.00% 0.00% 0.00% 0 ACE event
200 0 1 0 0.00% 0.00% 0.00% 0 ACE HAPI
201 0 5078 0 0.00% 0.00% 0.00% 0 ACE policy loade
202 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
203 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
204 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
205 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
206 0 1270 0 0.00% 0.00% 0.00% 0 DFS flush period
207 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
208 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
209 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
210 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
211 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
212 0 255 0 0.00% 0.00% 0.00% 0 IP Admin SM Proc
213 0 32 0 0.00% 0.00% 0.00% 0 Collection proce
214 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
215 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
216 1400 16528 84 0.00% 0.00% 0.00% 0 ADJ resolve proc
217 0 1 0 0.00% 0.00% 0.00% 0 PPCP RP Stats Ba
218 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
219 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping cl
220 0 638 0 0.00% 0.00% 0.00% 0 DHCP Snooping
221 0 16 0 0.00% 0.00% 0.00% 0 IP ARP Adjacency
222 240 2292751 0 0.00% 0.02% 0.00% 0 IP ARP Retry Age
223 70028 632119 110 0.15% 0.08% 0.08% 0 IP Input
224 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
225 0 3 0 0.00% 0.00% 0.00% 0 PIM register asy
226 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
227 0 181 0 0.00% 0.00% 0.00% 0 MOP Protocols
228 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
229 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
230 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
231 408 7964 51 0.00% 0.00% 0.00% 0 IFCOM Msg Hdlr
232 0 1 0 0.00% 0.00% 0.00% 0 HDLC HA
233 4 26 153 0.00% 0.00% 0.00% 0 SSM connection m
234 1212 54535 22 0.00% 0.00% 0.00% 0 Spanning Tree
235 4 5 800 0.00% 0.00% 0.00% 0 EAPoUDP Process
236 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager
237 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
238 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
239 112 295201 0 0.00% 0.00% 0.00% 0 SSS Feature Time
240 0 1 0 0.00% 0.00% 0.00% 0 SG DPM
241 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
242 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
243 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
244 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
245 0 1 0 0.00% 0.00% 0.00% 0 AAA EPD HANDLER
246 0 1 0 0.00% 0.00% 0.00% 0 PM EPD API
247 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA
248 0 3 0 0.00% 0.00% 0.00% 0 cv6 per prefix a
249 0 2 0 0.00% 0.00% 0.00% 0 Const MGRE Proce
250 0 1 0 0.00% 0.00% 0.00% 0 CCM
251 0 2 0 0.00% 0.00% 0.00% 0 CCM IPC flow con
252 0 1 0 0.00% 0.00% 0.00% 0 DMLP Counter
253 0 2 0 0.00% 0.00% 0.00% 0 802.1x Accountin
254 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
255 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
256 0 1 0 0.00% 0.00% 0.00% 0 EAP Test
257 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM
258 68 293550 0 0.00% 0.00% 0.00% 0 Ethernet Timer C
259 860 9142058 0 0.15% 0.10% 0.08% 0 Ethernet Msec Ti
260 0 2 0 0.00% 0.00% 0.00% 0 Ethernet LMI
261 0 1 0 0.00% 0.00% 0.00% 0 IMA PROC
262 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
263 236 2292773 0 0.00% 0.01% 0.00% 0 IPAM Manager
264 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
265 24 182 131 0.00% 0.00% 0.00% 0 EEM Server
266 12 37 324 0.00% 0.00% 0.00% 0 SW VLAN RP
267 0 2 0 0.00% 0.00% 0.00% 0 const ipfib per-
268 0 2 0 0.00% 0.00% 0.00% 0 CFMPAL-RP Proces
269 0 24 0 0.00% 0.00% 0.00% 0 ECFMPAL RPC Proc
270 0 2 0 0.00% 0.00% 0.00% 0 ACR platform pro
271 0 4 0 0.00% 0.00% 0.00% 0 OBFL Cfg Dispatc
272 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
273 0 5 0 0.00% 0.00% 0.00% 0 CEF RP IPC Backg
274 8 61 131 0.00% 0.00% 0.00% 0 HWIF QoS Process
275 24 5 4800 0.00% 0.00% 0.00% 0 crypto sw pk pro
276 0 1 0 0.00% 0.00% 0.00% 0 MLS FIB RP
277 0 1 0 0.00% 0.00% 0.00% 0 mcast_rp_icc Pro
278 0 2 0 0.00% 0.00% 0.00% 0 MIRP-RP Process
279 0 2 0 0.00% 0.00% 0.00% 0 const-mfib-rp Pr
280 0 2 0 0.00% 0.00% 0.00% 0 QOS Stats Export
281 4 7609 0 0.00% 0.00% 0.00% 0 QOS Stats Gather
282 0 1 0 0.00% 0.00% 0.00% 0 Switch IP Admiss
283 0 2 0 0.00% 0.00% 0.00% 0 Switch IP Host T
284 4 33 121 0.00% 0.00% 0.00% 0 TCAM API Process
285 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha
286 0 1 0 0.00% 0.00% 0.00% 0 TC SIP
287 0 2 0 0.00% 0.00% 0.00% 0 IP PORTBUNDLE
288 0 1 0 0.00% 0.00% 0.00% 0 SG CMD HANDLER
289 8 18602 0 0.00% 0.00% 0.00% 0 IP Static Sessio
290 0 1 0 0.00% 0.00% 0.00% 0 RADIUS Proxy
291 0 1 0 0.00% 0.00% 0.00% 0 vaccess_lock_pro
292 0 1 0 0.00% 0.00% 0.00% 0 va_lock_ha_proce
293 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
294 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
295 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
296 0 1 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
297 4 1 4000 0.00% 0.00% 0.00% 0 O-UNI Client Msg
298 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
299 0 1 0 0.00% 0.00% 0.00% 0 FRR Background P
300 0 1531 0 0.00% 0.00% 0.00% 0 CEF background p
301 0 2 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
302 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
303 0 3 0 0.00% 0.00% 0.00% 0 XDR background p
304 13180 56877 231 0.00% 0.00% 0.00% 0 XDR mcast
305 0 1 0 0.00% 0.00% 0.00% 0 LSD HA Proc
306 428 13001 32 0.00% 0.00% 0.00% 0 IPC LC Message H
307 0 3 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
308 16 1274 12 0.00% 0.00% 0.00% 0 XDR RP backgroun
309 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
310 4 1304 3 0.00% 0.00% 0.00% 0 IP Background
311 980 63 15555 0.00% 0.00% 0.00% 0 IP Connected Rou
312 22200 3683 6027 0.00% 0.00% 0.00% 0 IP RIB Update
313 0 1 0 0.00% 0.00% 0.00% 0 ACR HA
314 0 2 0 0.00% 0.00% 0.00% 0 ACR HA IPC flow
315 0 1 0 0.00% 0.00% 0.00% 0 ATM HA
316 0 2 0 0.00% 0.00% 0.00% 0 ATM HA IPC flow
317 0 1 0 0.00% 0.00% 0.00% 0 ATM HA ACR
318 0 3 0 0.00% 0.00% 0.00% 0 SNMP Timers
319 0 1 0 0.00% 0.00% 0.00% 0 CEM PROC
320 0 1 0 0.00% 0.00% 0.00% 0 CEM HA
321 0 1 0 0.00% 0.00% 0.00% 0 BFD HA
322 44 73980 0 0.00% 0.00% 0.00% 0 BGP Scheduler
323 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
324 156 108367 1 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
325 0 6 0 0.00% 0.00% 0.00% 0 ADJ background
326 0 1 0 0.00% 0.00% 0.00% 0 RETRY_REPOPULATE
327 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
328 0 1 0 0.00% 0.00% 0.00% 0 FR HA
329 336 295864 1 0.00% 0.00% 0.00% 0 TCP Timer
330 68 117 581 0.00% 0.00% 0.00% 0 TCP Protocols
331 0 255 0 0.00% 0.00% 0.00% 0 HTTP CORE
332 0 2 0 0.00% 0.00% 0.00% 0 HSRP HA
333 0 1 0 0.00% 0.00% 0.00% 0 IDS Timer
334 0 1 0 0.00% 0.00% 0.00% 0 Inspect Timer
335 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
336 0 253 0 0.00% 0.00% 0.00% 0 MFIB Master back
337 0 2 0 0.00% 0.00% 0.00% 0 EEM ED CLI
338 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa
339 0 2 0 0.00% 0.00% 0.00% 0 SCTP Main Proces
340 0 3 0 0.00% 0.00% 0.00% 0 IPv6 ACL RP Proc
341 20 7610 2 0.00% 0.00% 0.00% 0 QoS stats proces
342 0 1 0 0.00% 0.00% 0.00% 0 SLB CF process
343 0 2 0 0.00% 0.00% 0.00% 0 SLB Replicate IP
344 0 2 0 0.00% 0.00% 0.00% 0 VRRP HA
345 0 2 0 0.00% 0.00% 0.00% 0 MFI Comm RP Proc
346 0 1 0 0.00% 0.00% 0.00% 0 Path set broker
347 0 1 0 0.00% 0.00% 0.00% 0 LDP HA
348 0 2 0 0.00% 0.00% 0.00% 0 MPLS VPN HA Clie
349 0 1 0 0.00% 0.00% 0.00% 0 RSVP HA Services
350 0 2 0 0.00% 0.00% 0.00% 0 TSPTUN HA
351 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve
352 0 1 0 0.00% 0.00% 0.00% 0 ATM HA AC
353 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA
354 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA
355 0 1 0 0.00% 0.00% 0.00% 0 CEM HA AC
356 0 2 0 0.00% 0.00% 0.00% 0 VTEMPLATE IPC fl
357 0 1 0 0.00% 0.00% 0.00% 0 XC RIB MGR
358 0 1 0 0.00% 0.00% 0.00% 0 CMFI VPN HA Proc
359 0 2 0 0.00% 0.00% 0.00% 0 L2X Switching Ev
360 0 1 0 0.00% 0.00% 0.00% 0 AAA HA
361 0 2 0 0.00% 0.00% 0.00% 0 ATIP_UDP_TSK
362 0 2 0 0.00% 0.00% 0.00% 0 PPP NBF
363 0 1 0 0.00% 0.00% 0.00% 0 Cv6 RP Process
364 0 2 0 0.00% 0.00% 0.00% 0 XDR FOF process
365 0 1 0 0.00% 0.00% 0.00% 0 HQF MSFC Event P
366 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Inp
367 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Res
368 0 1 0 0.00% 0.00% 0.00% 0 COPS
369 0 1 0 0.00% 0.00% 0.00% 0 802.1x Critical
370 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework
371 0 2 0 0.00% 0.00% 0.00% 0 ECFM HA IPC flow
372 0 2 0 0.00% 0.00% 0.00% 0 EFP Errd
373 664 80053 8 0.00% 0.00% 0.00% 0 L3 Manager
374 0 4 0 0.00% 0.00% 0.00% 0 L3 Manager Commo
375 180 105941 1 0.00% 0.00% 0.00% 0 FM core
376 0 2 0 0.00% 0.00% 0.00% 0 GLBP HA
377 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
378 0 1 0 0.00% 0.00% 0.00% 0 IMA HA
379 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy
380 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
381 0 21 0 0.00% 0.00% 0.00% 0 static
382 40 75262 0 0.00% 0.00% 0.00% 0 PfR BR Learn
383 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
384 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
385 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
386 0 1 0 0.00% 0.00% 0.00% 0 CFIB RP process
387 0 10 0 0.00% 0.00% 0.00% 0 Const Rate Limit
388 77292 38104 2028 0.00% 0.05% 0.05% 0 HIDDEN VLAN Proc
389 0 1 0 0.00% 0.00% 0.00% 0 FR XDR manager
390 0 1 0 0.00% 0.00% 0.00% 0 CWAN LTL manager
391 4 1219 3 0.00% 0.00% 0.00% 0 CWAN-RP SCP Proc
392 8 9 888 0.00% 0.00% 0.00% 0 CWAN-RP SCP Inpu
393 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping HA
394 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Counter
395 0 8 0 0.00% 0.00% 0.00% 0 IPHC RP Process
396 0 2 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER
397 0 2 0 0.00% 0.00% 0.00% 0 CWPA QoS
398 0 2 0 0.00% 0.00% 0.00% 0 Const TCAM Mgr R
399 0 2 0 0.00% 0.00% 0.00% 0 MWAM_CONSOLE Tim
400 0 1 0 0.00% 0.00% 0.00% 0 Container Proces
401 356 18602 19 0.00% 0.00% 0.00% 0 IP SIP Process
402 0 2 0 0.00% 0.00% 0.00% 0 IP Inband Sessio
403 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc
404 0 1 0 0.00% 0.00% 0.00% 0 Crypto HW Proc
405 0 4 0 0.00% 0.00% 0.00% 0 Inter Chassis Pr
406 8 15224 0 0.00% 0.00% 0.00% 0 LSD Main Proc
407 0 2 0 0.00% 0.00% 0.00% 0 LFDp Input Proc
408 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
409 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
410 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
411 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
412 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
413 6000 20423 293 0.00% 0.00% 0.00% 0 BGP I/O
414 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
415 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
416 0 4 0 0.00% 0.00% 0.00% 0 MPLS Auto Mesh P
417 4 2 2000 0.00% 0.00% 0.00% 0 Crypto Support
418 0 13 0 0.00% 0.00% 0.00% 0 crypto engine pr
419 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
420 0 7 0 0.00% 0.00% 0.00% 0 Crypto CA
421 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
422 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL
423 0 1 0 0.00% 0.00% 0.00% 0 QOS PERUSER
424 0 2 0 0.00% 0.00% 0.00% 0 PIM HA
425 0 1 0 0.00% 0.00% 0.00% 0 Laminar Icc Eve
426 0 2 0 0.00% 0.00% 0.00% 0 SLB Main CPU pro
427 0 2 0 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE
428 4 4 1000 0.00% 0.00% 0.00% 0 Crypto ACL
429 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT
430 0 3 0 0.00% 0.00% 0.00% 0 Crypto IKMP
431 24 3811 6 0.00% 0.00% 0.00% 0 IPSEC key engine
432 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
433 0 1 0 0.00% 0.00% 0.00% 0 Key Proc
434 0 2 0 0.00% 0.00% 0.00% 0 Lawful Intercept
435 0 2 0 0.00% 0.00% 0.00% 0 LI messaging
436 0 1 0 0.00% 0.00% 0.00% 0 LI C6K
437 0 1 0 0.00% 0.00% 0.00% 0 LI C6K PROV
438 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr
439 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector
440 0 59 0 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
441 0 9 0 0.00% 0.00% 0.00% 0 EEM ED Routing
442 0 9 0 0.00% 0.00% 0.00% 0 EEM ED Track
443 0 17 0 0.00% 0.00% 0.00% 0 EEM ED Resource
444 0 1 0 0.00% 0.00% 0.00% 0 L3MM Process
445 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
446 0 6 0 0.00% 0.00% 0.00% 0 RPC aapi_rp
447 0 37 0 0.00% 0.00% 0.00% 0 RPC capi_rp
448 0 2 0 0.00% 0.00% 0.00% 0 RPC chapi_rp
449 0 6 0 0.00% 0.00% 0.00% 0 RPC dot1x_aaa_rp
450 0 2 0 0.00% 0.00% 0.00% 0 RPC ether_oam_sp
451 0 2 0 0.00% 0.00% 0.00% 0 RPC epld_sp2rp
452 0 2 0 0.00% 0.00% 0.00% 0 RPC gvrp_sp2rp
453 0 2 0 0.00% 0.00% 0.00% 0 RPC idbman_sp2mp
454 0 1 0 0.00% 0.00% 0.00% 0 LC Registry Expo
455 1260 9301 135 0.00% 0.00% 0.00% 0 RPC online_diag_
456 0 4 0 0.00% 0.00% 0.00% 0 RPC online_wan_d
457 0 2 0 0.00% 0.00% 0.00% 0 RPC pagp_switch_
458 0 7 0 0.00% 0.00% 0.00% 0 RPC pm_switch_sp
459 0 2 0 0.00% 0.00% 0.00% 0 RPC psecure_rp
460 0 2 0 0.00% 0.00% 0.00% 0 RPC pt_switch_sp
461 0 6 0 0.00% 0.00% 0.00% 0 RPC qnq_switch_s
462 0 2 0 0.00% 0.00% 0.00% 0 RPC rf_cli_sp2rp
463 0 1 0 0.00% 0.00% 0.00% 0 SONET Traps
465 0 2 0 0.00% 0.00% 0.00% 0 VTPMIB EDIT BUFF
466 0 2 0 0.00% 0.00% 0.00% 0 RPC snmp_notify
467 0 2 0 0.00% 0.00% 0.00% 0 RPC snmp_stackli
468 0 2 0 0.00% 0.00% 0.00% 0 RPC span_switch_
469 0 2 0 0.00% 0.00% 0.00% 0 RPC stp_sp2mp_ap
470 64552 75715 852 0.00% 0.00% 0.00% 0 OSPF-1 Router
471 0 2 0 0.00% 0.00% 0.00% 0 Module enable-di
472 16 28 571 0.00% 0.00% 0.00% 0 RPC c6k_power_rp
473 0 37 0 0.00% 0.00% 0.00% 0 RPC c6k_rp_envir
474 0 2 0 0.00% 0.00% 0.00% 0 RPC ecfmpal_rpc_
475 0 1 0 0.00% 0.00% 0.00% 0 CONST AFL
476 0 2 0 0.00% 0.00% 0.00% 0 RPC cwan_ltl_sp2
477 0 12623 0 0.00% 0.00% 0.00% 0 RP Error Detecti
478 0 2 0 0.00% 0.00% 0.00% 0 RPC error_detect
479 0 1 0 0.00% 0.00% 0.00% 0 HW Capacity ICC
480 0 2 0 0.00% 0.00% 0.00% 0 RPC itasca_rp
481 0 1 0 0.00% 0.00% 0.00% 0 RP L2 Applicatio
482 0 3 0 0.00% 0.00% 0.00% 0 LACP-MP Process
483 0 13 0 0.00% 0.00% 0.00% 0 Online Diag EEM
484 0 3 0 0.00% 0.00% 0.00% 0 PAgP-MP Process
485 0 2 0 0.00% 0.00% 0.00% 0 RPC pclc_g2_agsm
486 0 2 0 0.00% 0.00% 0.00% 0 RPC pclc_g2_fw_r
487 0 18 0 0.00% 0.00% 0.00% 0 Logger ICC Proce
488 0 2 0 0.00% 0.00% 0.00% 0 RPC pf_issu_sp2r
489 0 2 0 0.00% 0.00% 0.00% 0 RPC pikachu_rp
491 4 32 125 0.00% 0.00% 0.00% 0 RPC pm-mp
492 4 13898 0 0.00% 0.00% 0.00% 0 PM Callback
493 4320 77550 55 0.00% 0.00% 0.00% 0 Port manager per
494 16 15220 1 0.00% 0.00% 0.00% 0 Max CPU utilizat
495 0 6 0 0.00% 0.00% 0.00% 0 RPC lcc_sp
496 0 8 0 0.00% 0.00% 0.00% 0 RPC fabman_sp
497 0 23 0 0.00% 0.00% 0.00% 0 rp to lc clock u
498 520 4241 122 0.00% 0.00% 0.00% 0 SPA ENTITY Proce
499 42776 86442 494 0.00% 0.00% 0.00% 0 BGP Router
500 0 2 0 0.00% 0.00% 0.00% 0 SPAN Capture
501 0 3 0 0.00% 0.00% 0.00% 0 EC-Card-Cfg
502 0 2 0 0.00% 0.00% 0.00% 0 RPC sw_backup_in
503 0 22 0 0.00% 0.00% 0.00% 0 RPC sw_vlan_rp
504 0 4 0 0.00% 0.00% 0.00% 0 RPC udld_rp
505 0 14 0 0.00% 0.00% 0.00% 0 RPC vtp_const_ap
506 0 2 0 0.00% 0.00% 0.00% 0 RPC rep_sp2rp_ap
507 0 2 0 0.00% 0.00% 0.00% 0 RPC dot1ad_sp2mp
508 0 2 0 0.00% 0.00% 0.00% 0 Rommon upgrade p
509 0 2 0 0.00% 0.00% 0.00% 0 RPC mlacp_sp2mp
510 0 2 0 0.00% 0.00% 0.00% 0 ICRM
511 0 2 0 0.00% 0.00% 0.00% 0 RPC icrm_sp2rp
512 0 1 0 0.00% 0.00% 0.00% 0 ACR RP PROC
513 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Interface
514 0 2 0 0.00% 0.00% 0.00% 0 MRIB Process
515 0 2 0 0.00% 0.00% 0.00% 0 CWAN OIR IPC Rea
516 12 7603 1 0.00% 0.00% 0.00% 0 MFI LFD Stats Pr
517 16 14364 1 0.00% 0.00% 0.00% 0 MFI LFD Timer Pr
518 0 2 0 0.00% 0.00% 0.00% 0 MFI LFD Main Pro
519 4 1 4000 0.00% 0.00% 0.00% 0 PF Clock Process
520 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
521 0 3 0 0.00% 0.00% 0.00% 0 EEM ED None
522 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR
523 0 6 0 0.00% 0.00% 0.00% 0 EEM ED RF
524 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
525 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
526 0 1923 0 0.00% 0.00% 0.00% 0 EEM ED Timer
527 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
528 8 2 4000 0.00% 0.00% 0.00% 0 Call Home proces
529 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
530 0 1 0 0.00% 0.00% 0.00% 0 IP SLA AutoEther
531 0 2 0 0.00% 0.00% 0.00% 0 EEM ED RPC
532 4 488 8 0.00% 0.00% 0.00% 0 DRMI Config Disp
533 4 142 28 0.00% 0.00% 0.00% 0 Syslog
534 0 4 0 0.00% 0.00% 0.00% 0 CWAN Bridge task
535 0 2 0 0.00% 0.00% 0.00% 0 QM MRM Process o
536 0 7 0 0.00% 0.00% 0.00% 0 QM Process on RP
537 0 2 0 0.00% 0.00% 0.00% 0 QM Reply Process
538 0 2 0 0.00% 0.00% 0.00% 0 QM Timer ACL Pro
539 4 6095 0 0.00% 0.00% 0.00% 0 DHCP Snooping Sw
540 0 1270 0 0.00% 0.00% 0.00% 0 Call Home Timer
541 0 2 0 0.00% 0.00% 0.00% 0 CONST PC POLICYM
542 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
543 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
544 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD
545 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test
546 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config
547 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env
548 0 1270 0 0.00% 0.00% 0.00% 0 VACL Logger
549 0 6 0 0.00% 0.00% 0.00% 0 REP RP Proc
550 0 2 0 0.00% 0.00% 0.00% 0 SIP10G QM Proces
551 4 3790 1 0.00% 0.00% 0.00% 0 IP SLA MPLSLM Pr
552 1716156 5215 329080 0.00% 1.06% 1.18% 0 BGP Scanner
553 23044 10246 2249 0.00% 0.00% 0.00% 0 BGP Task
554 0 3 0 0.00% 0.00% 0.00% 0 TCP Listener
555 31992 231276 138 0.00% 0.00% 0.00% 0 IP SNMP
556 6744 114886 58 0.00% 0.00% 0.00% 0 PDU DISPATCHER
557 67964 503483 134 0.00% 0.00% 0.00% 0 SNMP ENGINE
558 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
559 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
560 0 2 0 0.00% 0.00% 0.00% 0 SNMP Traps
561 34256 92 372347 0.00% 0.00% 0.00% 0 BGP Event
562 740 25021 29 0.00% 0.00% 0.00% 0 OSPF-1 Hello
------------------ show process cpu history ------------------
555555554444455555555554444466666444444444444444444444444444
222111119999977777000008888822222888888888888888888889999988
100
90
80
70
60 ***** *****
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
666677875666667666666667666766665777655555555445554555555556
400288088455443867265472589442328254822222121883218244667870
100
90
80 **** *
70 *##* ** **** ** ****** *##*
60 ****####********#*****************### ****
50 #####################################*******************##
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
1 1
765554333399579099880
569292853299525051200
100 ** *** *
90 ** **** *
80 * ** *#*****
70 ** ** *####***
60 *** * ****####***
50 #**** ***########
40 ##****** ***########
30 #####********########
20 ######******#########
10 ###########*#########
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
------------------ show file systems ------------------
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
- - opaque rw tmpsys:
- - opaque ro flexwan-fpd:
* 978649088 936673280 disk rw disk0:
- - disk rw disk1:
518791168 191971328 disk rw sup-bootdisk:
143064752 0 opaque ro sup-microcode:
0 359259484 opaque wo sup-image:
127212 126656 nvram rw const_nvram:
- - opaque rw null:
- - opaque ro tar:
- - network rw tftp:
- - opaque wo syslog:
4059328 4052833 nvram rw nvram:
518791168 375496704 disk rw bootdisk:#
- - network rw rcp:
- - network rw ftp:
- - network rw http:
- - network rw scp:
- - network rw https:
- - opaque ro cns:
------------------ show file descriptors ------------------
File Descriptors:
No open file descriptors
------------------ show disk0: all ------------------
-#- --length-- -----date/time------ path
1 33554432 Jul 23 2012 14:18:36 +00:00 tftd
2 33554432 Jul 23 2012 14:21:14 +00:00 sea_log.dat
936673280 bytes available (41975808 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
Manufacturer Name Vendor
Model Number CF Card
Serial Number 7DF707050F0700112420
Firmware Revision Ver5.00M
Number of Heads 16
Number of Cylinders 1897
Sectors per Cylinder 63
Sector Size 512
Total Sectors 1912176
ATA PARTITION 1 INFO
Start Sector 63
Number of Sectors 1912113
Size in Bytes 979001856
File System Type FAT16
Number of FAT Sectors 234
Sectors Per Cluster 32
Number of Clusters 59732
Number of Data Sectors 1911424
Base FAT Sector 189
Base Root Sector 657
Base Data Sector 689
ATA MONLIB INFO
Image Monlib size 92420
Disk Monlib Size 92420
Disk Space Available 96256
Name rsp720-atafslib-m
Start sector 2
End sector 182
Updated By c7600rsp72043_sp-IPSERVICESK9-M12.2(33)SRE2
Version 2
RFS VERSION :
Negotiated Version : 0
Highest version supported in Server : 0
Highest version supported in Client : 0
------------------ show sup-bootdisk: all ------------------
1 33554432 Jul 23 2012 16:35:32 +00:00 sea_log.dat
2 143294340 Sep 28 2012 22:07:22 +00:00 c7600rsp72043-ipservicesk9-mz.122-33.SRE2.bin
3 149969316 Jul 23 2012 16:05:36 +00:00 c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin
191971328 bytes available (326819840 bytes used)
ATA CARD GEOMETRY
Manufacturer Name SMART MODULAR TECH
Model Number SMART CF
Serial Number 00001011510101683286
Firmware Revision 20060811
Number of Heads 16
Number of Cylinders 1006
Sector Size 512
Total Sectors 1014048
Start Sector 63
Number of Sectors 1013985
Size in Bytes 519160320
Number of FAT Sectors 248
Sectors Per Cluster 16
Number of Clusters 63329
Number of Data Sectors 1013264
Base FAT Sector 189
Base Root Sector 685
Base Data Sector 717
ATA MONLIB INFO
Start sector 2
End sector 182
Updated By c7600rsp72043_sp-ADVIPSERVICESK9-M12.2(33)SRE1
Version 2
RFS VERSION :
------------------ dir const_nvram: ------------------
Directory of const_nvram:/
1 -rw- 556
127212 bytes total (126656 bytes free)
------------------ dir nvram: ------------------
Directory of nvram:/
3965 -rw- 3346
3966 ---- 25
3967 -rw- 3346
1 ---- 0
2 ---- 206
3 -rw- 0
4059328 bytes total (4052833 bytes free)
------------------ show bootdisk: all ------------------
1 143294340 Aug 25 2012 04:39:50 +00:00 c7600rsp72043-ipservicesk9-mz.122-33.SRE2.bin
375496704 bytes available (143294464 bytes used)
ATA CARD GEOMETRY
Serial Number 00001011510101683267
Number of Heads 16
Sector Size 512
Start Sector 63
Base FAT Sector 189
ATA MONLIB INFO
Start sector 2
End sector 182
Updated By c7600rsp72043_rp-ADVIPSERVICESK9-M12.2(33)SRE1
Version 2
------------------ show redundancy ------------------
Redundant System Information :
Available system uptime = 21 hours, 11 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Simplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 21 hours, 10 minutes
Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 15-Mar-12 05:31 by prod_rel_team
BOOT = sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin,1;
CONFIG_FILE =
BOOTLDR =
Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
------------------ show redundancy history ------------------
00:00:00 client added: RF_INTERNAL_MSG(0) seq=0
00:00:00 client added: RF_LAST_CLIENT(65000) seq=379
00:00:00 RF_STATUS_SEND_RF_STATE(408) RF_LAST_CLIENT(65000) op=1 rc=0
00:00:02 client added: ISSU process(3099) seq=324
00:00:02 RF_STATUS_SEND_RF_STATE(408) ISSU process(3099) op=1 rc=0
00:00:02 client added: Force RPR(3200) seq=64
00:00:02 RF_STATUS_SEND_RF_STATE(408) Force RPR(3200) op=1 rc=0
00:00:02 client added: Cat6k Startup Config Sync(1301) seq=192
00:00:02 RF_STATUS_SEND_RF_STATE(408) Cat6k Startup Config Sync(1301) op=1 rc=0
00:00:02 client added: C6K/7600 penultimate client(1356) seq=349
00:00:02 RF_STATUS_SEND_RF_STATE(408) C6K/7600 penultimate client(1356) op=1 rc=0
00:00:02 client added: REP Protocol(212) seq=287
00:00:02 RF_STATUS_SEND_RF_STATE(408) REP Protocol(212) op=1 rc=0
00:00:02 client added: Persistent Variable(3300) seq=62
00:00:02 RF_STATUS_SEND_RF_STATE(408) Persistent Variable(3300) op=1 rc=0
00:00:02 client added: DATA DESCRIPTOR RF CLIENT(141) seq=341
00:00:02 client added: CHKPT RF(25) seq=68
00:00:02 RF_STATUS_SEND_RF_STATE(408) CHKPT RF(25) op=1 rc=0
00:00:02 client added: Event Manager(77) seq=77
00:00:02 RF_STATUS_SEND_RF_STATE(408) Event Manager(77) op=1 rc=0
00:00:02 client added: Cat6k CAPI(1317) seq=266
00:00:02 RF_STATUS_SEND_RF_STATE(408) Cat6k CAPI(1317) op=1 rc=0
00:00:04 client added: LAN-Switch Private Vlan(511) seq=335
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch Private Vlan(511) op=1 rc=0
00:00:04 client added: LAN-Switch Port Manager(502) seq=155
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch Port Manager(502) op=1 rc=0
00:00:04 client added: PM SP client(1321) seq=336
00:00:04 RF_STATUS_SEND_RF_STATE(408) PM SP client(1321) op=1 rc=0
00:00:04 client added: TABLEID FOF SP(1511) seq=114
00:00:04 RF_STATUS_SEND_RF_STATE(408) TABLEID FOF SP(1511) op=1 rc=0
00:00:04 client added: Switch SPAN client(504) seq=284
00:00:04 RF_STATUS_SEND_RF_STATE(408) Switch SPAN client(504) op=1 rc=0
00:00:04 client added: Cat6k Power(1318) seq=159
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Power(1318) op=1 rc=0
00:00:04 client added: Cat6k Fabric Manager(1302) seq=81
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Fabric Manager(1302) op=1 rc=0
00:00:04 client added: Cat6k Platform First Client(1319) seq=1
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform First Client(1319) op=1 rc=0
00:00:04 client added: Cat6k Platform(1313) seq=158
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform(1313) op=1 rc=0
00:00:04 client added: Cat6k Clear counter(1315) seq=339
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Clear counter(1315) op=1 rc=0
00:00:04 client added: Cat6k OIR(1303) seq=84
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k OIR(1303) op=1 rc=0
00:00:04 client added: Cat6k IDPROM(1307) seq=194
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k IDPROM(1307) op=1 rc=0
00:00:04 client added: MCM(3100) seq=73
00:00:04 RF_STATUS_SEND_RF_STATE(408) MCM(3100) op=1 rc=0
00:00:04 client added: PF_UCODE(1330) seq=72
00:00:04 RF_STATUS_SEND_RF_STATE(408) PF_UCODE(1330) op=1 rc=0
00:00:04 client added: REP SP client(1355) seq=286
00:00:04 RF_STATUS_SEND_RF_STATE(408) REP SP client(1355) op=1 rc=0
00:00:04 client added: IOS Config ARCHIVE(4020) seq=366
00:00:04 RF_STATUS_SEND_RF_STATE(408) IOS Config ARCHIVE(4020) op=1 rc=0
00:00:04 client added: IOS Config ROLLBACK(4021) seq=367
00:00:04 RF_STATUS_SEND_RF_STATE(408) IOS Config ROLLBACK(4021) op=1 rc=0
00:00:04 client added: LAN-Switch VTP VLAN(501) seq=122
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch VTP VLAN(501) op=1 rc=0
00:00:04 client added: LAN-Switch PAgP/LACP(510) seq=334
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch PAgP/LACP(510) op=1 rc=0
00:00:04 client added: Cat6k PAgP/LACP(1305) seq=261
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k PAgP/LACP(1305) op=1 rc=0
00:00:04 client added: VLAN Mapping(1322) seq=337
00:00:04 RF_STATUS_SEND_RF_STATE(408) VLAN Mapping(1322) op=1 rc=0
00:00:04 *my state = INITIALIZATION(2) *peer state = DISABLED(1)
00:00:04 RF_PROG_INITIALIZATION(100) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Platform First Client(1319) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Persistent Variable(3300) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Force RPR(3200) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) CHKPT RF(25) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) PF_UCODE(1330) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) MCM(3100) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Event Manager(77) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k OIR(1303) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) TABLEID FOF SP(1511) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch Port Manager(502) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Platform(1313) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Power(1318) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k IDPROM(1307) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k CAPI(1317) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Switch SPAN client(504) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) REP SP client(1355) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) REP Protocol(212) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) ISSU process(3099) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) PM SP client(1321) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) VLAN Mapping(1322) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Clear counter(1315) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:04 *my state = NEGOTIATION(3) peer state = DISABLED(1)
00:00:32 client added: Config Sync RF client(5006) seq=146
00:00:32 RF_STATUS_SEND_RF_STATE(408) Config Sync RF client(5006) op=3 rc=0
00:00:32 client added: Network RF Client(5023) seq=101
00:00:32 RF_STATUS_SEND_RF_STATE(408) Network RF Client(5023) op=3 rc=0
00:00:32 client added: CEF RRP RF Client(5025) seq=125
00:00:32 RF_STATUS_SEND_RF_STATE(408) CEF RRP RF Client(5025) op=3 rc=0
00:00:32 client added: CHKPT RF(5026) seq=68
00:00:32 RF_STATUS_SEND_RF_STATE(408) CHKPT RF(5026) op=3 rc=0
00:00:32 client added: Redundancy Mode RF(5030) seq=60
00:00:32 RF_STATUS_SEND_RF_STATE(408) Redundancy Mode RF(5030) op=3 rc=0
00:00:32 client added: SNMP RF Client(5035) seq=200
00:00:32 RF_STATUS_SEND_RF_STATE(408) SNMP RF Client(5035) op=3 rc=0
00:00:32 client added: History RF Client(5036) seq=210
00:00:32 RF_STATUS_SEND_RF_STATE(408) History RF Client(5036) op=3 rc=0
00:00:32 client added: ARP(5058) seq=241
00:00:32 RF_STATUS_SEND_RF_STATE(408) ARP(5058) op=3 rc=0
00:00:32 client added: XDR RRP RF Client(5072) seq=124
00:00:32 RF_STATUS_SEND_RF_STATE(408) XDR RRP RF Client(5072) op=3 rc=0
00:00:32 client added: Event Manager(5078) seq=77
00:00:32 RF_STATUS_SEND_RF_STATE(408) Event Manager(5078) op=3 rc=0
00:00:32 client added: SLB RF Client(5088) seq=281
00:00:32 RF_STATUS_SEND_RF_STATE(408) SLB RF Client(5088) op=3 rc=0
00:00:32 client added: Network RF 2 Client(5094) seq=331
00:00:32 RF_STATUS_SEND_RF_STATE(408) Network RF 2 Client(5094) op=3 rc=0
00:00:32 client added: Config Verify RF client(5095) seq=300
00:00:32 RF_STATUS_SEND_RF_STATE(408) Config Verify RF client(5095) op=3 rc=0
00:00:32 client added: DHCPC(5101) seq=187
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPC(5101) op=3 rc=0
00:00:32 client added: DHCPD(5102) seq=188
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPD(5102) op=3 rc=0
00:00:32 client added: MQC QoS(5103) seq=292
00:00:32 RF_STATUS_SEND_RF_STATE(408) MQC QoS(5103) op=3 rc=0
00:00:32 client added: MWAM RF Client(5104) seq=290
00:00:32 RF_STATUS_SEND_RF_STATE(408) MWAM RF Client(5104) op=3 rc=0
00:00:32 client added: SAMI RF Client(5105) seq=291
00:00:32 RF_STATUS_SEND_RF_STATE(408) SAMI RF Client(5105) op=3 rc=0
00:00:32 client added: CRYPTO RSA(5131) seq=313
00:00:32 RF_STATUS_SEND_RF_STATE(408) CRYPTO RSA(5131) op=3 rc=0
00:00:32 client added: IKE RF Client(5136) seq=311
00:00:32 RF_STATUS_SEND_RF_STATE(408) IKE RF Client(5136) op=3 rc=0
00:00:32 client added: IPSEC RF Client(5137) seq=312
00:00:32 RF_STATUS_SEND_RF_STATE(408) IPSEC RF Client(5137) op=3 rc=0
00:00:32 client added: IfIndex(5140) seq=61
00:00:32 RF_STATUS_SEND_RF_STATE(408) IfIndex(5140) op=3 rc=0
00:00:32 client added: DATA DESCRIPTOR RF CLIENT(5142) seq=341
00:00:32 RF_STATUS_SEND_RF_STATE(408) DATA DESCRIPTOR RF CLIENT(5142) op=3 rc=0
00:00:32 client added: DHCPv6 Relay(5149) seq=318
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPv6 Relay(5149) op=3 rc=0
00:00:32 client added: IP Tunnel RF(5152) seq=299
00:00:32 RF_STATUS_SEND_RF_STATE(408) IP Tunnel RF(5152) op=3 rc=0
00:00:32 client added: MFIB RRP RF Client(5307) seq=133
00:00:32 RF_STATUS_SEND_RF_STATE(408) MFIB RRP RF Client(5307) op=3 rc=0
00:00:32 client added: LAN-Switch IP Host Table(5510) seq=306
00:00:32 RF_STATUS_SEND_RF_STATE(408) LAN-Switch IP Host Table(5510) op=3 rc=0
00:00:32 client added: Cat6k Startup Config Sync(6302) seq=192
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Startup Config Sync(6302) op=3 rc=0
00:00:32 client added: Cat6k Platform(6314) seq=158
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform(6314) op=3 rc=0
00:00:32 client added: Cat6k Clear counter(6316) seq=339
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Clear counter(6316) op=3 rc=0
00:00:32 client added: Cat6k PF_ML_RP(6321) seq=332
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k PF_ML_RP(6321) op=3 rc=0
00:00:32 client added: Cat6k CWAN HA(6502) seq=94
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k CWAN HA(6502) op=3 rc=0
00:00:32 client added: CWAN APS HA RF Client(6503) seq=201
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN APS HA RF Client(6503) op=3 rc=0
00:00:32 client added: CWAN VLAN RF Client(6504) seq=95
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN VLAN RF Client(6504) op=3 rc=0
00:00:32 client added: Cat6k CWAN Interface Events(6505) seq=140
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k CWAN Interface Events(6505) op=3 rc=0
00:00:32 client added: Cat6k SPA TSM(6506) seq=107
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k SPA TSM(6506) op=3 rc=0
00:00:32 client added: CWAN SRP RF Client(6507) seq=267
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN SRP RF Client(6507) op=3 rc=0
00:00:32 client added: CWAN LTL Mgr HA RF Client(6508) seq=141
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN LTL Mgr HA RF Client(6508) op=3 rc=0
00:00:32 client added: TABLEID FOF RP(6513) seq=115
00:00:32 RF_STATUS_SEND_RF_STATE(408) TABLEID FOF RP(6513) op=3 rc=0
00:00:32 client added: ISSU Test Client(9006) seq=327
00:00:32 RF_STATUS_SEND_RF_STATE(408) ISSU Test Client(9006) op=3 rc=0
00:00:32 client added: IOS Config ARCHIVE(9021) seq=366
00:00:32 RF_STATUS_SEND_RF_STATE(408) IOS Config ARCHIVE(9021) op=3 rc=0
00:00:32 client added: IOS Config ROLLBACK(9022) seq=367
00:00:32 RF_STATUS_SEND_RF_STATE(408) IOS Config ROLLBACK(9022) op=3 rc=0
00:00:33 RF_EVENT_GO_ACTIVE(512) op=0 rc=0
00:00:33 *my state = ACTIVE-FAST(9) peer state = DISABLED(1)
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform First Client(1319) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IfIndex(5140) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Persistent Variable(3300) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Force RPR(3200) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CHKPT RF(25) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) PF_UCODE(1330) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MCM(3100) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Event Manager(77) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Event Manager(5078) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Fabric Manager(1302) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k OIR(1303) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Network RF Client(5023) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) TABLEID FOF SP(1511) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch VTP VLAN(501) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch Port Manager(502) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform(1313) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Power(1318) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPC(5101) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPD(5102) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Startup Config Sync(1301) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k IDPROM(1307) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) History RF Client(5036) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ARP(5058) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k PAgP/LACP(1305) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CAPI(1317) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Switch SPAN client(504) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) REP SP client(1355) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) REP Protocol(212) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MQC QoS(5103) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ISSU process(3099) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch PAgP/LACP(510) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch Private Vlan(511) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) PM SP client(1321) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) VLAN Mapping(1322) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Clear counter(1315) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) C6K/7600 penultimate client(1356) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ARCHIVE(4020) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ROLLBACK(4021) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) RF_LAST_CLIENT(65000) op=0 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE-DRAIN(10) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_DRAIN(201) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE_PRECONFIG(11) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE(13) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE(204) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:43 client added: Cat6k Multicast Shortcuts(1309) seq=263
00:00:43 RF_STATUS_SEND_RF_STATE(408) Cat6k Multicast Shortcuts(1309) op=13 rc=0
00:00:43 client added: Switch Backup Interface client(507) seq=285
00:00:43 RF_STATUS_SEND_RF_STATE(408) Switch Backup Interface client(507) op=13 rc=0
00:00:43 client added: CWAN static MAC RF Client(1552) seq=344
00:00:43 RF_STATUS_SEND_RF_STATE(408) CWAN static MAC RF Client(1552) op=13 rc=0
00:00:43 client added: 802.1x authenticator(210) seq=145
00:00:43 RF_STATUS_SEND_RF_STATE(408) 802.1x authenticator(210) op=13 rc=0
00:00:43 client added: CWAN LTL SP RF Client(1508) seq=254
00:00:43 RF_STATUS_SEND_RF_STATE(408) CWAN LTL SP RF Client(1508) op=13 rc=0
00:00:43 client added: Cat6k MLS Multicast(1312) seq=269
00:00:43 RF_STATUS_SEND_RF_STATE(408) Cat6k MLS Multicast(1312) op=13 rc=0
00:00:44 client added: 7600 CMFIB-SP(1353) seq=346
00:00:44 RF_STATUS_SEND_RF_STATE(408) 7600 CMFIB-SP(1353) op=13 rc=0
00:00:44 client added: Spanning-Tree Protocol(503) seq=262
00:00:44 RF_STATUS_SEND_RF_STATE(408) Spanning-Tree Protocol(503) op=13 rc=0
00:00:44 client added: tcam mgr rf client(1324) seq=160
00:00:44 RF_STATUS_SEND_RF_STATE(408) tcam mgr rf client(1324) op=13 rc=0
00:00:44 client added: GVRP RF(97) seq=295
00:00:44 RF_STATUS_SEND_RF_STATE(408) GVRP RF(97) op=13 rc=0
00:00:44 client added: BD MAC SECURITY RF CLIENT(206) seq=177
00:00:44 RF_STATUS_SEND_RF_STATE(408) BD MAC SECURITY RF CLIENT(206) op=13 rc=0
00:00:44 client added: RF_TS_CLIENT(4000) seq=325
00:00:44 RF_STATUS_SEND_RF_STATE(408) RF_TS_CLIENT(4000) op=13 rc=0
00:00:44 client added: TPM RF client(402) seq=143
00:00:44 client added: LACP(226) seq=179
00:00:44 RF_STATUS_SEND_RF_STATE(408) LACP(226) op=13 rc=0
00:00:44 client added: Port Security Client(508) seq=305
00:00:44 RF_STATUS_SEND_RF_STATE(408) Port Security Client(508) op=13 rc=0
00:00:44 client added: Cat6k Local Target Logic(1308) seq=149
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Local Target Logic(1308) op=13 rc=0
00:00:44 client added: MDR SM(138) seq=148
00:00:44 RF_STATUS_SEND_RF_STATE(408) MDR SM(138) op=13 rc=0
00:00:44 client added: IPROUTING NSF RF client(5021) seq=185
00:00:44 RF_STATUS_SEND_RF_STATE(408) IPROUTING NSF RF client(5021) op=13 rc=0
00:00:44 client added: Frame Relay(5024) seq=164
00:00:44 RF_STATUS_SEND_RF_STATE(408) Frame Relay(5024) op=13 rc=0
00:00:44 client added: HDLC(5050) seq=165
00:00:44 RF_STATUS_SEND_RF_STATE(408) HDLC(5050) op=13 rc=0
00:00:44 client added: FH_RF_Event_Detector_stub(5051) seq=248
00:00:44 RF_STATUS_SEND_RF_STATE(408) FH_RF_Event_Detector_stub(5051) op=13 rc=0
00:00:44 client added: ATM(5053) seq=202
00:00:44 RF_STATUS_SEND_RF_STATE(408) ATM(5053) op=13 rc=0
00:00:44 client added: SNMP HA RF Client(5055) seq=238
00:00:44 RF_STATUS_SEND_RF_STATE(408) SNMP HA RF Client(5055) op=13 rc=0
00:00:44 client added: Virtual Template RF Client(5069) seq=161
00:00:44 RF_STATUS_SEND_RF_STATE(408) Virtual Template RF Client(5069) op=13 rc=0
00:00:44 client added: AAA(5070) seq=206
00:00:44 RF_STATUS_SEND_RF_STATE(408) AAA(5070) op=13 rc=0
00:00:44 client added: LSD HA Proc(5073) seq=166
00:00:44 RF_STATUS_SEND_RF_STATE(408) LSD HA Proc(5073) op=13 rc=0
00:00:44 client added: LDP HA(5074) seq=239
00:00:44 RF_STATUS_SEND_RF_STATE(408) LDP HA(5074) op=13 rc=0
00:00:44 client added: MPLS VPN HA Client(5075) seq=198
00:00:44 RF_STATUS_SEND_RF_STATE(408) MPLS VPN HA Client(5075) op=13 rc=0
00:00:44 client added: Tableid HA(5076) seq=116
00:00:44 RF_STATUS_SEND_RF_STATE(408) Tableid HA(5076) op=13 rc=0
00:00:44 client added: IPRM(5077) seq=240
00:00:44 RF_STATUS_SEND_RF_STATE(408) IPRM(5077) op=13 rc=0
00:00:44 client added: TSPTUN HA(5079) seq=98
00:00:44 RF_STATUS_SEND_RF_STATE(408) TSPTUN HA(5079) op=13 rc=0
00:00:44 client added: CCM RF(5083) seq=209
00:00:44 RF_STATUS_SEND_RF_STATE(408) CCM RF(5083) op=13 rc=0
00:00:44 client added: AC RF Client(5084) seq=274
00:00:44 RF_STATUS_SEND_RF_STATE(408) AC RF Client(5084) op=13 rc=0
00:00:44 client added: AToM manager(5085) seq=276
00:00:44 RF_STATUS_SEND_RF_STATE(408) AToM manager(5085) op=13 rc=0
00:00:44 client added: SSM(5086) seq=277
00:00:44 RF_STATUS_SEND_RF_STATE(408) SSM(5086) op=13 rc=0
00:00:44 client added: HSRP(5089) seq=102
00:00:44 RF_STATUS_SEND_RF_STATE(408) HSRP(5089) op=13 rc=0
00:00:44 client added: L3 Mobility Manager(5090) seq=87
00:00:44 RF_STATUS_SEND_RF_STATE(408) L3 Mobility Manager(5090) op=13 rc=0
00:00:44 client added: RSVP HA Services(5091) seq=222
00:00:44 RF_STATUS_SEND_RF_STATE(408) RSVP HA Services(5091) op=13 rc=0
00:00:44 client added: DHCP Snooping(5106) seq=288
00:00:44 RF_STATUS_SEND_RF_STATE(408) DHCP Snooping(5106) op=13 rc=0
00:00:44 client added: MFI STATIC HA Proc(5114) seq=167
00:00:44 RF_STATUS_SEND_RF_STATE(408) MFI STATIC HA Proc(5114) op=13 rc=0
00:00:44 client added: GLBP(5115) seq=103
00:00:44 RF_STATUS_SEND_RF_STATE(408) GLBP(5115) op=13 rc=0
00:00:44 client added: CEM(5117) seq=204
00:00:44 RF_STATUS_SEND_RF_STATE(408) CEM(5117) op=13 rc=0
00:00:44 client added: IMA(5118) seq=205
00:00:44 RF_STATUS_SEND_RF_STATE(408) IMA(5118) op=13 rc=0
00:00:44 client added: XC L2TP HA manager(5120) seq=208
00:00:44 RF_STATUS_SEND_RF_STATE(408) XC L2TP HA manager(5120) op=13 rc=0
00:00:44 client added: ACR(5123) seq=203
00:00:44 RF_STATUS_SEND_RF_STATE(408) ACR(5123) op=13 rc=0
00:00:44 client added: VFI Mgr(5146) seq=275
00:00:44 RF_STATUS_SEND_RF_STATE(408) VFI Mgr(5146) op=13 rc=0
00:00:44 client added: BFD RF Client(5147) seq=126
00:00:44 RF_STATUS_SEND_RF_STATE(408) BFD RF Client(5147) op=13 rc=0
00:00:44 client added: BFD platform RF Client for 7600(5153) seq=127
00:00:44 RF_STATUS_SEND_RF_STATE(408) BFD platform RF Client for 7600(5153) op=13 rc=0
00:00:44 client added: ETHERNET OAM RF(5201) seq=173
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHERNET OAM RF(5201) op=13 rc=0
00:00:44 client added: ETHERNET LMI RF(5203) seq=176
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHERNET LMI RF(5203) op=13 rc=0
00:00:44 client added: ETHER INFRA RF(5205) seq=171
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHER INFRA RF(5205) op=13 rc=0
00:00:44 client added: BD MAC SECURITY RF CLIENT(5207) seq=177
00:00:44 RF_STATUS_SEND_RF_STATE(408) BD MAC SECURITY RF CLIENT(5207) op=13 rc=0
00:00:44 client added: ECFM RF(5208) seq=175
00:00:44 RF_STATUS_SEND_RF_STATE(408) ECFM RF(5208) op=13 rc=0
00:00:44 client added: 802.1x authenticator(5211) seq=145
00:00:44 RF_STATUS_SEND_RF_STATE(408) 802.1x authenticator(5211) op=13 rc=0
00:00:44 client added: VRRP(5226) seq=104
00:00:44 RF_STATUS_SEND_RF_STATE(408) VRRP(5226) op=13 rc=0
00:00:44 client added: EEM Server RF CLIENT(5251) seq=234
00:00:44 RF_STATUS_SEND_RF_STATE(408) EEM Server RF CLIENT(5251) op=13 rc=0
00:00:44 client added: EEM POLICY-DIR RF CLIENT(5253) seq=236
00:00:44 RF_STATUS_SEND_RF_STATE(408) EEM POLICY-DIR RF CLIENT(5253) op=13 rc=0
00:00:44 client added: MRIB RP RF Client(5302) seq=129
00:00:44 RF_STATUS_SEND_RF_STATE(408) MRIB RP RF Client(5302) op=13 rc=0
00:00:44 client added: IP multicast RF Client(5305) seq=100
00:00:44 RF_STATUS_SEND_RF_STATE(408) IP multicast RF Client(5305) op=13 rc=0
00:00:44 client added: Multicast ISSU Consolidation RF(5306) seq=99
00:00:44 RF_STATUS_SEND_RF_STATE(408) Multicast ISSU Consolidation RF(5306) op=13 rc=0
00:00:44 client added: TPM RF client(5403) seq=143
00:00:44 RF_STATUS_SEND_RF_STATE(408) TPM RF client(5403) op=13 rc=0
00:00:44 client added: Cat6k QoS Manager(6307) seq=89
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k QoS Manager(6307) op=13 rc=0
00:00:44 client added: Cat6k Feature Manager(6311) seq=96
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Feature Manager(6311) op=13 rc=0
00:00:44 client added: Cat6k Layer3 Manager(6312) seq=265
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Layer3 Manager(6312) op=13 rc=0
00:00:44 client added: Cat6k VPN RF Client(6326) seq=111
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k VPN RF Client(6326) op=13 rc=0
00:00:44 client added: Cat6k HA Vpnsm(6327) seq=342
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k HA Vpnsm(6327) op=13 rc=0
00:00:44 client added: CV6 RF Client(6328) seq=113
00:00:44 RF_STATUS_SEND_RF_STATE(408) CV6 RF Client(6328) op=13 rc=0
00:00:44 client added: 7600 CMFIB-RP(6355) seq=347
00:00:44 RF_STATUS_SEND_RF_STATE(408) 7600 CMFIB-RP(6355) op=13 rc=0
00:00:44 client added: Call-Home RF(6511) seq=293
00:00:44 RF_STATUS_SEND_RF_STATE(408) Call-Home RF(6511) op=13 rc=0
00:00:44 client added: CWAN ATOM HA RF Client(6552) seq=343
00:00:44 RF_STATUS_SEND_RF_STATE(408) CWAN ATOM HA RF Client(6552) op=13 rc=0
00:00:44 client added: Network Clock(9007) seq=345
00:00:44 RF_STATUS_SEND_RF_STATE(408) Network Clock(9007) op=13 rc=0
00:00:47 Configuration parsing complete
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform First Client(1319) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(5030) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(5140) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Force RPR(3200) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(5026) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PF_UCODE(1330) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MCM(3100) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(5078) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Fabric Manager(1302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k OIR(1303) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) L3 Mobility Manager(5090) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k QoS Manager(6307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CWAN HA(6502) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN VLAN RF Client(6504) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Feature Manager(6311) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TSPTUN HA(5079) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Multicast ISSU Consolidation RF(5306) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP multicast RF Client(5305) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(5023) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) HSRP(5089) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) GLBP(5115) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VRRP(5226) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k SPA TSM(6506) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k VPN RF Client(6326) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CV6 RF Client(6328) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TABLEID FOF SP(1511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TABLEID FOF RP(6513) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Tableid HA(5076) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(5072) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(5025) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BFD RF Client(5147) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BFD platform RF Client for 7600(5153) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MRIB RP RF Client(5302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MFIB RRP RF Client(5307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CWAN Interface Events(6505) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN LTL Mgr HA RF Client(6508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TPM RF client(5403) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 802.1x authenticator(210) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 802.1x authenticator(5211) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5006) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MDR SM(138) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Local Target Logic(1308) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform(1313) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform(6314) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Power(1318) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) tcam mgr rf client(1324) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Virtual Template RF Client(5069) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Frame Relay(5024) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) HDLC(5050) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LSD HA Proc(5073) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MFI STATIC HA Proc(5114) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHER INFRA RF(5205) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHERNET OAM RF(5201) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ECFM RF(5208) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHERNET LMI RF(5203) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BD MAC SECURITY RF CLIENT(206) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BD MAC SECURITY RF CLIENT(5207) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LACP(226) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPROUTING NSF RF client(5021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPC(5101) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(5102) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Startup Config Sync(1301) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Startup Config Sync(6302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k IDPROM(1307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MPLS VPN HA Client(5075) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(5035) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN APS HA RF Client(6503) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ATM(5053) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ACR(5123) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEM(5117) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IMA(5118) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AAA(5070) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XC L2TP HA manager(5120) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CCM RF(5083) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(5036) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RSVP HA Services(5091) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EEM Server RF CLIENT(5251) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EEM POLICY-DIR RF CLIENT(5253) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP HA RF Client(5055) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LDP HA(5074) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPRM(5077) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(5058) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FH_RF_Event_Detector_stub(5051) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN LTL SP RF Client(1508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k PAgP/LACP(1305) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Spanning-Tree Protocol(503) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Multicast Shortcuts(1309) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Layer3 Manager(6312) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CAPI(1317) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN SRP RF Client(6507) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k MLS Multicast(1312) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AC RF Client(5084) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VFI Mgr(5146) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AToM manager(5085) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SSM(5086) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SLB RF Client(5088) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch SPAN client(504) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch Backup Interface client(507) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) REP SP client(1355) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) REP Protocol(212) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCP Snooping(5106) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MWAM RF Client(5104) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SAMI RF Client(5105) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MQC QoS(5103) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Call-Home RF(6511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) GVRP RF(97) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Tunnel RF(5152) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(5095) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security Client(508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch IP Host Table(5510) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IKE RF Client(5136) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPSEC RF Client(5137) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(5131) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPv6 Relay(5149) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU process(3099) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RF_TS_CLIENT(4000) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(9006) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF 2 Client(5094) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k PF_ML_RP(6321) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Private Vlan(511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PM SP client(1321) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VLAN Mapping(1322) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Clear counter(1315) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Clear counter(6316) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DATA DESCRIPTOR RF CLIENT(5142) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k HA Vpnsm(6327) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN ATOM HA RF Client(6552) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN static MAC RF Client(1552) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network Clock(9007) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 7600 CMFIB-SP(1353) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 7600 CMFIB-RP(6355) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) C6K/7600 penultimate client(1356) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(9021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(9022) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RF_LAST_CLIENT(65000) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform First Client(1319) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Redundancy Mode RF(5030) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IfIndex(5140) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Persistent Variable(3300) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Force RPR(3200) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(25) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(5026) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PF_UCODE(1330) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MCM(3100) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(77) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(5078) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Fabric Manager(1302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k OIR(1303) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) L3 Mobility Manager(5090) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k QoS Manager(6307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CWAN HA(6502) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN VLAN RF Client(6504) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Feature Manager(6311) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TSPTUN HA(5079) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Multicast ISSU Consolidation RF(5306) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP multicast RF Client(5305) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF Client(5023) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) HSRP(5089) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) GLBP(5115) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VRRP(5226) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k SPA TSM(6506) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k VPN RF Client(6326) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CV6 RF Client(6328) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TABLEID FOF SP(1511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TABLEID FOF RP(6513) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Tableid HA(5076) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XDR RRP RF Client(5072) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEF RRP RF Client(5025) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BFD RF Client(5147) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BFD platform RF Client for 7600(5153) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MRIB RP RF Client(5302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MFIB RRP RF Client(5307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CWAN Interface Events(6505) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN LTL Mgr HA RF Client(6508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TPM RF client(5403) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 802.1x authenticator(210) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 802.1x authenticator(5211) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Sync RF client(5006) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MDR SM(138) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Local Target Logic(1308) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Port Manager(502) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform(1313) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform(6314) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Power(1318) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) tcam mgr rf client(1324) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Virtual Template RF Client(5069) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Frame Relay(5024) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) HDLC(5050) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LSD HA Proc(5073) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MFI STATIC HA Proc(5114) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHER INFRA RF(5205) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHERNET OAM RF(5201) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ECFM RF(5208) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHERNET LMI RF(5203) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BD MAC SECURITY RF CLIENT(206) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BD MAC SECURITY RF CLIENT(5207) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LACP(226) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPROUTING NSF RF client(5021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPC(5101) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPD(5102) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Startup Config Sync(1301) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Startup Config Sync(6302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k IDPROM(1307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MPLS VPN HA Client(5075) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP RF Client(5035) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN APS HA RF Client(6503) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ATM(5053) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ACR(5123) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEM(5117) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IMA(5118) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AAA(5070) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XC L2TP HA manager(5120) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CCM RF(5083) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) History RF Client(5036) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RSVP HA Services(5091) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EEM Server RF CLIENT(5251) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EEM POLICY-DIR RF CLIENT(5253) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP HA RF Client(5055) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LDP HA(5074) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPRM(5077) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ARP(5058) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FH_RF_Event_Detector_stub(5051) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN LTL SP RF Client(1508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k PAgP/LACP(1305) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Spanning-Tree Protocol(503) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Multicast Shortcuts(1309) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Layer3 Manager(6312) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CAPI(1317) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN SRP RF Client(6507) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k MLS Multicast(1312) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AC RF Client(5084) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VFI Mgr(5146) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AToM manager(5085) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SSM(5086) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SLB RF Client(5088) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch SPAN client(504) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch Backup Interface client(507) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) REP SP client(1355) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) REP Protocol(212) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCP Snooping(5106) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MWAM RF Client(5104) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SAMI RF Client(5105) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MQC QoS(5103) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Call-Home RF(6511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) GVRP RF(97) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP Tunnel RF(5152) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Verify RF client(5095) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Port Security Client(508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch IP Host Table(5510) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IKE RF Client(5136) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPSEC RF Client(5137) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CRYPTO RSA(5131) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPv6 Relay(5149) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU process(3099) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RF_TS_CLIENT(4000) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU Test Client(9006) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF 2 Client(5094) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k PF_ML_RP(6321) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Private Vlan(511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PM SP client(1321) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VLAN Mapping(1322) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Clear counter(1315) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Clear counter(6316) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DATA DESCRIPTOR RF CLIENT(5142) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k HA Vpnsm(6327) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN ATOM HA RF Client(6552) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN static MAC RF Client(1552) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network Clock(9007) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 7600 CMFIB-SP(1353) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 7600 CMFIB-RP(6355) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) C6K/7600 penultimate client(1356) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(9021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(9022) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RF_LAST_CLIENT(65000) op=7 rc=0
00:00:50 System initialization complete
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show ipc status ------------------
IPC System Status
Time last IPC stat cleared all zones : 00:00:00
This processor is an IPC slave server in zone 0 (default).
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
Rx Side Tx Side
Total Frames 565807 577387
Total from Local Ports 364870 282305
Total Protocol Control Frames 416 180
Total Frames Dropped 0 0
Service Usage
Total via Unreliable Connection-Less Service 38088 37999
Total via Unreliable Sequenced Connection-Less Svc 0 0
Total via Reliable Connection-Oriented Service 332718 244299
Total Messages via Fragmentation 784 9
Total Fragments 6302 37
Total Internal IPC Messages 351 0
Total Messages Flushed 0 1
IPC Protocol Version 0
Total Acknowledgements 244307 295054
Total Negative Acknowledgements 0 0
Device Drivers
Total via Local Driver 0 0
Total via Platform Driver 565806 577387
Total Frames Dropped by Platform Drivers 0 0
Total Frames Sent when media is quiesced 0
Reliable Tx Statistics
Re-Transmission 7
Re-Tx Timeout 0
Rx Errors Tx Errors
Unsupp IPC Proto Version 0 Tx Session Error 0
Corrupt Frame 0 Tx Seat Error 0
Duplicate Frame 0 Tx No Send Vector 0
Unrel Out-of-Seq Frame 0 Tx Driver Failed 0
Rx IPC Transform Errors 0 Tx IPC Transform Errors 0
Unable to Deliver Msg 0 Tx Test Drop 0
Rx Msg Callback Hog 0 Ack Alloc Failed 0
Rel Out-of-Seq Frame 0
Dest Port does Not Exist 0
Rx IPC Msg Alloc Failed 0
Rx IPC Frag Dropped 0
Rx Bootstrap Delivered 2
Rx Bootstrap Dropped 0
Buffer Errors Misc Errors
IPC Msg Alloc 0 IPC Open Port 1
Emer IPC Msg Alloc 0 No HWQ 0
IPC Frame PakType Alloc 0 Hardware Error 0
IPC Frame MemD Alloc 0 Invalid Messages 0
IPC Backup Open Port 0
IPC Fragment Errors 0
Message Timer Errors 0
Messages no xmt pending flag 0
Tx Driver Errors
No Transport 0
MTU Failure 0
Dest does not Exist 0
IPC Message Bundling Statistics
Seat-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/282333/0/0
Seat-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/565806/0
Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/282298/144368/0
Session-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/290702/0
------------------ show ipc queue ------------------
There are 0 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use : 20
Message cache size : 6000
Maximum message cache usage : 6000
0 times message cache crossed 12000 [max]
Emergency messages currently in use : 0
There are 19 messages currently reserved for reply msg.
Cache low watermark [default/new]: [100/100]
No of low watermark reached : 0
Total get cache after low watermark : 0
No of times zero cache reached : 0
No of times one cache added : 0
No of times cache chunk added : 0
Max no of get cache between wake2grow : 0
------------------ show ipc rpc ------------------
IPC RPC Status
Rx Side Tx Side
Total RPC requests 69738 74584
Total RPC replies 74584 69738
IPC RPC Statistics
Maximum RPC timeout(seconds) 600
Number of RPC timeouts crossed default max[ 600] 0
IPC RPC Errors
No Pending RPC Request for Received RPC Reply 0
RPC Request which have timeout out 0
RPC Reply not sent due to NULL reply message 0
RPC Reply not sent due to NULL request message 0
RPC Reply not sent for NON RPC request message 398
RPC Reply with NULL reply and request message 0
Time last IPC RPC stat cleared 00:00:00
------------------ show ipc port ------------------
IPC ACTIVE PORT TABLE
There are 39 ports defined.
Port ID Type Name (current/peak/total)
2150000.1 unicast Card5/1:Zone
2150000.2 unicast Card5/1:Echo
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 7622
rcv pending/peak/total = 0/1/7622
stateful_mode = 0 peer_port = 0, peer_seat = 0
seq-window size = 128 number of messages in window = 0
maximum out-of-seq received = 0 maximum pending in window = 0
number of messages dropped = 0 number of window resets = 0
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/7622/0
2150000.3 multicast Card5/1:Control
2150000.4 unicast Rf_Proxy:Client:5
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 540
rcv pending/peak/total = 0/2/540
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/540/0
2150000.5 unicast ERP Agent Port #21
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 1
rcv pending/peak/total = 0/1/1
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1/0
2150000.6 unicast OBFL Master Port
2150000.7 unicast Card5/1:Request
port_index = 1 seat_id = 0x10000 last sent = 0 last heard = 20
rcv pending/peak/total = 0/4/20
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/20/0
port_index = 2 seat_id = 0x10000 last sent = 0 last heard = 32652
rcv pending/peak/total = 0/313/32624
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/32624/0
port_index = 3 seat_id = 0x10000 last sent = 0 last heard = 0
rcv pending/peak/total = 0/1/38086
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/38086/0
port_index = 4 seat_id = 0x2150000 last sent = 0 last heard = 0
rcv pending/peak/total = 0/0/0
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/0/0
port_index = 5 seat_id = 0x2150000 last sent = 0 last heard = 0
port_index = 6 seat_id = 0x2150000 last sent = 0 last heard = 0
port_index = 7 seat_id = 0x2150000 last sent = 0 last heard = 0
2150000.8 unicast Card21:Request
2150000.9 unicast Card5/1:Event
2150000.A unicast Card5/1:Exception
2150000.B multicast Card5/1:McastRequest
10000.3 multicast IPC Master:Control
2150000.C unicast CHKPT:ACTIVE RP
2150000.D unicast RED MODE: Active Port
2150000.E unicast Config Sync ISSU nego active
2150000.F unicast TID HA: Active RP
2150000.10 unicast issu:rfs:34930688
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 242
rcv pending/peak/total = 0/2/242
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/242/0
2150000.11 unicast RFS Pri RP Partfs Server Port
2150000.12 unicast Pri RP console: RTTY port
2150000.13 unicast RTTYEnh Master Port
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 33
rcv pending/peak/total = 0/2/33
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/33/0
2150000.14 unicast Master RFS Server Port
2150000.15 unicast issu:rfs:Master RFS Server Port
2150000.16 unicast ifindex_sync_active_port
2150000.17 unicast IPC-Apps:Active
2150000.18 unicast ISSU TEST::same port 1 0
2150000.19 unicast ISSU TEST::shared msg port 1 0
2150000.1A unicast ISSU TEST::same port 1 1
2150000.1B unicast ISSU TEST::shared msg port 1 1
2150000.1C unicast ISSU TEST::shared nego port 1 0
2150000.1D unicast ProcMIB Statistics Server Port
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 43549
rcv pending/peak/total = 0/2/43549
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/43549/0
2150000.1E unicast FIB Master: DFS.process_level.msgs
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 7026
rcv pending/peak/total = 0/1/7026
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/7026/0
2150000.1F unicast FIB Master: DFS.interrupt.msgs
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 20728
rcv pending/peak/total = 0/1/86264
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/86264/0
2150000.20 unicast RP: MRIB.control.RIL
2150000.21 unicast Draco:Laminar:Ref
2150000.22 unicast CWAN IPC Master:Init
2150000.23 unicast RP: MFIB.RIL
2150000.24 unicast Remote TTY Server Port
2150000.25 unicast Resource Manager Master
port_index = 0 seat_id = 0x10000 last sent = 0 last heard = 1123
rcv pending/peak/total = 0/5/1110
rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1110/0
2150000.26 unicast IPC Master: Slot 3/0 ICP
RPC packets: current/peak/total
1/5/74584
IPC STANDBY PORT TABLE
There are 0 ports defined.
1/5/74584
------------------ show ipc port open ------------------
IPC ACTIVE OPEN PORT TABLE
There are 16 ports defined.
10000.4 unicast ERP Agent Port #5
port_index = 0 last sent = 4 last heard = 0
session creator pc = 8D287FC
xmt pending/peak/total = 0/3/4
session bundle status is OFF seat bundle flag is NOT OK
stateful_mode = 0, remote_seat = 10000
Session/Seat level flow control state = 0x0/0x0
Receiver seq-window size = 128
10000.8 unicast Card5/0:Event
port_index = 0 last sent = 2 last heard = 0
xmt pending/peak/total = 0/1/2
10000.9 unicast Card5/0:Exception
port_index = 0 last sent = 0 last heard = 0
xmt pending/peak/total = 0/0/0
10000.6 unicast Card5/0:Request
port_index = 3 last sent = 3398 last heard = 0
xmt pending/peak/total = 0/10/68934
port_index = 4 last sent = 1830 last heard = 0
xmt pending/peak/total = 0/7/1830
port_index = 5 last sent = 22 last heard = 0
xmt pending/peak/total = 0/4/22
port_index = 6 last sent = 0 last heard = 0
xmt pending/peak/total = 0/1/37999
10000.A unicast Unknown
session creator pc = 0
stateful_mode = 0, remote_seat = 0
port_index = 1 last sent = 0 last heard = 0
10000.5 unicast Rf_Proxy:Server:5
port_index = 0 last sent = 97 last heard = 0
xmt pending/peak/total = 0/1/97
10000.2 unicast Unknown
port_index = 0 last sent = 7624 last heard = 0
session creator pc = 8D286CC
xmt pending/peak/total = 0/3/7624
10000.C unicast RTTYEnh Client Port 00010000
port_index = 0 last sent = 18 last heard = 0
xmt pending/peak/total = 0/5/18
10000.E unicast issu:rfs:Primary RFS Server Port
port_index = 0 last sent = 124 last heard = 0
xmt pending/peak/total = 0/5/124
10000.D unicast Primary RFS Server Port
port_index = 0 last sent = 524 last heard = 0
xmt pending/peak/total = 0/4/526
10000.17 unicast Unknown
10000.19 unicast Slot 5: FAST.control.RIL
port_index = 0 last sent = 32402last heard = 0
xmt pending/peak/total = 0/9/32402
10000.18 unicast Slot 5: DFS.control.IL
port_index = 0 last sent = 14275last heard = 0
xmt pending/peak/total = 0/5/14275
10000.1B unicast Unknown
port_index = 4 last sent = 0 last heard = 0
stateful_mode = 0, remote_seat = 2150000
port_index = 5 last sent = 0 last heard = 0
port_index = 7 last sent = 0 last heard = 0
10000.15 unicast L3MM port 5
0/2/69738
IPC STANDBY OPEN PORT TABLE
0/2/69738
------------------ show scp status ------------------
Rx 71187, Tx 71187, scp_my_addr 0x14
Id Sap Channel name current/peak/retry/dropped/total time(queue/process/ack)
0 18 SCP Unsolicited:18 0/ 0/ 0/ 0/ 0 0/ 0/ 0
1 80 SCP Unsolicited:80 0/ 0/ 0/ 0/ 0 0/ 0/ 0
2 23 SCP async: LCP#5 0/ 1/ 2/ 1/ 2 0/2000/ 0
3 0 SCP Unsolicited:0 0/ 1/ 0/ 0/ 2 0/ 0/ 0
4 25 SCP async: Draco-LC 0/ 1/ 0/ 0/ 1216 4/ 760/ 760
------------------ show scp counters ------------------
received packets = 71187
transmitted packets = 71187
retransmitted packets = 2
fast retransmitted packets = 0
loop back packets = 0
transmit failures = 0
recv pkts not for me = 0
recv pkts to dead process = 2
recv pkts not enqueuable = 0
response has wrong opcode = 0
response has wrong seqnum = 0
response is not an ack = 0
response is too big = 0
received expedited packets = 0
transmitted expedited pkts = 0
------------------ show scp accounting ------------------
Total 11 19 29 100 123 138 1FF
Tot: 160F 4C0 A3F5 36A6 0 1 36A6 D
1612 4C0 A3F5 36A6 1 2 36A6 E
03: 4C3 4C0 0 0 0 1 0 2
4C6 4C0 0 0 1 2 0 3
05: 114C 0 A3F5 36A6 0 0 36A6 B
------------------ show ibc ------------------
Interface information:
Interface IBC0/0(idb 0x183CD514)
5 minute rx rate 52098000 bits/sec, 85888 packets/sec
5 minute tx rate 126231000 bits/sec, 171809 packets/sec
4471644835 packets input, 347898071160 bytes
4471537060 broadcasts received
4470390017 packets output, 347507459495 bytes
12786 broadcasts sent
0 Bridge Packet loopback drops
3410958444 Packets CEF Switched, 0 Packets Fast Switched
0 Packets SLB Switched, 3845323 Packets CWAN Switched
Label switched pkts dropped: 0 Pkts dropped during dma: 4423
Invalid pkts dropped: 0 Pkts dropped(not cwan consumed): 0
IPSEC pkts: 0
Xconnect pkts processed: 0, dropped: 0
Xconnect pkt reflection drops: 0
Total paks copied for process level 0
Total short paks sent in route cache 64348
Total throttle drops 4420 Input queue drops 3
total spd packets classified (698190 low, 34253 medium, 19974 high)
total spd packets dropped (4423 low, 0 medium, 0 high)
spd prio pkts allowed in due to selective throttling (0 med, 0 high)
IBC resets = 1; last at 10:00:57.839 UTC Sat Sep 29 2012
Driver Level Counters: (Cumulative, Zeroed only at Reset)
Frames Bytes
Rx(0) 50973 6766619
Rx(1) 186111180 452037576
Tx(0) 183543210 807879819
Input Drop Frame Count
Rx0 = 0 Rx1 = 4185866
Per Queue Receive Errors:
FRME OFLW BUFE NOENP DISCRD DISABLE BADCOUNT
Rx0 0 0 0 0 0 0 0
Rx1 0 0 0 957 0 0 0
Tx Errors/State:
One Collision Error = 0 More Collisions = 0
No Encap Error = 0 Deferred Error = 0
Loss Carrier Error = 0 Late Collision Error = 0
Excessive Collisions = 0 Buffer Error = 0
Tx Freeze Count = 0 Tx Intrpt Serv timeout= 1
Tx Flow State = FLOW_ON
Tx Flow Off Count = 0 Tx Flow On Count = 0
Counters collected at Idb:
Is input throttled = 0 Throttle Count = 0
Rx Resource Errors = 0 Input Drops = 4185866
Input Errors = 1753512
Output Drops = 0 Giants/Runts = 0/0
Dma Mem Error = 0 Input Overrun = 0
Hash match table for multicast (in use 0, maximum 64 entries):
------------------ show icc status ------------------
Total Tx msgs pending : 0
Total Rx msgs pending : 0
Class Name Msgs Pending Max Pending Total
0 ICC(HQ) 0 0 14
0 1 1
2 RPC 0 6 67617
0 6 4874
3 MSC 0 0 0
0 1 2
4 MCAST-SP(FC) 0 0 1538
0 0 0
6 L2-DRV(FC) 0 0 8
0 0 0
8 L2-AGING(FC) 0 0 159
0 0 0
11 L3-MGMT(FC) 0 7 38
0 0 0
13 EARL-ACL-TCAM(FC 0 2 6
0 0 0
14 QM(FC) 0 5 60
0 0 0
15 ICC-SHIM 0 0 0
0 1 2
23 IP-FIB 0 1 1
0 0 0
29 EARL-INFO 0 0 1
0 0 0
30 ESW-VLAN-STAT 0 0 0
0 1 7610
31 HEARTBEAT 0 2 38001
0 1 38086
36 LOGGER(FC) 0 4 20
0 4 20
40 REMOTE-CONSOLE 0 7 1135
0 313 20120
46 PF-CS(HQ) 0 4 8
0 0 0
49 L2_APPL_REQUESTS 0 0 107
0 0 0
50 MPLS_REQUESTS 0 0 3
0 0 0
56 RATE_LIMIT_REQUE 0 2 7
0 0 0
57 CFIB_ERM_REQUEST 0 1 1
0 0 0
58 OIR 0 0 0
0 2 16
61 SNMP_ICC_REQUEST 0 0 20
0 0 0
72 MLS_CEF_REQUESTS 0 3 3
0 0 0
79 L3-MGR-FM 0 1 3
0 0 0
84 EARL-QOS-TCAM(FC 0 1 1
0 0 0
88 PF_REDUN 0 0 12
0 0 0
------------------ show icc counters ------------------
total tx ICC(HQ) packets to slot 5 CPU0/ = 14
detail by request id: (
2 =1 9 =1 13=2 24=1
31=9
total rx ICC(HQ) packets from slot 5 CPU0/ = 9
2 =0 9 =0 13=0 24=0
31=9
total tx RPC packets to slot 5 CPU0/ = 67585
0 =3 4 =4 5 =6 11=5
12=5 15=53 16=9 28=9
29=74 30=796 31=66621
total rx RPC packets from slot 5 CPU0/ = 67582
0 =0 4 =4 5 =6 11=5
total tx MCAST-SP(FC) packets to slot 5 CPU0/ = 1538
4 =53 8 =53 10=53 15=53
16=53 17=53 26=53 28=53
30=53 31=1061
total rx MCAST-SP(FC) packets from slot 5 CPU0/ = 1485
4 =0 8 =53 10=53 15=53
30=53 31=1061
total tx L2-DRV(FC) packets to slot 5 CPU0/ = 8
9 =4 18=4
total rx L2-DRV(FC) packets from slot 5 CPU0/ = 8
9 =4 18=4
total tx L2-AGING(FC) packets to slot 5 CPU0/ = 159
31=159
total rx L2-AGING(FC) packets from slot 5 CPU0/ = 159
31=159
total tx L3-MGMT(FC) packets to slot 5 CPU0/ = 14
13=3 17=5 26=6
total rx L3-MGMT(FC) packets from slot 5 CPU0/ = 14
13=3 17=5 26=6
total tx EARL-ACL-TCAM(FC) packets to slot 5 CPU0/ = 4
0 =4
total rx EARL-ACL-TCAM(FC) packets from slot 5 CPU0/ = 62
0 =62
total tx QM(FC) packets to slot 5 CPU0/ = 53
1 =53
total rx QM(FC) packets from slot 5 CPU0/ = 53
1 =53
total tx EARL-INFO packets to slot 5 CPU0/ = 1
3 =1
total rx EARL-INFO packets from slot 5 CPU0/ = 1
3 =1
total tx HEARTBEAT packets to slot 5 CPU0/ = 37999
1 =37999
total rx HEARTBEAT packets from slot 5 CPU0/ = 0
1 =0
total tx LOGGER(FC) packets to slot 5 CPU0/ = 15
6 =11 8 =4
total rx LOGGER(FC) packets from slot 5 CPU0/ = 15
6 =11 8 =4
total tx L2_APPL_REQUESTS packets to slot 5 CPU0/ = 107
31=107
total rx L2_APPL_REQUESTS packets from slot 5 CPU0/ = 106
31=106
total tx MPLS_REQUESTS packets to slot 5 CPU0/ = 3
8 =1 13=1 14=1
total rx MPLS_REQUESTS packets from slot 5 CPU0/ = 3
8 =1 13=1 14=1
total tx RATE_LIMIT_REQUESTS packets to slot 5 CPU0/ = 1
31=1
total rx RATE_LIMIT_REQUESTS packets from slot 5 CPU0/ = 1
31=1
total tx SNMP_ICC_REQUESTS packets to slot 5 CPU0/ = 20
1 =19 3 =1
total rx SNMP_ICC_REQUESTS packets from slot 5 CPU0/ = 20
1 =19 3 =1
total tx L3-MGR-FM packets to slot 5 CPU0/ = 0
2 =0
total rx L3-MGR-FM packets from slot 5 CPU0/ = 3
2 =3
total tx EARL-QOS-TCAM(FC) packets to slot 5 CPU0/ = 0
0 =0
total rx EARL-QOS-TCAM(FC) packets from slot 5 CPU0/ = 1
0 =1
total tx PF_REDUN packets to slot 5 CPU0/ = 12
1 =12
total rx PF_REDUN packets from slot 5 CPU0/ = 0
1 =0
total tx CONST_MFIB_PFINFO_REQUESTS packets to slot 5 CPU0/ = 0
1 =0
total rx CONST_MFIB_PFINFO_REQUESTS packets from slot 5 CPU0/ = 4
1 =4
------------------ show icc flowcontrol ------------------
Class Name FC state FC Counts (on/off)
[ Local ] [ Remote ] [ IPC ]
5 L3-MGR(FC) [ OFF ] 0/0 0/0 0/0
13 EARL-ACL-TCAM(FC [ OFF ] 0/0 0/0 0/0
14 QM(FC) [ OFF ] 0/0 0/0 0/0
37 EARL_NDE(FC) [ OFF ] 0/0 0/0 0/0
71 ACE_REQUESTS [ OFF ] 0/0 0/0 0/0
77 ICC_FC_TEST_REQU [ OFF ] 0/0 0/0 0/0
78 L3-MGR-QM(FC) [ OFF ] 0/0 0/0 0/0
79 L3-MGR-FM [ OFF ] 0/0 0/0 0/0
80 L3-MGR-INTF(FC) [ OFF ] 0/0 0/0 0/0
82 L3-MGR-DSS(FC) [ OFF ] 0/0 0/0 0/0
84 EARL-QOS-TCAM(FC [ OFF ] 0/0 0/0 0/0
125 CONST_MFIB_PFINF [ OFF ] 0/0 0/0 0/0
------------------ show hw-module all fpd ------------------
% No cards with FPD support can be found in the system.
------------------ show hw-module all sensors ------------------
------------------ show hw-module subslot all oir ------------------
------------------ show ip nbar version ------------------
NBAR software version: 4
1 base Mv: 2
2 ftp Mv: 2
3 http Mv: 7
4 static Mv: 6
5 tftp Mv: 1
6 exchange Mv: 1
7 vdolive Mv: 1
8 sqlnet Mv: 1
9 rcmd Mv: 1
10 netshow Mv: 1
11 sunrpc Mv: 2
12 streamwork Mv: 1
13 citrix Mv: 5
14 fasttrack Mv: 2
15 gnutella Mv: 1
16 kazaa2 Mv: 6
17 custom-protocols Mv: 1
18 rtsp Mv: 3
19 rtp Mv: 3
20 mgcp Mv: 1
21 skinny Mv: 1
22 h323 Mv: 1
23 sip Mv: 1
24 rtcp Mv: 1
25 edonkey Mv: 2
26 winmx Mv: 1
{Iv:
------------------ show crypto key mypubkey rsa ------------------
------------------ show inventory ------------------
NAME: "CISCO7606-S", DESCR: "Cisco Systems Cisco 7600 6-slot Chassis System"
PID: CISCO7606-S , VID: V01, SN: FOX1249G0P1
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600 , VID: , SN: NWG124701GP
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "module 5", DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.9"
PID: RSP720-3C-GE , VID: V09, SN: JAE14070RU2
NAME: "msfc sub-module of 5", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.5"
PID: 7600-MSFC4 , VID: 000, SN: JAE14070R0N
NAME: "switching engine sub-module of 5", DESCR: "7600-PFC3C Policy Feature Card 3 Rev. 1.2"
PID: 7600-PFC3C , VID: 000, SN: JAE1408021J
NAME: "Transceiver Gi5/1", DESCR: "Transceiver 1000BaseLH Gi5/1"
PID: N/A , VID: , SN: FNS0836R0N5
NAME: "Transceiver Gi5/2", DESCR: "Transceiver 1000BaseLH Gi5/2"
PID: N/A , VID: , SN: FNS0839K0RA
NAME: "FAN-MOD-6SHS 1", DESCR: "High Speed Fan Module for CISCO7606-S 1"
PID: FAN-MOD-6SHS , VID: V01, SN: DCH12242403
NAME: "PS 1 PWR-2700-AC", DESCR: "(power supply type 0.0.1.4) 1"
PID: PWR-2700-AC , VID: V02, SN: APS134300C1
NAME: "PS 2 PWR-2700-AC", DESCR: "(power supply type 0.0.1.4) 2"
PID: PWR-2700-AC , VID: V02, SN: APS1335006V
------------------ show region ------------------
Region Manager:
Start End Size(b) Class Media Name
0x04000000 0x77FFFFFF 1946157056 Local R/W main
0x04000000 0x07FFFFFF 67108864 Local R/W main:rommon
0x08000000 0x0FFFFFFF 134217728 IText R/O main:text
0x10000000 0x115449B7 22301112 IData R/W main:data
0x115449B8 0x1322CA93 30310620 IBss R/W main:bss
0x1322CA94 0x77FFFFFF 1692218732 Local R/W main:heap
0x78000000 0x7FFFFFFF 134217728 Iomem R/W iomem
Free Region Manager:
------------------ Mempool statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 1322CA94 1692218732 522442036 1169776696 1167289628 1168873196
I/O 78000000 134217728 50320188 83897540 83838016 83831612
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
PC Total Count Name
0x0877BA30 573424 38 Virtual Exec
0x08D313FC 119028 13 IPC Port
0x086DBED0 84980 1 AAA DB Elt Chunk
0x09AD6FA8 82636 17 TCL Chunks
0x0B892EDC 65588 1 MFI: InfoRply
0x0BD10994 65588 1 BITLIST CHUNK
0x08EB7F74 65588 1 MRIB route entry
0x08F2D9C8 65588 1 MRIB route entry
0x08D664E0 62584 74 IPC Tx Bit table
0x08D53BF4 45100 5 IPC Session Desc
0x08A39A70 32440 10 EEM Auto Registration Proc
0x08A1D3BC 29820 10 EEM Auto Registration Proc
0x08098758 20052 1 ARP Entry
0x08DE8B78 20052 1 IP ARP Adjacency Subblock
0x09AD7174 20052 1 TCL Chunks
0x08A38B4C 13320 10 policy_info
0x08D7C89C 10320 5 IPC Mcast Group
0x09A41C3C 10312 1 Virtual Exec
0x09C55660 10052 1 Watched Boolea
0x08091118 10052 1 ARP IDB Subblock
0x0B09BB88 9844 1 PM port_data
0x09BADFA0 8296 2 Resource User IDs
0x0A675998 5504 36 IPC Split Init
0x0BD28D60 5456 2 IP routing table
0x0BCCC224 4728 1 LI IDB IPC Chunk
0x086DBE34 4148 1 AAA Unique Id Hash Table
0x0A696DD8 3364 2 message nego r
0x091E371C 3160 2 TCP CB
0x08093BD4 3052 1 static ARP subblock
0x0ADFA1D4 2744 7 draco-oir:slot 5
0x08D73788 2736 36 IPC RMI Thresh table entries
0x09BA30A8 2152 2 Resource User IDs
0x0B07E954 2100 1 PF ISSU PRST media read proc
0x08CC6C14 2076 1 IPC Split Init
0x08D90118 1820 5 IPC Mcast Tx Group Session Structure
0x08091EF8 1744 1 interface ARP subblock
0x08D71C88 1580 13 IPC RU Context
0x08741490 1436 1 Connection
0x0BD345CC 1408 6 Virtual Exec
0x0875C9F8 1324 17 NameDB String
0x0B892E64 1188 1 MFI: InfoReq
0x08D716BC 1092 13 IPC RU Context Entity
0x083612CC 1040 2 BGP Open
0x08D71634 976 11 IPC Seat RU
0x08A38C64 952 10 policy_info_ent
0x0913D960 908 1 RIB: Control Block
0x09BAE2B8 844 11 IPC Split Init
0x094963F4 780 1 OSPF sw subblock
0x09C9C1D4 736 4 VPN ecomm list
0x0B179C5C 724 3 QM-SB
0x0874FEF4 704 5 TTY timer block
0x084B5E20 608 2 CEF: FIBSWSB control
0x094B2A54 608 1 Virtual Exec
0x08D73744 572 6 IPC RMI Thresh table
0x08D35C74 480 6 IPC Name
0x0A6759D4 456 6 IPC ISSU Receive Process
0x08479980 412 3 CDP sw subblock
0x09498E74 400 1 Virtual Exec
0x08D53EB8 380 5 IPC Subscriber Callback Element
0x085A3A6C 364 2 IPv4 FIB subblock
0x09C9DCDC 340 1 VPN record
0x0875D0BC 332 1 DRMI Master Reg. Slave Process
0x0A8CEE68 324 2 State Machine debug data
0x0876EA50 324 1 Virtual Exec
0x0B312020 272 2 dai_hwsb_t
0x08942744 264 2 DSS-SB
0x0A84A598 252 1 PF ISSU PRST media read proc
0x08479A54 252 3 CDP hw subblock
0x0B3A4250 236 1 RTTY Client Registration
0x08D8931C 228 3 IPC Mcast Member
0x0A5E9AD8 224 1 IPC ISSU Session
0x08837214 220 2 IPC Split Init
0x0A8CEE18 188 2 State Machine debug meta data
0x09C9DC4C 180 1 VRF sub record
0x0ADCA620 164 1 c6k ivrfs
0x0941AD18 164 1 SWIDB_SB: NETBIOS Info
0x0A8CE2B4 160 2 State Machine Instance
0x08D88EA8 156 1 IPC Mcast Group Member Session
0x09BB5D44 148 1 DRMI Master Reg. Slave Process
0x0808EA38 140 1 ARP APP Data Client
0x0A480FF8 136 1 DRMI Master Reg. Slave Process
0x0A48147C 136 1 DRMI Master Reg. Slave Process
0x0962CE28 124 1 QOS policymap name
0x0878FA10 112 1 Parser Mode
0x08F2D984 108 1 MRIB IPv6 Init Process
0x08EB7F30 108 1 MRIB IPv4 Init Process
0x087104A0 104 1 AAA MI SG NAME
0x0A5E9AF4 76 1 IPC ISSU Block the traffic
0x0B400684 76 1 PF ISSU PRST media read proc
0x09C9F93C 76 1 c6k ivrfs
0x0913D9C4 76 1 IP: RIB Name
0x0BD0D354 76 1 c6k ivrfs
0x0BD0D36C 76 1 c6k ivrfs
0x0BD0D398 76 1 c6k ivrfs
0x0A2E5D8C 76 1 c6k ivrfs
0x08CBA9FC 76 1 c6k ivrfs
0x08CBB4B8 76 1 c6k ivrfs
0x0877937C 76 1 Parser Linkage
0x0878FA78 76 1 Parser Mode Q1
0x0878FA9C 76 1 Parser Mode Q2
0x0BA9871C 76 1 MPLS VPN MIB sw subblock
Allocator PC Summary for: I/O
PC Total Count Name
------------------ remote command switch show nvlog ------------------
NVRAM log:
01. 07/28/2012 12:15:02: oir_reload_chassis:Reload Chassis requested
02. 07/28/2012 12:16:32: pf_redun_negotiate:Initialized as ACTIVE processor
03. 08/13/2012 12:11:06: oir_reload_chassis:Reload Chassis requested
04. 08/13/2012 12:12:37: pf_redun_negotiate:Initialized as ACTIVE processor
05. 08/17/2012 07:11:22: oir_reload_chassis:Reload Chassis requested
06. 08/17/2012 07:12:53: pf_redun_negotiate:Initialized as ACTIVE processor
07. 08/17/2012 07:16:11: oir_reload_chassis:Reload Chassis requested
08. 08/17/2012 07:17:41: pf_redun_negotiate:Initialized as ACTIVE processor
09. 08/21/2012 15:28:38: oir_reload_chassis:Reload Chassis requested
10. 08/21/2012 15:30:10: pf_redun_negotiate:Initialized as ACTIVE processor
11. 08/23/2012 08:14:13: oir_reload_chassis:Reload Chassis requested
12. 08/23/2012 08:15:44: pf_redun_negotiate:Initialized as ACTIVE processor
13. 08/23/2012 11:31:47: oir_reload_chassis:Reload Chassis requested
14. 08/23/2012 11:33:18: pf_redun_negotiate:Initialized as ACTIVE processor
15. 08/25/2012 03:47:44: oir_reload_chassis:Reload Chassis requested
16. 08/25/2012 03:49:15: pf_redun_negotiate:Initialized as ACTIVE processor
17. 08/25/2012 04:49:51: oir_reload_chassis:Reload Chassis requested
18. 08/25/2012 04:51:18: pf_redun_negotiate:Initialized as ACTIVE processor
19. 08/25/2012 10:02:34: oir_reload_chassis:Reload Chassis requested
20. 08/25/2012 10:04:00: pf_redun_negotiate:Initialized as ACTIVE processor
21. 08/26/2012 02:53:23: oir_reload_chassis:Reload Chassis requested
22. 08/26/2012 02:54:55: pf_redun_negotiate:Initialized as ACTIVE processor
23. 09/28/2012 20:38:05: oir_reload_chassis:Reload Chassis requested
24. 09/28/2012 20:40:14: pf_redun_negotiate:Initialized as ACTIVE processor
25. 09/28/2012 20:52:37: oir_reload_chassis:Reload Chassis requested
26. 09/28/2012 20:56:12: pf_redun_negotiate:Initialized as ACTIVE processor
27. 09/28/2012 22:09:51: oir_reload_chassis:Reload Chassis requested
28. 09/28/2012 22:11:17: pf_redun_negotiate:Initialized as ACTIVE processor
29. 09/29/2012 09:58:27: oir_reload_chassis:Reload Chassis requested
30. 09/29/2012 09:59:58: pf_redun_negotiate:Initialized as ACTIVE processor
------------------ remote command switch show platform nvhmr previous all ------------------
No reference time info
--- show ibc ---
5 minute rx rate 52072000 bits/sec, 85844 packets/sec
5 minute tx rate 126175000 bits/sec, 171722 packets/sec
4471824027 packets input, 347911664783 bytes
4471716250 broadcasts received
4470569225 packets output, 347521079624 bytes
3411137586 Packets CEF Switched, 0 Packets Fast Switched
IPSEC pkts: 0
total spd packets classified (698239 low, 34253 medium, 19975 high)
Frames Bytes
Rx(0) 50973 6766619
Rx(1) 186290388 474240607
Tx(0) 183722434 827234336
Rx0 0 0 0 0 0 0 0
Rx1 0 0 0 957 0 0 0
Tx Errors/State:
--- remote command switch show ibc ---
Interface IBC0/0(idb 0x12A0BE9C)
5 minute rx rate 0 bits/sec, 0 packets/sec
5 minute tx rate 10000 bits/sec, 16 packets/sec
83810 packets input, 5905868 bytes
34080 broadcasts received
630405 packets output, 43273548 bytes
117830 broadcasts sent
0 Packets CEF Switched, 0 Packets Fast Switched
0 Packets SLB Switched, 0 Packets CWAN Switched
Label switched pkts dropped: 0 Pkts dropped during dma: 0
IPSEC pkts: 0
Total short paks sent in route cache 0
Total throttle drops 0 Input queue drops 0
total spd packets classified (0 low, 0 medium, 9 high)
total spd packets dropped (0 low, 0 medium, 0 high)
IBC resets = 1; last at 10:00:57.820 UTC Sat Sep 29 2012
Frames Bytes
Rx(0) 34031 4099634
Rx(1) 49808 5832456
Tx(0) 630720 61091404
Rx0 = 0 Rx1 = 0
Rx0 0 0 0 0 0 0 0
Rx1 0 0 0 0 0 0 0
Tx Errors/State:
Rx Resource Errors = 0 Input Drops = 0
Input Errors = 0
--- show fabric errors ---
Module errors:
slot channel crc hbeat sync DDR sync
5 0 0 0 0 0
Fabric errors:
slot channel sync buffer timeout
5 0 0 0 0
--- show fabric channel-counters ---
slot channel rxErrors txErrors txDrops lbusDrops
5 0 0 0 0 0
--- show eobc ---
Statistics for eobc from SP/RP to linecards
Hardware is RSP720 EOBC
Interface EOBC0/0(idb 0x17CCC6D0)
108696 packets input, 27128580 bytes
4 broadcasts received
126940 packets output, 45937033 bytes
4301 broadcasts sent
Dev_Instance=0x183C6B98 406612888
Receive/Transmit Buffer Descriptors
RingSz Shadow StartBD LastBD Head Tail Pend
Rx0 512 183C7534 79C43CC0 79C44CB8 152 0 0
Tx0 512 0 79C44D00 79C45CF8 476 476 0
Rx Drop On Busy Disabled
Hash match table for multicast (in use 1, maximum 64 entries):
Entry 0 MAC Addr = 0100.8300.0000
ETSEC counters in Hardware
64b = 685 64b-127b = 227 128b-255b = 51
256b-511b = 609 512b-1023b = 566 1024b-1518b = 937
1519b-1522b = 0 RxBytes = 0 RxPkt = 49
RxFCSErr = 0 RxMCast = 27 RxBCast = 4
RxCntrlFr = 0 RxPauseFR = 0 RxUnkop = 0
RxAlignErr = 0 RxLenErr = 0 RxCodeErr = 0
RxSenseErr = 0 RxUnder = 0 RxOver = 0
RxFrag = 10 RxJab = 0 RxDrop = 0
RxFilerRej = 0 Txbytes = 0 TxPkt = 988
TxMCast = 203 TxBCast = 0 TxPause = 0
TxDef = 205 TxCol = 29 TxMCol = 3
TxLateCol = 0 TxExCol = 0 TxTotCol = 38
TxDrop = 0 TxJab = 0 TxFCS = 0
TxOver = 0 TxUnder = 0 TxFrg = 0
Statistics for eobc fifo between RP and SP
Hardware is RSP720 FIFO EOBC
Interface EOBC0/2(idb 0x17C37190)
528379 packets input, 217642492 bytes
522054 packets output, 80299976 bytes
0 broadcasts sent
Dev_Instance=0x18AC804C 413958220
Rx0 256 18AC89E8 7AA85D40 7AA86538 251 0 0
Tx0 256 0 7AA86580 7AA86D78 70 70 0
64b = 911 64b-127b = 77 128b-255b = 323
256b-511b = 145 512b-1023b = 900 1024b-1518b = 525
1519b-1522b = 0 RxBytes = 0 RxPkt = 1019
RxFCSErr = 0 RxMCast = 0 RxBCast = 0
RxFrag = 0 RxJab = 0 RxDrop = 0
RxFilerRej = 0 Txbytes = 0 TxPkt = 838
TxMCast = 0 TxBCast = 0 TxPause = 0
TxDef = 0 TxCol = 0 TxMCol = 0
TxLateCol = 0 TxExCol = 0 TxTotCol = 0
--- remote command switch show eobc ---
Interface EOBC0/0(idb 0x119A9C18)
178322 packets input, 14379237 bytes
4305 broadcasts received
174034 packets output, 30797540 bytes
28 broadcasts sent
Dev_Instance=0x12305D74 305159540
Rx0 512 12306710 3D9ECE40 3D9EDE38 146 0 0
Tx0 512 0 3D9EDE80 3D9EEE78 466 466 0
Hash match table for multicast (in use 5, maximum 64 entries):
Entry 0 MAC Addr = 0100.8200.0000
Entry 1 MAC Addr = 0100.8100.0000
Entry 2 MAC Addr = 0100.8600.0000
Entry 3 MAC Addr = 0100.8b00.0000
Entry 4 MAC Addr = 0100.8500.0000
64b = 686 64b-127b = 226 128b-255b = 51
256b-511b = 609 512b-1023b = 566 1024b-1518b = 936
1519b-1522b = 0 RxBytes = 0 RxPkt = 82
RxFCSErr = 0 RxMCast = 203 RxBCast = 6
RxFrag = 34 RxJab = 0 RxDrop = 0
RxFilerRej = 0 Txbytes = 0 TxPkt = 978
TxMCast = 27 TxBCast = 0 TxPause = 0
TxDef = 25 TxCol = 2 TxMCol = 1
TxLateCol = 0 TxExCol = 0 TxTotCol = 6
Interface EOBC0/2(idb 0x11C0B184)
543300 packets input, 82449311 bytes
1 broadcasts received
549625 packets output, 248488229 bytes
0 broadcasts sent
Dev_Instance=0x12A07104 312504580
Rx0 256 12A07AA0 3E82EEC0 3E82F6B8 68 0 0
Tx0 256 0 3E82F700 3E82FEF8 249 249 0
64b = 914 64b-127b = 82 128b-255b = 325
256b-511b = 147 512b-1023b = 901 1024b-1518b = 260
1519b-1522b = 0 RxBytes = 0 RxPkt = 580
RxSenseErr = 0 RxUnder = 21240 RxOver = 0
RxFilerRej = 0 Txbytes = 0 TxPkt = 761
Slot 5
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 1 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 2 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 3 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 4 error-counters print-non-zero ---
--- show tech platform earl ---
--- show mls statistics ---
Statistics for Earl in Module 5
L2 Forwarding Engine
Total packets Switched : 19023027249
L3 Forwarding Engine
Total packets Processed : 19022993212 @ 343905 pps
Total packets L3 Switched : 10040602606 @ 177693 pps
Total Packets Bridged : 4473070904
Total Packets FIB Switched : 10040602606
Total Packets ACL Routed : 0
Total Packets Netflow Switched : 0
Total Mcast Packets Switched/Routed : 101545
Total ip packets with TOS changed : 2
Total ip packets with COS changed : 2
Total non ip packets COS changed : 0
Total packets dropped by ACL : 154738
Total packets dropped by Policing : 0
Total packets exceeding CIR : 0
Total packets exceeding PIR : 0
Errors
MAC/IP length inconsistencies : 0
Short IP packets received : 0
IP header checksum errors : 0
No-route packet drops : 213434601
TTL failures : 160
MTU failures : 4389
Total packets L3 Processed by all Modules: 19022993212 @ 343905 pps
--- remote command switch show platform hardware earl status ---
Superman 0 interrupt counts : Total 3224800
se_one: 0
se_hwm: 0
se_dn: 3192033
ntfy_one: 0
ntfy_hwm: 0
ntfy_ovfl: 0
ft_b0_corr_ecc: 0
ft_b0_uncorr_ecc: 0
ft_b1_corr_ecc: 0
ft_b1_uncorr_ecc: 0
ft_b0_multi_pg_hit: 0
ft_b1_multi_pg_hit: 0
l2_flush_done: 0
loop_ntfy: 0
ntfy_fifo_full: 0
l2_line_full: 0
mc_cap: 32775
b0_invld_pg_acc: 0
b1_invld_pg_acc: 0
pkt_crc32_err: 0
cpu_par_err: 0
cpu_timeout: 0
rbus_timeout: 0
dbus_timeout: 0
ip_chksum_err: 0
l3_fcs_err: 0
dbus_seq_err: 0
dbus_hdr_err: 0
l2l3_seq_mismatch: 0
l3_rcv_ovfl_err: 0
l2_merge_err: 0
Tycho Interrupts: Total - 187826
CPU interrupt block : Total interrupts - 0
Netflow interrupt block : Total interrupts - 0
IFIFO_OVF_INT : 0
SINGLE_BIT_ECC_INT : 0
MULTI_BIT_ECC_INT : 0
ECC_DATA_CAPT_INT : 0
TCAM_THRLD_EXCD_INT : 0
ICAM_THRLD_EXCD_INT : 0
TABLE_FULL_INT : 0
ENTRY_ALIAS_INT : 0
FIB interrupt block : Total interrupts - 0
FC_FOVR_INT : 0
FC_FUDR_INT : 0
BP_FOVR_INT : 0
BP_FUDR_INT : 0
RS_FOVR_INT : 0
RS_FUDR_INT : 0
AJ_FOVR_INT : 0
AJ_FUDR_INT : 0
FB_COR_ECC_INT : 0
FB_UNCOR_ECC_INT : 0
Search interrupt block : Total interrupts - 187796
Adj. Statistics tabl block : Total interrupts - 0
Adj. table interface block : Total interrupts - 0
AT_SEQ_ERR_INT : 0
AT_FOVR_INT : 0
AT_FUDR_INT : 0
AT_IB_ADJ_INT : 0
AT_BZONE_INT : 0
AT_CORR_ECC_ERR_INT : 0
AT_UNCORR_ECC_ERR_INT : 0
AT_ECC_ERR_DATA_CAPT : 0
Packet Parser block block : Total interrupts - 0
IP_LEN_INT : 0
IP_SHRT_INT : 0
IP_CS_INT : 0
QDBUS_CRC_INT : 0
QDBUS_LEN_INT : 0
IB_LEN_INT : 0
IB_SEC_INT : 0
Decision Engine bloc block : Total interrupts - 0
NS_ECC_SBE_INT : 0
NS_ECC_MBE_INT : 0
NS_ECC_DCE_INT : 0
ACL_SEQ_ERR_INT : 0
STAT_FOVF_INT : 0
RSLT_FOVF_INT : 0
GEM_MEM_LEAK_INT : 0
Rewrite block interr block : Total interrupts - 0
RW_VO_INT : 0
RW_VU_INT : 0
RW_RO_INT : 0
RW_RU_INT : 0
Statistics block int block : Total interrupts - 30
GLOBAL_OVFL : 0
BGP_OVFL : 30
VLAN_OVFL_0 : 0
VLAN_OVFL_1 : 0
VLAN_OVFL_2 : 0
VLAN_OVFL_3 : 0
VLAN_OVFL_4 : 0
VLAN_OVFL_5 : 0
INIT_DONE : 0
Level 4 Map interfac block : Total interrupts - 0
L4MAP_OVFL : 0
Key Queue Block inte block : Total interrupts - 0
KQ_OVFL : 0
Interrupt statistics for Kuma 0
Kuma cpu parity error : 0
Kuma K interface: data intf crc error : 0
Kuma K'interface: data intf crc error : 0
Kuma K interface: result intf hdr fcs err : 0
Kuma K interface: result intf data fcs err : 0
Kuma K'interface: result intf hdr fcs err : 0
Kuma K'interface: result intf data fcs err : 0
Kuma K interface: intf freeze err : 0
Kuma K'interface: intf freeze err : 0
Kuma stats overflow_0 err : 0
Kuma stats overflow_1 err : 0
Kuma stats saturate_0 err : 0
Kuma stats saturate_1 err : 0
Kuma K'interface err : 0
Kuma K interface err : 0
Kuma E interface: frame crc error on received dbus frame : 0
Kuma E interface: header crc error on received dbus frame : 0
Kuma E interface: length error on received dbus frame : 0
Kuma E interface: received rbus frame seqeunce mismatch err : 0
Kuma E interface: seqtbl overflow err : 0
Kuma E interface: seqtbl underrun err : 0
Kuma E interface: seqtbl is not empty when dbus or rbus out : 0
Kuma E interface: rbrx fcs1/header checksum err : 0
Kuma E interface: rbrx fcs2/data checksum err : 0
Kuma E interface: dbus seq num out of order err : 0
Kuma E interface: rbus seq num out of order : 0
Kuma E interface: dbus fci counter reached : 0
Kuma E interface: dbus idle timeout : 0
Kuma E interface: rbus idle timeout : 0
Kuma E interface: rbus async fifo flow controlled : 0
Kuma E interface: dbus async fifo flow controlled : 0
Kuma E interface: dbus transmit for K' fifo full : 0
Kuma E interface: dbus transmit for K fifo full : 0
Kuma E interface: rbus transmit fifo full : 0
Kuma E interface: rbus transmit fcs1 err : 0
Kuma E interface: rbus transmit fcs2 err : 0
No of times all interrupts got throttled : 0
No of times all interrupts got unthrottled : 0
Kuma 1 Soft Reset Reg
SOFT_RESET_REG: FFFF
Kuma 1 EIF Ebus Cfg Reg
EIF_EBUS_CFG: E8C6Forwarding statistics for kuma 0
KIF DBUS PKTS: 0x00000000
KIF RBUS PKTS: 0x00000000
KIF DBUS PKT CRC ERRORS: 0x00000000
KIF RBUS PKT HDR FCS ERRORS: 0x00000000
KIF RBUS PKT DATA ERRORS: 0x00000000
PIF RBUS PKTS: 0x15AF413D
PIF DBUS PKT CRC ERRORS: 0x00000000
PIF RBUS PKT HDR FCS ERRORS: 0x00000000
PIF RBUS PKT DATA ERRORS: 0x00000000
EIF DBUS COMPACT PKTS: 0x15AF413B
EIF DBUS LEGACY PKTS: 0x00000000
EIF DBUS TRUNCATED PKTS: 0x00001C09
EIF DBUS EXTENDED PKTS: 0x00000000
EIF RBUS NORMAL PKTS: 0x15AF413B
EIF RBUS EXTENDED PKTS: 0x00000000
EIF DBUS PKT HDR CRC ERRORS: 0x00000000
EIF DBUS PKT DATA CRC ERRORS: 0x00000000
EIF RBUS PKT HDR FCS ERRORS: 0x00000000
EIF RBUS PKT DATA ERRORS: 0x00000000
--- remote command switch show platform hardware earl statistics ---
Superman 0 Forwarding statistics:
Forwarded Frames = 0x000000046DDD4DF4 (19023089140)
Frames fwd'ed to Tycho = 0x000000046DDCC900 (19023055104)
L3 results rcvd = 0x000000046DDCC8FF (19023055103)
Src Mac entries created in Bank 0 = 0x00000001FA770847 (8497072199)
Src Mac entries created in Bank 1 = 0x00000002736645AE (10526016942)
Dst Mac entries created in Bank 0 = 0x000000000019D3F7 (1692663)
Dst Mac entries created in Bank 1 = 0x000000046DC379FE (19021396478)
L2 banks congest status = 0x0000000000000000 (0)
frames redirected due to Src Mac = 0x0000000000000003 (3)
frames redirected due to Dst Mac = 0x00000000000084F0 (34032)
Src Mac misses = 0x00000003635A3D02 (14551760130)
Dst Mac misses = 0x0000000360F15B9F (14511332255)
line full encountered during New l = 0x0000000000000000 (0)
frames matching fid_hit reg = 0x0000000000085756 (546646)
frames rcvd with protocol code 0 = 0x000000046DD29B4E (19022388046)
frames rcvd with protocol code 1 = 0x0000000000000000 (0)
frames rcvd with protocol code 2 = 0x0000000000000000 (0)
frames rcvd with protocol code 3 = 0x000000000000016C (364)
frames rcvd with protocol code 4 = 0x0000000000000000 (0)
frames rcvd with protocol code 5 = 0x0000000000000000 (0)
frames rcvd with protocol code 6 = 0x0000000000007551 (30033)
frames rcvd with protocol code 7 = 0x0000000000000000 (0)
frames rcvd with protocol code 8 = 0x0000000000000000 (0)
frames rcvd with protocol code 9 = 0x0000000000000000 (0)
frames rcvd with protocol code 10 = 0x0000000000000000 (0)
frames rcvd with protocol code 11 = 0x0000000000000000 (0)
frames rcvd with protocol code 12 = 0x0000000000000000 (0)
frames rcvd with protocol code 13 = 0x0000000000000000 (0)
frames rcvd with protocol code 14 = 0x0000000000000000 (0)
frames rcvd with protocol code 15 = 0x00000000000A3BEB (670699)
bytes rcvd with protocol code 0 = 0x0000018DF77CC81E (1709254166558)
bytes rcvd with protocol code 1 = 0x0000000000000000 (0)
bytes rcvd with protocol code 2 = 0x0000000000000000 (0)
bytes rcvd with protocol code 3 = 0x000000000000732C (29484)
bytes rcvd with protocol code 4 = 0x0000000000000000 (0)
bytes rcvd with protocol code 5 = 0x0000000000000000 (0)
bytes rcvd with protocol code 6 = 0x0000000000319E6B (3251819)
bytes rcvd with protocol code 7 = 0x0000000000000000 (0)
bytes rcvd with protocol code 8 = 0x0000000000000000 (0)
bytes rcvd with protocol code 9 = 0x0000000000000000 (0)
bytes rcvd with protocol code 10 = 0x0000000000000000 (0)
bytes rcvd with protocol code 11 = 0x0000000000000000 (0)
bytes rcvd with protocol code 12 = 0x0000000000000000 (0)
bytes rcvd with protocol code 13 = 0x0000000000000000 (0)
bytes rcvd with protocol code 14 = 0x0000000000000000 (0)
bytes rcvd with protocol code 15 = 0x0000000002CAA4DE (46834910)
frames rate limited = 0x0000000000000000 (0)
correctable errors in bank 0 = 0x0000000000000000 (0)
uncorrectable errors in bank 0 = 0x0000000000000000 (0)
correctable errors in bank 1 = 0x0000000000000000 (0)
uncorrectable errors in bank 1 = 0x0000000000000000 (0)
DBus Header Checksum errors = 0x0000000000000000 (0)
address of the line full = 0x00000000
address of the last error in Bank0 = 0x0000BD6F
address of the last error in Bank1 = 0x0000FFFF
--- remote command switch show mls cef hardware ---
CEF TCAM v2:
65536 rows/device, 4 device(s)
32 entries/mask-block
8192 total blocks (32b wide)
1212416 s/w table memory
Options:
sanity check: on
sanity interval: 301 seconds
consistency check: on
consistency interval: 11 seconds
redistribution: off
redistribution interval: 120 seconds
redistribution threshold: 10
compression: on
compression interval: 31 seconds
tcam/ssram shadowing: on
Operation Statistics:
Entries inserted: 0000000000341693
Entries deleted: 0000000000010497
Entries compressed: 0000000000001668
Blocks inserted: 0000000000069830
Blocks deleted: 0000000000063677
Blocks compressed: 0000000000000121
Blocks shuffled: 0000000000059315
Blocks deleted for exception: 0000000000004220
Direct h/w modifications: 0000000000000000
Background Task Statistics:
Consistency Check count: 0000000000006898
Consistency Errors: 0000000000000000
SSRAM Consistency Errors: 0000000000000000
Sanity Check count: 0000000000000253
Sanity Check Errors: 0000000000000000
Compression count: 0000000000000351
Exception Handling status : on
L3 Hardware switching status : on
Fatal Error Handling Status : Reset
Fatal Errors: 0000000000000000
Fatal Error Recovery Count: 0000000000000000
SSRAM ECC error summary:
Uncorrectable ecc entries : 0
Correctable ecc entries : 0
Packets dropped : 0
Packets software switched : 0
FIB SSRAM Entry status
Key: UC - Uncorrectable error, C - Correctable error
SSRAM banks : Bank0 Bank1
No ECC errors reported in FIB SSRAM.
--- remote command switch show platform hardware superman interrupts ---
Superman 0 interrupt counts : Total 3224822
se_one: 0
se_hwm: 0
se_dn: 3192055
ntfy_one: 0
ntfy_hwm: 0
ntfy_ovfl: 0
ft_b0_corr_ecc: 0
ft_b0_uncorr_ecc: 0
ft_b1_corr_ecc: 0
ft_b1_uncorr_ecc: 0
l2_flush_done: 0
loop_ntfy: 0
ntfy_fifo_full: 0
l2_line_full: 0
mc_cap: 32775
b0_invld_pg_acc: 0
b1_invld_pg_acc: 0
pkt_crc32_err: 0
cpu_par_err: 0
cpu_timeout: 0
rbus_timeout: 0
dbus_timeout: 0
ip_chksum_err: 0
l3_fcs_err: 0
dbus_seq_err: 0
dbus_hdr_err: 0
l3_rcv_ovfl_err: 0
l2_merge_err: 0
--- remote command switch show platform hardware superman forwarding-table-ecc ---
No forwarding table ecc errors found
--- remote command switch show platform hardware superman config ---
Superman hash configuration
Hash 0: x^12+x^8+x^6+x^5+1
Hash 1: x^12+x^9+x^8+x^6+x^5+x^4+1
Superman 1 Control Reg
SYS_CONFIG: 2
NEW_MIX_HASH_EN: Enable
PACKET_FORMAT: Compact
GE_SUPP_EN: Disable
IPV6_RUNT_ETHERNET_CHK_DIS: 0
IPV6_IGN_L4_HDR_CHK_DIS: 0
IPV6_LANE_HDR_VLD_CHK_DIS: 0
VLAN_IP_HASH_EN: Enable
ROHINI_WRKARND_EN: Disable
ARGOS_MN_EGRS_WRKARND_EN: Disable
ARGOS_MN_IGRS_WRKARND_EN: Disable
ETHERCHNL_SLOT_NUM: 0xD
NEG_MN_FLOOD_DIS: 0
POS_MN_FLOOD_DIS: 0
CAP2_GEN_ORPOE_DIS: Disable
BRDG_ON_FF_DIS: Disable
DBUS_CRC: Enable
L3_FCS1_EN: Enable
L3_FCS2_EN: Enable
TIMEOUT_DIAG: Disable
TIMEOUT_CNT: 0
RBUS_TIMEOUT: Enable
DBUS_TIMEOUT: Enable
RBUS: Enable
DBUS: Enable
CPU_PAR_CHK: Disable
CPU_PAR_POL: Enable
LOOP_NTFY_DIAG: Disable
LOOP_NTFY_EN: Disable
RED_FLUSH_EN: Disable
L2_ONLY: Disable
IGMP_SNOOP_ON_MCAST_ONLY: Enable
IPV6_IGMP_SNOOP_DIS: Disable
INGRESS_GEN_MN_DIS: Enable
RB_SC_DIS: Disable
RES_CAP_SEL: CAP1 and CAP2
EGRESS_CAP_SEL: Enable
DONT_USE_IP_FOR_RBH: Disable
BNDL_SEL: IP
BNDL_HASH: Source XOR Destination
RBH_HASH_SEL: x^17 + x^4 + 1
USE_HDR_RBH: Enable
IGNR_VLAN: Disable
HASH_CNFG: 0
HASH_INPUT_SEL: Lyra mode
BCST_MISS: Disable
COND_LRN: Enable
FT_ECC_CHK_DIS: Disable
FT_ECC_CORR_DIS: Disable
BPDU_CHK: Enable
NTFY_FF_CTL: Modify
NTFY_IL: Disable
NTFY_NL: Disable
CLEAR_IGS: Disable
CACHE_ENH_EN: Disable
ALWAYS_L3_VLAN_LKUP: Enable
CCC_FIX_NON_L3_FRM_EN: Disable
CCC_FIX_EGR_EN: Disable
CCC_FIX: Enable
--- remote command switch show platform hardware tycho interrupts ---
Tycho Interrupts: Total - 187830
IFIFO_OVF_INT : 0
TABLE_FULL_INT : 0
ENTRY_ALIAS_INT : 0
FC_FOVR_INT : 0
FC_FUDR_INT : 0
BP_FOVR_INT : 0
BP_FUDR_INT : 0
RS_FOVR_INT : 0
RS_FUDR_INT : 0
AJ_FOVR_INT : 0
AJ_FUDR_INT : 0
FB_COR_ECC_INT : 0
Search interrupt block : Total interrupts - 187800
AT_SEQ_ERR_INT : 0
AT_FOVR_INT : 0
AT_FUDR_INT : 0
AT_IB_ADJ_INT : 0
AT_BZONE_INT : 0
IP_LEN_INT : 0
IP_SHRT_INT : 0
IP_CS_INT : 0
QDBUS_CRC_INT : 0
QDBUS_LEN_INT : 0
IB_LEN_INT : 0
IB_SEC_INT : 0
NS_ECC_SBE_INT : 0
NS_ECC_MBE_INT : 0
NS_ECC_DCE_INT : 0
ACL_SEQ_ERR_INT : 0
STAT_FOVF_INT : 0
RSLT_FOVF_INT : 0
RW_VO_INT : 0
RW_VU_INT : 0
RW_RO_INT : 0
RW_RU_INT : 0
GLOBAL_OVFL : 0
BGP_OVFL : 30
VLAN_OVFL_0 : 0
VLAN_OVFL_1 : 0
VLAN_OVFL_2 : 0
VLAN_OVFL_3 : 0
VLAN_OVFL_4 : 0
VLAN_OVFL_5 : 0
INIT_DONE : 0
L4MAP_OVFL : 0
KQ_OVFL : 0
--- remote command switch show platform software earl reset config ---
EBUS Out of seq. : Enabled
Earl freeze check. : Enabled
EARL Patch invocation limit per every 30 secs : 10
Upon reaching EARL patch invocation limit : Crash
--- remote command switch show platform software earl reset history ---
Num. of times patch applied : 0
Num. of times patch requested : 0
AclDeny detection: (Total=0 Failed=0)
Slot 5
--- remote command switch show platform hardware asic-versions slot 5 ---
ASIC Name Version
slot : 5
ST_TYCHO (68) (3.2)
ST_SUPERMAN (67) (2.2)
KUMA (70) (3.0)
SSA (43) (9.0)
SSO (44) (2.0)
HYPERION (42) (6.0)
PINNACLE (26) (4.0)
--- remote command module 5 show platform hardware earl status ---
se_one: 0
se_hwm: 0
se_dn: 3192055
ntfy_one: 0
ntfy_hwm: 0
ntfy_ovfl: 0
ft_b0_corr_ecc: 0
ft_b0_uncorr_ecc: 0
ft_b1_corr_ecc: 0
ft_b1_uncorr_ecc: 0
l2_flush_done: 0
loop_ntfy: 0
ntfy_fifo_full: 0
l2_line_full: 0
mc_cap: 32775
b0_invld_pg_acc: 0
b1_invld_pg_acc: 0
pkt_crc32_err: 0
cpu_par_err: 0
cpu_timeout: 0
rbus_timeout: 0
dbus_timeout: 0
ip_chksum_err: 0
l3_fcs_err: 0
dbus_seq_err: 0
dbus_hdr_err: 0
l3_rcv_ovfl_err: 0
l2_merge_err: 0
IFIFO_OVF_INT : 0
TABLE_FULL_INT : 0
ENTRY_ALIAS_INT : 0
FC_FOVR_INT : 0
FC_FUDR_INT : 0
BP_FOVR_INT : 0
BP_FUDR_INT : 0
RS_FOVR_INT : 0
RS_FUDR_INT : 0
AJ_FOVR_INT : 0
AJ_FUDR_INT : 0
FB_COR_ECC_INT : 0
AT_SEQ_ERR_INT : 0
AT_FOVR_INT : 0
AT_FUDR_INT : 0
AT_IB_ADJ_INT : 0
AT_BZONE_INT : 0
IP_LEN_INT : 0
IP_SHRT_INT : 0
IP_CS_INT : 0
QDBUS_CRC_INT : 0
QDBUS_LEN_INT : 0
IB_LEN_INT : 0
IB_SEC_INT : 0
NS_ECC_SBE_INT : 0
NS_ECC_MBE_INT : 0
NS_ECC_DCE_INT : 0
ACL_SEQ_ERR_INT : 0
STAT_FOVF_INT : 0
RSLT_FOVF_INT : 0
RW_VO_INT : 0
RW_VU_INT : 0
RW_RO_INT : 0
RW_RU_INT : 0
GLOBAL_OVFL : 0
BGP_OVFL : 30
VLAN_OVFL_0 : 0
VLAN_OVFL_1 : 0
VLAN_OVFL_2 : 0
VLAN_OVFL_3 : 0
VLAN_OVFL_4 : 0
VLAN_OVFL_5 : 0
INIT_DONE : 0
L4MAP_OVFL : 0
KQ_OVFL : 0
PIF RBUS PKTS: 0x0009CBFB
EIF DBUS COMPACT PKTS: 0x0009CBFC
EIF DBUS TRUNCATED PKTS: 0x0000000D
EIF RBUS NORMAL PKTS: 0x0009CBFE
--- remote command module 5 show platform hardware earl statistics ---
Forwarded Frames = 0x000000046DE71C31 (19023731761)
Frames fwd'ed to Tycho = 0x000000046DE6973B (19023697723)
L3 results rcvd = 0x000000046DE6973B (19023697723)
Src Mac entries created in Bank 0 = 0x00000001FA799073 (8497238131)
Src Mac entries created in Bank 1 = 0x00000002736D8BBE (10526493630)
Dst Mac entries created in Bank 0 = 0x000000000019D408 (1692680)
Dst Mac entries created in Bank 1 = 0x000000046DCD4829 (19022039081)
frames redirected due to Dst Mac = 0x00000000000084F1 (34033)
Src Mac misses = 0x000000036361AB8B (14552247179)
Dst Mac misses = 0x0000000360F8CA29 (14511819305)
frames matching fid_hit reg = 0x0000000000085763 (546659)
frames rcvd with protocol code 0 = 0x000000046DDC6974 (19023030644)
frames rcvd with protocol code 6 = 0x0000000000007557 (30039)
frames rcvd with protocol code 15 = 0x00000000000A3BFA (670714)
bytes rcvd with protocol code 0 = 0x0000018DFAE33B5A (1709311212378)
bytes rcvd with protocol code 6 = 0x000000000031A063 (3252323)
bytes rcvd with protocol code 15 = 0x0000000002CAA8D2 (46835922)
--- remote command module 5 show platform hardware superman interrupts ---
Superman 0 interrupt counts : Total 3224874
se_one: 0
se_hwm: 0
se_dn: 3192107
ntfy_one: 0
ntfy_hwm: 0
ntfy_ovfl: 0
ft_b0_corr_ecc: 0
ft_b0_uncorr_ecc: 0
ft_b1_corr_ecc: 0
ft_b1_uncorr_ecc: 0
l2_flush_done: 0
loop_ntfy: 0
ntfy_fifo_full: 0
l2_line_full: 0
mc_cap: 32775
b0_invld_pg_acc: 0
b1_invld_pg_acc: 0
pkt_crc32_err: 0
cpu_par_err: 0
cpu_timeout: 0
rbus_timeout: 0
dbus_timeout: 0
ip_chksum_err: 0
l3_fcs_err: 0
dbus_seq_err: 0
dbus_hdr_err: 0
l3_rcv_ovfl_err: 0
l2_merge_err: 0
--- remote command module 5 show platform hardware superman forwarding-table-ecc ---
--- remote command module 5 show platform hardware superman config ---
SYS_CONFIG: 2
GE_SUPP_EN: Disable
NEG_MN_FLOOD_DIS: 0
POS_MN_FLOOD_DIS: 0
DBUS_CRC: Enable
L3_FCS1_EN: Enable
L3_FCS2_EN: Enable
TIMEOUT_CNT: 0
RBUS: Enable
DBUS: Enable
CPU_PAR_POL: Enable
L2_ONLY: Disable
RB_SC_DIS: Disable
BNDL_SEL: IP
USE_HDR_RBH: Enable
IGNR_VLAN: Disable
HASH_CNFG: 0
BCST_MISS: Disable
COND_LRN: Enable
BPDU_CHK: Enable
NTFY_FF_CTL: Modify
NTFY_IL: Disable
NTFY_NL: Disable
CLEAR_IGS: Disable
CCC_FIX: Enable
SYS_CONFIG: 2
GE_SUPP_EN: Disable
NEG_MN_FLOOD_DIS: 0
POS_MN_FLOOD_DIS: 0
DBUS_CRC: Enable
L3_FCS1_EN: Enable
L3_FCS2_EN: Enable
TIMEOUT_CNT: 0
RBUS: Enable
DBUS: Enable
CPU_PAR_POL: Enable
L2_ONLY: Disable
RB_SC_DIS: Disable
BNDL_SEL: IP
USE_HDR_RBH: Enable
IGNR_VLAN: Disable
HASH_CNFG: 0
BCST_MISS: Disable
COND_LRN: Enable
BPDU_CHK: Enable
NTFY_FF_CTL: Modify
NTFY_IL: Disable
NTFY_NL: Disable
CLEAR_IGS: Disable
CCC_FIX: Enable
--- remote command module 5 show platform software earl reset config ---
--- remote command module 5 show platform software earl reset history ---
--- show error-detection crc status ---
------------------ show buffers ------------------
Buffer elements:
850 in free list (500 max allowed)
4276969 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
1017 in free list (128 min, 2048 max allowed)
1523393 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Medium buffers, 256 bytes (total 3000, permanent 3000):
3000 in free list (64 min, 3000 max allowed)
74456 hits, 0 misses, 0 trims, 0 created
Middle buffers, 600 bytes (total 512, permanent 512, peak 584 @ 19:08:45):
508 in free list (64 min, 1024 max allowed)
82034 hits, 24 misses, 72 trims, 72 created
Big buffers, 1536 bytes (total 1000, permanent 1000):
1000 in free list (64 min, 1000 max allowed)
199887 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 300 max allowed)
628 hits, 0 misses, 0 trims, 0 created
Large buffers, 9240 bytes (total 8, permanent 8):
8 in free list (0 min, 10 max allowed)
30 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 2, permanent 2):
2 in free list (0 min, 4 max allowed)
15 hits, 0 misses, 0 trims, 0 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 100, permanent 100):
100 in free list (100 min, 200 max allowed)
CF Middle buffers, 600 bytes (total 100, permanent 100):
Syslog ED Pool buffers, 600 bytes (total 288, permanent 288):
256 in free list (288 min, 288 max allowed)
177 hits, 0 misses
LI Middle buffers, 600 bytes (total 512, permanent 256, peak 512 @ 21:09:25):
256 in free list (256 min, 768 max allowed)
171 hits, 85 fallbacks, 0 trims, 256 created
256 max cache size, 256 in cache
0 hits in cache, 0 misses in cache
DMA-2 buffers, 1536 bytes (total 1024, permanent 1024):
512 in free list (0 min, 1024 max allowed)
512 hits, 0 misses
512 max cache size, 512 in cache
CF Big buffers, 1536 bytes (total 25, permanent 25):
25 in free list (25 min, 50 max allowed)
LI Big buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 21:09:25):
EOBC0/0 buffers, 2198 bytes (total 6144, permanent 6144):
3072 in free list (0 min, 6144 max allowed)
3072 hits, 0 fallbacks
3072 max cache size, 2559 in cache
109208 hits in cache, 0 misses in cache
EOBC0/2 buffers, 2198 bytes (total 6144, permanent 6144):
3072 max cache size, 2816 in cache
528908 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 2016, permanent 2016):
1994 in free list (448 min, 4480 max allowed)
157875 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 2, permanent 2):
2 in free list (2 min, 4 max allowed)
LI Very Big buffers, 4520 bytes (total 257, permanent 128, peak 257 @ 21:10:22):
129 in free list (128 min, 384 max allowed)
85 hits, 43 fallbacks, 14 trims, 143 created
128 max cache size, 128 in cache
CF Large buffers, 5024 bytes (total 1, permanent 1):
1 in free list (1 min, 2 max allowed)
Private Huge IPC buffers, 18024 bytes (total 2, permanent 2):
2 in free list (1 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 2, permanent 2):
107 hits, 0 misses, 0 trims, 0 created
Header pools:
Particle Clones:
1024 clones, 5 hits, 0 misses
Public particle pools:
Normal buffers, 1532 bytes (total 1024, permanent 1024):
1024 in free list (512 min, 2048 max allowed)
8703 hits, 0 misses, 0 trims, 0 created
F/S buffers, 1590 bytes (total 512, permanent 512):
0 in free list (0 min, 512 max allowed)
512 hits, 0 misses
3 hits in cache, 0 misses in cache
Private particle pools:
IBC0/0 buffers, 648 bytes (total 512, permanent 512):
512 hits, 8703 fallbacks
512 max cache size, 256 in cache
186740492 hits in cache, 0 misses in cache
------------------ show buffers usage ------------------
Statistics for the Small pool
Input IDB : Gi5/2 count: 1
Caller pc : 0x B42FFD8 count: 2
Resource User: IP Input count: 2
Caller pc : 0x B3F1948 count: 3
Resource User: *Dead* count: 3
Caller pc : 0x B1DFA38 count: 3
Resource User: Init count: 3
Number of Buffers used by packets generated by system: 1022
Number of Buffers used by incoming packets: 2
Statistics for the Medium pool
Number of Buffers used by packets generated by system: 3000
Number of Buffers used by incoming packets: 0
Statistics for the Middle pool
Output IDB : Gi5/2 count: 9
Caller pc : 0x 91DFCDC count: 10
Resource User: Virtual Ex count: 10
Number of Buffers used by packets generated by system: 512
Statistics for the Big pool
Number of Buffers used by packets generated by system: 1000
Statistics for the VeryBig pool
Statistics for the Large pool
Number of Buffers used by packets generated by system: 8
Statistics for the Huge pool
Number of Buffers used by packets generated by system: 2
Statistics for the CF Small pool
Statistics for the CF Middle pool
Statistics for the Syslog ED Pool pool
Caller pc : 0x 8A961E8 count: 32
Resource User: EEM ED Sys count: 32
Number of Buffers used by packets generated by system: 288
Statistics for the LI Middle pool
Statistics for the DMA-2 pool
Number of Buffers used by packets generated by system: 1024
Statistics for the CF Big pool
Number of Buffers used by packets generated by system: 25
Statistics for the LI Big pool
Statistics for the EOBC0/0 pool
Caller pc : 0x AAB898C count: 513
Resource User: IPC Memory count: 506
Resource User: SCP async: count: 7
Input IDB : EO0/0 count: 1
Number of Buffers used by packets generated by system: 6144
Statistics for the EOBC0/2 pool
Caller pc : 0x AAB898C count: 256
Resource User: IPC Memory count: 245
Resource User: Port manag count: 10
Statistics for the IPC pool
Caller pc : 0x 8D6050C count: 22
Resource User: *Dead* count: 1
Resource User: IPC Seat R count: 14
Resource User: Card 0x15 count: 1
Resource User: Card 0x15 count: 2
Resource User: XDR mcast count: 2
Resource User: Init count: 1
Number of Buffers used by packets generated by system: 2016
Statistics for the CF VeryBig pool
Statistics for the LI Very Big pool
Number of Buffers used by packets generated by system: 257
Statistics for the CF Large pool
Statistics for the Private Huge IPC pool
Statistics for the Private Huge pool
Statistics for the FS Header pool
Caller pc : 0x B3BAE80 count: 2
Resource User: Init count: 13
Caller pc : 0x B87475C count: 1
Caller pc : 0x 8B79C40 count: 1
Caller pc : 0x A3D00D0 count: 8
Caller pc : 0x A26760C count: 1
Caller pc : 0x 85AE3F8 count: 1
Resource User: IP ARP Adj count: 1
Number of Buffers used by packets generated by system: 31
Statistics for the l2frag pak pool pool
Number of Buffers used by packets generated by system: 0
Statistics for the SW Crypto Header pool
Caller pc : 0x 9DDB1AC count: 1
------------------ show controllers cwan ------------------
------------------ show diagbus ------------------
------------------ show logging ------------------
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 177 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 177 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 171 message lines logged
Log Buffer (8192 bytes):
4:46:31.186: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 14:46:38.282: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 14:56:52.814: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 14:57:02.234: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 15:34:31.346: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 29 15:37:35.862: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 15:37:41.198: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 15:50:12.182: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 29 16:11:31.718: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 16:11:37.574: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 16:24:14.434: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.23)
*Sep 29 17:09:21.522: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:17:42.865: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:29:16.721: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:29:41.329: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.13)
*Sep 29 18:32:51.561: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:33:52.253: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:44:55.645: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:51:33.697: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Sep 29 18:51:33.697: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Sep 29 18:52:43.697: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Down BGP Notification sent
*Sep 29 18:52:43.697: %BGP-3-NOTIFICATION: sent to neighbor 192.168.18.1 4/0 (hold time expired) 0 bytes
*Sep 29 18:52:58.537: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.18.1 IPv4 Unicast topology base removed from session BGP Notification sent
*Sep 29 18:55:47.865: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:56:30.773: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 18:59:51.181: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(180.149.7.153)
*Sep 29 19:15:36.477: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 19:18:28.337: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 19:28:52.937: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 3(117.18.231.26)
*Sep 29 19:35:30.877: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 19:36:13.377: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 19:36:15.581: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 4(180.149.7.153)
*Sep 29 19:46:14.357: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 19:50:47.061: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:50:48.917: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:37.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:51:37.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:51:44.941: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:44.941: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:54.357: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Up
*Sep 29 19:52:49.705: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:52:50.141: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:53:24.729: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Down BGP Notification sent
*Sep 29 19:53:24.729: %BGP-3-NOTIFICATION: sent to neighbor 192.168.18.1 4/0 (hold time expired) 0 bytes
*Sep 29 19:53:39.693: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.18.1 IPv4 Unicast topology base removed from session BGP Notification sent
*Sep 29 19:54:11.517: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:54:15.801: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:55:04.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:55:04.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:56:59.149: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:56:59.149: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:57:06.549: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Up
*Sep 29 19:59:03.525: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
SLOT 3: *Sep 29 20:08:48.085: %ETH_SPA_GILA_FUGU-3-SPI4_RDOOF_ERR: Fugu : TXHSPI Rdata Out of Frame error
SLOT 3: *Sep 29 20:08:48.089: %CARDMGR-2-SYNC_CHECK_FAIL: The SPA in subslot 3/0 egress SPI4 interface sync with the host failed.
SLOT 3: *Sep 29 20:08:48.101: %ETH_SPA_MAC-3-SPI4_ERROR: Marvel MAC : SPI4 Error occured in the MAC
*Sep 29 20:08:48.513: %SPA_OIR-6-OFFLINECARD: SPA (SPA-5X1GE-V2) offline in subslot 3/0
SLOT 3: *Sep 29 20:08:48.509: %SPA_OIR-6-REMCARD: Card removed from Subslot 0, interfaces disabled
*Sep 29 20:09:00.349: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:09:59.593: %OIR-6-REMCARD: Card removed from slot 3, interfaces disabled
*Sep 29 20:09:59.599: %OIR-SP-6-REMCARD: Card removed from slot 3, interfaces disabled
*Sep 29 20:11:00.553: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:11:56.897: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:13:17.513: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:16:00.797: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.26)
*Sep 29 20:22:25.917: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.26)
*Sep 29 20:49:26.873: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(180.149.7.153)
*Sep 29 21:00:42.857: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 30 03:32:39.735: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.9)
*Sep 30 04:07:23.811: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.58.247.137)
*Sep 30 04:33:08.155: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 30 06:02:23.519: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.28)
*Sep 30 06:13:35.786: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 06:14:10.722: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(103.23.171.5)
*Sep 30 06:39:56.186: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 06:45:13.806: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 07:10:36.746: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
------------------ show module ------------------
Mod Ports Card Type Model Serial No.
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE14070RU2
Mod MAC addresses Hw Fw Sw Status
5 001c.584f.2abc to 001c.584f.2abf 5.9 12.2(33r)SRD 12.2(33)SRE6 Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 7600-PFC3C JAE1408021J 1.2 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE14070R0N 1.5 Ok
Mod Online Diag Status
5 Pass
------------------ show mls asic ------------------
Earl in Module 5
Tycho - ver : 2, Cisco-id : 2A4, Vendor-id : 215
Superman - ver : 2, Cisco-id : 2A4, Vendor-id : 215
------------------ show mls cef summary ------------------
Total routes: 196319
IPv4 unicast routes: 194265
IPv4 Multicast routes: 4
MPLS routes: 2048
IPv6 unicast routes: 2
IPv6 multicast routes: 3
EoM routes: 0
------------------ show power ------------------
system power redundancy mode = redundant
system power total = 2669.10 Watts (63.55 Amps @ 42V)
system power used = 800.94 Watts (19.07 Amps @ 42V)
system power available = 1868.16 Watts (44.48 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-2700-AC 2669.10 63.55 OK OK on
2 PWR-2700-AC 2669.10 63.55 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 FAN-MOD-6SHS 180.18 4.29 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
5 RSP720-3C-GE 310.38 7.39 310.38 7.39 on on
6 (Redundant Sup) - - 310.38 7.39 - -
------------------ show environment ------------------
environmental alarms:
no alarms
backplane:
operating clock count: 2
fan-tray 1:
fan-tray 1 type: FAN-MOD-6SHS
fan-tray 1 mode: Auto
fan-tray 1 fan-fail: OK
clock 1:
clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: AC 220V
power-supply 1 power-output-mode: high
power-supply 1 incompatible with fan: OK
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: AC 220V
power-supply 2 power-output-mode: high
power-supply 2 incompatible with fan: OK
power-supply 2 power-output-fail: OK
module 5:
module 5 power-output-fail: OK
module 5 outlet temperature: 27C
module 5 inlet temperature: 23C
module 5 device-1 temperature: 31C
module 5 device-2 temperature: 32C
module 5 asic-1 (SSO-1) temp: 23C
module 5 asic-2 (SSO-2) temp: 23C
module 5 asic-3 (SSO-3) temp: 23C
module 5 asic-4 (SSO-4) temp: 23C
module 5 asic-5 (SSA-1) temp: 23C
module 5 asic-6 (HYPERION-1) temp: 24C
module 5 RP outlet temperature: 27C
module 5 RP inlet temperature: 25C
module 5 EARL outlet temperature: 29C
module 5 EARL inlet temperature: 24C
chassis connector rating: 1680.00 Watts (40.00 Amps @ 42V)
module 5
module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 5 power consumption: 310.38 Watts ( 7.39 Amps @ 42V)
chassis per slot cooling capacity: 91 cfm
ambient temperature: < 55C
module 5 cooling requirement: 35 cfm
------------------ show catalyst6000 all ------------------
chassis MAC addresses: 64 addresses from 0021.a00b.1f80 to 0021.a00b.1fbf
traffic meter = 0% Last cleared at 10:00:23 UTC Sat Sep 29 2012
peak = 1% reached at 10:00:23 UTC Sat Sep 29 2012
switching-clock: clock switchover and system reset is allowed
------------------ show diagnostic result module all detail ------------------
Current bootup diagnostic level: minimal
Module 5: Route Switch Processor 720 (Active) SerialNo : JAE14070RU2
Overall Diagnostic Result for Module 5 : PASS
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
___________________________________________________________________________
1) TestScratchRegister -------------> .
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 2344
Last test execution time ----> Sep 30 2012 07:10:45
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> Sep 30 2012 07:10:45
Total failure count ---------> 0
Consecutive failure count ---> 0
2) TestSPRPInbandPing --------------> .
Total run count -------------> 4688
Last test execution time ----> Sep 30 2012 07:10:47
Last test pass time ---------> Sep 30 2012 07:10:47
CPU util(5sec) SP -----------> 11%
CPU util(5sec) RP -----------> 54%
Traffic ---------------------> 0%
netint_thr_active -----------> 0
Inband Tx_Rate --------------> 1661
Inband Rx_Rate --------------> 193
Per-device Failure Count ----> n/a
3) TestTransceiverIntegrity:
Port 1 2
Total run count -------------> 0
Last test execution time ----> n/a
Last test pass time ---------> n/a
4) TestActiveToStandbyLoopback:
Port 1 2
U U
5) TestLoopback:
Port 1 2
Total run count -------------> 1
Last test execution time ----> Sep 29 2012 10:00:53
Last test pass time ---------> Sep 29 2012 10:00:53
6) TestNewIndexLearn ---------------> .
7) TestDontConditionalLearn --------> .
😎 TestBadBpduTrap -----------------> .
9) TestMatchCapture ----------------> .
Last test execution time ----> Sep 29 2012 10:00:54
Last test pass time ---------> Sep 29 2012 10:00:54
10) TestProtocolMatchChannel --------> .
11) TestFibDevices ------------------> .
Last test execution time ----> Sep 29 2012 10:00:55
Last test pass time ---------> Sep 29 2012 10:00:55
12) TestIPv4FibShortcut -------------> .
13) TestL3Capture2 ------------------> .
14) TestIPv6FibShortcut -------------> .
15) TestMPLSFibShortcut -------------> .
Last test execution time ----> Sep 29 2012 10:00:56
Last test pass time ---------> Sep 29 2012 10:00:56
16) TestNATFibShortcut --------------> .
17) TestAclPermit -------------------> .
18) TestQoSTcam ---------------------> .
19) TestL3VlanMet -------------------> .
20) TestIngressSpan -----------------> .
21) TestEgressSpan ------------------> .
22) TestNetflowInlineRewrite:
Port 1 2
U U
23) TestFabricSnakeForward ----------> .
24) TestFabricSnakeBackward ---------> .
Last test execution time ----> Sep 29 2012 10:00:57
Last test pass time ---------> Sep 29 2012 10:00:57
25) TestTrafficStress ---------------> U
26) TestFibTcamSSRAM ----------------> U
27) TestAsicMemory ------------------> U
28) TestAclQosTcam ------------------> U
29) TestNetflowTcam -----------------> U
30) ScheduleSwitchover --------------> U
31) FirmwareDiagStatus --------------> .
32) TestFabricFlowControlStatus -----> U
Current run count -------------------------->: 0
First test execution time ------------------>:
Last test execution time ------------------->:
Total FPOE Rate0 Count --------------------->: 0
Total FPOE Reduced Rate Count -------------->: 0
33) TestErrorCounterMonitor ---------> .
Error Records ---------------> n/a
------------------ show diagnostic events ------------------
Diagnostic events (storage for 500 events, 4 events recorded)
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp ET [Card] Event Message
09/29 10:00:57.547 I [5] Diagnostics Passed
09/29 10:01:46.103 E [3] BusConnectivityTest Failed
09/29 10:01:46.127 E [3] Minor Error Detected
09/29 10:01:50.487 I [3] Diagnostics Passed
------------------ show interfaces switchport brief ------------------
------------------ show interfaces trunk ------------------
------------------ show vlan ------------------
VLAN Name Status Ports
1 default active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
------------------ show mac-address-table ------------------
Legend: * - primary entry
age - seconds since last seen
n/a - not available
vlan mac address type learn age ports
* 1 0100.0ccc.ccce static No - Switch
* --- 0000.0000.aaaa static No - Switch
* --- 0021.a00b.1f80 static No - Router
------------------ show spanning-tree active ------------------
No spanning tree instance exists.
------------------ show spanning-tree summary ------------------
Switch is in pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is disabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
Total 0 0 0 0 0
------------------ show heartbeat ------------------
Out of buffers = 0
EOBC tx failures = 0
Negative clock updates = 0
Fatal errors = 0
Last heartbeat sched = 872
Last heartbeat sent = 872
Peer 5/0 [online]:
Heartbeats received = 38091
Config msgs received = 0
Clock cfg msgs received = 0
Unknown msgs received = 0
Not heard warnings = 0
Current rx warnings = 0 (max 5)
Peer 5/1 [online]:
Heartbeats received = 0
Scheduler history [show techsupport huge_stack 50%/48% (00:00:00.916 53%/48%)] [show techsupport huge_stack 00:00:00.020] [SSS Feature Timer 00:00:00.020] [show techsupport huge_stack 00:00:00.020]
--- remote command switch show process memory ---
Processor Pool Total: 612166308 Used: 249681824 Free: 362484484
I/O Pool Total: 67108864 Used: 43819104 Free: 23289760
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 186015264 351372 168224364 6698 34840 *Init*
0 0 14040 7708612 14040 0 0 *Sched*
0 0 111306764 105074580 20117948 774 1285 *Dead*
0 0 0 0 393528 0 0 *MallocLite*
1 0 131176 0 138404 0 0 Chunk Manager
2 0 236 236 4228 0 0 Load Meter
3 0 0 0 13092 0 0 CFC stats broker
4 0 0 0 7228 0 0 Retransmission o
5 0 15124 0 7228 1 1 IPC ISSU Dispatc
6 0 0 0 7228 0 0 PF Redun ICC Req
7 0 3344 236 10336 0 0 Check heaps
8 0 0 0 7228 5560 0 Pool Manager
9 0 0 0 7228 0 0 DiscardQ Backgro
10 0 236 236 7228 0 0 Timers
11 0 0 0 4228 0 0 WATCH_AFS
12 0 236 236 7228 0 0 Serial Backgroun
13 0 0 0 7228 0 0 AAA_SERVER_DEADT
14 0 0 0 13228 0 0 Policy Manager
15 0 0 0 25228 0 0 Crash writer
16 0 304 0 7532 0 0 Exception contro
17 0 0 0 7228 0 0 RO Notify Timers
18 0 0 0 4228 0 0 RMI RM Notify Wa
19 0 80 568 7228 0 0 IPC Event Notifi
20 0 15208 0 7228 1 1 IPC Mcast Pendin
21 0 0 0 7228 0 0 IPC Dynamic Cach
22 0 0 0 7228 348 348 IPC Service NonC
23 0 0 0 7228 0 0 IPC Zone Manager
24 0 0 0 7228 27555 27555 IPC Periodic Tim
25 0 2432 5112 7228 8 8 IPC Deferred Por
26 0 0 0 7228 0 0 IPC Process leve
27 0 13964 9820 12392 260 258 IPC Seat Manager
28 0 0 0 7228 0 0 IPC Check Queue
29 0 545424 1900 366844 355 338 IPC Seat RX Cont
30 0 0 0 7228 0 0 IPC Seat TX Cont
31 0 19132 472 16536 11275 11275 IPC Keep Alive M
32 0 0 0 7228 0 0 IPC Loadometer
33 0 236 236 7228 0 0 PrstVbl
34 1 540 0 13732 18 16 Virtual Exec
35 0 0 0 7228 2 3 ARP Input
36 0 0 0 7228 0 0 ARP Background
37 0 236 236 7228 0 0 DDR Timers
38 0 0 0 7228 0 0 SERIAL A'detect
39 0 236 236 7228 0 0 GraphIt
40 0 4484 4484 7228 57 57 fabm_ch_sync:4
41 0 0 0 7228 0 0 Reset Process
42 0 472 604 7228 0 0 RPC pf_media_lay
43 0 45460 6176 36148 21 21 client_entity_se
44 0 236 236 13228 0 0 Dialer event
45 0 0 0 7228 0 0 Critical Bkgnd
46 0 116880 0 98196 0 0 Net Background
47 0 1676 1360 13544 0 0 IDB Work
48 0 236 236 13228 65 65 Logger
49 0 236 236 7228 0 0 TTY Background
50 0 4728 804 11956 89 103 SCP Multicast
51 0 5740 0 12832 0 0 CEF LC Stats
52 0 106524 1012 29640 1628551 1698538 SCP Download Lis
53 0 0 0 7228 0 0 LCP Bootupg proc
54 0 11940 944 18224 45 45 RPC Sync
55 0 0 132 7228 0 0 RPC rpc-master
56 0 472 236 7464 0 0 DFC Command Task
57 0 0 0 7228 9 9 Net Input
58 0 1180 1180 7228 10 10 Module oper stat
59 0 0 0 13228 0 0 SNMP Traps
60 0 4720 4720 7228 40 40 Snmp ICC Process
61 0 88952 63964 32288 501 501 rf proxy sp agen
62 0 0 0 7228 0 0 IPC ISSU Version
63 0 0 0 7228 0 0 IPC ISSU Version
65 0 0 0 7228 0 0 IPC ISSU Version
66 0 0 0 7228 0 0 IPC ISSU Version
67 0 0 0 7228 0 0 IPC ISSU Version
68 0 0 0 7228 0 0 IPC ISSU Version
69 0 0 0 7228 0 0 IPC ISSU Version
70 0 0 0 7228 0 0 IPC ISSU Version
71 0 0 0 7228 0 0 IPC ISSU Version
72 0 0 0 7228 0 0 IPC ISSU Version
73 0 0 0 7228 0 0 IPC ISSU Version
74 0 0 0 7228 0 0 IPC ISSU Version
75 0 0 0 7228 0 0 IPC ISSU Version
76 0 0 0 7228 0 0 IPC ISSU Version
77 0 0 0 7228 0 0 IPC ISSU Version
78 0 0 0 7228 0 0 RTTYS Process
79 0 0 0 7228 0 0 IPC ISSU Version
80 0 0 0 7228 0 0 IPC ISSU Version
81 0 0 0 7228 0 0 IPC ISSU Version
82 0 4728 0 11956 0 0 IPC ISSU Version
83 0 0 0 7228 0 0 IPC ISSU Version
84 0 0 0 7228 0 0 IPC ISSU Version
85 0 0 0 7228 0 0 IPC ISSU Version
86 0 0 0 7228 0 0 IPC ISSU Version
87 0 0 0 7228 0 0 IPC ISSU Version
88 0 0 0 7228 0 0 IPC ISSU Version
89 0 0 0 7228 0 0 IPC ISSU Version
90 0 0 0 7228 0 0 IPC ISSU Version
91 0 0 0 7228 0 0 IPC ISSU Version
92 0 0 0 7228 0 0 IPC ISSU Version
93 0 0 0 7228 0 0 IPC ISSU Version
94 0 0 0 7228 0 0 IPC ISSU Version
95 0 0 0 7228 0 0 IPC ISSU Version
96 0 0 0 7228 0 0 IPC ISSU Version
97 0 0 0 7228 0 0 IPC ISSU Version
98 0 0 0 7228 0 0 IPC ISSU Version
99 0 0 0 7228 0 0 IPC ISSU Version
100 0 0 0 7228 0 0 ISSU PROCESS IPC
101 0 8608 8608 7228 0 0 PF Sync process
102 0 65824 236 72816 0 0 ACE_REQUESTS han
103 0 0 0 7228 0 0 ACE Process Msg
104 0 0 0 7228 0 0 ACE SP Tunnel Ta
105 0 0 0 7228 0 0 MDR SM Platform
106 0 0 0 7228 0 0 ICC Nego
107 0 0 0 7228 0 0 PF DB SCP ICC pr
108 0 0 0 10228 0 0 PF SCP process
109 0 0 0 7228 0 0 PrstVbl IPC Msg
110 0 0 0 7228 0 0 EOBC ETSEC FREEZ
111 0 5076 5784 7228 70 70 Logger SP Proces
112 0 38444 19048 26624 0 0 Env action
113 0 472 604 7228 0 0 RPC rf_set_debug
114 0 110900 45312 7228 192 192 RF Status
115 0 0 0 4228 0 0 Inode Table Dest
116 0 0 0 7228 0 0 cpf_msg_holdq_pr
117 0 0 0 7228 0 0 cpf_msg_rcvq_pro
118 0 0 0 7228 0 0 CAPI HA IPC flow
119 0 3264 2632 7860 20 20 Const ICC reques
120 0 0 0 7228 0 0 Const ICC event
121 0 0 0 7228 0 0 Const ICC except
122 0 0 0 7228 0 0 ICC Local Reques
123 0 0 944 7228 0 0 ICC Async mcast
124 0 0 20180 7228 0 0 ICC Async true m
125 0 0 80 7228 0 0 ICC Mcast IPC Ev
126 0 0 0 7228 0 0 ICC_REQ Debug Pr
127 0 0 0 7228 0 0 ICC FC Process
128 0 0 0 7228 0 0 ICC FC Test Send
129 0 0 0 7228 0 0 ICC FC Test Low
130 0 0 0 13092 0 0 CFC LC Test Stat
131 0 0 0 7228 0 0 IVFS SP ICC Proc
132 0 9188 8800 10092 2 2 spa diag process
133 0 2405400 2564668 35612 18353 27470 OIR Process
134 0 116 0 7344 76180 76180 Heartbeat Proces
135 0 9032 1652 13492 5114 5116 Fabric Manager
136 0 62768556 62552672 241112 814354 814354 slcp process
137 0 0 0 7228 0 0 CHKPT Test clien
138 0 0 0 7228 0 0 MDR SM Proxy Mas
139 0 28904 0 15484 2 2 CEF: IPv4 proces
140 0 0 0 7228 0 0 itasca_sp
141 0 117584 36592 73764 471 471 rf task
142 0 0 0 7228 0 0 RF High Priority
143 0 236 236 7228 0 0 Compute load avg
144 0 0 0 7228 0 0 Per-minute Jobs
145 0 9556 236 19548 1 1 Per-Second Jobs
146 0 72228 5904 54628 14 14 RPC cygnus-oir
147 0 248508 2676 142724 19 18 PF_Init Process
148 0 0 0 7228 0 0 Fabman Timeout P
149 0 0 0 7228 2 0 Heartbeat
150 0 236 236 7228 0 0 SP BACKGROUND
151 0 0 0 7228 0 0 RF Messaging Pro
152 0 1536 1376 7388 32 32 IPC RTTYC Messag
153 0 1416 1416 7228 30 30 PF_Split Sync Pr
154 0 2788 2336 7812 12 12 RPC pf-split-sp
155 0 820 952 7812 0 0 RPC idprom-SP
156 0 0 0 7228 0 0 RTTYC Flush
157 0 5593884 0 13228 393 393 RFS server proce
158 0 0 0 7228 0 0 BACK CHECK
159 0 1356 3016 7228 6 6 AggMgr Process
160 0 0 0 7228 0 0 cpf_process_tpQ
161 0 224 0 7492 0 0 EARL Intr Thrtl
162 0 0 0 7228 0 0 Transport Port A
163 0 0 0 7228 0 0 EARL FIB Manager
164 0 224 0 7452 0 0 SPAN EARL Task
165 0 236 236 7228 0 0 Protocol Filteri
166 0 2422416 350996 14716 1472 1471 Remote Console P
167 0 0 0 7228 0 0 ADJ MGR
168 0 2860 0 10088 0 0 ADJ_MGR
169 0 82276 78584 12180 66 66 L2 Control Task
170 0 107744 1804 97532 46 46 L2 Throttle Task
171 0 4312808 4312356 7680 318 318 L2 Aging Task
172 0 2136604 2132556 11276 15222 15222 Vlan Statistics
173 0 890050804 890050804 7228 0 0 L2 PI_E consiste
174 0 1744 0 11972 0 0 EARL7 monitor ta
175 0 272228 272228 7228 0 0 TYFIB Table Mana
176 0 1426376 1421648 11956 0 0 NF Exception Tas
177 0 1351940 1351292 10228 8479 8479 L3 Control Task
178 0 6259248 0 6237564 0 0 Netflow NDE Task
179 0 152 0 7380 0 0 Netflow Aging Ta
180 0 0 0 7228 0 0 Task for pre-pro
181 0 10516 5368 12376 83 83 Netflow Mgmt_Sta
182 0 0 0 7228 0 0 Netflow Sampling
183 0 224 0 7452 0 0 Online Linecard
184 0 0 0 7228 0 0 CFIB-BGP Task
185 0 236 236 7228 0 0 CFIB LC High Pri
186 0 10101188 10101024 10107944 4 4 CFIB LC Main Tas
187 0 0 0 7228 0 0 CFIB LC Timer Ta
188 0 0 0 7228 0 0 CFIB LC STATS Ta
189 0 448 236 7440 0 0 Gemini SP proces
190 0 236 0 4464 0 0 Async write proc
191 0 236 0 4464 0 0 Async write proc
192 0 236 0 4464 0 0 Async write proc
193 0 236 0 4464 0 0 Async write proc
194 0 0 0 4228 0 0 DFS flush period
195 0 236 0 4464 0 0 Async write proc
196 0 236 0 4464 0 0 Async write proc
197 0 236 0 4464 0 0 Async write proc
198 0 236 0 4464 0 0 Async write proc
199 0 0 0 4228 0 0 DFS flush period
200 0 236 236 7228 0 0 AAA Dictionary R
201 0 236 236 7228 0 0 AAA Server
202 0 0 0 7228 0 0 AAA ACCT Proc
203 0 49384 0 56612 0 0 ACCT Periodic Pr
204 0 0 0 7228 0 0 AAA System Acct
205 0 84 196 7312 0 0 PIM Snooping Pro
206 0 0 0 4228 0 0 BGP INT
207 0 3268 708 9788 1 1 mls-hal Process
208 0 10380 236 17372 0 0 mls-msc-ha proce
209 0 78476 3412 81240 11 12 mls-msc Process
210 0 84 0 7312 0 0 mls-msc-cc Proce
211 0 472 236 7464 0 0 Spanning Tree
212 0 236 236 7228 0 0 Ethchnl
213 0 932 236 13924 0 0 DTP Protocol
214 0 25660 25660 25228 265 267 QoS SP Process
215 0 23056860 395652 22679208 136 135 TCAM Manager pro
216 0 1204 944 7228 12285 12285 Mcast Hw Agent6
217 0 236 236 7228 0 0 capture process
218 0 32308692 32242880 73040 0 0 L2 MAC oob sync
219 0 236 236 7228 2 2 Const Rate Limit
220 0 0 0 7228 0 0 SP DHCP Snooping
221 0 75640 0 82868 0 0 Private hosts sp
222 0 0 0 7228 0 0 L3 Manager SP Co
223 0 0 0 13228 0 0 L3 Manager SP
224 0 236 236 10228 0 0 GVRP Process
225 0 236 236 7228 0 0 MAC-Security-Agi
226 0 0 0 13228 0 0 STATIC MAC HANDL
227 0 0 0 7228 0 0 CWAN static MAC
228 0 0 0 13228 0 0 CWAN PORT CHANNE
229 0 236 236 7228 0 0 REP Topology cha
230 0 1084 0 14312 0 0 IP ARP Adjacency
231 0 49384 0 56612 0 0 IP ARP Retry Age
232 0 0 0 13228 0 0 IP Input
233 0 0 0 7228 0 0 ICMP event handl
234 0 236 236 7228 0 0 IPAM/ODAP Events
235 0 49384 0 62612 0 0 IPAM Manager
236 0 236 236 13228 0 0 IPAM Events
237 0 236 236 7228 0 0 PPP SIP
238 0 236 236 7228 0 0 PPP Bind
239 0 236 236 13228 0 0 PPP IP Route
240 0 2192 0 9420 0 0 Switch Backup In
241 0 780 472 7536 2 2 UDLD
242 0 224 0 7452 0 0 Port-Security
243 0 0 0 7228 8 8 802.1x switch
244 0 276 0 13504 0 0 CEF switching ba
245 0 4964 236 11956 0 0 OCE punted Pkts
246 0 0 0 13228 0 0 SSS Manager
247 0 0 0 13228 0 0 SSS Policy Manag
248 0 0 0 7228 0 0 SSS Feature Mana
249 0 0 0 7228 0 0 SSS Feature Time
250 0 0 0 7228 0 0 SG DPM
251 0 0 0 7228 0 0 Timer handler fo
252 0 0 0 7228 0 0 Prepaid response
253 0 0 0 7228 0 0 Timed Policy act
254 0 0 0 7228 0 0 AAA response han
255 0 0 0 7228 0 0 AAA EPD HANDLER
256 0 0 0 7228 0 0 PM EPD API
257 0 0 0 7228 0 0 EAP Framework
258 0 0 0 7228 0 0 EAP Test
259 0 10372 236 23364 0 0 SSM connection m
260 0 686316 686316 7228 0 0 QoS stats proces
261 0 0 0 13228 0 0 TCP Timer
262 0 0 0 13228 0 0 TCP Protocols
263 0 0 0 7228 0 0 Socket Timers
264 0 940 0 11168 0 0 HTTP CORE
265 0 472 236 4464 0 0 PfR BR Learn
266 0 0 0 7228 0 0 CFMPAL OIR POWER
267 0 472 236 7464 0 0 CFMPAL Process
268 0 224 0 7452 0 0 XDR background p
269 0 13172 2792 17916 7028 7027 XDR mcast
270 0 1504088 1499716 16052 15434 15434 mls-gc Process
271 0 0 0 7228 0 0 mls-pimsn Proces
272 0 1924 1760 7484 5 5 MLTL Agent
273 0 7544 14952 13592 8 8 mfib-const-lc Pr
274 0 224 0 7452 0 0 mls-igmp Process
275 0 224 0 7452 0 0 mls-cgmp Process
276 0 224 0 7452 0 0 mls-mld Process
277 0 224 0 7452 0 0 mld-mrouter Proc
278 0 0 0 7228 0 0 FRR Background P
279 0 224 152 13452 0 0 CEF background p
280 0 224 0 13452 0 0 fib_fib_bfd_sb e
281 0 6734648 6734648 7228 74730 74728 XDR LC PRIO Back
282 0 0 0 7228 0 0 XDR LC PRIO Crit
283 0 96408632 1386128 85084404 11553 11552 XDR LC Backgroun
284 0 224 0 13452 0 0 MFIB Master back
285 0 0 0 7228 0 0 STP HA IPC flow
286 0 472 236 7464 0 0 CEF LC IPC Backg
287 0 236 236 7228 0 0 LC ETHER EFP Com
288 0 236 236 7228 0 0 BD MACSEC HA
289 0 236 236 7228 0 0 REP LSL Proc
290 0 10288 236 17280 0 0 REP BPA/EPA Proc
291 0 19492 236 26484 0 0 SCTP Main Proces
292 0 0 0 7228 0 0 IP Traceroute
293 0 0 0 7228 0 0 Probe Input
294 0 0 0 7228 0 0 RARP Input
295 0 0 0 7228 0 0 X.25 Encaps Mana
296 0 224 0 7452 0 0 Hardware API bac
297 0 0 0 13228 0 0 Path set broker
298 0 224 0 7452 0 0 XDR FOF process
299 0 236 236 7228 0 0 LOCAL AAA
300 0 236 236 7228 0 0 ENABLE AAA
301 0 236 236 7228 0 0 LINE AAA
302 0 236 236 7228 0 0 AAA Cached Serve
303 0 0 0 7228 0 0 EM Background Pr
304 0 0 0 7228 0 0 IDMGR CORE
305 0 0 0 7228 0 0 Pre-download RP
306 0 0 0 7228 0 0 Pre-dnld LC to A
307 0 0 0 7228 0 0 Pre-download pee
308 0 66624 236 8028 0 0 TPLUS
309 0 236 236 10228 0 0 GVRP SWITCH Proc
310 0 236 51616 7228 0 0 AAA SEND STOP EV
311 0 0 0 7228 0 0 HW Capacity ICC
312 0 0 0 7228 0 0 PM Vlan Timer Pr
313 0 0 0 7228 0 0 pm icc process
314 0 58960 41852 11708 141 142 pm scp process
315 0 1552 1552 7228 35 35 PM CP Process
316 0 2541104 11668 2534860 70 70 RPC pm-cp
317 0 5704 12448 7228 0 0 PM Callback
318 0 333724 260836 85912 32 32 VLAN Manager
319 0 236 236 7228 0 0 Port manager per
320 0 0 0 7228 0 0 Max CPU utilizat
321 0 1416 1548 7228 10 10 RPC ecfmpal_rpc_
322 0 236 368 7228 0 0 RPC icrm_rp2sp
323 0 0 0 7228 0 0 Inline Power Por
324 0 236 368 7228 0 0 RPC storm_contro
325 0 0 0 7228 0 0 StandbyDiagDaemo
326 0 0 0 7228 0 0 DiagInbandRatePr
327 0 486116 0 471592 0 0 SEA main process
328 0 14308 14440 7228 106 106 RPC pf_issu_rp2s
329 0 2360 2492 7228 18 18 RPC pf_prst_vbl_
330 0 236 368 7228 0 0 RPC pf_redun_rp2
331 0 224 0 7520 0 0 SEA write CF pro
332 0 0 0 7228 0 0 TM Stat Adj Task
333 0 28304 28076 10456 7102 7102 L2 Application T
334 0 0 0 13228 0 0 VPN_MAPPER
335 0 236 368 7228 0 0 RPC dhcp_snoopin
336 0 236 368 7228 0 0 RPC pvt_hosts_sw
337 0 0 0 7228 0 0 Const FIB excep
338 0 236 368 7228 0 0 RPC pclc_g2_fw_s
339 0 236 368 7228 0 0 RPC pclc_g2_ids_
340 0 224 0 7452 2 2 SEA write messag
341 0 12283144 12199784 25000 43551 43551 C6K PROCMIB SP P
342 0 0 0 7228 0 0 CMFI CC Backgrou
343 0 236 368 7228 0 0 RPC cfib_rp2sp
344 0 236 236 7228 0 0 Rommon upgrade p
345 0 0 0 7228 0 0 CONST SMC
346 0 236 368 61228 0 0 RPC epld_isp_rpc
347 0 236 368 7228 0 0 RPC itasca_sp
348 0 236 368 7228 0 0 RPC cdump_rp_req
349 0 236 368 7228 0 0 RPC logging_even
350 0 0 0 7228 0 0 NV Health Monito
351 0 236 368 7228 0 0 RPC sw_backup_in
352 0 2360 2492 7228 18 18 RPC mlacp_mp2sp
353 0 9259100 9259232 10228 68723 68723 RPC sw_vlan_sp
354 0 22380 22512 7228 160 160 RPC stp_switch_a
355 0 212504 212636 7228 1592 1592 RPC pagp_switch_
356 0 236 368 7228 0 0 RPC lacp_switch_
357 0 236 368 7228 0 0 RPC pt_switch_mp
358 0 236 368 7228 0 0 RPC qnq_switch_m
359 0 944 1076 10228 6 6 RPC span_switch_
360 0 15828 15960 7228 116 116 RPC mapping_sp
361 0 236 368 7228 0 0 RPC intacc_rp
362 0 57032 57164 7228 426 426 RPC udld_sp
363 0 236 236 7228 0 0 SP Error Detecti
364 0 236 368 7228 0 0 RPC error_detect
365 0 824716 824848 13228 6004 6004 RPC c6k_power_sp
366 0 2041524 2041524 7228 22542 24973 Env Poll
367 0 5589356 5589488 7228 40396 40396 RPC c6k_sp_envir
368 0 236 368 7228 0 0 RPC chapi_sp
369 0 445900 423320 27024 3142 3142 RPC pm_switch_rp
370 0 236 368 7228 0 0 RPC const_nv_cfg
371 0 236 368 7228 0 0 RPC l2_bridge
372 0 328876 329008 7228 6762 6762 RPC online_diag_
373 0 236 368 7228 0 0 RPC online_diag_
374 0 33032 43956 7560 12 12 RPC online_wan_d
375 0 4356 4488 7228 28 28 RPC pikachu_sp
376 0 1604672 1604804 7228 10598 10598 RPC rf_cli_rp2sp
377 0 59292 59424 7228 444 444 RPC issu_cli_rp2
378 0 2668 2800 7228 16 16 RPC c6k_stack_mi
379 0 236 368 7228 0 0 RPC psecure_sp
380 0 3068 3200 7228 30 30 RPC gbic_seprom_
381 0 236 368 7228 0 0 RPC const_ehsa_r
382 0 236 368 7228 0 0 RPC const_platfo
383 0 236 368 7228 0 0 RPC pm_mat_mp2sp
384 0 236 368 7228 0 0 RPC switch_engin
385 0 236 368 7228 0 0 RPC ether_oam_rp
386 0 236 368 7228 0 0 RPC dot1ad_mp2sp
387 0 236 368 7228 0 0 RPC acr_rp2sp
388 0 472 604 7228 3 3 RPC rep_rp2sp_ap
389 0 236 368 7228 0 0 RPC dot1x_sp
390 0 708 840 7228 4 4 RPC lcc_rp
391 0 210828 210960 7228 1568 1568 RPC fabman_rp
392 0 14376 14508 7228 106 106 RPC sea_rp_cli_r
393 0 236 368 7228 0 0 RPC const_ifs_rp
394 0 236 368 7228 0 0 RPC gvrp_rp2sp
395 0 1988 472 7456 6 6 L2 Manager Task
396 0 212 0 7440 0 0 L2 Manager Earl6
397 0 33012 33328 7612 56 57 LTL MGR
398 0 460 0 7688 0 0 LTL MGR cc
399 0 236 236 7228 0 0 SPAN switch
400 0 3068 13248 7464 36 42 SPAN Switch SP
401 0 4952 0 12180 0 0 SPAN Switch SP B
402 0 2380 236 7380 6 6 LC Registry Expo
403 0 236 236 7228 0 0 LC IPC ICC Init
404 0 2801792 0 2809020 0 0 Const2 IPv6 Proc
405 0 0 0 7228 0 0 v6fib stat colle
406 0 10052 0 17280 0 0 CMFI
407 0 0 4960 7228 0 0 CMFI Scanner
408 0 708 708 7228 6 6 CMFI Misc
409 0 0 0 7228 0 0 CMFI Background
410 0 0 0 7228 0 0 CMFI iEdge Proce
411 0 236 236 7228 0 0 EI SP
412 0 236 236 7228 0 0 REP SP Proc
413 0 3568 3500 7316 0 0 ADJ background
414 0 224 0 7452 2 3 SEA receive proc
415 0 7284 7284 13228 30 30 Syslog
416 0 0 0 7228 0 0 NDE - IPV4
417 0 0 0 7228 0 0 NDE - MPLS
418 0 0 0 7228 0 0 NDE - L2
419 0 0 0 7228 0 0 NDE - IPV6
420 0 0 0 7228 0 0 SpanTree Helper
421 0 0 0 7092 0 0 MFI LFD Stats Pr
422 0 0 0 13092 0 0 MFI LFD Timer Pr
423 0 93576 304 100284 0 0 MFI LFD Main Pro
424 0 19092 33704 13316 0 0 Collection proce
426 0 64652816 64621540 42144 645982 645982 DiagCard5/-1
427 0 33186536 33186536 7092 393434 393434 SCP async: LCP#5
428 0 0 0 7092 0 0 IPC ISSU Version
429 0 0 0 7152 0 0 system Image Rec
431 0 0 0 7116 0 0 fabm_ch_sync:2
324163108 Total
--- remote command switch show process cpu ---
CPU utilization for five seconds: 10%/0%; one minute: 10%; five minutes: 10%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 4 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 48 15244 3 0.00% 0.00% 0.00% 0 Load Meter
3 8 7123 1 0.00% 0.00% 0.00% 0 CFC stats broker
4 0 223 0 0.00% 0.00% 0.00% 0 Retransmission o
5 0 3 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
6 4 13 307 0.00% 0.00% 0.00% 0 PF Redun ICC Req
7 298148 17983 16579 0.00% 0.32% 0.35% 0 Check heaps
8 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
9 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
10 0 2 0 0.00% 0.00% 0.00% 0 Timers
11 0 200 0 0.00% 0.00% 0.00% 0 WATCH_AFS
12 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
13 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
14 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
15 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
16 0 1 0 0.00% 0.00% 0.00% 0 Exception contro
17 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
18 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
19 4 15249 0 0.00% 0.00% 0.00% 0 IPC Event Notifi
20 28 74394 0 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
21 0 1271 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
22 12 15247 0 0.00% 0.00% 0.00% 0 IPC Service NonC
23 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
24 16 74394 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
25 4 74402 0 0.00% 0.00% 0.00% 0 IPC Deferred Por
26 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
27 48 11397 4 0.00% 0.00% 0.00% 0 IPC Seat Manager
28 0 1387 0 0.00% 0.00% 0.00% 0 IPC Check Queue
29 16 173 92 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
30 0 2 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
31 32 7666 4 0.00% 0.00% 0.00% 0 IPC Keep Alive M
32 88 15248 5 0.00% 0.00% 0.00% 0 IPC Loadometer
33 852 4 213000 0.00% 0.00% 0.00% 0 PrstVbl
34 4 6 666 0.00% 0.00% 0.00% 1 Virtual Exec
35 0 2 0 0.00% 0.00% 0.00% 0 ARP Input
36 20 79468 0 0.00% 0.00% 0.00% 0 ARP Background
37 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
38 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
39 16 76212 0 0.00% 0.00% 0.00% 0 GraphIt
40 4 23 173 0.00% 0.00% 0.00% 0 fabm_ch_sync:4
41 0 1 0 0.00% 0.00% 0.00% 0 Reset Process
42 0 3 0 0.00% 0.00% 0.00% 0 RPC pf_media_lay
43 0 13 0 0.00% 0.00% 0.00% 0 client_entity_se
44 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
45 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
46 4 15318 0 0.00% 0.00% 0.00% 0 Net Background
47 0 5 0 0.00% 0.00% 0.00% 0 IDB Work
48 0 28 0 0.00% 0.00% 0.00% 0 Logger
49 88 75977 1 0.00% 0.00% 0.00% 0 TTY Background
50 0 71 0 0.00% 0.00% 0.00% 0 SCP Multicast
51 44 84389 0 0.00% 0.00% 0.00% 0 CEF LC Stats
52 3832 408172 9 0.00% 0.01% 0.00% 0 SCP Download Lis
53 0 1 0 0.00% 0.00% 0.00% 0 LCP Bootupg proc
54 0 113 0 0.00% 0.00% 0.00% 0 RPC Sync
55 0 1 0 0.00% 0.00% 0.00% 0 RPC rpc-master
56 0 2 0 0.00% 0.00% 0.00% 0 DFC Command Task
57 0 10 0 0.00% 0.00% 0.00% 0 Net Input
58 4 11 363 0.00% 0.00% 0.00% 0 Module oper stat
59 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
60 0 41 0 0.00% 0.00% 0.00% 0 Snmp ICC Process
61 28 553 50 0.00% 0.00% 0.00% 0 rf proxy sp agen
62 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
63 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
65 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
66 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
67 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
68 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
69 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
70 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
71 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
72 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
73 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
74 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
75 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
76 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
77 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
78 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
79 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
80 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
81 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
82 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
83 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
84 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
85 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
86 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
87 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
88 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
89 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
90 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
91 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
92 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
93 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
94 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
95 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
96 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
97 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
98 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
99 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
100 0 1 0 0.00% 0.00% 0.00% 0 ISSU PROCESS IPC
101 4 5 800 0.00% 0.00% 0.00% 0 PF Sync process
102 0 2 0 0.00% 0.00% 0.00% 0 ACE_REQUESTS han
103 0 1 0 0.00% 0.00% 0.00% 0 ACE Process Msg
104 0 12 0 0.00% 0.00% 0.00% 0 ACE SP Tunnel Ta
105 0 1 0 0.00% 0.00% 0.00% 0 MDR SM Platform
106 0 1 0 0.00% 0.00% 0.00% 0 ICC Nego
107 0 1 0 0.00% 0.00% 0.00% 0 PF DB SCP ICC pr
108 0 1 0 0.00% 0.00% 0.00% 0 PF SCP process
109 0 1 0 0.00% 0.00% 0.00% 0 PrstVbl IPC Msg
110 64 76011 0 0.00% 0.00% 0.00% 0 EOBC ETSEC FREEZ
111 0 49 0 0.00% 0.00% 0.00% 0 Logger SP Proces
112 8 177 45 0.00% 0.00% 0.00% 0 Env action
113 0 5 0 0.00% 0.00% 0.00% 0 RPC rf_set_debug
114 0 194 0 0.00% 0.00% 0.00% 0 RF Status
115 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
116 0 2 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
117 0 1 0 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
118 0 2 0 0.00% 0.00% 0.00% 0 CAPI HA IPC flow
119 0 25 0 0.00% 0.00% 0.00% 0 Const ICC reques
120 0 1 0 0.00% 0.00% 0.00% 0 Const ICC event
121 0 1 0 0.00% 0.00% 0.00% 0 Const ICC except
122 0 1 0 0.00% 0.00% 0.00% 0 ICC Local Reques
123 0 8 0 0.00% 0.00% 0.00% 0 ICC Async mcast
124 0 46 0 0.00% 0.00% 0.00% 0 ICC Async true m
125 0 3 0 0.00% 0.00% 0.00% 0 ICC Mcast IPC Ev
126 0 1 0 0.00% 0.00% 0.00% 0 ICC_REQ Debug Pr
127 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Process
128 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Test Send
129 0 1 0 0.00% 0.00% 0.00% 0 ICC FC Test Low
130 0 1 0 0.00% 0.00% 0.00% 0 CFC LC Test Stat
131 0 1 0 0.00% 0.00% 0.00% 0 IVFS SP ICC Proc
132 0 4 0 0.00% 0.00% 0.00% 0 spa diag process
133 1092 47292 23 0.00% 0.00% 0.00% 0 OIR Process
134 184 76073 2 0.00% 0.00% 0.45% 0 Heartbeat Proces
135 8 5104 1 0.00% 0.00% 0.00% 0 Fabric Manager
136 949724 9332830 101 7.19% 7.23% 7.22% 0 slcp process
137 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
138 0 1 0 0.00% 0.00% 0.00% 0 MDR SM Proxy Mas
139 316 110582 2 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
140 0 1 0 0.00% 0.00% 0.00% 0 itasca_sp
141 24 256 93 0.00% 0.00% 0.00% 0 rf task
142 0 1 0 0.00% 0.00% 0.00% 0 RF High Priority
143 16 15250 1 0.00% 0.00% 0.00% 0 Compute load avg
144 10172 1291 7879 0.00% 0.00% 0.00% 0 Per-minute Jobs
145 48 76268 0 0.00% 0.00% 0.00% 0 Per-Second Jobs
146 424 17 24941 0.00% 0.00% 0.00% 0 RPC cygnus-oir
147 1484 76043 19 0.00% 0.00% 0.00% 0 PF_Init Process
148 0 4 0 0.00% 0.00% 0.00% 0 Fabman Timeout P
149 196 496195 0 0.00% 0.00% 0.00% 0 Heartbeat
150 24 50755 0 0.00% 0.00% 0.00% 0 SP BACKGROUND
151 0 1 0 0.00% 0.00% 0.00% 0 RF Messaging Pro
152 4 19 210 0.00% 0.00% 0.00% 0 IPC RTTYC Messag
153 0 24 0 0.00% 0.00% 0.00% 0 PF_Split Sync Pr
154 0 14 0 0.00% 0.00% 0.00% 0 RPC pf-split-sp
155 0 5 0 0.00% 0.00% 0.00% 0 RPC idprom-SP
156 0 9 0 0.00% 0.00% 0.00% 0 RTTYC Flush
157 96 404 237 0.00% 0.02% 0.00% 0 RFS server proce
158 0 17 0 0.00% 0.00% 0.00% 0 BACK CHECK
159 0 8 0 0.00% 0.00% 0.00% 0 AggMgr Process
160 0 1 0 0.00% 0.00% 0.00% 0 cpf_process_tpQ
161 180 1207151 0 0.00% 0.00% 0.00% 0 EARL Intr Thrtl
162 0 1 0 0.00% 0.00% 0.00% 0 Transport Port A
163 0 3 0 0.00% 0.00% 0.00% 0 EARL FIB Manager
164 0 1 0 0.00% 0.00% 0.00% 0 SPAN EARL Task
165 0 2 0 0.00% 0.00% 0.00% 0 Protocol Filteri
166 156 1215 128 0.07% 0.01% 0.00% 0 Remote Console P
167 0 1 0 0.00% 0.00% 0.00% 0 ADJ MGR
168 0 2 0 0.00% 0.00% 0.00% 0 ADJ_MGR
169 16 108 148 0.00% 0.00% 0.00% 0 L2 Control Task
170 4 77 51 0.00% 0.00% 0.00% 0 L2 Throttle Task
171 44 30822 1 0.00% 0.00% 0.00% 0 L2 Aging Task
172 1022588 31167 32809 1.35% 1.38% 1.36% 0 Vlan Statistics
173 70648 3378979 20 0.15% 0.19% 0.18% 0 L2 PI_E consiste
174 16 40648 0 0.00% 0.00% 0.00% 0 EARL7 monitor ta
175 327812 9601 34143 0.00% 0.41% 0.43% 0 TYFIB Table Mana
176 52016 272925 190 0.00% 0.00% 0.00% 0 NF Exception Tas
177 764 65765 11 0.00% 0.00% 0.00% 0 L3 Control Task
178 12 1 12000 0.00% 0.00% 0.00% 0 Netflow NDE Task
179 72 37117 1 0.00% 0.00% 0.00% 0 Netflow Aging Ta
180 0 41 0 0.00% 0.00% 0.00% 0 Task for pre-pro
181 44 7681 5 0.00% 0.00% 0.00% 0 Netflow Mgmt_Sta
182 0 1 0 0.00% 0.00% 0.00% 0 Netflow Sampling
183 0 1 0 0.00% 0.00% 0.00% 0 Online Linecard
184 0 1271 0 0.00% 0.00% 0.00% 0 CFIB-BGP Task
185 0 2 0 0.00% 0.00% 0.00% 0 CFIB LC High Pri
186 28532 4088 6979 0.00% 0.00% 0.00% 0 CFIB LC Main Tas
187 32 7621 4 0.00% 0.00% 0.00% 0 CFIB LC Timer Ta
188 4 7621 0 0.00% 0.00% 0.00% 0 CFIB LC STATS Ta
189 0 3 0 0.00% 0.00% 0.00% 0 Gemini SP proces
190 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
191 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
192 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
193 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
194 0 1271 0 0.00% 0.00% 0.00% 0 DFS flush period
195 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
196 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
197 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
198 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
199 0 1271 0 0.00% 0.00% 0.00% 0 DFS flush period
200 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
201 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
202 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
203 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
204 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
205 0 2 0 0.00% 0.00% 0.00% 0 PIM Snooping Pro
206 20 31 645 0.00% 0.00% 0.00% 0 BGP INT
207 48 47894 1 0.00% 0.00% 0.00% 0 mls-hal Process
208 0 2 0 0.00% 0.00% 0.00% 0 mls-msc-ha proce
209 4 25 160 0.00% 0.00% 0.00% 0 mls-msc Process
210 0 1 0 0.00% 0.00% 0.00% 0 mls-msc-cc Proce
211 0 2 0 0.00% 0.00% 0.00% 0 Spanning Tree
212 0 7623 0 0.00% 0.00% 0.00% 0 Ethchnl
213 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol
214 8 139 57 0.00% 0.00% 0.00% 0 QoS SP Process
215 708 2668 265 0.00% 0.00% 0.00% 0 TCAM Manager pro
216 144 757514 0 0.00% 0.00% 0.00% 0 Mcast Hw Agent6
217 0 2 0 0.00% 0.00% 0.00% 0 capture process
218 0 2394 0 0.00% 0.00% 0.00% 0 L2 MAC oob sync
219 4 11 363 0.00% 0.00% 0.00% 0 Const Rate Limit
220 0 1 0 0.00% 0.00% 0.00% 0 SP DHCP Snooping
221 0 1 0 0.00% 0.00% 0.00% 0 Private hosts sp
222 12 4250 2 0.00% 0.00% 0.00% 0 L3 Manager SP Co
223 92 4228 21 0.00% 0.00% 0.00% 0 L3 Manager SP
224 0 2 0 0.00% 0.00% 0.00% 0 GVRP Process
225 0 18605 0 0.00% 0.00% 0.00% 0 MAC-Security-Agi
226 0 1 0 0.00% 0.00% 0.00% 0 STATIC MAC HANDL
227 0 1 0 0.00% 0.00% 0.00% 0 CWAN static MAC
228 0 1 0 0.00% 0.00% 0.00% 0 CWAN PORT CHANNE
229 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha
230 0 1 0 0.00% 0.00% 0.00% 0 IP ARP Adjacency
231 160 2330277 0 0.00% 0.01% 0.00% 0 IP ARP Retry Age
232 4 1271 3 0.00% 0.00% 0.00% 0 IP Input
233 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
234 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
235 176 2330462 0 0.07% 0.02% 0.00% 0 IPAM Manager
236 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
237 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
238 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
239 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
240 0 1 0 0.00% 0.00% 0.00% 0 Switch Backup In
241 0 76215 0 0.00% 0.00% 0.00% 0 UDLD
242 4 1271 3 0.00% 0.00% 0.00% 0 Port-Security
243 0 5 0 0.00% 0.00% 0.00% 0 802.1x switch
244 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
245 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
246 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager
247 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
248 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
249 36 297674 0 0.00% 0.00% 0.00% 0 SSS Feature Time
250 0 1 0 0.00% 0.00% 0.00% 0 SG DPM
251 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
252 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
253 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
254 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
255 0 1 0 0.00% 0.00% 0.00% 0 AAA EPD HANDLER
256 0 1 0 0.00% 0.00% 0.00% 0 PM EPD API
257 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
258 0 1 0 0.00% 0.00% 0.00% 0 EAP Test
259 4 15246 0 0.00% 0.00% 0.00% 0 SSM connection m
260 8 7617 1 0.00% 0.00% 0.00% 0 QoS stats proces
261 0 1 0 0.00% 0.00% 0.00% 0 TCP Timer
262 0 1 0 0.00% 0.00% 0.00% 0 TCP Protocols
263 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
264 0 255 0 0.00% 0.00% 0.00% 0 HTTP CORE
265 80 76478 1 0.00% 0.00% 0.00% 0 PfR BR Learn
266 0 1 0 0.00% 0.00% 0.00% 0 CFMPAL OIR POWER
267 12 27436 0 0.00% 0.00% 0.00% 0 CFMPAL Process
268 0 1 0 0.00% 0.00% 0.00% 0 XDR background p
269 4 7093 0 0.00% 0.00% 0.00% 0 XDR mcast
270 180 22409 8 0.00% 0.00% 0.00% 0 mls-gc Process
271 0 1 0 0.00% 0.00% 0.00% 0 mls-pimsn Proces
272 488 76135 6 0.00% 0.00% 0.00% 0 MLTL Agent
273 0 35 0 0.00% 0.00% 0.00% 0 mfib-const-lc Pr
274 0 4066 0 0.00% 0.00% 0.00% 0 mls-igmp Process
275 0 1 0 0.00% 0.00% 0.00% 0 mls-cgmp Process
276 4 7623 0 0.00% 0.00% 0.00% 0 mls-mld Process
277 0 1 0 0.00% 0.00% 0.00% 0 mld-mrouter Proc
278 0 1 0 0.00% 0.00% 0.00% 0 FRR Background P
279 4 1276 3 0.00% 0.00% 0.00% 0 CEF background p
280 0 3 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
281 272 74802 3 0.00% 0.00% 0.00% 0 XDR LC PRIO Back
282 56 14278 3 0.00% 38.05% 39.55% 0 XDR LC PRIO Crit
283 17832 8123 2195 0.00% 0.00% 0.00% 0 XDR LC Backgroun
284 0 3 0 0.00% 0.00% 0.00% 0 MFIB Master back
285 0 2 0 0.00% 0.00% 0.00% 0 STP HA IPC flow
286 0 2 0 0.00% 0.00% 0.00% 0 CEF LC IPC Backg
287 16 7622 2 0.00% 0.00% 0.00% 0 LC ETHER EFP Com
288 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA
289 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc
290 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc
291 0 2 0 0.00% 0.00% 0.00% 0 SCTP Main Proces
292 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
293 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
294 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
295 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
296 1412 17320 81 0.00% 0.00% 0.00% 0 Hardware API bac
297 0 1 0 0.00% 0.00% 0.00% 0 Path set broker
298 0 2 0 0.00% 0.00% 0.00% 0 XDR FOF process
299 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
300 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
301 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
302 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
303 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
304 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
305 0 1 0 0.00% 0.00% 0.00% 0 Pre-download RP
306 0 1 0 0.00% 0.00% 0.00% 0 Pre-dnld LC to A
307 0 1 0 0.00% 0.00% 0.00% 0 Pre-download pee
308 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
309 0 2 0 0.00% 0.00% 0.00% 0 GVRP SWITCH Proc
310 4 136 29 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
311 0 1 0 0.00% 0.00% 0.00% 0 HW Capacity ICC
312 0 2 0 0.00% 0.00% 0.00% 0 PM Vlan Timer Pr
313 0 1 0 0.00% 0.00% 0.00% 0 pm icc process
314 0 21 0 0.00% 0.00% 0.00% 0 pm scp process
315 0 15 0 0.00% 0.00% 0.00% 0 PM CP Process
316 12 40 300 0.00% 0.00% 0.00% 0 RPC pm-cp
317 8 18674 0 0.00% 0.00% 0.00% 0 PM Callback
318 488 20 24400 0.00% 0.00% 0.00% 0 VLAN Manager
319 8 7622 1 0.00% 0.00% 0.00% 0 Port manager per
320 8 15241 0 0.00% 0.00% 0.00% 0 Max CPU utilizat
321 0 12 0 0.00% 0.00% 0.00% 0 RPC ecfmpal_rpc_
322 0 2 0 0.00% 0.00% 0.00% 0 RPC icrm_rp2sp
323 4 15241 0 0.00% 0.00% 0.00% 0 Inline Power Por
324 0 2 0 0.00% 0.00% 0.00% 0 RPC storm_contro
325 0 1 0 0.00% 0.00% 0.00% 0 StandbyDiagDaemo
326 8 25400 0 0.00% 0.00% 0.00% 0 DiagInbandRatePr
327 4 100 40 0.00% 0.00% 0.00% 0 SEA main process
328 8 108 74 0.00% 0.00% 0.00% 0 RPC pf_issu_rp2s
329 0 20 0 0.00% 0.00% 0.00% 0 RPC pf_prst_vbl_
330 0 2 0 0.00% 0.00% 0.00% 0 RPC pf_redun_rp2
331 8 15586 0 0.00% 0.00% 0.00% 0 SEA write CF pro
332 36 7621 4 0.00% 0.00% 0.00% 0 TM Stat Adj Task
333 176 135 1303 0.00% 0.00% 0.00% 0 L2 Application T
334 0 1 0 0.00% 0.00% 0.00% 0 VPN_MAPPER
335 0 2 0 0.00% 0.00% 0.00% 0 RPC dhcp_snoopin
336 0 2 0 0.00% 0.00% 0.00% 0 RPC pvt_hosts_sw
337 0 2 0 0.00% 0.00% 0.00% 0 Const FIB excep
338 0 2 0 0.00% 0.00% 0.00% 0 RPC pclc_g2_fw_s
339 0 2 0 0.00% 0.00% 0.00% 0 RPC pclc_g2_ids_
340 0 3 0 0.00% 0.00% 0.00% 0 SEA write messag
341 4164 44729 93 0.00% 0.00% 0.00% 0 C6K PROCMIB SP P
342 0 1 0 0.00% 0.00% 0.00% 0 CMFI CC Backgrou
343 0 2 0 0.00% 0.00% 0.00% 0 RPC cfib_rp2sp
344 0 2 0 0.00% 0.00% 0.00% 0 Rommon upgrade p
345 0 1 0 0.00% 0.00% 0.00% 0 CONST SMC
346 0 2 0 0.00% 0.00% 0.00% 0 RPC epld_isp_rpc
347 0 2 0 0.00% 0.00% 0.00% 0 RPC itasca_sp
348 0 2 0 0.00% 0.00% 0.00% 0 RPC cdump_rp_req
349 0 3 0 0.00% 0.00% 0.00% 0 RPC logging_even
350 32 76161 0 0.00% 0.00% 0.00% 0 NV Health Monito
351 0 2 0 0.00% 0.00% 0.00% 0 RPC sw_backup_in
352 4 20 200 0.00% 0.00% 0.00% 0 RPC mlacp_mp2sp
353 3816 68420 55 0.00% 0.00% 0.00% 0 RPC sw_vlan_sp
354 16 162 98 0.00% 0.00% 0.00% 0 RPC stp_switch_a
355 92 1588 57 0.00% 0.00% 0.00% 0 RPC pagp_switch_
356 0 2 0 0.00% 0.00% 0.00% 0 RPC lacp_switch_
357 0 2 0 0.00% 0.00% 0.00% 0 RPC pt_switch_mp
358 0 2 0 0.00% 0.00% 0.00% 0 RPC qnq_switch_m
359 0 8 0 0.00% 0.00% 0.00% 0 RPC span_switch_
360 8 118 67 0.00% 0.00% 0.00% 0 RPC mapping_sp
361 0 2 0 0.00% 0.00% 0.00% 0 RPC intacc_rp
362 28 425 65 0.00% 0.00% 0.00% 0 RPC udld_sp
363 8 7623 1 0.00% 0.00% 0.00% 0 SP Error Detecti
364 0 2 0 0.00% 0.00% 0.00% 0 RPC error_detect
365 324 5966 54 0.23% 0.02% 0.00% 0 RPC c6k_power_sp
366 3476 62347 55 0.07% 0.04% 0.05% 0 Env Poll
367 1712 40116 42 0.00% 0.00% 0.00% 0 RPC c6k_sp_envir
368 0 2 0 0.00% 0.00% 0.00% 0 RPC chapi_sp
369 148 3134 47 0.00% 0.00% 0.00% 0 RPC pm_switch_rp
370 0 2 0 0.00% 0.00% 0.00% 0 RPC const_nv_cfg
371 0 2 0 0.00% 0.00% 0.00% 0 RPC l2_bridge
372 176 2434 72 0.07% 0.00% 0.00% 0 RPC online_diag_
373 0 2 0 0.00% 0.00% 0.00% 0 RPC online_diag_
374 0 12 0 0.00% 0.00% 0.00% 0 RPC online_wan_d
375 0 30 0 0.00% 0.00% 0.00% 0 RPC pikachu_sp
376 520 10533 49 0.00% 0.17% 0.04% 0 RPC rf_cli_rp2sp
377 24 444 54 0.00% 0.00% 0.00% 0 RPC issu_cli_rp2
378 0 18 0 0.00% 0.00% 0.00% 0 RPC c6k_stack_mi
379 0 2 0 0.00% 0.00% 0.00% 0 RPC psecure_sp
380 4 20 200 0.00% 0.00% 0.00% 0 RPC gbic_seprom_
381 0 2 0 0.00% 0.00% 0.00% 0 RPC const_ehsa_r
382 0 2 0 0.00% 0.00% 0.00% 0 RPC const_platfo
383 0 2 0 0.00% 0.00% 0.00% 0 RPC pm_mat_mp2sp
384 0 2 0 0.00% 0.00% 0.00% 0 RPC switch_engin
385 0 2 0 0.00% 0.00% 0.00% 0 RPC ether_oam_rp
386 0 2 0 0.00% 0.00% 0.00% 0 RPC dot1ad_mp2sp
387 0 2 0 0.00% 0.00% 0.00% 0 RPC acr_rp2sp
388 0 4 0 0.00% 0.00% 0.00% 0 RPC rep_rp2sp_ap
389 0 2 0 0.00% 0.00% 0.00% 0 RPC dot1x_sp
390 0 6 0 0.00% 0.00% 0.00% 0 RPC lcc_rp
391 96 1564 61 0.00% 0.00% 0.00% 0 RPC fabman_rp
392 0 108 0 0.00% 0.00% 0.00% 0 RPC sea_rp_cli_r
393 0 2 0 0.00% 0.00% 0.00% 0 RPC const_ifs_rp
394 0 2 0 0.00% 0.00% 0.00% 0 RPC gvrp_rp2sp
395 4 4 1000 0.00% 0.00% 0.00% 0 L2 Manager Task
396 0 1 0 0.00% 0.00% 0.00% 0 L2 Manager Earl6
397 56 730 76 0.00% 0.00% 0.00% 0 LTL MGR
398 0 1 0 0.00% 0.00% 0.00% 0 LTL MGR cc
399 0 3 0 0.00% 0.00% 0.00% 0 SPAN switch
400 0 15 0 0.00% 0.00% 0.00% 0 SPAN Switch SP
401 4 7620 0 0.00% 0.00% 0.00% 0 SPAN Switch SP B
402 0 10 0 0.00% 0.00% 0.00% 0 LC Registry Expo
403 0 2 0 0.00% 0.00% 0.00% 0 LC IPC ICC Init
404 8 38 210 0.00% 0.00% 0.00% 0 Const2 IPv6 Proc
405 0 1 0 0.00% 0.00% 0.00% 0 v6fib stat colle
406 0 18 0 0.00% 0.00% 0.00% 0 CMFI
407 0 27 0 0.00% 0.00% 0.00% 0 CMFI Scanner
408 0 8 0 0.00% 0.00% 0.00% 0 CMFI Misc
409 20 7938 2 0.00% 0.00% 0.00% 0 CMFI Background
410 0 1 0 0.00% 0.00% 0.00% 0 CMFI iEdge Proce
411 0 2 0 0.00% 0.00% 0.00% 0 EI SP
412 0 2 0 0.00% 0.00% 0.00% 0 REP SP Proc
413 0 7 0 0.00% 0.00% 0.00% 0 ADJ background
414 0 2 0 0.00% 0.00% 0.00% 0 SEA receive proc
415 0 16 0 0.00% 0.00% 0.00% 0 Syslog
416 0 2495 0 0.00% 0.00% 0.00% 0 NDE - IPV4
417 0 1 0 0.00% 0.00% 0.00% 0 NDE - MPLS
418 0 1 0 0.00% 0.00% 0.00% 0 NDE - L2
419 0 124 0 0.00% 0.00% 0.00% 0 NDE - IPV6
420 0 1 0 0.00% 0.00% 0.00% 0 SpanTree Helper
421 4 7620 0 0.00% 0.00% 0.00% 0 MFI LFD Stats Pr
422 4 14380 0 0.00% 0.00% 0.00% 0 MFI LFD Timer Pr
423 4 3 1333 0.00% 0.00% 0.00% 0 MFI LFD Main Pro
424 4 47 85 0.00% 0.00% 0.00% 0 Collection proce
426 984 256290 3 0.00% 0.02% 0.00% 0 DiagCard5/-1
427 52 262099 0 0.00% 0.00% 0.00% 0 SCP async: LCP#5
428 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
429 4 1271 3 0.00% 0.00% 0.00% 0 system Image Rec
431 0 2 0 0.00% 0.00% 0.00% 0 fabm_ch_sync:2
--- remote command switch show ipc status ---
IPC System Status
Time last IPC stat cleared all zones : 00:00:00
This processor is the IPC master server in zone 0 (default).
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
Rx Side Tx Side
Total Frames 481095 482971
Total from Local Ports 237025 304573
Total Protocol Control Frames 185 364
Total Frames Dropped 7 0
Service Usage
Total via Unreliable Connection-Less Service 38008 38093
Total via Unreliable Sequenced Connection-Less Svc 0 0
Total via Reliable Connection-Oriented Service 199232 266479
Total Messages via Fragmentation 9 791
Total Fragments 37 6328
Total Internal IPC Messages 352 0
Total Messages Flushed 0 0
IPC Protocol Version 0
Total Acknowledgements 272015 172861
Total Negative Acknowledgements 0 0
Device Drivers
Total via Local Driver 16396 16396
Total via Platform Driver 464697 466575
Total Frames Dropped by Platform Drivers 0 0
Total Frames Sent when media is quiesced 0
Reliable Tx Statistics
Re-Transmission 1
Re-Tx Timeout 0
Rx Errors Tx Errors
Unsupp IPC Proto Version 0 Tx Session Error 0
Corrupt Frame 0 Tx Seat Error 0
Duplicate Frame 7 Tx No Send Vector 0
Unrel Out-of-Seq Frame 0 Tx Driver Failed 0
Rx IPC Transform Errors 0 Tx IPC Transform Errors 0
Unable to Deliver Msg 0 Tx Test Drop 0
Rx Msg Callback Hog 0 Ack Alloc Failed 0
Rel Out-of-Seq Frame 0
Dest Port does Not Exist 0
Rx IPC Msg Alloc Failed 0
Rx IPC Frag Dropped 0
Rx Bootstrap Delivered 2
Rx Bootstrap Dropped 0
Buffer Errors Misc Errors
IPC Msg Alloc 0 IPC Open Port 51
Emer IPC Msg Alloc 0 No HWQ 0
IPC Frame PakType Alloc 0 Hardware Error 0
IPC Frame MemD Alloc 0 Invalid Messages 0
IPC Backup Open Port 0
IPC Fragment Errors 0
Message Timer Errors 0
Messages no xmt pending flag 0
Tx Driver Errors
No Transport 0
MTU Failure 0
Dest does not Exist 0
IPC Message Bundling Statistics
Seat-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/310110/0/0
Seat-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/481093/0
Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/304572/139887/0
Session-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/176436/0
--- remote command switch show ipc queue ---
There are 4 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use : 31
Message cache size : 6000
Maximum message cache usage : 6000
0 times message cache crossed 12000 [max]
Emergency messages currently in use : 0
There are 25 messages currently reserved for reply msg.
Cache low watermark [default/new]: [100/100]
No of low watermark reached : 0
Total get cache after low watermark : 0
No of times zero cache reached : 0
No of times one cache added : 0
No of times cache chunk added : 0
Max no of get cache between wake2grow : 0
IPC Retransmission Table:
Source Destination Size Tries Seq Msg
10000.0 IPC Master 2150000.25 Resource Man... 37 0 1182 0x10E8F058
10000.0 IPC Master 2150000.25 Resource Man... 25 0 1183 0x10E8D014
10000.0 IPC Master 2150000.25 Resource Man... 37 0 1184 0x10E90B14
10000.0 IPC Master 2150000.7 Card5/1:Reques 16 0 32968 0x10E8DC10
--- remote command switch show heartbeat ---
Out of buffers = 0
Fatal errors = 0
Last heartbeat sched = 632
Last heartbeat sent = 1324
Peer 5/0 [online]:
Peer 5/1 [online]:
Heartbeats received = 38006
Config msgs received = 1
Clock cfg msgs received = 1
Scheduler history [Virtual Exec 10%/0% (00:00:04.004 12%/0%)] [Virtual Exec 00:00:00.152] [Remote Console Process 00:00:00.156] [UDLD 00:00:00.156]
RTLSGR1#
09-30-2012 03:42 AM
I can see input drops on Gig 5/1.
Please get me the following outputs. Take 3 sets of outputs with ~ 1 minute interval between the captures
1. Show ip traffic
2. show int gi 5/1 stat
3. show int gi 5/1 switching
4. Show int gi 5/2 stat
5. show int gi 5/2 switching
09-30-2012 04:08 AM
RTLSGR1#sh ip traffic
IP statistics:
Rcvd: 1201087872 total, 646509 local destination
0 format errors, 0 checksum errors, 6546 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 8 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 8 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 1296 received, 0 sent
Mcast: 19513 received, 9486 sent
Sent: 762481 generated, 3989749131 forwarded
Drop: 12 encapsulation failed, 0 unresolved, 0 no adjacency
1295 no route, 0 unicast RPF, 0 forced drop, 0 unsupported-addr
0 options denied, 0 source IP address zero
ICMP statistics:
Rcvd: 6 format errors, 0 checksum errors, 0 redirects, 286 unreachable
397547 echo, 165 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 0 timestamp, 0 info request, 2 other
0 irdp solicitations, 0 irdp advertisements
Sent: 0 redirects, 98909 unreachable, 175 echo, 397547 echo reply
0 mask requests, 0 mask replies, 0 quench, 0 timestamp
0 info reply, 481 time exceeded, 0 parameter problem
BGP statistics:
Rcvd: 135688 total, 7 opens, 2 notifications, 132580 updates
3099 keepalives, 0 route-refresh, 0 unrecognized
Sent: 4284 total, 7 opens, 3 notifications, 0 updates
4274 keepalives, 0 route-refresh
EIGRP-IPv4 statistics:
Rcvd: 0 total
Sent: 0 total
TCP statistics:
Rcvd: 93741 total, 18 checksum errors, 23 no port
Sent: 121184 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
UDP statistics:
Rcvd: 135147 total, 0 checksum errors, 295 no port
Sent: 134835 total, 0 forwarded broadcasts
OSPF statistics:
Last clearing of OSPF traffic counters never
Rcvd: 19596 total, 0 checksum errors
18877 hello, 44 database desc, 8 link state req
361 link state updates, 197 link state acks
Sent: 9661 total
9241 hello, 39 database desc, 11 link state req
172 link state updates, 202 link state acks
Probe statistics:
Rcvd: 0 address requests, 0 address replies
0 proxy name requests, 0 where-is requests, 0 other
Sent: 0 address requests, 0 address replies (0 proxy)
0 proxy name replies, 0 where-is replies
ARP statistics:
Rcvd: 168 requests, 16 replies, 0 reverse, 0 other
Sent: 9070 requests, 25 replies (0 proxy), 0 reverse
Drop due to input queue full: 0
RTLSGR1#
RTLSGR1#sh int gi5/1 stat
GigabitEthernet5/1
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 106745 9048634 51710 16055410
Route cache 4730160497 361950786744 270 22832
Distributed cache 3603516173 470043068068 10055243954 914016291307
Total 8333783415 832002903446 10055295934 914032369549
RTLSGR1#
RTLSGR1#show int gi 5/1 switching
GigabitEthernet5/1 Internet With NetroNext
Throttle count 3
Drops RP 4426 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 26866 Drops 0
Protocol IP
Process 57139 4966228 46179 17182152
Cache misses 0 - - -
Fast 4739191132 362656259906 270 22832
Auton/SSE 3612493106 471074695184 10071708798 915679168901
Protocol DEC MOP
Process 32 2464 127 14351
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Spanning Tree
Process 38436 1998672 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 7084 425872 5547 532512
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 1237 566546 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
RTLSGR1#sh int gi5/2 stat
GigabitEthernet5/2
Processor 653281 67059528 669349 73389781
Route cache 775338 280445136 5805678066 444689501595
Distributed cache 5851631726 473093070689 619334594 50306453853
Total 5853060345 473440575353 6425682009 495069345229
RTLSGR1#
RTLSGR1#show int gi 5/2 switching
GigabitEthernet5/2
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 10240 Drops 0
Protocol IP
Process 653681 64478658 669593 94836007
Fast 775436 280451853 5810691636 445082995797
Auton/SSE 5856326840 473484061519 619782207 50344143470
Protocol DEC MOP
Process 0 0 147 16611
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 8 480 8 768
Fast 0 0 0 0
Auton/SSE 0 0 0 0
RTLSGR1#
After 5 Min After 5 Min After 5 Min After 5 Min
IP statistics:
Rcvd: 1325523576 total, 651172 local destination
0 other
Bcast: 1304 received, 0 sent
Mcast: 19671 received, 9559 sent
Sent: 767796 generated, 4168295526 forwarded
ICMP statistics:
401563 echo, 165 echo reply, 0 mask requests, 0 mask replies, 0 quench
Sent: 0 redirects, 99699 unreachable, 175 echo, 401563 echo reply
BGP statistics:
Rcvd: 136112 total, 7 opens, 2 notifications, 132979 updates
3124 keepalives, 0 route-refresh, 0 unrecognized
Sent: 4320 total, 7 opens, 3 notifications, 0 updates
4310 keepalives, 0 route-refresh
Rcvd: 0 total
Sent: 0 total
TCP statistics:
Rcvd: 94218 total, 18 checksum errors, 23 no port
Sent: 121612 total
Queue drops: 0
State-Refresh: 0/0
Queue drops: 0
UDP statistics:
Rcvd: 135159 total, 0 checksum errors, 295 no port
Sent: 134847 total, 0 forwarded broadcasts
OSPF statistics:
Rcvd: 19754 total, 0 checksum errors
19032 hello, 44 database desc, 8 link state req
363 link state updates, 198 link state acks
Sent: 9735 total
9313 hello, 39 database desc, 11 link state req
172 link state updates, 204 link state acks
Probe statistics:
ARP statistics:
Rcvd: 169 requests, 16 replies, 0 reverse, 0 other
Sent: 9132 requests, 25 replies (0 proxy), 0 reverse
RTLSGR1#
GigabitEthernet5/1
Processor 108078 9151786 52629 16159723
Route cache 4785047155 366243453033 270 22832
Distributed cache 3668518490 477550142800 10168662168 925524284345
Total 8453673723 843802747619 10168715067 925540466900
RTLSGR1#
Throttle count 3
Drops RP 4426 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 27120 Drops 0
Protocol IP
Process 58127 5042647 47087 17318573
Fast 4794386221 366974472835 270 22832
Auton/SSE 3680358933 478916563850 10189693235 927664285151
Protocol DEC MOP
Process 32 2464 128 14464
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Process 38822 2018744 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 7085 425932 5586 536256
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 1250 572500 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
RTLSGR1#
GigabitEthernet5/2
Processor 658087 67465441 674124 73794790
Route cache 777936 280610295 5857530651 448745142886
Distributed cache 5902969561 477363657083 624035056 50703987462
Total 5904405584 477711732819 6482239831 499522925138
RTLSGR1#
GigabitEthernet5/2
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 10287 Drops 0
Protocol IP
Process 658702 64879453 674568 95424560
Fast 778053 280617813 5862646520 449144181072
Auton/SSE 5907375471 477729069916 624497683 50743545627
Protocol DEC MOP
Process 0 0 148 16724
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 8 480 8 768
Fast 0 0 0 0
Auton/SSE 0 0 0 0
RTLSGR1#
09-30-2012 06:45 AM
We see lot of packets gettign fast switched. Also the traffic in and out to the CPU is very high
------------------ show ibc ------------------
Interface information:
Interface IBC0/0(idb 0x183CD514)
5 minute rx rate 52098000 bits/sec, 85888 packets/sec
5 minute tx rate 126231000 bits/sec, 171809 packets/sec
To find which packets are hitting the CPU, either we need to sniff the CPU or capture netdr output
Sniffing the CPU is mentioend in below link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
To collect the netdr output. Please do the following
1. Run the following command from enable mode
Debug netdr
2. wait for 2 minutes and execute the following command
Undebug all
3. Collect the following output and attach here
show netdr captured packets
note: The command starts with the word debug. But this doesn't add any load to CPU and it safe to run even when CPU is running at 99%
09-30-2012 07:52 PM
The first step is " debug netdr capture" instead of "debug netdr"
09-30-2012 09:47 PM
Hi Rajs,
How to avoid fast switching as already CEF is on. Yes i am sharing you the capture file of netdr.
09-30-2012 10:08 PM
yes. CEF is on. We need to analyze the packets hitting the CPU, to analyze this
09-30-2012 10:09 PM
----- dump of outgoing inband packet -------
interface Gi5/2, routine naboo_fastsend, timestamp 04:40:22.261
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
00020000 03F82800 03800000 4E000000 00110000 20B00000 50330000 7F0A2000
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 39111E60 670E5033 465625BA C9882A76
00280000 80128543 615D9EA0 23064664 54B3FBD1 4C4FF2AC
07C4547A D9D5ED6E 000003F8 00000101 00000380 7AC6
------- dump of incoming inband packet -------
interface Gi5/1, routine process_rx_packet_inline, timestamp 04:40:22.261
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
60000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 184.170.135.50
udp src 7038, dst 8570 len 40 checksum 0x0
------- dump of outgoing inband packet -------
00020000 03F82800 03800000 4E000000 00110000 80300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 1B7E217A
00280000 801227DD 615D9EA0 03EE668C 6DA20847 92DFB214
14E96702 484F72A9 000003F8 00000101 00000380 7AC5
70000400 03FB0000 01000000 4E000000 0011BC8A 60E6670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.96.230
udp src 20428, dst 11358 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116CFF 670E5033 BC8A60E6 4FCC2C5E
00280000 801235CA 615D9EA0 209C45FE 7548C6EB 28124C6F
63D04056 B49E9F62 000003F8 00000101 00000380 7AC8
78000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.41.250
udp src 16688, dst 7362 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 41301CC2
00280000 8012721F 615D9EA0 188E7DEC 77C883F0 92C5AE62
0A913E6B D8E04E12 000003F8 00000101 00000380 7AC5
90000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.36
udp src 5890, dst 7450 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 17021D1A
00280000 80121352 615D6F70 144D712F AB3AAC5B 9B3BE337
01E5ABDE 9F553773 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.57.246
udp src 44344, dst 10646 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 AD382996
00280000 80125C00 615D6F70 768913EB 79BF8AB3 42D7D081
744C3876 8E06CCEE 000003F8 00000101 00000380 7AC8
C0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.51
udp src 58458, dst 24496 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 E45A5FB0
00280000 80128478 615D6F70 6A200F42 78009CC6 A6FB1750
2696F8BE E3D43DA2 000003F8 00000101 00000380 7AC8
28000400 03FB0000 01000000 4E000000 00115519 B829670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.184.41
udp src 11216, dst 9522 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39117D2D 670E5033 5519B829 2BD02532
00280000 80128B49 615D6F70 36F05392 13E0D132 B87D2F01
136F1AA5 D13A4B4C 000003F8 00000101 00000380 7AC5
40000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.226
udp src 16142, dst 8206 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 3F0E200E
00280000 80124DAE 615D6F70 05746016 F6DBC213 3BA0A96A
1353F6DB C1865899 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.43
udp src 38414, dst 9146 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B 960E23BA
00280000 80123A03 816188A0 176C720E 5C1A9CD8 02BB0C61
625042CA DC4BA7E2 000003F8 00000101 00000380 7AC7
D8000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.73.69
udp src 29514, dst 10494 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 734A28FE
00280000 80127646 3DE30510 72F21790 D4E08704 C038C8FA
D041D4F0 B20EC076 000003F8 00000101 00000380 7AC8
E8000400 03FB0000 01000000 4E000000 0011482C 4C3D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.76.61
udp src 20176, dst 10002 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F606 670E5033 482C4C3D 4ED02712
00280000 80123A14 3DE30510 0FFA6A98 606ABC3E DF0A940A
121E40D7 B9315742 000003F8 00000101 00000380 7AC7
10000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.46.152
udp src 65124, dst 8294 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 FE642066
00280000 8012D38E 3DE30510 330C566E F8F0C9EB CEEBC2F4
DD1E7503 F88BF312 000003F8 00000101 00000380 7AC6
38000400 03FB0000 01000000 4E000000 0011ADF6 27C4670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.246.39.196
udp src 12684, dst 3358 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911B4B5 670E5033 ADF627C4 318C0D1E
00280000 8012A4C0 816188A0 7BD71EB5 5C3B98F8 8732082E
BE1472B3 2176F5E2 000003F8 00000101 00000380 7AC5
50000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.208.29
udp src 37036, dst 6530 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D 90AC1982
00280000 80121CA0 3DE30510 1048752A F21B7372 B93FD0E4
271032E0 B3A15D3E 000003F8 00000101 00000380 7AC8
60000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 29596, dst 50792 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 739CC668
00280000 80120781 816188A0 53533631 7856AB60 00FAC200
07D678EB 6B6000FA 000003F8 00000101 00000380 7AC5
68000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.105
udp src 63858, dst 6750 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 F9721A5E
00280000 80126F6A 3DE30510 223F475D 52F9E5C8 0212D2DF
7616FC18 7C7253AE 000003F8 00000101 00000380 7AC5
70000400 03FB0000 01000000 4E000000 00114E81 B22E670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.178.46
udp src 10198, dst 6222 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391189C0 670E5033 4E81B22E 27D6184E
00280000 8012097C 3DE30510 2E714B13 78CAB3EE E42ED26F
151678AA D739A7B2 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.228.3.77
udp src 65328, dst 56864 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FF30DE20
00280000 80121E38 816188A0 06DC63BE 8EDF168B 9861F1DA
098A576C 9607D16C 000003F8 00000101 00000380 7AC7
90000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.25
udp src 51148, dst 9210 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 C7CC23FA
00280000 80123F50 3DE30510 182B7D49 F82BF625 3F7A522D
265B70CA D1E16C22 000003F8 00000101 00000380 7AC8
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0xDA(218)
A0000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 200, identifier 0
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.40.105
udp src 43236, dst 28134 len 180 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0xDA(218)
00020000 03F82800 03800000 DA000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 A8E46DE6
00B40000 800870CC 816188A0 06756317 D555D5D5 55D5D5D5
D5D5D5D5 D5D5D5D5 000003F8 00000101 00000380 7AC6
A8000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 25564, dst 29446 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 63DC7306
00280000 8012E324 3DE30510 63A706C5 05F8C6F2 A9A717BB
918C0FEE 07CB08DE 000003F8 00000101 00000380 7AC9
B0000400 03FB0000 01000000 4E000000 0011D5E5 539B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 213.229.83.155
udp src 43474, dst 11250 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391160EF 670E5033 D5E5539B A9D22BF2
00280000 801242E1 816188A0 559D30FF 5C14E589 D8D9080D
54344A41 E160F95D 000003F8 00000101 00000380 7AC7
B8000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.95.18
udp src 13458, dst 18434 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 34924802
00280000 801239E2 3DE30510 1579701B 35D3C4CD 136EFC20
91C43DF2 C81BF9B3 000003F8 00000101 00000380 7AC7
C8000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.176.247
udp src 6528, dst 7218 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 19801C32
00280000 801265E1 816188A0 2B884EEA 705F7BC8 7FD817EA
301014BB 78D653AA 000003F8 00000101 00000380 7AC8
interface Gi5/2, routine naboo_fastsend, timestamp 04:40:22.269
layer 3 data: 4500003C 00004000 3911F60A 670E5033 43D45091 A30C92AE
00280000 80120247 615D9EF0 66EF038D 781680A0 00FAC200
07D67873 40A000FA 000003F8 00000101 00000380 7AC8
interface Gi5/1, routine process_rx_packet_inline, timestamp 04:40:22.269
A8000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.30.35.41
udp src 35372, dst 6170 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 8A2C181A
00280000 80122047 615D9EF0 27154277 21931137 FC63EB7D
D6C833DD 2F544393 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 00114298 A8E4670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.228
udp src 63438, dst 8406 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119EF3 670E5033 4298A8E4 F7CE20D6
00280000 80124699 615D9EF0 2B774E15 D629A2E6 AAE0A810
DC9651FB 4284771E 000003F8 00000101 00000380 7AC5
C0000400 03FB0000 01000000 4E000000 0011482C 436B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.67.107
udp src 46554, dst 8878 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FED8 670E5033 482C436B B5DA22AE
00280000 801259C2 615D9EF0 22FC479E 42E36513 AD4A98BA
121A407B F4D8FCA2 000003F8 00000101 00000380 7AC7
E0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 64848, dst 45846 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FD50B316
00280000 801293C3 615D9EF0 26C043A2 E070573C 845BCB30
DB54A85A 7CEC6B93 000003F8 00000101 00000380 7AC6
E8000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 59948, dst 9182 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 EA2C23DE
00280000 801297A2 615D9EF0 46D923BB 30402051 1F88CFB8
11D2F832 93D0B512 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.234
udp src 50978, dst 6390 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA C72218F6
00280000 80120D5F 615D9EF0 7EFF1B9D 4C058B58 B0B8355C
11FFBF1E 4B96E053 000003F8 00000101 00000380 7AC6
F8000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 28786, dst 10214 len 40 checksum 0x0
RTLSGR1#
09-30-2012 11:01 PM
The netdr can capture 4096 packets. your capture has only 63 packets. analysis of 4096 packets can give more detailed analysis
I have looked at the 63 packets uploaded. and most of traffic is coming from 103.14.80.51.
1. Can you check this is expected traffic.
it was sending udp traffic of 60 bytes to destinations
70.87.221.51 3, 209.44.127.36 3, 67.228.3.77 2, 213.229.83.155 1, 174.136.40.105 1 , 67.212.80.25 69.162.95.18 78.129.178.46 50.30.35.41 108.166.199.234.
Chcek if we have routes to the following
1. Send me the followign outputs too
show ip route 70.87.221.51 3
show ip route 209.44.127.36
show mls rate
show mls rate usage
10-01-2012 12:06 AM
I am giving you 4096 packet with content of your asked show command.
103.14.80.51 is the expected server where pubpic ip should hit. Rest real ip are customer (Carrier of voice traffic) who and all are passing there voice traffic through 103.14.80.51. 103.14.80.51 then send the requested traffic to other private block ip's.Customer is an IGW.
interface Gi5/2, routine naboo_fastsend, timestamp 06:30:06.856
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 EE5C1A6E
00280000 80125B82 64813790 45FE209C 781A6F89 E95A5B72
891A5229 6B794A9B 000003F8 00000101 00000380 7AC6
interface Gi5/1, routine process_rx_packet_inline, timestamp 06:30:06.856
udp src 22698, dst 58740 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 58AAE574
00280000 80123DA5 64813790 6A0B0F69 4597C5F0 8DAAB115
E64929D0 4629641D 000003F8 00000101 00000380 7AC8
68000400 03FB0000 01000000 4E000000 0011D040 E513670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 208.64.229.19
udp src 34638, dst 6526 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911D51B 670E5033 D040E513 874E197E
00280000 80126C76 64813790 7D471825 47C489EE 7262BE3D
C116BDBB FF216DF2 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 0011CFB6 884A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 207.182.136.74
udp src 53670, dst 6154 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911326F 670E5033 CFB6884A D1A6180A
00280000 8012E0E8 64813790 37C052A2 7212D984 0FBA469D
65D1421A FC2E2AB2 000003F8 00000101 00000380 7AC5
88000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 16546, dst 8274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 40A22052
00280000 80122603 64813790 0BBF6EDD 0D626A0F F7A24839
FE1A054D A513B19A 000003F8 00000101 00000380 7AC7
90000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.72.26
udp src 21916, dst 6338 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A 559C18C2
00280000 80122FC7 64813790 7B8F1EED 91B487C0 B85F2F15
591A267C 471A6363 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 0011C694 7EAA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.126.170
udp src 65216, dst 6282 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30A00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114531 670E5033 C6947EAA FEC0188A
00280000 801200BF 64813790 34665104 78FB40A0 00FAC200
07D6782E 80A000FA 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 55506, dst 17258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D D8D2436A
00280000 80129CB2 4106CCE0 028867EA 708B6B20 A6BB7E3C
BC9AF894 F2879D0E 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 001143D4 5A3D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.90.61
udp src 15402, dst 7746 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911EC5E 670E5033 43D45A3D 3C2A1E42
00280000 80121670 4106CCE0 12A777C5 8DBAC755 D0834B96
969F26D8 45B22CAB 000003F8 00000101 00000380 7AC6
E0000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.100.106
udp src 12754, dst 6830 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 31D21AAE
00280000 80123173 4106CCE0 686A0D08 B07B1F54 6BBB1481
FEC730AD 630E3563 000003F8 00000101 00000380 7AC5
E8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.34.176.54
udp src 23474, dst 21026 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 5BB25222
00280000 80122610 4106CCE0 06E9638B 5000BCA4 A713C240
C8120242 43A3C2C2 000003F8 00000101 00000380 7AC8
F0000400 03FB0000 01000000 4E000000 0011CDCC 4772670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.71.114
udp src 60230, dst 6854 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00700000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39117531 670E5033 CDCC4772 EB461AC6
00280000 80123466 4106CCE0 34145176 657ECD52 70DF7175
FC4F2792 CD959F99 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x8A(138)
F8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 120, identifier 0
udp src 7216, dst 56030 len 100 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x8A(138)
00020000 03F82800 03800000 8A000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 1C30DADE
00640000 80082D27 4106CD80 1BDC7EBE 545654D1 D15454D5
D6D65650 D4D0D756 000003F8 00000101 00000380 7AC5
08000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
udp src 53094, dst 6470 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A CF661946
00280000 801227DA 4106CD30 50C435A6 58F06958 093BF1E4
F552306A D9885533 000003F8 00000101 00000380 7AC5
10000400 03FB0000 01000000 4E000000 0011AE8E 2764670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.142.39.100
udp src 30820, dst 7258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B47D 670E5033 AE8E2764 78641C5A
00280000 8012312D 4106CCE0 60BC05DE 787E9725 88FA5590
9194E420 6A0421EE 000003F8 00000101 00000380 7AC9
20000400 03FB0000 01000000 4E000000 00116CA6 DAD2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.210
udp src 47142, dst 6882 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391142F7 670E5033 6CA6DAD2 B8261AE2
00280000 80122C00 4106CCE0 402F254D 3063FFFD 94D8154F
05527CD7 7E8CF53A 000003F8 00000101 00000380 7AC8
28000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 19790, dst 33598 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 4D4E833E
00280000 8012B93F 4106CCE0 19FD7C9F F8FB9317 7E12D807
5252406D D30A8733 000003F8 00000101 00000380 7AC7
38000400 03FB0000 01000000 4E000000 0011266C 5C4B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 38.108.92.75
udp src 35416, dst 8272 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391107B9 670E5033 266C5C4B 8A582050
00280000 801203F9 4106CD30 3CD659B4 0D624C39 CA59730C
D4F168DB 4C70179A 000003F8 00000101 00000380 7AC6
udp src 61266, dst 9542 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 EF522546
00280000 80120CC3 84855070 08A66DC4 2005DFD4 79428C05
8E9472CD EF8CA893 000003F8 00000101 00000380 7AC9
48000400 03FB0000 01000000 4E000000 0011C694 72B2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.114.178
udp src 17996, dst 7082 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115129 670E5033 C69472B2 464C1BAA
00280000 8012AE82 4106CCE0 6DE9088B 79A3CC77 0A88D120
8896F286 B5E3103B 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x52(82)
50000400 03FB0000 01000000 52000000 00116CA6 DAE8670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 64, identifier 0
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.232
udp src 59374, dst 9286 len 44 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x52(82)
00020000 03F82800 03800000 52000000 00110000 90E00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 391142DD 670E5033 6CA6DAE8 E7EE2446
002C0000 80040083 84855160 27A342C1 F04E6A0B 0AA4A889
02000000 B2807519 000003F8 00000101 00000380 7AC9
60000400 03FB0000 01000000 4E000000 0011ADF4 A4D2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.244.164.210
udp src 36176, dst 7562 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391137A9 670E5033 ADF4A4D2 8D501D8A
00280000 80125C5A 84855070 2A9C4FFE E2A98702 2A277012
060863E9 478BF0AD 000003F8 00000101 00000380 7AC9
78000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 29738, dst 13594 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 742A351A
00280000 8012563D 84855070 49E32C81 69DC9946 51AEF2AE
CEF3613B C5F29CA5 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 0011482C 4D9B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.77.155
udp src 43654, dst 10782 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F4A8 670E5033 482C4D9B AA862A1E
00280000 801223F7 84855070 0D18687A 7241F4C9 873A5E7B
A1927801 CE1D0EDA 000003F8 00000101 00000380 7AC6
88000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 32652, dst 44338 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 7F8CAD32
00640000 8008869B 84855110 0F3F6A5D 55555555 55555555
55545455 55D5D5D5 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 35906, dst 63366 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 8C42F786
00280000 80121BBE 84855070 27C642A4 753888C4 EA48D049
44C64262 F8D5FA5A 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 0011D1BE 1DD2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.29.210
udp src 16394, dst 11990 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119ADF 670E5033 D1BE1DD2 400A2ED6
00280000 8012A40D 84855070 67CB02A9 72454EDC 17094C50
D6D2DC30 12BD9C68 000003F8 00000101 00000380 7AC7
B0000400 03FB0000 01000000 4E000000 0011642A 4B83670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.75.131
udp src 51642, dst 6398 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911DAC2 670E5033 642A4B83 C9BA18FE
00280000 80122582 84855070 37CA52A8 D16280B3 A77F4116
9292769B 0E01196B 000003F8 00000101 00000380 7AC7
B8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 11400, dst 56796 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 2C88DDDC
00640000 800801D1 84855110 56AF33CD 55555555 55555555
55555555 55555555 000003F8 00000101 00000380 7AC7
C8000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 48974, dst 10810 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B BF4E2A3A
00280000 80120A48 84855070 505A3538 1FD3C5BB B5C30FB4
C4C2F6EB C668FB5F 000003F8 00000101 00000380 7AC8
D0000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.123.87.2
udp src 61260, dst 9030 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 EF4C2346
00280000 80122EBA 84855070 7B8A1EE8 7506FB4B E4B8D00B
ECD278EB 1A164D9B 000003F8 00000101 00000380 7AC8
E0000400 03FB0000 01000000 4E000000 00113261 278B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.39.139
udp src 53440, dst 11762 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113084 670E5033 3261278B D0C02DF2
00280000 801228CA 84855070 5C9739F5 09E086F2 AE530C3B
C7D37EF3 C6365DE8 000003F8 00000101 00000380 7AC6
E8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 31530, dst 31404 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 7B2A7AAC
00280000 8012BA15 84855070 5B1A3E78 146FD012 B1AE143F
BE745482 EA4E3C98 000003F8 00000101 00000380 7AC5
08000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 51984, dst 32226 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 CB107DE2
00280000 80120829 648166C0 1B7F7E1D 54BAFE90 FC465049
796E54D6 BDCB3FB8 000003F8 00000101 00000380 7AC6
10000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 63256, dst 50670 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F718C5EE
00640000 800873EA 64816710 06C963AB D5D55455 D5D5D4D4
D55555D5 D5D45456 000003F8 00000101 00000380 7AC6
20000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 6884, dst 40138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 1AE49CCA
00280000 8012BE58 648166C0 25A040C2 F8E8E7FC 321A421D
B2585943 B4879F43 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.38.90
udp src 32100, dst 36414 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 7D648E3E
00280000 8012A4FA 648166C0 64700112 493A8679 98EB52CA
451F26C2 C709EB62 000003F8 00000101 00000380 7AC8
40000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 61092, dst 6802 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 EEA41A92
00280000 80127C22 648166C0 5DB338D1 6030FA2C D49A0E95
5F16F8BF 41D4F68F 000003F8 00000101 00000380 7AC8
50000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 46388, dst 9978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B B53426FA
00280000 8012206B 648166C0 7FC81AAA 78AF55D2 8F1A8AD4
F0DB3052 E00C9ABA 000003F8 00000101 00000380 7AC6
58000400 03FB0000 01000000 4E000000 0011D1A0 219D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.160.33.157
udp src 22476, dst 15474 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119732 670E5033 D1A0219D 57CC3C72
00280000 80128EAE 64816670 1C5B7939 B97446B3 84B20D53
830EFD07 4700A9AA 000003F8 00000101 00000380 7AC5
68000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 9582, dst 38014 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 256E947E
00280000 801212E2 648166C0 31EC548E 16C0CD0A 56CC3041
6E359AC1 8D0B7797 000003F8 00000101 00000380 7AC8
70000400 03FB0000 01000000 4E000000 00113261 74E3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.116.227
udp src 5668, dst 9582 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911E32B 670E5033 326174E3 1624256E
00280000 801211EC 648166C0 56FD339F 60B3E230 6733492A
B1DF59F8 DC1A0E13 000003F8 00000101 00000380 7AC7
78000400 03FB0000 01000000 4E000000 00114E81 8E07670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.142.7
udp src 19360, dst 6290 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911ADE7 670E5033 4E818E07 4BA01892
00280000 8012B779 648166C0 51AC34CE 78A77280 4263D013
57907960 FFFEC6EF 000003F8 00000101 00000380 7AC9
80000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
udp src 55190, dst 11274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 D7962C0A
00280000 8012045F 648166C0 764F132D 71E0927C F15B175F
A474147F F2D914C3 000003F8 00000101 00000380 7AC5
88000400 03FB0000 01000000 4E000000 0011CDCC 504F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.80.79
udp src 36316, dst 7302 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116C54 670E5033 CDCC504F 8DDC1C86
00280000 80128A97 648166C0 34AE51CC 64A3CD0C 6762529B
4E117093 9546047B 000003F8 00000101 00000380 7AC7
90000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
udp src 26260, dst 6362 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 669418DA
00280000 80122755 648166C0 679302F1 CAEF8BC6 9C99EEA4
A63D4AAD 0B0B09A7 000003F8 00000101 00000380 7AC8
98000400 03FB0000 01000000 4E000000 0011ADC0 2123670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.192.33.35
udp src 49328, dst 10546 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BB8C 670E5033 ADC02123 C0B02932
00280000 801207B1 648166C0 5FEB3A89 38F2714F 033E4D6D
59DF7D54 456324CE 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
udp src 40708, dst 9018 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA 9F04233A
00280000 80127101 648166C0 4D69280B E0736013 91C3D02A
8B5A7203 4C365F13 000003F8 00000101 00000380 7AC8
B0000400 03FB0000 01000000 4E000000 0011D1A0 183F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.160.24.63
udp src 62546, dst 21662 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911A090 670E5033 D1A0183F F452549E
00280000 801240FF 648166C0 3268570A F240D2F5 3E42D31E
14D2B0CE 4F3E74C2 000003F8 00000101 00000380 7AC8
B8000400 03FB0000 01000000 4E000000 00114005 20D7670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.32.215
udp src 18608, dst 15618 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39112994 670E5033 400520D7 48B03D02
00280000 801269A9 648166C0 2D3C485E 024818AC 605241CD
19977927 5DEECDD2 000003F8 00000101 00000380 7AC7
C0000400 03FB0000 01000000 4E000000 00116CA6 DBE4670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.219.228
udp src 26930, dst 7218 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391141E5 670E5033 6CA6DBE4 69321C32
00280000 8012B4E4 648166C0 73FD169F C0E78622 78FA4F82
CDD4F820 F1D4D972 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
udp src 49926, dst 9186 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 C30623E2
00280000 80121715 648166C0 2ECC4BAE 67A65A8A 5E3DF3BF
C16A677A DB666670 000003F8 00000101 00000380 7AC7
E8000400 03FB0000 01000000 4E000000 001143D5 4E64670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.213.78.100
udp src 50640, dst 6570 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F836 670E5033 43D54E64 C5D019AA
00280000 8012044B 648166C0 147B7119 79E46002 7BF350EC
14907232 E600CABB 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 41316, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B A1642A62
00280000 80120347 1AE911E0 297F4C1D 78AEC0A0 00FAC200
07D67878 00A000FA 000003F8 00000101 00000380 7AC5
F8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 13070, dst 9554 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 330E2552
00280000 80120AD6 648166C0 776D120F 12740C3B 8E4E736A
DB3F1AFF 8CF4905D 000003F8 00000101 00000380 7AC5
10000400 03FB0000 01000000 4E000000 0011CDCC 518F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.81.143
udp src 32968, dst 11110 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116B14 670E5033 CDCC518F 80C82B66
00280000 801217FB 1AE911E0 02EF678D 7CDE67A6 DD5B0E98
BCD85858 75F30353 000003F8 00000101 00000380 7AC8
20000400 03FB0000 01000000 4E000000 0011482C 4D9B670E 50330000 7F0A2000
udp src 33966, dst 9194 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F4A8 670E5033 482C4D9B 84AE23EA
00280000 8012E96E 648166C0 568A33E8 F80FF208 2E3A0D89
E39238BE DC8C3E6A 000003F8 00000101 00000380 7AC9
38000400 03FB0000 01000000 8A000000 0011C7BD 5491670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 199.189.84.145
udp src 6448, dst 10442 len 100 checksum 0x0
00020000 03F82800 03800000 8A000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 45000078 00004000 39116DE5 670E5033 C7BD5491 193028CA
00640000 80008182 64816710 26224340 706D6970 767076F4
EF7678ED EFF6ECEC 000003F8 00000101 00000380 7AC7
40000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 21568, dst 8862 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 5440229E
00280000 80120F4A 1AE911E0 463E235C 7087E4AD B9E20600
FC91F85B 3E836922 000003F8 00000101 00000380 7AC6
58000400 03FB0000 01000000 4E000000 0011AE24 7CD3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.36.124.211
udp src 6446, dst 6222 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115F78 670E5033 AE247CD3 192E184E
00280000 80121C41 1AE911E0 5AE23F80 4CFB7F3A 714B14D7
2A5C72DB 60D629F3 000003F8 00000101 00000380 7AC7
60000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
udp src 37920, dst 8434 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA 942020F2
00280000 8012B64C 648166C0 27064264 49D297F1 3833EC56
AA9F0DAF D8367CA3 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.16.86
udp src 60198, dst 9862 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 EB262686
00280000 80128420 648166C0 258040E2 186055C7 1A999371
B2BD48E9 13947099 000003F8 00000101 00000380 7AC7
78000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 50094, dst 21710 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A C3AE54CE
00280000 8012E0C3 1AE911E0 1F1F7A7D 78029DF0 6A9B09EB
091A68A8 74DC20B2 000003F8 00000101 00000380 7AC6
88000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 54066, dst 9338 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B D332247A
00280000 80122F98 648166C0 26DA43B8 64B33ABD D71A5568
C3D43091 5312D6B2 000003F8 00000101 00000380 7AC6
90000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 15596, dst 28046 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 3CEC6D8E
00280000 801292DA 1AE911E0 0AE16F83 73F38E0C 775D337E
ADEB5FD8 0E41805E 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.188.66
udp src 22410, dst 6046 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 578A179E
00280000 801240FA 1AE911E0 368553E7 F67D83E2 84C56E05
1DA834D5 C3A64246 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
udp src 56702, dst 6522 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A DD7E197A
00280000 8012253E 648166C0 66D603B4 23C986A8 0FC7CEB2
6A8A26B2 85E4023F 000003F8 00000101 00000380 7AC7
F8000400 03FB0000 01000000 4E000000 0011ADF6 27C4670E 50330000 7F0A2000
udp src 33140, dst 3430 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B4B5 670E5033 ADF627C4 81740D66
00280000 80122C28 1AE911E0 09476C25 7C80991C 145A52FE
B4D852D5 1B37CF38 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
udp src 63712, dst 6166 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 F8E01816
00280000 80120DE7 648166C0 640B0169 DEB64321 84C32BE7
CF754496 03B91CA1 000003F8 00000101 00000380 7AC8
10000400 03FB0000 01000000 4E000000 00115C30 7F8B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 92.48.127.139
udp src 60552, dst 11258 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911AEB4 670E5033 5C307F8B EC882BFA
00280000 80122D31 1AE911E0 0B176E75 B0E6F665 819B0F49
E0967802 732C4893 000003F8 00000101 00000380 7AC6
udp src 55090, dst 52282 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 D732CC3A
00280000 80120F7C 1AE911E0 7F6B1A09 14F3448D D2DFDEAD
921CD43B 007EB952 000003F8 00000101 00000380 7AC7
48000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
udp src 33376, dst 7418 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 82601CFA
00280000 801215AD 648166C0 10BB75D9 B62324E4 823DEF09
64863672 3E404EC8 000003F8 00000101 00000380 7AC9
50000400 03FB0000 01000000 4E000000 00114005 3984670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.57.132
udp src 20790, dst 28678 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391110E7 670E5033 40053984 51367006
00280000 8012CCCC 1AE911E0 266B4309 78F7A1F0 47A3D002
379E1523 5C8AC0A2 000003F8 00000101 00000380 7AC9
58000400 03FB0000 01000000 4E000000 0011B2FF 2C83670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 178.255.44.131
udp src 58644, dst 6030 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911AAED 670E5033 B2FF2C83 E514178E
00280000 80122529 648166C0 27A442C6 74C27ABA 6F86D321
9D4878B7 664316A6 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 43200, dst 37826 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 A8C093C2
00280000 80128236 648166C0 13D876BA 69E0CBCF 786F1247
B97B2F52 4CF3FC90 000003F8 00000101 00000380 7AC8
78000400 03FB0000 01000000 4E000000 00114005 312C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.49.44
udp src 11582, dst 24520 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911193F 670E5033 4005312C 2D3E5FC8
00280000 80120F54 1AE911E0 32E05782 F327D6C9 1F83154F
2BCAF50B 0A248910 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
udp src 22178, dst 36914 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 56A29032
00B40000 8008111B 648166C0 3FA55AC7 D5D5D554 D5D5D5D4
D55454D5 D5D4D555 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 9540, dst 18962 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 25444A12
00280000 80120DE1 1AE911E0 6C440926 4573D057 9C68715C
723B2F22 50132677 000003F8 00000101 00000380 7AC5
A8000400 03FB0000 01000000 52000000 00114837 85F0670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.55.133.240
udp src 65340, dst 7602 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 80F00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 3911BC44 670E5033 483785F0 FF3C1DB2
002C0000 8004203E 648167B0 6569000B 505B5770 38E5409E
51AA6E87 00CB2EA2 000003F8 00000101 00000380 7AC7
B8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 50646, dst 14610 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C5D63912
00280000 801234F7 648166C0 4AE22F80 583AB32E 953A5B78
3014D412 736CAAB2 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 6552, dst 37986 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 19989462
00280000 80126D20 648166C0 4AAD2FCF 14467335 C7AA5154
C21472AB B1DE530E 000003F8 00000101 00000380 7AC9
D8000400 03FB0000 01000000 4E000000 00115BDD 9885670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 91.221.152.133
udp src 48434, dst 10074 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911960D 670E5033 5BDD9885 BD32275A
00280000 801205AE 1AE911E0 0CFA6998 785240A0 00FAC200
07D67812 80A000FA 000003F8 00000101 00000380 7AC8
udp src 16838, dst 44246 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 41C6ACD6
00280000 801208A1 648166C0 67A202C0 753B5C06 04EA594E
2252606F 4E8B3572 000003F8 00000101 00000380 7AC7
udp src 52654, dst 25490 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 CDAE6392
00280000 80121495 1AE911E0 5F533A31 42F2D3C4 53334FA9
835F78BA 76291962 000003F8 00000101 00000380 7AC6
F0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 50788, dst 35674 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C6648B5A
00280000 8012025C 648166C0 62E70785 78A800A0 00FAC200
07D67852 C0A000FA 000003F8 00000101 00000380 7AC7
F8000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 54196, dst 10942 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 D3B42ABE
00280000 801224DE 1AE911E0 564F332D 75AFF280 20E25728
0EDBF828 1C4E6C22 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x6A(106)
28000400 03FB0000 01000000 6A000000 001155C3 5BD2670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 88, identifier 0
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.195.91.210
udp src 47298, dst 11154 len 68 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x6A(106)
00020000 03F82800 03800000 6A000000 00110000 10D00000 50330000 7F0A2000
layer 3 data: 45000058 00004000 3911D8BE 670E5033 55C35BD2 B8C22B92
00440000 80046E00 64816620 4F1D2A7F 08649065 D4C49B63
A2BC49CA 2C501E88 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 60162, dst 9562 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 EB02255A
00280000 80120894 64813790 189A7DF8 050C4D97 A8B31127
341E2D22 4E4BDFA3 000003F8 00000101 00000380 7AC9
40000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 18824, dst 27314 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 49886AB2
00280000 80120830 64813790 589A3DF8 97428B14 813591E1
0F68973A CC74BB75 000003F8 00000101 00000380 7AC8
58000400 03FB0000 01000000 4E000000 0011C64A 670A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.103.10
udp src 37220, dst 6582 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115D1B 670E5033 C64A670A 916419B6
00280000 801219BA 64813790 17447226 6CD2BECE 9D5F581C
E6F02EBF 7FB9F88A 000003F8 00000101 00000380 7AC7
68000400 03FB0000 01000000 4E000000 00114447 32F1670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.50.241
udp src 16926, dst 11006 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111338 670E5033 444732F1 421E2AFE
00280000 8012360C 64813790 6219077B 525DE473 D9FE1258
39921459 79790550 000003F8 00000101 00000380 7AC8
70000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
udp src 46346, dst 9170 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 B50A23D2
00280000 8012178F 64813790 2E254B47 521072CD 77C28B8A
811E60E7 58FEA573 000003F8 00000101 00000380 7AC6
78000400 03FB0000 01000000 4E000000 0011D12C 7A03670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.122.3
udp src 48284, dst 6450 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113F40 670E5033 D12C7A03 BC9C1932
00280000 80128D55 64813790 127A7718 75FA3843 538E11C4
E54064A0 3D9284C3 000003F8 00000101 00000380 7AC6
80000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
udp src 8978, dst 54146 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 2312D382
00B40000 80084854 64813790 5E423B20 D5D5D5D5 D5D5D5D5
D5D5D5D5 D7D5D4D5 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 00116DEC 5620670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 109.236.86.32
udp src 18966, dst 7610 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911C663 670E5033 6DEC5620 4A161DBA
00280000 8012318E 64813790 34775115 BD7E74D9 2F9485DF
298A3D22 9D25EE95 000003F8 00000101 00000380 7AC6
90000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.42.232
udp src 13072, dst 8174 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 33101FEE
00280000 801235F8 64813790 7F691A0B 00E7A821 B8221B18
E79EF298 0F3E8D38 000003F8 00000101 00000380 7AC6
udp src 38022, dst 13898 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 9486364A
00280000 80120ACE 64813790 6EA60BC4 6B734CB2 F8E93281
F8886173 0CE59739 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 41020, dst 9526 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 A03C2536
00280000 80120E0C 64813790 6DD908BB 782B7288 3A0A54A7
919A04E1 7BD85B32 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 9420, dst 38592 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 24CC96C0
00280000 801218B6 64813790 2B694E0B 780DD8A1 51420D52
DE1B7068 3798EF5E 000003F8 00000101 00000380 7AC5
10000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.98
udp src 60342, dst 11298 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 EBB62C22
00280000 80122B68 4106CD30 031C667E 0D3B5234 798BD1BE
14BF1851 11A7C00E 000003F8 00000101 00000380 7AC5
18000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 45338, dst 25968 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 B11A6570
00280000 8012B310 4106CD30 469523F7 30CFB7C4 C73A9215
6E569A7C 0973AD66 000003F8 00000101 00000380 7AC6
20000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.210
udp src 51580, dst 6458 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 C97C193A
00280000 80128D6A 4106CD30 28E14D83 1422AE7D D1AB5B89
1E52F8F8 FED4DC4B 000003F8 00000101 00000380 7AC7
28000400 03FB0000 01000000 52000000 00114A3F DBA2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.63.219.162
udp src 8166, dst 6758 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 90A00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 3911648A 670E5033 4A3FDBA2 1FE61A66
002C0000 80044CCF 4106CE20 16F57397 008C5533 2B006BB1
031D50F0 B0CF8241 000003F8 00000101 00000380 7AC8
30000400 03FB0000 01000000 4E000000 0011C694 7EAA670E 50330000 7F0A2000
udp src 10296, dst 6034 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114531 670E5033 C6947EAA 28381792
00280000 80126ED4 4106CD30 575B3239 F68BE69B A37AB1C4
4B7335A7 F49EC36A 000003F8 00000101 00000380 7AC5
38000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
udp src 29124, dst 11646 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 71C42D7E
00280000 801209A8 4106CD30 32A057C2 7A08F633 8E8281E7
F09078E3 A2623BD3 000003F8 00000101 00000380 7AC8
50000400 03FB0000 01000000 4E000000 0011D5E5 4ED2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 213.229.78.210
udp src 12098, dst 7186 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391165B8 670E5033 D5E54ED2 2F421C12
00280000 80122F5F 4106CD30 554B3029 DFD94C6B 87E77195
C90FC365 0CA072E1 000003F8 00000101 00000380 7AC8
60000400 03FB0000 01000000 4E000000 00114298 BD82670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.189.130
udp src 21324, dst 9166 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118A55 670E5033 4298BD82 534C23CE
00280000 80127C99 4106CD30 5F423A20 72EAD015 6B1353DE
431EF828 CCBA4C5A 000003F8 00000101 00000380 7AC5
70000400 03FB0000 01000000 4E000000 0011BC8A 0B8F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.11.143
udp src 64062, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911C256 670E5033 BC8A0B8F FA3E2A62
00280000 80128454 4106CD30 6D360854 30637D01 D11A926C
4C927257 E0C0A25A 000003F8 00000101 00000380 7AC8
80000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 10794, dst 52050 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 2A2ACB52
00280000 8012075F 84855070 3E145B76 4583526A 3408B258
37952AF7 92A49827 000003F8 00000101 00000380 7AC7
udp src 32914, dst 50154 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 8092C3EA
00280000 80123978 4106CD30 6B810EE3 6D4B9F0F D35EF015
75712BF3 5F06E08B 000003F8 00000101 00000380 7AC6
udp src 7238, dst 49578 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 1C46C1AA
00280000 80123149 84855070 76651307 78CA546A FD520F39
DA927923 2F0CBB02 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 4E000000 00114298 B722670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.183.34
udp src 23546, dst 7462 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391190B5 670E5033 4298B722 5BFA1D26
00280000 801234AF 84855070 20C545A7 6374D01E 6D6C30E1
C08F62DE D011F3FF 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
udp src 17460, dst 7342 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 44341CAE
00280000 80128AB3 4106CD30 619D04FF 10E7DCCF 4568DB82
A11E68F2 E3D035AA 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 0011642A 4B85670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.75.133
udp src 56380, dst 6154 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911DAC0 670E5033 642A4B85 DC3C180A
00280000 80128148 4106CD30 319C54FE 53B44D12 DE2B95E8
32DC403C 9E3418B9 000003F8 00000101 00000380 7AC6
B8000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 39326, dst 30246 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 999E7626
00280000 8012F6D1 848550C0 073A6258 603283FF 073B0A6D
5CD47C46 F2838542 000003F8 00000101 00000380 7AC5
C0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 63136, dst 8110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 F6A01FAE
00280000 80123D69 4106CD30 1528704A 0533FE96 A0AB10EC
CB580CBB 6F925362 000003F8 00000101 00000380 7AC7
udp src 11986, dst 37944 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 2ED29438
00280000 80120ECE 848550C0 30135571 D85B4A35 2C83C83E
8CD87857 6761964A 000003F8 00000101 00000380 7AC7
D8000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 38762, dst 24112 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 976A5E30
00280000 8012827F 4106CD30 679D02FF 084A4746 A671557E
41372F26 4923EC6B 000003F8 00000101 00000380 7AC8
E0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
udp src 26146, dst 9282 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 66222442
00280000 80121329 848550C0 07AC62CE 75750CF3 88A8C420
8498740B CB5D26D9 000003F8 00000101 00000380 7AC6
E8000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.195.204
udp src 10428, dst 6318 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 28BC18AE
00280000 8012394B 4106CD30 6D2B0849 235B5E20 B5320E6C
45CE05DB E162C7A9 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 0011D12C 7A03670E 50330000 7F0A2000
udp src 45634, dst 6790 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113F40 670E5033 D12C7A03 B2421A86
00280000 8012810D 84855070 108575E7 F813D22D 173251BF
D29E308F 55CAA8CA 000003F8 00000101 00000380 7AC6
F8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 59226, dst 30898 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 E75A78B2
00280000 8012264F 4106CD30 70511533 0EA90B10 B7DE2C87
32E98A58 892F9E56 000003F8 00000101 00000380 7AC6
18000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 202.95.120.13
udp src 6578, dst 17964 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 19B2462C
002C0000 8004498D 4106CDD0 6A960FF4 5CE66CB6 C00826E6
2F796AB5 86CC85F0 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 00114298 A214670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.162.20
udp src 44094, dst 6606 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911A5C3 670E5033 4298A214 AC3E19CE
00280000 80120DD4 848550C0 25B040D2 655346FD C12B15D2
679ED8F2 9E6F354B 000003F8 00000101 00000380 7AC6
40000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
udp src 46254, dst 50782 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 B4AEC65E
00B40000 80086284 848550C0 3CC859AA 54545754 5754D5D5
D5D7D655 54555454 000003F8 00000101 00000380 7AC9
50000400 03FB0000 01000000 4E000000 0011CDCC 43C9670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.67.201
udp src 40818, dst 10790 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391178DA 670E5033 CDCC43C9 9F722A26
00280000 80123624 848550C0 5639335B 7505BCAF 3FBB1E35
F052F838 24341842 000003F8 00000101 00000380 7AC6
58000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
udp src 60926, dst 9226 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 EDFE240A
00280000 8012026C 848550C0 541F317D 79CB7744 AF39D04E
E2DE66C6 DBE20CA3 000003F8 00000101 00000380 7AC7
60000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 13564, dst 8686 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 34FC21EE
00280000 8012C30A 848550C0 19E87C8A 74BAC786 729A9248
8C58600B 7F25A182 000003F8 00000101 00000380 7AC6
68000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 35632, dst 55884 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 8B30DA4C
00280000 80125A5F 848550C0 22EB4789 63EB09A2 8F68F002
BDF3C311 8844113C 000003F8 00000101 00000380 7AC6
88000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 21836, dst 6922 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 554C1B0A
00280000 8012D0E0 84855070 724C172E 75E2FB81 EE0A513F
3452140A F57F45AA 000003F8 00000101 00000380 7AC7
A0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 55240, dst 9506 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 D7C82522
00280000 80121024 84855070 4E9D2BFF 706BAE3D 953EC50E
6F1EF8F2 E50076D8 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
udp src 48896, dst 7894 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 BF001ED6
00280000 80126BA1 848550C0 2F974AF5 F88E9308 CE32127E
CC107842 F80F999B 000003F8 00000101 00000380 7AC8
udp src 65030, dst 11710 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 FE062DBE
00280000 8012024E 848550C0 013C645E F2E3415B 21420E93
4313F88F A958AC52 000003F8 00000101 00000380 7AC5
28000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 59046, dst 55950 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 E6A6DA8E
00640000 8008F7BB 64816710 5F333A51 55D45555 D555D4D4
54D45555 5454D556 000003F8 00000101 00000380 7AC7
38000400 03FB0000 01000000 4E000000 00114298 AC3A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.172.58
udp src 59750, dst 6078 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119B9D 670E5033 4298AC3A E96617BE
00280000 80123623 648166C0 630F066D F0029996 8A821334
CC5375A8 73EACA13 000003F8 00000101 00000380 7AC8
48000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 20258, dst 38744 len 40 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 4F229758
00280000 8012023E 648166C0 7EC51BA7 4D308CE2 F86DD23F
2F384DEA 4D4D3331 000003F8 00000101 00000380 7AC8
------- dump of incoming inband packet -------
50000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 43168, dst 11110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 A8A02B66
00280000 8012C8B3 648166C0 18AC7DCE B07A8627 514B102E
271EE073 0849B45B 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
58000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
udp src 13620, dst 9226 len 40 checksum 0x0
------- dump of outgoing inband packet -------
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 3534240A
00280000 80126521 648166C0 348E51EC F5E8D69C 4792EECD
38D8F853 E2BF189A 000003F8 00000101 00000380 7AC7
60000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 57620, dst 11730 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 E1142DD2
00280000 80122237 648166C0 7018157A F85BEC12 02B25EE2
8A5802E0 32DF1E5A 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 4E000000 001143D4 5A3D670E 50330000 7F0A2000
udp src 8262, dst 7666 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC5E 670E5033 43D45A3D 20461DF2
00280000 80123AB0 648166C0 39F05C92 72F3B48C F383CED3
AB9E587E 33E99F62 000003F8 00000101 00000380 7AC8
78000400 03FB0000 01000000 6A000000 0011BC8A 30BD670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.48.189
udp src 54550, dst 6970 len 68 checksum 0x0
00020000 03F82800 03800000 6A000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 45000058 00004000 39119D0C 670E5033 BC8A30BD D5161B3A
00440000 80044335 64816620 1B6D7E0F 448AC93A F5583984
C1A86420 74024332 000003F8 00000101 00000380 7AC7
B0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 65052, dst 14450 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 FE1C3872
00280000 801237BD 648166C0 7E181B7A FC1A8ED8 47B9CD4A
5318647B 3CB97D82 000003F8 00000101 00000380 7AC5
udp src 63358, dst 28938 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F77E710A
00640000 80084A18 64816710 04406122 D5D555D4 D5D4D7D5
D4D45451 51575555 000003F8 00000101 00000380 7AC6
udp src 54110, dst 51136 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 D35EC7C0
00280000 8012110C 648166C0 2B094E6B 089769D2 180BD4DB
785E601B 8C728036 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
udp src 21320, dst 6674 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A 53481A12
00280000 80121D91 648166C0 5B053E67 44B0E91C BF129604
549040CB D3D19178 000003F8 00000101 00000380 7AC8
D8000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 18064, dst 11250 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 46902BF2
00280000 80123506 648166C0 418424E6 5BF34A2D 815234CF
8B180EF3 CAA9C7B2 000003F8 00000101 00000380 7AC9
E8000400 03FB0000 01000000 4E000000 00114005 312C670E 50330000 7F0A2000
udp src 63666, dst 17448 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911193F 670E5033 4005312C F8B24428
00280000 80127C27 648166C0 78681D0A 787EBD5E E248C984
895EF8E8 F70D9B9B 000003F8 00000101 00000380 7AC5
F0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.51
udp src 8868, dst 59380 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 22A4E7F4
00280000 80126580 1AE911E0 0D8568E7 14FB040C 44E2132C
0252F963 9139D19B 000003F8 00000101 00000380 7AC5
F8000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.41.250
udp src 30928, dst 11182 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 78D02BAE
00280000 80121332 648166C0 4DA828CA 762284CB CCA28294
B7583866 C52A77FA 000003F8 00000101 00000380 7AC6
08000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
udp src 40276, dst 19434 len 44 checksum 0x0
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 9D544BEA
002C0000 8004019A 1AE91230 07DE62BC 9422A024 1C2C7E6A
81A88A02 BAE6B727 000003F8 00000101 00000380 7AC7
28000400 03FB0000 01000000 4E000000 00116CA6 C14B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.193.75
udp src 18646, dst 8466 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115C7E 670E5033 6CA6C14B 48D62112
00280000 80120045 1AE911E0 7BD91EBB 60FA682C A18B5409
C7907512 AA0FAF72 000003F8 00000101 00000380 7AC9
48000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
udp src 50774, dst 8830 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D C656227E
00280000 80129546 648166C0 046E610C 2396C674 D0D3EFDC
509169BE 46229763 000003F8 00000101 00000380 7AC9
58000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 64118, dst 60150 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 FA76EAF6
00280000 80122A25 1AE911E0 3F215A43 7246F205 296A5D6A
EE9A405D BA2A1202 000003F8 00000101 00000380 7AC7
70000400 03FB0000 01000000 4E000000 00114298 A8BA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.186
udp src 53478, dst 11026 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119F1D 670E5033 4298A8BA D0E62B12
00280000 80124B5B 64813790 65A000C2 58A9F886 9231EE6C
C2977018 E5DF148A 000003F8 00000101 00000380 7AC9
78000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.47
udp src 12962, dst 6078 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F 32A217BE
00280000 8012498A 64813790 18177D75 13AEC491 B4C1B010
953B2C9D 8412C587 000003F8 00000101 00000380 7AC6
90000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 45652, dst 10258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 B2542812
00280000 80122829 64813790 0128644A 727BF0FE 5899CF4B
64D214D3 B788DA58 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
udp src 63768, dst 8722 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 F9182212
00280000 80123A30 64813790 14A271C0 6DAB4248 756BEA2E
EE57A723 42468D38 000003F8 00000101 00000380 7AC7
B8000400 03FB0000 01000000 8A000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 34266, dst 12278 len 100 checksum 0x0
00020000 03F82800 03800000 8A000000 00110000 20500000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911921B 670E5033 D1BE265A 85DA2FF6
00640000 800854A5 648137E0 5249372B B1BFB8BF B18D9561
01343637 3703134F 000003F8 00000101 00000380 7AC7
C0000400 03FB0000 01000000 4E000000 0011D1A0 219D670E 50330000 7F0A2000
udp src 35918, dst 14350 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119732 670E5033 D1A0219D 8C4E380E
00280000 8012F4E8 64813790 31375455 615F5866 67D312C0
E9CB11D8 1832B053 000003F8 00000101 00000380 7AC8
E0000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
udp src 38388, dst 39762 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 95F49B52
00B40000 80081271 64813790 3FFB5A99 F1E4E4F0 C0C6DF5F
43465B58 5F52D7C9 000003F8 00000101 00000380 7AC7
E8000400 03FB0000 01000000 52000000 00114022 B036670E 50330000 7F0A2000
udp src 35530, dst 16458 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 45000040 00004000 39119A13 670E5033 4022B036 8ACA404A
002C0000 80042A05 648137E0 6548002A B05F530B 496BCF4E
700FAE26 4A428599 000003F8 00000101 00000380 7AC6
F0000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 26134, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 66162A62
00280000 80122491 64813790 77661204 765AF24F BE225E8A
A2C03E73 45A519CB 000003F8 00000101 00000380 7AC7
08000400 03FB0000 01000000 4E000000 0011602B 5342670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 96.43.83.66
udp src 50184, dst 6042 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911D702 670E5033 602B5342 C408179A
00280000 80124520 64813790 7FB41AD6 29D38C37 B0573294
89E3B360 8C27E3B1 000003F8 00000101 00000380 7AC6
20000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.40.105
udp src 12308, dst 24904 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 30146148
00280000 80121325 64813790 654A0028 E423D479 D7725018
251EB5C7 7538C7E8 000003F8 00000101 00000380 7AC5
30000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 21678, dst 17834 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 54AE45AA
00280000 80129B15 64813790 3308566A 4272B9E6 D0B29788
B152E0E0 7FE4ECBA 000003F8 00000101 00000380 7AC6
40000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 61868, dst 51956 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 F1ACCAF4
00280000 80121D29 64813790 2FFE4A9C 78E7FCB4 039B07B4
83525291 43F8AF6A 000003F8 00000101 00000380 7AC8
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.43
udp src 54928, dst 9982 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B D69026FE
00280000 80122095 64813790 43FD269F 2EA36223 0F6E3300
14D43094 A16BBBBB 000003F8 00000101 00000380 7AC8
58000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 44188, dst 32618 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A AC9C7F6A
00280000 8012FEBA 64813790 2C8E49EC 009B8840 FA925016
9390F8BB 654CDCA2 000003F8 00000101 00000380 7AC7
68000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
udp src 38842, dst 6326 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 97BA18B6
00280000 80121CEE 64813790 0A616F03 0ADB0C6F 2833F002
D2C1491A 8B481E50 000003F8 00000101 00000380 7AC5
78000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
udp src 45682, dst 8782 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 B272224E
00280000 8012391C 64813790 2F364A54 72BDF328 C0088B04
C94C14B0 F19BD066 000003F8 00000101 00000380 7AC6
80000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
udp src 57310, dst 10338 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F DFDE2862
00280000 8012A02E 64813790 3A955FF7 5AFBF92C 29334802
19701C5F FAAECE22 000003F8 00000101 00000380 7AC8
90000400 03FB0000 01000000 4E000000 0011C64A 62DA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.98.218
udp src 55394, dst 6274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911614B 670E5033 C64A62DA D8621882
00280000 8012289C 64813790 54A731C5 782757A0 B8D29481
7F1078D3 B524AC02 000003F8 00000101 00000380 7AC8
udp src 24990, dst 37306 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 619E91BA
00280000 80122770 64813790 59693C0B 787261A6 1CEB46BC
F0D4513B 7DCCFF8B 000003F8 00000101 00000380 7AC6
A8000400 03FB0000 01000000 4E000000 0011C64A 632A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.99.42
udp src 16086, dst 9962 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391160FB 670E5033 C64A632A 3ED626EA
00280000 80127914 64813790 7B801EE2 49BB51B0 1C682FA9
D511615B D132CFAC 000003F8 00000101 00000380 7AC6
C8000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.25
udp src 39056, dst 9634 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 989025A2
00280000 80120489 64813790 568E33EC 782B6B60 00FAC200
07D678FE AB6000FA 000003F8 00000101 00000380 7AC8
D0000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 25696, dst 11582 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 64602D3E
00280000 8012031C 64813790 32E8578A 306A66C3 46534B01
FE1E719A E76669D3 000003F8 00000101 00000380 7AC7
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.105
udp src 34464, dst 9922 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 86A026C2
00280000 80124489 64813790 66560334 331009B4 2BC11008
32BB555A 096A013C 000003F8 00000101 00000380 7AC5
E0000400 03FB0000 01000000 4E000000 00116CA6 C0DC670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.192.220
udp src 16590, dst 10698 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115CED 670E5033 6CA6C0DC 40CE29CA
00280000 80124DC1 64813790 6BF30E91 D9BB47C9 B8620240
F091407A AAC51108 000003F8 00000101 00000380 7AC9
F0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.228.3.77
udp src 27426, dst 36642 len 40 checksum 0x0
interface Gi5/2, routine naboo_fastsend, timestamp 06:30:06.856
00020000 03F82800 03800000 4E000000 00110000 00400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 6B228F22
00280000 80125556 64813790 31745416 783B99DA 2C08CC1D
8BDA407B F80FFA3A 000003F8 00000101 00000380 7AC7
interface Gi5/1, routine process_rx_packet_inline, timestamp 06:30:06.856
30000400 03FB0000 01000000 4E000000 0011CDCC 518F670E 50330000 7F0A2000
udp src 51212, dst 11106 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116B14 670E5033 CDCC518F C80C2B62
00280000 8012183A 4106CD30 2D014863 70A35FCE 4E58D167
E6587847 FE9C641A 000003F8 00000101 00000380 7AC8
40000400 03FB0000 01000000 4E000000 0011D040 E513670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 208.64.229.19
udp src 54240, dst 8542 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911D51B 670E5033 D040E513 D3E0215E
00280000 80124CC3 4106CD30 18FA7D98 757F4481 C8E9D304
F3547273 B7D972BA 000003F8 00000101 00000380 7AC7
48000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
udp src 50826, dst 6430 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 C68A191E
00280000 80129166 4106CD30 18B67DD4 8A904841 66D0AFB4
02655BB0 C5E428C1 000003F8 00000101 00000380 7AC7
50000400 03FB0000 01000000 4E000000 0011C64A 6192670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.146
udp src 10186, dst 9110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116293 670E5033 C64A6192 27CA2396
00280000 801245E6 848550C0 5E093B6B 6873DA98 61DA49F3
6B54301A 9B7DD722 000003F8 00000101 00000380 7AC7
58000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.57.246
udp src 24152, dst 8786 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 5E582252
00280000 80126A04 848550C0 33075665 1A72D6D6 68BF120E
E2F91AF8 D6520B9D 000003F8 00000101 00000380 7AC8
60000400 03FB0000 01000000 4E000000 00114A37 710C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.55.113.12
udp src 63834, dst 10138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911CF2C 670E5033 4A37710C F95A279A
00280000 80129140 848550C0 168473E6 58EAB6A3 AE1A94DB
4758F833 9B2BD402 000003F8 00000101 00000380 7AC8
68000400 03FB0000 01000000 4E000000 0011BC8A 30BD670E 50330000 7F0A2000
udp src 11882, dst 7130 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119D28 670E5033 BC8A30BD 2E6A1BDA
00280000 801277C4 848550C0 3E0A5B68 86A3CB51 BDAD8952
45D3BEAB C9A0BA03 000003F8 00000101 00000380 7AC8
70000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 29272, dst 41458 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 7258A1F2
00640000 80088BDD 84855110 1259773B D15554D5 54545757
5757D554 55D4D6D6 000003F8 00000101 00000380 7AC7
78000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
udp src 17960, dst 7714 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 46281E22
00280000 80125361 848550C0 30FE559C 3327A4F3 87C6BB52
05263E7B E5D5B111 000003F8 00000101 00000380 7AC9
80000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.176.247
udp src 48946, dst 10654 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 BF32299E
00280000 80121B5D 848550C0 19A87CCA BE955083 9B11131F
4498DE00 916DC4E7 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 0011BC8A 68D3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.104.211
udp src 53876, dst 6002 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116512 670E5033 BC8A68D3 D2741772
00280000 801211EE 848550C0 2A5E4F3C 75C3D30C A6D9F226
815C3567 BD0C414A 000003F8 00000101 00000380 7AC5
90000400 03FB0000 01000000 4E000000 00114076 5517670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.118.85.23
udp src 10962, dst 8614 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F4E2 670E5033 40765517 2AD221A6
00280000 80121CAC 848550C0 14627100 4DE3D59B 925954DA
5AC0617B 8E057FE3 000003F8 00000101 00000380 7AC5
98000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.72.26
udp src 53514, dst 7214 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A D10A1C2E
00280000 8012035C 848550C0 3DFE589C 781340A0 00FAC200
07D678AE 80A000FA 000003F8 00000101 00000380 7AC7
A0000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.73.69
udp src 51682, dst 6618 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 C9E219DA
00280000 801228BE 848550C0 36535331 74737673 E3D9D7CA
B3125CB7 C403492B 000003F8 00000101 00000380 7AC6
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.226
udp src 28308, dst 8658 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 6E9421D2
00280000 8012C98B 848550C0 30415523 C6E3D5D6 D7E71262
B7883752 95D7AB06 000003F8 00000101 00000380 7AC6
C8000400 03FB0000 01000000 4E000000 00116CA6 C78A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.138
udp src 56182, dst 7174 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911563F 670E5033 6CA6C78A DB761C06
00280000 80120323 648166C0 4D462824 79C0C32A DE680B0D
471B4221 02CF1338 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 0011CC0D 9992670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 204.13.153.146
udp src 10836, dst 6134 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391124D0 670E5033 CC0D9992 2A5417F6
00280000 80125045 648166C0 669E03FC DCDB488B 4782D7B4
874B78A7 6B344C52 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 00114E81 B22E670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.178.46
udp src 12658, dst 6270 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391189C0 670E5033 4E81B22E 3172187E
00280000 80121D28 648166C0 2FA94ACB EA74CCFA 08FF5571
73024AD6 CBCAD558 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 0011AE88 248B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.36.139
udp src 61866, dst 31030 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B75C 670E5033 AE88248B F1AA7936
00280000 80120A68 648166C0 1CD579B7 30D4CE58 582B112E
569078CB 49FA432A 000003F8 00000101 00000380 7AC7
10000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 40082, dst 46176 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 9C92B460
00280000 80120FCC 648166C0 25704012 BED0DEEC D384CA65
54E43834 80F975BD 000003F8 00000101 00000380 7AC6
18000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 15756, dst 39492 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 3D8C9A44
00280000 80127C7D 648166C0 74EE118C 787ACA37 65825ABB
6E9E5233 E343FA4E 000003F8 00000101 00000380 7AC7
20000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
udp src 33246, dst 6234 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 81DE185A
00280000 80123C68 648166C0 3C235941 72F4EA51 5AA8DB24
9A126473 4FAC08DB 000003F8 00000101 00000380 7AC6
28000400 03FB0000 01000000 4E000000 00115519 B829670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.184.41
udp src 43978, dst 10562 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39117D2D 670E5033 5519B829 ABCA2942
00280000 80120315 648166C0 24F64194 0E6F28A2 BBA19C6C
503C4E10 FFEF01DC 000003F8 00000101 00000380 7AC9
38000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 19854, dst 60222 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 4D8EEB3E
00280000 80121E4A 648166C0 39575C35 87CA893D 9E524E62
7558AB72 8A75B415 000003F8 00000101 00000380 7AC9
40000400 03FB0000 01000000 4E000000 0011400F 4767670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.15.71.103
udp src 49740, dst 10110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391102FA 670E5033 400F4767 C24C277E
00280000 8012286D 648166C0 28234D41 31A314EC D0E254A3
38C04CFE EBE27669 000003F8 00000101 00000380 7AC7
50000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 7342, dst 64874 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 1CAEFD6A
00280000 80124A4B 648166C0 78801DE2 F8EAE60B 84CFC3E2
D952746B 793E3E9B 000003F8 00000101 00000380 7AC6
udp src 64218, dst 8538 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 FADA215A
00280000 80121DE0 648166C0 2E164B74 12ABFC77 F0D29BD1
CC9A540B 6EFCE77B 000003F8 00000101 00000380 7AC8
udp src 47544, dst 9322 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 B9B8246A
00280000 80123146 648166C0 55503032 70D2F53C F868D35C
361E3662 CB126403 000003F8 00000101 00000380 7AC8
70000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.95.18
udp src 11412, dst 6534 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 2C941986
00280000 801201A3 648166C0 680D0D6F 78AA40A0 00FAC200
07D6787A 80A000FA 000003F8 00000101 00000380 7AC7
88000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
udp src 63468, dst 8334 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 F7EC208E
00280000 80121FD9 648166C0 018C64EE D235BAE4 1F8B076B
00D8F83A 8062BCC2 000003F8 00000101 00000380 7AC5
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.34.176.54
udp src 46492, dst 16074 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 B59C3ECA
00280000 8012C548 1AE911E0 46142376 2EAC91AD 0C5971EA
641F2E9D D1A7B8AF 000003F8 00000101 00000380 7AC8
98000400 03FB0000 01000000 4E000000 00114A3F DBA2670E 50330000 7F0A2000
udp src 28918, dst 6306 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90A00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911648E 670E5033 4A3FDBA2 70F618A2
00280000 801261E8 648166C0 32E9578B 0469F1DD 0BA38E6B
809251BB E913DCCA 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 00114005 20D7670E 50330000 7F0A2000
udp src 40832, dst 16862 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39112994 670E5033 400520D7 9F8041DE
00280000 801234B6 648166C0 4F1F2A7D 70DAABFB 942B5482
CD1030A8 3374C01B 000003F8 00000101 00000380 7AC8
B0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
udp src 35560, dst 8706 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 8AE82202
00280000 80123235 1AE911E0 11FF749D 0C22EA4C FBE3F35B
D19C95A2 884D3092 000003F8 00000101 00000380 7AC6
B8000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.30.35.41
udp src 44392, dst 6066 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 AD6817B2
00280000 80123FBF 648166C0 6BC90EAB 09A6CDC8 785D4D47
F5E167B3 CD4533D3 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0xDA(218)
C8000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 200, identifier 0
udp src 36644, dst 55712 len 180 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0xDA(218)
00020000 03F82800 03800000 DA000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 8F24D9A0
00B40000 800815AD 648166C0 2C19497B 253A330B 149481B4
B0BFB9B0 8EE61C00 000003F8 00000101 00000380 7AC6
D0000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.46.152
udp src 16530, dst 9254 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 40922426
00280000 80120261 1AE911E0 4DE62884 78136B60 00FAC200
07D6783E AB6000FA 000003F8 00000101 00000380 7AC7
D8000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
udp src 22546, dst 10974 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 58122ADE
00280000 80120FF7 1AE91230 70551537 7858D133 BE3A4DB5
DF105C33 538BAB32 000003F8 00000101 00000380 7AC8
F0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 37584, dst 8810 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 92D0226A
00280000 8012A4AF 1AE911E0 638A06E8 149AF6E2 3802497A
7D58F203 A95217A3 000003F8 00000101 00000380 7AC9
28000400 03FB0000 01000000 4E000000 0011482C 44F3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.68.243
udp src 47066, dst 6254 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FD50 670E5033 482C44F3 B7DA186E
00280000 801209CF 1AE91230 01EF648D 78AB28BE D652962C
9958F256 CFBCCA7A 000003F8 00000101 00000380 7AC7
38000400 03FB0000 01000000 4E000000 0011D818 F34A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 216.24.243.74
udp src 16350, dst 7438 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BF0C 670E5033 D818F34A 3FDE1D0E
00280000 80129419 648166C0 070B6269 60DA6052 757292E3
D4D4405B BAB8464A 000003F8 00000101 00000380 7AC8
48000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 21450, dst 50226 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 53CAC432
00280000 801252AA 1AE91230 1F9E7AFC 7CA57570 06684E2C
7E74F43F 59C43A98 000003F8 00000101 00000380 7AC7
50000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 49638, dst 6286 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 C1E6188E
00280000 80122096 648166C0 090E6C6C 7BE18D5A 3358B198
F285557C 0D85C821 000003F8 00000101 00000380 7AC8
60000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 31476, dst 26282 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 7AF466AA
00280000 80125E76 1AE91230 2B294E4B 5C427525 F523D039
D9467492 CAF8A58B 000003F8 00000101 00000380 7AC9
68000400 03FB0000 01000000 4E000000 00117751 0565670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 119.81.5.101
udp src 23346, dst 8458 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39110DBA 670E5033 77510565 5B32210A
00280000 801285FB 648166C0 258A40E8 54F2C89E 2CEB0640
F55472CA 9E741D1A 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 41500, dst 33526 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D A21C82F6
00280000 80121DCD 648166C0 68CE0DAC 6D5852E3 48FB4D64
AA4779C2 D2AE2E72 000003F8 00000101 00000380 7AC6
80000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 38514, dst 8498 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 96722132
00280000 80121C95 1AE91230 0A9B6FF9 32AFFE58 9C624130
CA9238F0 11B2008A 000003F8 00000101 00000380 7AC8
udp src 23350, dst 10982 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 5B362AE6
00280000 80122047 648166C0 6E180B7A 57800B58 3D8CF200
39FD35D3 0B5D989E 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x8A(138)
90000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 120, identifier 0
udp src 15492, dst 22956 len 100 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x8A(138)
00020000 03F82800 03800000 8A000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 3C8459AC
00640000 8008DB15 1AE91280 5F373A55 54D4D457 54D7D756
57D7D657 51D5D1D5 000003F8 00000101 00000380 7AC5
98000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 58936, dst 9706 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA E63825EA
00280000 80125752 648166C0 21144476 F83375A7 43620D0A
7A9B789B F3B7E1CA 000003F8 00000101 00000380 7AC6
A0000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 56108, dst 11302 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 DB2C2C26
00280000 80123289 1AE91230 29D54CB7 1502D655 E17814BA
A61E747E D9474159 000003F8 00000101 00000380 7AC6
A8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 26596, dst 19068 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 67E44A7C
00640000 80083039 1AE91280 62C607A4 116971D1 DF52465D
476476EB 878D8196 000003F8 00000101 00000380 7AC8
C0000400 03FB0000 01000000 4E000000 0011D1BE 1DD2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.29.210
udp src 29166, dst 6714 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119ADF 670E5033 D1BE1DD2 71EE1A3A
00280000 80128326 648166C0 608D05EF 7CA2818D 3F720C83
061A6472 64A66942 000003F8 00000101 00000380 7AC6
E0000400 03FB0000 01000000 4E000000 0011C694 6B6A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.107.106
udp src 15044, dst 9182 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115871 670E5033 C6946B6A 3AC423DE
00280000 80126A26 1AE911E0 4D8728E5 A8D16989 18D9D677
EC123ADE 5831687A 000003F8 00000101 00000380 7AC6
E8000400 03FB0000 01000000 4E000000 0011400F 443D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.15.68.61
udp src 25976, dst 11754 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39110624 670E5033 400F443D 65782DEA
00280000 8012040F 648166C0 046B6109 0DB2CCA1 15C92F84
CED302F3 CC29037F 000003F8 00000101 00000380 7AC8
F0000400 03FB0000 01000000 4E000000 00114624 600C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.36.96.12
udp src 9670, dst 10862 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E43F 670E5033 4624600C 25C62A6E
00280000 80120016 1AE91230 1F487A2A 0DBA46AA 073F15C0
167C68AB C8CB31E2 000003F8 00000101 00000380 7AC5
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 184.170.135.50
udp src 31652, dst 8622 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 7BA421AE
00280000 80120D06 648166C0 0D2F684D 68729FC5 E5E0523F
8648126E A00A5A67 000003F8 00000101 00000380 7AC8
10000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 51858, dst 21404 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 CA92539C
00640000 800825BC 1AE91280 7E221B40 D3D1D551 535357D7
D3D2D155 51535057 000003F8 00000101 00000380 7AC8
30000400 03FB0000 01000000 4E000000 001145A2 67F2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.103.242
udp src 38532, dst 6774 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911DCDB 670E5033 45A267F2 96841A76
00280000 80124631 648166C0 47D322B1 7C50ACC9 EB834F30
B75B12D4 7A33A28A 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x52(82)
40000400 03FB0000 01000000 52000000 00116CA6 C14B670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 64, identifier 0
udp src 59722, dst 8494 len 44 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x52(82)
00020000 03F82800 03800000 52000000 00110000 80400000 50330000 7F0A2000
layer 3 data: 45000040 00004000 39115C7A 670E5033 6CA6C14B E94A212E
002C0000 80040128 64816760 13CD76AF 04ECAD0C 993C0CC2
B0076030 B25BAA90 000003F8 00000101 00000380 7AC6
58000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 9292, dst 48772 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 244CBE84
00280000 80120252 648166C0 64F9019B 71E515CB 1455D338
23E9724B 55C64E04 000003F8 00000101 00000380 7AC5
70000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
udp src 29758, dst 6830 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 743E1AAE
00280000 80120FDB 648166C0 427C271E 7C6F3E52 0ED3DEB8
8D58946B E9CEBBF3 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 00116CA6 C76A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.106
udp src 19432, dst 1374 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911565F 670E5033 6CA6C76A 4BE8055E
00280000 8012B5EE 648166C0 0DC668A4 B0E2F3A8 F808D115
D6DE00B2 B6EEC2F3 000003F8 00000101 00000380 7AC8
udp src 35736, dst 56586 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 8B98DD0A
00640000 80082B6D 64816710 7B2D1E4F DDDCD2D3 DFDED2D5
D7D6525D 56575D45 000003F8 00000101 00000380 7AC8
98000400 03FB0000 01000000 4E000000 001153DE F08F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 83.222.240.143
udp src 38852, dst 6454 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114602 670E5033 53DEF08F 97C41936
00280000 80120298 648166C0 5FFF3A9D 78AEAB60 00FAC200
07D6787B 6B6000FA 000003F8 00000101 00000380 7AC6
A0000400 03FB0000 01000000 4E000000 00116CA6 C76A670E 50330000 7F0A2000
udp src 44430, dst 1214 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911565F 670E5033 6CA6C76A AD8E04BE
00280000 801209FA 648166C0 42C527A7 D8507FEB 2A1298E7
99D250CA 1DE3E0D8 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 35708, dst 40990 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 8B7CA01E
00280000 80120194 648166C0 31BB54D9 B5DA420C 5621E71D
9EE335BB C14AD06E 000003F8 00000101 00000380 7AC7
C0000400 03FB0000 01000000 4E000000 00116DEC 5592670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 109.236.85.146
udp src 26776, dst 11454 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911C6F1 670E5033 6DEC5592 68982CBE
00280000 80127476 648166C0 3F595A3B 3022E598 3A5B4ADF
A9125AF4 7537FCCA 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 0011BC8A 30BD670E 50330000 7F0A2000
udp src 23084, dst 7590 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119D28 670E5033 BC8A30BD 5A2C1DA6
00280000 8012EEB5 648166C0 617C041E 14FADA95 307A5B9A
78907C33 7BC6DF72 000003F8 00000101 00000380 7AC6
E0000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 52284, dst 23108 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 CC3C5A44
00640000 80080A7C 64816710 596E3C0C D4D5D4D7 55D4D555
54D55457 54545756 000003F8 00000101 00000380 7AC8
udp src 29602, dst 9726 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 73A225FE
00280000 8012553B 648166C0 50623500 97231087 083113A7
668957E4 90DC7A11 000003F8 00000101 00000380 7AC7
F8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 62666, dst 10504 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F4CA2908
00640000 8008FA18 64816710 77D612B4 FBDB1668 E899EC4A
F596E97A 1479C84A 000003F8 00000101 00000380 7AC7
08000400 03FB0000 01000000 4E000000 001143D4 5091670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.145
udp src 31288, dst 37856 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F60A 670E5033 43D45091 7A3893E0
00280000 80127A25 648166C0 45F32091 72162A88 2FC20F23
2E1E42D7 7CEB4493 000003F8 00000101 00000380 7AC5
10000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 39024, dst 30978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 98707902
00280000 80125A18 648166C0 40AA25C8 D47AA4E0 3FC30927
00D25850 F6BBA7AB 000003F8 00000101 00000380 7AC6
18000400 03FB0000 01000000 4E000000 0011CDCC 518F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.81.143
udp src 11794, dst 10722 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116B14 670E5033 CDCC518F 2E1229E2
00280000 80125487 648166C0 76601302 40673485 9D38699B
8B3A6A53 748872A1 000003F8 00000101 00000380 7AC9
28000400 03FB0000 01000000 4E000000 00116CA6 CBE3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.203.227
udp src 44694, dst 6966 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391151E6 670E5033 6CA6CBE3 AE961B36
00280000 80122A68 64813790 0D8B68E9 9C6C85EB 84F25DB2
E7905428 976C730B 000003F8 00000101 00000380 7AC6
udp src 56212, dst 38210 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 DB949542
00280000 80125A1F 64813790 2BC04EA2 2EB842D7 056E2AF2
030AA762 824256AC 000003F8 00000101 00000380 7AC6
50000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
udp src 19652, dst 22114 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 4CC45662
00B40000 8000DFBC 64813790 3F5D5A3F A3A7B59D B1C1A854
5A4C3C33 2E5E355A 000003F8 00000101 00000380 7AC6
60000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 60838, dst 40912 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D EDA69FD0
00280000 80120DC6 64813790 13D376B1 A8366164 B83A7C8E
F41A4C03 492C976A 000003F8 00000101 00000380 7AC6
68000400 03FB0000 01000000 4E000000 0011C694 6912670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.105.18
udp src 40278, dst 26720 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115AC9 670E5033 C6946912 9D566860
00280000 801204C5 64813790 23B346D1 78AB40A0 00FAC200
07D6787E 80A000FA 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 00116CA6 CB3A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.203.58
udp src 13500, dst 9094 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911528F 670E5033 6CA6CB3A 34BC2386
00280000 8012311B 64813790 4DB628D4 745257A7 442A4E0E
071B306B DEA2969B 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
udp src 17518, dst 10086 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 446E2766
00280000 80126A1E 64813790 129877FA 7E7BD82E 5967F2E0
DCBA3EBB D7F7673C 000003F8 00000101 00000380 7AC7
C0000400 03FB0000 01000000 4E000000 0011C7A7 93B3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 199.167.147.179
udp src 9372, dst 6938 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39112F15 670E5033 C7A793B3 249C1B1A
00280000 8012CBD1 4106CD30 30C755A5 09C3CDCE F7514FD4
036509A7 CE04D582 000003F8 00000101 00000380 7AC6
C8000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 12236, dst 6074 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 2FCC17BA
00280000 80125AE8 4106CD30 4AD62FB4 7C8DD833 66DA4C48
DAD272DA 57A9343B 000003F8 00000101 00000380 7AC6
D0000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 7650, dst 10978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B 1DE22AE2
00280000 80120589 4106CD30 2DB048D2 1037E1F6 C250144C
B9AA5C00 62BF3089 000003F8 00000101 00000380 7AC7
D8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 42244, dst 22298 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 A504571A
00280000 801238E7 4106CD30 68FF0D9D ABBBC66B 823E6D21
3B0BAB66 856302B6 000003F8 00000101 00000380 7AC6
E0000400 03FB0000 01000000 4E000000 0011B2EE E3FE670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 178.238.227.254
udp src 13476, dst 9734 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F382 670E5033 B2EEE3FE 34A42606
00280000 8012E4CE 848550C0 3C1C597E 10F746A2 0EBEC70D
3714F27B 2DB3C919 000003F8 00000101 00000380 7AC7
E8000400 03FB0000 01000000 4E000000 00116CA6 DAE8670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.232
udp src 35758, dst 11662 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391142E1 670E5033 6CA6DAE8 8BAE2D8E
00280000 80126F42 4106CD30 51AF34CD D897DA96 E8F71071
E0B6DC3B 1A1F47B9 000003F8 00000101 00000380 7AC8
udp src 25954, dst 18818 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 65624982
00280000 8012728A 4106CD30 300A5568 7EEFEA5A 95A9DEA1
7ADF79EC 54360B2B 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 00114E81 8E07670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.142.7
udp src 13908, dst 6354 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911ADE7 670E5033 4E818E07 365418D2
00280000 80120BCD 4106CD30 0279671B B3BF8968 ABCFF11B
66E366C3 89E80F29 000003F8 00000101 00000380 7AC7
20000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 12324, dst 46454 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 3024B576
00640000 80082194 84855110 3759523B 7BC0E5ED 9790E065
1312684D FFEDEA97 000003F8 00000101 00000380 7AC5
30000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 6382, dst 9358 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 18EE248E
00280000 80122B16 848550C0 147D711F F472FEDA C2DF6DC5
A974F652 CBCBDCC2 000003F8 00000101 00000380 7AC8
38000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 11064, dst 8430 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 2B3820EE
00280000 8012F172 848550C0 0DEB6889 3FBB806F C12B6102
90CF171D CED0D5FB 000003F8 00000101 00000380 7AC6
40000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 45122, dst 9182 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B B04223DE
00280000 80122E1A 4106CD30 1A3A7F58 70EB67B5 587244F9
06C6F8A0 F5651898 000003F8 00000101 00000380 7AC5
50000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 54346, dst 23962 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 D44A5D9A
00280000 8012465C 4106CD30 673B0259 50E9F7C2 66B80C48
2E11709B E956AD9A 000003F8 00000101 00000380 7AC7
60000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 17962, dst 9054 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 462A235E
00280000 80126F0B 4106CD30 4C452927 78D6A769 71A9D11F
4AD25412 B635000A 000003F8 00000101 00000380 7AC8
68000400 03FB0000 01000000 4E000000 00114A3F DBA2670E 50330000 7F0A2000
udp src 43612, dst 6058 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911648E 670E5033 4A3FDBA2 AA5C17AA
00280000 801226E3 848550C0 60D305B1 11F3F3BA 0BCB7811
845F4177 2DFA8012 000003F8 00000101 00000380 7AC6
78000400 03FB0000 01000000 4E000000 0011CDCC 43C9670E 50330000 7F0A2000
udp src 63806, dst 8718 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391178DA 670E5033 CDCC43C9 F93E220E
00280000 8012C58A 848550C0 54DE31BC 0CE83AA1 9C83D84E
E0D20AE0 194C72DA 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 23142, dst 19330 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 5A664B82
00280000 80124CDD 4106CD30 41B124D3 70837576 A9C2CC0C
0C947CE6 D518CD3A 000003F8 00000101 00000380 7AC6
88000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 21294, dst 9546 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 532E254A
00280000 80120BBF 4106CD30 1F117A73 11DDE01B E3A2593B
474628EC 47D41821 000003F8 00000101 00000380 7AC5
udp src 60222, dst 29186 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 EB3E7202
00280000 801234A8 848550C0 428527E7 EDBBC668 E457FA62
23C909E7 09AC450E 000003F8 00000101 00000380 7AC5
98000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 19832, dst 50102 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 4D78C3B6
00280000 80126E4B 848550C0 629507F7 696F0E92 3593D5B0
6D4EE50B D50EFF68 000003F8 00000101 00000380 7AC9
A0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 50588, dst 19906 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C59C4DC2
00280000 80122401 4106CD30 0B3D6E5F F683C7C5 67F351C6
AC1176C3 C4DA427A 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.208.29
udp src 32948, dst 9810 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D 80B42652
00280000 80125156 4106CD30 5C623900 48644675 5B924AC2
799C5250 EC856BA2 000003F8 00000101 00000380 7AC8
B0000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
udp src 12546, dst 9126 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F 310223A6
00280000 8012EB5B 848550C0 7DA818CA 77F142CE 623F2C00
2E6F0ED0 03391B09 000003F8 00000101 00000380 7AC6
B8000400 03FB0000 01000000 4E000000 00116CA6 DBE2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.219.226
udp src 5878, dst 6362 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391141E7 670E5033 6CA6DBE2 16F618DA
00280000 80125719 4106CD30 4D1F287D 757F63CA 4882CF2A
C8C4746A AA89D43A 000003F8 00000101 00000380 7AC9
C0000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.188.66
udp src 19052, dst 6734 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 4A6C1A4E
00280000 80120398 848550C0 618C04EE F8EB7A2D 535215EE
FA90B0D6 2393C82B 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 61004, dst 33500 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 EE4C82DC
00280000 8012104F 848550C0 37C552A7 4073F14A 181A124C
3052D0B1 A05AAE0B 000003F8 00000101 00000380 7AC9
E0000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.36
udp src 28092, dst 9678 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 6DBC25CE
00280000 80120D45 4106CD30 43C426A6 FABB4D03 892A4F75
63720221 0F291B5A 000003F8 00000101 00000380 7AC9
E8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 33440, dst 39774 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 82A09B5E
00280000 801210A4 848550C0 0AFA6F98 196B006F E232A164
E288494B 4E4193D3 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 00114298 AFEB670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.175.235
udp src 15194, dst 6410 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391197EC 670E5033 4298AFEB 3B5A190A
00280000 8012A147 4106CD30 05D160B3 97A2A1FB 077CBE41
DC387796 B45B1D66 000003F8 00000101 00000380 7AC6
F8000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.38.90
udp src 36600, dst 25898 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 8EF8652A
00280000 80120A5F 848550C0 7EDC1BBE 23B4CC6E 7ED36FFE
94E90D62 4C20E75E 000003F8 00000101 00000380 7AC7
08000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
udp src 19922, dst 8778 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 4DD2224A
00280000 8012020C 848550C0 01AF64CD 815ACB40 9E20B249
76912FBC 4CB12F20 000003F8 00000101 00000380 7AC8
10000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 14666, dst 19642 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 394A4CBA
00280000 8012040B 848550C0 046E610C 37F31353 ED21F274
533809F1 1346B140 000003F8 00000101 00000380 7AC7
18000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.42.232
udp src 20692, dst 11746 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 50D42DE2
00280000 8012E5C4 848550C0 328B57E9 1CB80CA8 6A6E4BC7
93469C63 5BB760A3 000003F8 00000101 00000380 7AC7
30000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.100.106
udp src 26290, dst 6354 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 66B218D2
00280000 8012387C 848550C0 733E165C 70CFEBA9 57CA919E
911A58FA FD0E730B 000003F8 00000101 00000380 7AC7
38000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
udp src 34046, dst 6350 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 84FE18CE
00280000 80125C5C 848550C0 5CF53997 D203D65B 092A420E
0DD27834 97F74343 000003F8 00000101 00000380 7AC8
48000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 61916, dst 16186 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 F1DC3F3A
00280000 80128C59 648166C0 7D8918EB F8EE2A54 1632882F
4A5A7472 FAB62708 000003F8 00000101 00000380 7AC8
udp src 58082, dst 10442 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 E2E228CA
00280000 80122E8A 648166C0 5C1D397F FCD7753A 0338D3DD
0D806C77 5AC0B9EE 000003F8 00000101 00000380 7AC6
60000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.123.87.2
udp src 60302, dst 9622 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 EB8E2596
00280000 8012CAD4 648166C0 05526030 D2DBAF04 D5D24E36
07465216 31D0806A 000003F8 00000101 00000380 7AC5
70000400 03FB0000 01000000 4E000000 0011D12C 7ABE670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.122.190
udp src 39054, dst 10798 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113E85 670E5033 D12C7ABE 988E2A2E
00280000 801206C1 648166C0 31F75495 DE7C45E1 9CCC0D0C
C1010091 C5725C9D 000003F8 00000101 00000380 7AC6
78000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 42570, dst 11490 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 A64A2CE2
00280000 8012179B 648166C0 489A2DF8 10EAF372 FB4B77CC
871664BA DC130633 000003F8 00000101 00000380 7AC7
88000400 03FB0000 01000000 4E000000 0011D87F A884670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 216.127.168.132
udp src 44058, dst 10602 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911096C 670E5033 D87FA884 AC1A296A
00280000 80123407 648166C0 3FCD5AAF F6F94AA0 E01B902C
A7BAF4AB 4DD5C53E 000003F8 00000101 00000380 7AC6
90000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
udp src 54102, dst 6770 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F D3561A72
00280000 801221A6 648166C0 464B2329 6036C209 CE7A68B3
739A7848 26848539 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 11138, dst 16462 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 2B82404E
00640000 8008C24A 64816710 4CB429D6 D5D5D5D5 5455D5D5
D4D5D5D5 55555555 000003F8 00000101 00000380 7AC8
B0000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 48772, dst 51430 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 BE84C8E6
00640000 8008E293 64816710 55CD30AF 54555657 D5D4D4D5
D5D4D5D5 D5D554D4 000003F8 00000101 00000380 7AC6
B8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 32264, dst 39378 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 7E0899D2
00280000 80126477 648166C0 1D327850 52CF7E88 A6B3D9CC
86C67962 A60F6E12 000003F8 00000101 00000380 7AC5
C0000400 03FB0000 01000000 4E000000 0011D87F BCD3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 216.127.188.211
udp src 28604, dst 6494 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F51C 670E5033 D87FBCD3 6FBC195E
00280000 80121AE4 648166C0 63E70685 0CB1362A DAB8DABD
425F3542 EBE3BB5B 000003F8 00000101 00000380 7AC7
C8000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.16.86
udp src 40622, dst 11662 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 9EAE2D8E
00280000 80123F73 648166C0 2E264B44 63240AB0 E2F75205
8C38421F 4B0B2D71 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 46172, dst 52916 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 B45CCEB4
00640000 80082340 64816710 43EC268E D555D554 54D5D5D5
D5D5D5D5 D5D555D5 000003F8 00000101 00000380 7AC9
udp src 27906, dst 27626 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 6D026BEA
00280000 80122B0B 648166C0 57EB3289 7CE33CE4 93DFD4AE
03DF71B8 CB1A5E1A 000003F8 00000101 00000380 7AC5
E0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 18104, dst 28906 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 46B870EA
00280000 801271F0 648166C0 06606302 7479F520 DBB24FC4
E312D207 E34D2A2B 000003F8 00000101 00000380 7AC7
F0000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.195.204
udp src 59454, dst 6002 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC E83E1772
00280000 8012653D 1AE91230 509835FA 51DB5772 938071EA
DAAD09D3 16C1D3AD 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 0011C64A 670A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.103.10
udp src 30292, dst 7126 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115D1B 670E5033 C64A670A 76541BD6
00280000 801200B8 648166C0 6EF60B94 78AB6B60 00FAC200
07D6787E AB6000FA 000003F8 00000101 00000380 7AC6
18000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 12956, dst 7866 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 329C1EBA
00280000 80123367 648166C0 275E423C 301B1472 729845D0
4A1410F3 682C8822 000003F8 00000101 00000380 7AC8
20000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 22360, dst 17346 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 575843C2
00280000 80122FC8 1AE91230 41EC248E 74A4664E 38E8D264
4F4EF411 D65ACC62 000003F8 00000101 00000380 7AC8
30000400 03FB0000 01000000 4E000000 00113261 4E6D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.109
udp src 46524, dst 7170 len 40 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 391109A2 670E5033 32614E6D B5BC1C02
00280000 801295B9 648166C0 6E040B66 504CAB70 36C76DE4
EE78D869 0ABA1AB9 000003F8 00000101 00000380 7AC7
------- dump of incoming inband packet -------
38000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 21008, dst 35188 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 52108974
00280000 80128B3A 1AE91230 56E73385 60B2F36C D24A504B
7A583860 732F820A 000003F8 00000101 00000380 7AC9
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
40000400 03FB0000 01000000 4E000000 00114298 AFEB670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
udp src 44408, dst 6294 len 40 checksum 0x0
------- dump of outgoing inband packet -------
layer 3 data: 4500003C 00004000 391197EC 670E5033 4298AFEB AD781896
00280000 801282DF 648166C0 0FE96A8B 3042A0CD 2498C1A3
34C6F43E 16D84998 000003F8 00000101 00000380 7AC7
50000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
udp src 60656, dst 7978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 ECF01F2A
00280000 80124F67 1AE91230 3DD958BB 42438D9A 4D92288D
34527998 380AE6BA 000003F8 00000101 00000380 7AC8
60000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
udp src 21512, dst 6114 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 540817E2
00280000 8012E2B9 64813790 7FAA1AC8 F59BDBA5 543A73E9
FAC176B2 18F6C0DB 000003F8 00000101 00000380 7AC7
70000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 65346, dst 11198 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B FF422BBE
00280000 801202CC 64813790 29354C57 00BFA909 F24A4A06
39DB3040 6A16503A 000003F8 00000101 00000380 7AC7
88000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
udp src 22880, dst 8974 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 5960230E
00280000 80122130 64813790 438826EA EDFA9357 10AB95A6
00FF3F37 43B03B97 000003F8 00000101 00000380 7AC8
90000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 50268, dst 31686 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A C45C7BC6
00280000 8012AE89 64813790 2F354A57 58561DF4 E7CA5C62
E7D0F278 F9316492 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 33458, dst 28546 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 82B26F82
00280000 8012971E 64813790 136C760E 3833457E D62A4EA2
679764EA 7D5C0B1E 000003F8 00000101 00000380 7AC6
A0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 34966, dst 40570 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 88969E7A
00280000 801255FB 64813790 44212143 73DC05A5 C07C7024
B8696734 05EF357E 000003F8 00000101 00000380 7AC7
A8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 64462, dst 33794 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 FBCE8402
00280000 801247D7 64813790 25134071 7846C0A0 00FAC200
07D63062 C0A000FA 000003F8 00000101 00000380 7AC5
B8000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
udp src 55304, dst 6178 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 D8081822
00280000 80120BA0 64813790 78251D47 F856D276 C0AA8FAA
695B429A AEF645EA 000003F8 00000101 00000380 7AC5
C0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 56308, dst 25694 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 DBF4645E
00280000 801289C2 64813790 2BBF4EDD C267C449 6A3439C7
15E990C3 86E7C905 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 19108, dst 9902 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 4AA426AE
00280000 80125C77 64813790 5F0D3A6F 0E000E50 9A51DC1C
2F1328D7 91387C3E 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 0011AE88 248B670E 50330000 7F0A2000
udp src 57594, dst 11522 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911B75C 670E5033 AE88248B E0FA2D02
00280000 80122455 64813790 73231641 8DB24ED4 249B2DB5
034B8873 4FE05CEB 000003F8 00000101 00000380 7AC6
D8000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
udp src 33804, dst 9890 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D 840C26A2
00280000 801247D2 64813790 49CD2CAF 60B2E82D 53E8D9BA
FCD2123B A7B88C42 000003F8 00000101 00000380 7AC7
E8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 33406, dst 9150 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 827E23BE
00280000 80125D8F 64813790 3A485F2A 78727C21 3E6B4A8B
5216783B C0A3890A 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 51972, dst 6546 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 CB041992
00280000 801201EB 64813790 5A023F60 78AE80A0 00FAC200
07D6787B 40A000FA 000003F8 00000101 00000380 7AC7
20000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 54826, dst 9390 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 D62A24AE
00280000 80122379 64813790 0059653B 13120AEC 004B3278
E4BB183F 0AF40829 000003F8 00000101 00000380 7AC7
30000400 03FB0000 01000000 4E000000 00114005 312C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.49.44
udp src 49848, dst 20664 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911193F 670E5033 4005312C C2B850B8
00280000 8012AEF7 64813790 188C7DEE 776006E9 427C323B
910B54D6 87044BC5 000003F8 00000101 00000380 7AC8
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.51
udp src 64384, dst 24884 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 FB806134
00280000 80120290 64813790 1A917FF3 783B8E52 646B0190
8C90F283 FE080062 000003F8 00000101 00000380 7AC6
50000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 12310, dst 11026 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 30162B12
00280000 80123B57 64813790 15137071 F5F0664D DC48F36B
B292F5DB 13596DB8 000003F8 00000101 00000380 7AC7
68000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 28592, dst 36968 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 6FB09068
00640000 800853EB 648137E0 2EDC4BBE 3788840E 1B8EB507
1C9B8C93 1B67E70B 000003F8 00000101 00000380 7AC9
70000400 03FB0000 01000000 4E000000 0011CDCC 4772670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.71.114
udp src 24408, dst 10962 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00700000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39117531 670E5033 CDCC4772 5F582AD2
00280000 8012F079 64813790 7E781B1A A9604A3D CA21D7C0
09E73722 8CB8179B 000003F8 00000101 00000380 7AC9
78000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 52926, dst 49760 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 CEBEC260
00280000 8012B389 64813790 0B1C6E7E 0C80E77B 64BA618D
2CC22260 658B6CE2 000003F8 00000101 00000380 7AC6
80000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
udp src 43316, dst 8254 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 A934203E
00280000 8012457A 64813790 7BA31EC1 2B22C6E4 40F27247
85590D33 46B0B75F 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 00114540 267B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.64.38.123
udp src 14800, dst 6736 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20700000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111EB5 670E5033 4540267B 39D01A50
00280000 801211C7 64813790 14067164 78F3BB5A 639E1677
699A2AD2 FAE1E3EA 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 26470, dst 8510 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B 6766213E
00280000 80124471 64813790 33525630 0C5A8337 99BA6B7D
C11A493F 432B28DA 000003F8 00000101 00000380 7AC8
interface Gi5/1, routine process_rx_packet_inline, timestamp 06:30:06.860
10000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 46828, dst 11374 len 40 checksum 0x0
interface Gi5/2, routine naboo_fastsend, timestamp 06:30:06.860
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 B6EC2C6E
00280000 80126DAD 4106CD30 76D413B6 AB765C1C 6F6DE4BD
28C586DB 9A8056CE 000003F8 00000101 00000380 7AC5
20000400 03FB0000 01000000 4E000000 00113261 278B670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.39.139
udp src 41356, dst 6974 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113084 670E5033 3261278B A18C1B3E
00280000 8012045D 4106CD30 50CA35A8 60F44A38 8A4ED828
C5107852 BFAD0C33 000003F8 00000101 00000380 7AC7
28000400 03FB0000 01000000 4E000000 00116CA6 C78A670E 50330000 7F0A2000
udp src 12684, dst 7178 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911563F 670E5033 6CA6C78A 318C1C0A
00280000 80121793 848550C0 4A502F32 F850FA25 00A3CE37
AA5FE0AC E9069D7B 000003F8 00000101 00000380 7AC8
70000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.41.250
udp src 16808, dst 10858 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 41A82A6A
00280000 80122429 4106CD30 10F9759B 97FB07C1 1F9C7199
52EF1FA9 4898C049 000003F8 00000101 00000380 7AC9
78000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 39816, dst 11454 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 9B882CBE
00280000 80128C00 848550C0 540F316D 79433ED1 E70A5D65
1B10149D 5DE79F18 000003F8 00000101 00000380 7AC8
80000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
udp src 34534, dst 11702 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 86E62DB6
00280000 80120D72 4106CD30 2A924FF0 581BF9AA 2C2B0890
181079F4 6516761B 000003F8 00000101 00000380 7AC7
88000400 03FB0000 01000000 4E000000 0011C64A 670A670E 50330000 7F0A2000
udp src 28496, dst 8738 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115D1B 670E5033 C64A670A 6F502222
00280000 80128F84 848550C0 2EFF4B9D 5A1B4BD5 99AA5495
B4906075 BF738B7A 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.40.105
udp src 20402, dst 37614 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 4FB292EE
00640000 80083FF2 4106CD80 28964DF4 55555555 55D5D555
555555D5 55D5D5D5 000003F8 00000101 00000380 7AC7
A8000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 16730, dst 10742 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 415A29F6
00280000 801244E3 848550C0 79A31CC1 F873CDCD D2228D88
AA107532 F8C6D808 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 31734, dst 8606 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 7BF6219E
00280000 80120D9F 4106CD30 07D062B2 586508C1 96B619A8
A0405480 BCAA095E 000003F8 00000101 00000380 7AC6
C0000400 03FB0000 01000000 4E000000 00114657 DC0A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.220.10
udp src 36818, dst 9890 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911680E 670E5033 4657DC0A 8FD226A2
00280000 80120A9B 848550C0 43BC26DE 749B9DB9 F06A5242
FDFA5409 874B0498 000003F8 00000101 00000380 7AC9
D0000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
udp src 62672, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 F4D02A62
00280000 801203DE 848550C0 474F222D 78FEC0A0 00FAC200
07D6783A 80A000FA 000003F8 00000101 00000380 7AC8
E0000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
udp src 41090, dst 10530 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 A0822922
00280000 8012EE07 1AE91230 5668330A E9BA53C3 0F28D22C
11C18DA6 29DAD7FA 000003F8 00000101 00000380 7AC7
E8000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
udp src 39104, dst 10066 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 98C02752
00280000 80126C90 1AE91230 1C677905 083B1C0D F8E2F1C2
A54A236A DD3A6923 000003F8 00000101 00000380 7AC8
F0000400 03FB0000 01000000 4E000000 00114298 A8BA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.186
udp src 16028, dst 10170 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119F1D 670E5033 4298A8BA 3E9C27BA
00280000 80126B05 1AE91230 0B116E73 02B4792C 8BC00F57
7BCB02C7 C482608E 000003F8 00000101 00000380 7AC7
08000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 14958, dst 34626 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 3A6E8742
00280000 8012017E 1AE91230 6E890BEB E0CADB25 6EBA44D1
E9166045 7813AEEA 000003F8 00000101 00000380 7AC6
20000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.228.3.77
udp src 32778, dst 16770 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 800A4182
00280000 801205BB 1AE91230 1A847FE6 F860AA52 3EBA9590
6A90F8E2 B884003A 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 24372, dst 17074 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 5F3442B2
00640000 800807AB 1AE91280 4C512933 55D554D5 D5555555
D5D55555 D5D5D555 000003F8 00000101 00000380 7AC5
48000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
udp src 51292, dst 6098 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 C85C17D2
00280000 801200CF 1AE91230 1768720A 51112955 77512B1D
8E0B433E E8ED67E3 000003F8 00000101 00000380 7AC6
60000400 03FB0000 01000000 4E000000 00114A3F DBA2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.63.219.162
udp src 62636, dst 6082 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911648E 670E5033 4A3FDBA2 F4AC17C2
00280000 8012729D 1AE91230 364A5328 10E68E5A C19A4D20
631E7CBA F67C456A 000003F8 00000101 00000380 7AC8
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.43
udp src 59866, dst 10798 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B E9DA2A2E
00280000 80120B88 1AE91230 6D760814 5C7B0784 2C423459
9F1042C2 B8456663 000003F8 00000101 00000380 7AC6
88000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 9274, dst 46274 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 243AB4C2
00640000 80083459 64816710 0E0F6B6D D5D5D5D5 525FD4DB
C0C4D4D5 5D5E5D5F 000003F8 00000101 00000380 7AC8
90000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.98
udp src 56420, dst 11718 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 DC642DC6
00280000 8012005C 1AE91230 48412D23 78A82B60 00FAC200
07D67816 EB6000FA 000003F8 00000101 00000380 7AC5
udp src 15838, dst 25466 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 3DDE637A
00280000 80123F7C 1AE91230 3C68590A C5734AF1 7F8692C6
86B589B6 DE39F86C 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 35136, dst 23072 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 89405A20
00280000 8012CBB5 648166C0 2D034861 0C7351EE 786B780C
A31042E3 D223A792 000003F8 00000101 00000380 7AC6
A8000400 03FB0000 01000000 52000000 001145A2 481A670E 50330000 7F0A2000
udp src 22638, dst 6082 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 45000040 00004000 3911FCAF 670E5033 45A2481A 586E17C2
002C0000 80042A25 1AE912D0 087D6D1F 78E72047 88E00605
621726EE 8EEF80A6 000003F8 00000101 00000380 7AC6
C0000400 03FB0000 01000000 4E000000 00114A3F DBA2670E 50330000 7F0A2000
udp src 65014, dst 6978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911648E 670E5033 4A3FDBA2 FDF61B42
00280000 801232B1 1AE91230 71D714B5 AFA01096 99F9F442
297AAFD3 5053E98F 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
udp src 36716, dst 6230 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 8F6C1856
00280000 801275BE 1AE91230 17467224 A8E0CE0E 3363D157
6CCEB8F3 68FC2CEB 000003F8 00000101 00000380 7AC8
D0000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 21838, dst 9966 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 554E26EE
00280000 801203D3 648166C0 63D906BB 7C7373F3 25D2C529
AF111403 161A82A8 000003F8 00000101 00000380 7AC7
E0000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
udp src 31796, dst 6162 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 7C341812
00280000 80120E19 648166C0 1DE9788B BA580B5D 6C6272F6
9ACB9AAB CB8A6198 000003F8 00000101 00000380 7AC5
E8000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 26888, dst 60670 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 6908ECFE
00280000 80124D84 648166C0 12AD77CF 541D8337 FAA3F502
C0F030DC D1B88439 000003F8 00000101 00000380 7AC6
udp src 32930, dst 17290 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B75C 670E5033 AE88248B 80A2438A
00280000 80120392 648166C0 53E73685 588B7B97 FD721BE9
50D8F810 1738BDE3 000003F8 00000101 00000380 7AC7
10000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 10462, dst 22234 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 28DE56DA
00280000 801211F7 648166C0 112C744E 12E2B664 B3B3C287
195274CC 24E92623 000003F8 00000101 00000380 7AC8
18000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
udp src 47010, dst 11806 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 B7A22E1E
00280000 8012B95E 648166C0 3FB65AD4 40D96688 394A562C
21D2F960 75A9D962 000003F8 00000101 00000380 7AC6
28000400 03FB0000 01000000 4E000000 0011BC8A 00F8670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.0.248
udp src 48470, dst 9662 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911CCED 670E5033 BC8A00F8 BD5625BE
00280000 80122903 648166C0 70221540 14975550 3E3F141A
966694A6 D435BD39 000003F8 00000101 00000380 7AC8
30000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.105
udp src 58102, dst 10662 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 E2F629A6
00280000 801246C2 648166C0 51B734D5 D2CABC34 BD4A5743
F910F8F3 4AB903DB 000003F8 00000101 00000380 7AC7
40000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 32114, dst 8870 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 7D7222A6
00280000 801204A5 648166C0 7A081F6A 753A8939 C32947EF
8F1ED113 54E9AC3E 000003F8 00000101 00000380 7AC6
50000400 03FB0000 01000000 4E000000 00114447 32F1670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.50.241
udp src 49542, dst 7078 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111338 670E5033 444732F1 C1861BA6
00280000 801298D4 648166C0 4A782F1A 2ADA647D 939BF17F
4FDA6853 8B53B89F 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 202.95.120.13
udp src 33366, dst 18660 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 825648E4
002C0000 8004065A 64816760 13027660 608AD652 784B218D
5221F6BC 9EC9A1C2 000003F8 00000101 00000380 7AC8
80000400 03FB0000 01000000 4E000000 0011C694 6E2A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.110.42
udp src 10538, dst 6986 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391155B1 670E5033 C6946E2A 292A1B4A
00280000 80120FA4 648166C0 0F3B6A59 145AFED5 D0E2EC4B
0D907807 7896A15A 000003F8 00000101 00000380 7AC5
88000400 03FB0000 01000000 4E000000 00113F8F 2D5A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 63.143.45.90
udp src 16588, dst 6058 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111D87 670E5033 3F8F2D5A 40CC17AA
00280000 80122331 648166C0 34245146 72FC4D01 C21B1BA1
6BDB5C52 D12E32F3 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 4E000000 00114298 B94A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.185.74
udp src 56828, dst 6582 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118E8D 670E5033 4298B94A DDFC19B6
00280000 80125C51 64816710 10CD75AF 47A805A8 C7B9D11E
80FF2EFF 4620BD51 000003F8 00000101 00000380 7AC9
A0000400 03FB0000 01000000 4E000000 00116CA6 C04A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.192.74
udp src 34020, dst 6942 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115D7F 670E5033 6CA6C04A 84E41B1E
00280000 80122E53 648166C0 60C905AB 723835E2 9D6B54BC
0E5330C8 F6696D5A 000003F8 00000101 00000380 7AC6
udp src 61694, dst 53194 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F0FECFCA
00640000 8008E81B 64816710 6E810BE3 55545555 D5D5D555
D5D5D554 D5D5D554 000003F8 00000101 00000380 7AC5
B0000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
udp src 19286, dst 7138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 4B561BE2
00280000 80121AC1 648166C0 43152677 014286EF C0DFF574
A15B094C 4798DFCD 000003F8 00000101 00000380 7AC7
C0000400 03FB0000 01000000 52000000 00114540 267B670E 50330000 7F0A2000
udp src 62302, dst 6394 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 20700000 50330000 7F0A2000
layer 3 data: 45000040 00004000 39111EB1 670E5033 4540267B F35E18FA
002C0000 80040D43 64816800 356B5009 8CB5C825 48146D2A
1EC6DA0C F4260666 000003F8 00000101 00000380 7AC7
D0000400 03FB0000 01000000 4E000000 00115519 54ED670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.84.237
udp src 24406, dst 14444 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911E069 670E5033 551954ED 5F56386C
00280000 80126FD4 64816710 6759023B 1ED78BDC 656D7299
4A89964E 0BC2236C 000003F8 00000101 00000380 7AC7
udp src 24106, dst 24118 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 5E2A5E36
00280000 80120A6D 648166C0 2BF54E97 D2EDBAB6 2206CD36
45D86CC8 FE5CBDE0 000003F8 00000101 00000380 7AC8
10000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 54990, dst 63818 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 D6CEF94A
00280000 80129176 648166C0 4518207A 58F0753B 5C92162A
94D2B043 BD1BF208 000003F8 00000101 00000380 7AC7
udp src 23402, dst 26284 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 5B6A66AC
00280000 801211C0 648166C0 395D5C3F 37DBD69D 569A73DB
D6DFF5FA 97334BEA 000003F8 00000101 00000380 7AC6
68000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.34.176.54
udp src 34088, dst 22138 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 8528567A
00280000 8012265B 648166C0 52DC37BE 1AF94C73 8197F047
73091833 0C732DAD 000003F8 00000101 00000380 7AC6
70000400 03FB0000 01000000 4E000000 001143D4 5091670E 50330000 7F0A2000
udp src 55538, dst 27242 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F60A 670E5033 43D45091 D8F26A6A
00280000 80120D9C 648166C0 748311E1 6013A236 E6620F4B
44D178A3 CFEAE3B2 000003F8 00000101 00000380 7AC6
78000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 34942, dst 35114 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 887E892A
00280000 80124F6E 648166C0 728B17E9 7AF3630A F74216EC
74CBB0B0 F5AE0ECA 000003F8 00000101 00000380 7AC8
90000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 18624, dst 34406 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 48C08666
00280000 80127321 648166C0 71641406 300B7D5F CA8A5EB3
8B907846 B755C152 000003F8 00000101 00000380 7AC7
udp src 65046, dst 19732 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FE164D14
00280000 80121903 648166C0 21B644D4 5AFB78CE 734A5BA0
82D2758A D42D6F82 000003F8 00000101 00000380 7AC8
udp src 43682, dst 6702 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 AAA21A2E
00280000 80120202 648166C0 7419117B 029893C7 BBCB1411
5191E86A D8E02E2B 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.226
udp src 23334, dst 9498 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 5B26251A
00280000 80121289 64816710 59B93CDB 60B7796E 59B21805
2A7012B0 61E14C7A 000003F8 00000101 00000380 7AC7
B8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 54710, dst 9302 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 D5B62456
00280000 801233DA 648166C0 4A2C2F4E 6240C326 5832C306
35C0788A E12C9692 000003F8 00000101 00000380 7AC6
C0000400 03FB0000 01000000 4E000000 00114624 66CA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.36.102.202
udp src 64000, dst 11206 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911DD81 670E5033 462466CA FA002BC6
00280000 8012BF52 64816710 7AF61F94 647D7A69 FE824D0F
4C90B0B2 FBD238C3 000003F8 00000101 00000380 7AC6
D0000400 03FB0000 01000000 4E000000 0011ADF4 A4DB670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.244.164.219
udp src 29536, dst 6006 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391137A0 670E5033 ADF4A4DB 73601776
00280000 801226FA 648166C0 11267444 7012AC1E 3D92010C
AE5240CB DC5A9962 000003F8 00000101 00000380 7AC8
E0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 52782, dst 9514 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 CE2E252A
00280000 80120F0B 64813790 626E070C 704768F5 7C535305
70D81062 9D6DF328 000003F8 00000101 00000380 7AC8
E8000400 03FB0000 01000000 4E000000 00114298 A8E4670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.228
udp src 47180, dst 6454 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119EF3 670E5033 4298A8E4 B84C1936
00280000 80124A41 648166C0 5E863BE4 F88EE27D D69B1544
ADD2301A ABF9DEC2 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0xDA(218)
20000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 200, identifier 0
udp src 5898, dst 33972 len 180 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0xDA(218)
00020000 03F82800 03800000 DA000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 170A84B4
00B40000 80089244 648166C0 259E40FC D557D657 D5D457D4
5554D757 55D756D5 000003F8 00000101 00000380 7AC5
28000400 03FB0000 01000000 52000000 00114022 B036670E 50330000 7F0A2000
udp src 46814, dst 26434 len 44 checksum 0x0
00020000 03F82800 03800000 52000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 45000040 00004000 39119A13 670E5033 4022B036 B6DE6742
002C0000 800400E9 648137E0 4D7B2819 28ECE307 BC537E46
E51CF629 1C047884 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 55568, dst 11138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA D9102B82
00280000 80121613 64813790 6E580B3A 0BD351E7 0F61515F
73CA695D D2388288 000003F8 00000101 00000380 7AC8
48000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 41236, dst 57188 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 A114DF64
00640000 80082B95 648137E0 14AC71CE 1749E5E9 EBEEE7C6
5A4F7446 C0FFFFF4 000003F8 00000101 00000380 7AC5
58000400 03FB0000 01000000 4E000000 0011D12C 6C78670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.108.120
udp src 35160, dst 8286 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114CCB 670E5033 D12C6C78 8958205E
00280000 80120FF6 64813790 555A3038 757B0A70 09AC4FE8
52F96DE5 497D5B5F 000003F8 00000101 00000380 7AC9
68000400 03FB0000 01000000 4E000000 0011B89A 6F1A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 184.154.111.26
udp src 19770, dst 31174 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391162BB 670E5033 B89A6F1A 4D3A79C6
00280000 80120C15 64816710 1EDC7BBE 564C44C4 19481103
6D95B577 45F60B1F 000003F8 00000101 00000380 7AC5
88000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.47
udp src 22516, dst 10910 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F 57F42A9E
00280000 801286B4 648166C0 610C046E F93757F9 4AAF505C
D39C2063 05B45C9A 000003F8 00000101 00000380 7AC5
90000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 37404, dst 41146 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 921CA0BA
00280000 8012010A 64813790 161C737E C002B251 265E5997
04906993 698A7822 000003F8 00000101 00000380 7AC6
98000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 50328, dst 16824 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 C49841B8
00280000 8012428F 648166C0 46DF23BD F4F44412 6BA9C336
F03E70F3 5224DEFA 000003F8 00000101 00000380 7AC7
udp src 11432, dst 57264 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 2CA8DFB0
00280000 8012005B 64813790 3E955BF7 65AB7456 0C61922E
05FB62AA F45DB0DD 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
udp src 24512, dst 10614 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 5FC02976
00280000 801248F9 64813790 3B035E61 58147DDC 0F029871
DF907868 E55CD8CA 000003F8 00000101 00000380 7AC9
B8000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
udp src 27152, dst 7110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 6A101BC6
00280000 8012E82A 648166C0 394E5C2C 129AAA8F 6DF21885
63727CBC 7379E5BA 000003F8 00000101 00000380 7AC7
E0000400 03FB0000 01000000 4E000000 00114447 32F1670E 50330000 7F0A2000
udp src 51326, dst 7126 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111338 670E5033 444732F1 C87E1BD6
00280000 8012072C 64813790 4B7E2E1C 6DD30060 48B09EE9
C0B4CE3C FE477422 000003F8 00000101 00000380 7AC9
08000400 03FB0000 01000000 4E000000 00114005 20D7670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.32.215
udp src 43874, dst 17466 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39112994 670E5033 400520D7 AB62443A
00280000 801240A2 64813790 1B767E14 2EF00791 F667F061
060993B3 47141722 000003F8 00000101 00000380 7AC6
10000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.72.26
udp src 60814, dst 7090 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A ED8E1BB2
00280000 80125C48 648166C0 028867EA F52ADF80 B59B7D5F
C0D244DE 03F98A02 000003F8 00000101 00000380 7AC8
20000400 03FB0000 01000000 4E000000 001143D5 4E64670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.213.78.100
udp src 11560, dst 6722 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F836 670E5033 43D54E64 2D281A42
00280000 8012AE07 64813790 44622100 79609163 5B1154A3
C7BE574F D1F1BED7 000003F8 00000101 00000380 7AC8
28000400 03FB0000 01000000 4E000000 00113E4B FE32670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.50
udp src 24662, dst 10010 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF2 670E5033 3E4BFE32 6056271A
00280000 801230D0 64813790 32015763 10F5677C 5393D8CA
CA110523 325735A2 000003F8 00000101 00000380 7AC7
30000400 03FB0000 01000000 4E000000 00116CA6 DAE7670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.231
udp src 32594, dst 7410 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391142E2 670E5033 6CA6DAE7 7F521CF2
00280000 80120676 648166C0 35025060 F8A812F2 0B734B1E
095870CA 5695F842 000003F8 00000101 00000380 7AC8
udp src 52922, dst 6490 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 CEBA195A
00280000 801220DF 64813790 759410F6 28724705 124B711C
D4C92659 C6A5FAEB 000003F8 00000101 00000380 7AC7
58000400 03FB0000 01000000 4E000000 0011400F 474D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.15.71.77
udp src 41870, dst 7466 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39110314 670E5033 400F474D A38E1D2A
00280000 8012D2C4 64813790 79821CE0 28058414 84EB03A6
E95B91F0 C2CA5CFB 000003F8 00000101 00000380 7AC6
60000400 03FB0000 01000000 4E000000 0011CC0D 9992670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 204.13.153.146
udp src 16906, dst 6790 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391124D0 670E5033 CC0D9992 420A1A86
00280000 80121A99 648166C0 1EF37B91 384335B7 311ECD58
6DD242F7 F5E37CCA 000003F8 00000101 00000380 7AC7
70000400 03FB0000 01000000 4E000000 00116CA6 C132670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.193.50
udp src 5904, dst 6134 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115C97 670E5033 6CA6C132 171017F6
00280000 801266D1 64813790 2449412B 52FC6303 62C8D6B7
C44234E8 F2956C1B 000003F8 00000101 00000380 7AC9
78000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
udp src 8182, dst 9274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 1FF6243A
00280000 8012E5F0 648166C0 008465E6 09BACB81 AEB75130
0D3B3331 4C2D5B79 000003F8 00000101 00000380 7AC5
udp src 20386, dst 9702 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 4FA225E6
00280000 8012CB17 64813790 32B857DA F423C74E 594A51F6
3FDBF542 87179188 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x52(82)
98000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 64, identifier 0
udp src 26174, dst 18176 len 44 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x52(82)
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 663E4700
002C0000 8004A24E 64816710 16B673D4 045C1450 B2604DC6
6A386565 7E5B0C13 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 0011C694 6B42670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.107.66
udp src 34996, dst 6782 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115899 670E5033 C6946B42 88B41A7E
00280000 8012B5BE 64813790 0E8D6BEF 726804C3 5E9E4109
EA0CB68D 81D8C2E6 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
udp src 12204, dst 6606 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 2FAC19CE
00280000 80120CAE 64813790 09C86CAA 7072F2D1 3A824764
825AE07B 3028024E 000003F8 00000101 00000380 7AC7
B0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 27310, dst 34722 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 6AAE87A2
00280000 80121503 648166C0 3D345856 7832EA10 195213F3
C1D2F813 24ADC602 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x76(118)
D0000400 03FB0000 01000000 76000000 00116CA6 CB3A670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 100, identifier 0
udp src 35365, dst 9135 len 80 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x76(118)
00020000 03F82800 03800000 76000000 00110000 80300000 50330000 7F0A2000
layer 3 data: 45000064 00004000 39115267 670E5033 6CA6CB3A 8A2523AF
00500000 81C8000C 2BFB4E99 00033757 44189326 64816710
00002B30 00035FC0 000003F8 00000101 00000380 7AC6
D8000400 03FB0000 01000000 76000000 00114447 2AE8670E 50330000 7F0A2000
udp src 54847, dst 7375 len 80 checksum 0x0
00020000 03F82800 03800000 76000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 45000064 00004000 39111B19 670E5033 44472AE8 D63F1CCF
00500000 81C8000C 0AB76FD5 00033757 44189326 64816710
00006DB1 000891D4 000003F8 00000101 00000380 7AC8
E8000400 03FB0000 01000000 76000000 0011D12C 6AC3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.106.195
udp src 48717, dst 7551 len 80 checksum 0x0
00020000 03F82800 03800000 76000000 00110000 20C00000 50330000 7F0A2000
layer 3 data: 45000064 00004000 39114E58 670E5033 D12C6AC3 BE4D1D7F
00500000 81C8000C 05AD60CF 00033757 44189326 648166C0
00017409 001D10B4 000003F8 00000101 00000380 7AC8
10000400 03FB0000 01000000 4E000000 0011C694 61BA670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.97.186
udp src 46960, dst 9010 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116221 670E5033 C69461BA B7702332
00280000 8012593F 4106CD30 4D6E280C E1575B36 87510F05
5505A576 D7F6C860 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.210
udp src 43554, dst 9034 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 AA22234A
00280000 80120B33 4106CD30 1D447826 F43AFD8F 8738D326
BA9A759A FEC21558 000003F8 00000101 00000380 7AC7
40000400 03FB0000 01000000 4E000000 0011AD2D 61C2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.45.97.194
udp src 44454, dst 7058 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39117B80 670E5033 AD2D61C2 ADA61B92
00280000 801222BF 848550C0 66DA03B8 F8A6724F DE0A493A
3A1794F3 FCB8F683 000003F8 00000101 00000380 7AC6
48000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
udp src 48298, dst 10558 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B BCAA293E
00280000 801210E2 4106CD30 0AE16F83 9423C283 98B3D563
929436F3 BAE80E62 000003F8 00000101 00000380 7AC7
50000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 26424, dst 9054 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 6738235E
00280000 80127B2A 848550C0 36CE53AC 78587445 FD3FDE34
95167587 7FED8712 000003F8 00000101 00000380 7AC5
68000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
udp src 5684, dst 6466 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F 16341942
00280000 8012342D 4106CD30 51DE34BC 3042DD3D CEDA50FD
C89670B5 C19CE793 000003F8 00000101 00000380 7AC9
70000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 44490, dst 31258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 ADCA7A1A
00280000 801211CB 848550C0 70B015D2 70E86016 5D8816E5
E21E7927 5592892B 000003F8 00000101 00000380 7AC7
78000400 03FB0000 01000000 4E000000 0011AD2D 61C2670E 50330000 7F0A2000
udp src 35146, dst 7214 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39117B80 670E5033 AD2D61C2 894A1C2E
00280000 801207AF 4106CD30 0D8268E0 00B37FBF 0868982A
36D4376B 5D689838 000003F8 00000101 00000380 7AC7
80000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 29094, dst 10230 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 71A627F6
00280000 80122DAF 848550C0 11FC749E 526260CB 562A5C5C
B854E0D0 72403E02 000003F8 00000101 00000380 7AC5
88000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
udp src 36254, dst 8110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 8D9E1FAE
00280000 80123994 848550C0 76A013C2 2823DD72 8129CEEF
A996E07D 5D6E3EF2 000003F8 00000101 00000380 7AC9
udp src 51946, dst 11174 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 CAEA2BA6
00280000 8012358E 848550C0 31CF54AD 75DFC9BB 56429670
0954F5B3 C2176E6B 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 00115519 54ED670E 50330000 7F0A2000
udp src 50946, dst 18108 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E069 670E5033 551954ED C70246BC
00280000 80123450 4106CD30 2B764E14 51BB905C 68B299CE
7A1AF86A 381F74A2 000003F8 00000101 00000380 7AC8
A8000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 184.170.135.50
udp src 51632, dst 8998 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 C9B02326
00280000 80120195 848550C0 63EE068C 78136B60 00FAC200
07D678AE AB6000FA 000003F8 00000101 00000380 7AC8
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x8A(138)
B8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 120, identifier 0
udp src 28086, dst 21136 len 100 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x8A(138)
00020000 03F82800 03800000 8A000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 6DB65290
00640000 80083486 84855110 0CCD69AF 5555D5D5 D5D4D4D4
D4D4D4D4 D4D5D5D5 000003F8 00000101 00000380 7AC6
C8000400 03FB0000 01000000 4E000000 0011D12C 7A03670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.122.3
udp src 55408, dst 8338 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113F40 670E5033 D12C7A03 D8702092
00280000 801243BC 848550C0 70E41586 039108CE 9AA1EFA0
256F8160 C80EFEA7 000003F8 00000101 00000380 7AC8
D0000400 03FB0000 01000000 4E000000 0011D5E5 7810670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 213.229.120.16
udp src 16672, dst 10054 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113C7A 670E5033 D5E57810 41202746
00280000 80120F61 4106CD30 2EBA4BD8 518B47D8 4A1215D2
829E78E3 8D8F8D3B 000003F8 00000101 00000380 7AC6
D8000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
udp src 18786, dst 8838 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 49622286
00280000 80120267 848550C0 6F2D0A4F E9B4208D F97A2D83
945FAE56 49FBCD3F 000003F8 00000101 00000380 7AC8
E8000400 03FB0000 01000000 4E000000 00114624 600C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.36.96.12
udp src 23362, dst 10854 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E43F 670E5033 4624600C 5B422A66
00280000 80120651 4106CD30 67FD029F F8FE11E8 63AA5D2F
485474FB 7214C7CA 000003F8 00000101 00000380 7AC7
F8000400 03FB0000 01000000 4E000000 0011ADC0 2122670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.192.33.34
udp src 9314, dst 11982 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BB8D 670E5033 ADC02122 24622ECE
00280000 8012D926 848550C0 6A8C0FEE 2C63AA58 517F1081
7DF80770 4E545A51 000003F8 00000101 00000380 7AC7
08000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 46786, dst 7898 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 B6C21EDA
00280000 8012658F 848550C0 2BFF4E9D F8539766 2563D48D
DB58F833 C63E5B8A 000003F8 00000101 00000380 7AC8
udp src 47032, dst 31850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A B7B87C6A
00280000 8012302F 848550C0 2EF44B96 A7B2CCE8 213233C8
5111CDBB CD82A853 000003F8 00000101 00000380 7AC7
18000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 13612, dst 32566 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 352C7F36
00280000 801293AC 848550C0 34A051C2 2BBACB83 BCEBF6A8
DD33AB63 4D8E5047 000003F8 00000101 00000380 7AC7
30000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 5960, dst 22288 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 17485710
00280000 80121243 848550C0 7A3C1F5E B053E084 C1D8CE5C
827EF208 99583C93 000003F8 00000101 00000380 7AC8
38000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 37758, dst 10130 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 937E2792
00280000 80121F13 848550C0 728A17E8 FCB649BD 335B142A
4CF8F8B7 EEB62C6F 000003F8 00000101 00000380 7AC5
48000400 03FB0000 01000000 4E000000 0011642A 4B85670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.75.133
udp src 16948, dst 6366 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911DAC0 670E5033 642A4B85 423418DE
00280000 80120357 848550C0 0119647B 787BEB60 00FAC200
07D678A8 6B6000FA 000003F8 00000101 00000380 7AC5
50000400 03FB0000 01000000 4E000000 0011D12C 6703670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.103.3
udp src 29248, dst 6634 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115240 670E5033 D12C6703 724019EA
00280000 8012D408 848550C0 2E7B4B19 6046C97E CBAA5559
CF1EF8AB 1BB5521B 000003F8 00000101 00000380 7AC7
58000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
udp src 40654, dst 18836 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 9ECE4994
00280000 80123FD4 848550C0 1F637A01 609B1997 39EA5ED3
3D10D2E7 DBB3DE23 000003F8 00000101 00000380 7AC6
68000400 03FB0000 01000000 4E000000 001143D4 50AE670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.174
udp src 51124, dst 10194 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10A00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F5ED 670E5033 43D450AE C7B427D2
00280000 80123C78 848550C0 53D736B5 4DF0C9A5 3910EFCC
C63537BB C8D68554 000003F8 00000101 00000380 7AC8
78000400 03FB0000 01000000 4E000000 00116CA6 C78A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.138
udp src 34306, dst 6038 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911563F 670E5033 6CA6C78A 86021796
00280000 8012DA61 848550C0 2FBB4AD9 B558C561 10C7CF30
ED68CD3F 4491D1CB 000003F8 00000101 00000380 7AC7
udp src 19162, dst 12628 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 4ADA3154
00640000 800882C9 84855110 5EE53B87 9007F3B0 B49B9987
7B001811 1517DD9C 000003F8 00000101 00000380 7AC7
98000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
udp src 43848, dst 9766 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 AB482626
00280000 8012C1C5 848550C0 30B855DA 78BAA765 C2A3CC38
74D278FB 64F516D2 000003F8 00000101 00000380 7AC8
A0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.25
udp src 60800, dst 11394 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 ED802C82
00280000 8012EE79 848550C0 6D08086A 58F2FC77 F0DA508E
E1566013 066987A3 000003F8 00000101 00000380 7AC7
A8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
udp src 14996, dst 11882 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 3A942E6A
00640000 8008BD89 84855110 569F33FD 5555D5D5 D5D5D5D5
55D5D5D4 D4D4D4D5 000003F8 00000101 00000380 7AC6
C0000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
udp src 28258, dst 10462 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 6E6228DE
00280000 801205B4 848550C0 43F52697 F543FA22 3558D19F
EEB2F4F6 BA3AABE6 000003F8 00000101 00000380 7AC8
C8000400 03FB0000 01000000 4E000000 0011D87F BFBD670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 216.127.191.189
udp src 52636, dst 17100 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 B0B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F232 670E5033 D87FBFBD CD9C42CC
00280000 80128F75 848550C0 5F9A3AF8 782A6B60 00FAC200
07D678FA AB6000FA 000003F8 00000101 00000380 7AC6
udp src 19860, dst 46040 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 4D94B3D8
00640000 8008AFAA 1AE91280 1F2E7A4C 37333C25 320C360B
1A117DC4 FCE7949B 000003F8 00000101 00000380 7AC8
D8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 51604, dst 61634 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D C994F0C2
00280000 8012E90C 1AE91230 030C666E 50073524 2BAB9BCA
39115007 02CF1DAB 000003F8 00000101 00000380 7AC8
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x6A(106)
E0000400 03FB0000 01000000 6A000000 0011482C 4D9B670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 88, identifier 0
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.77.155
udp src 46282, dst 10078 len 68 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x6A(106)
00020000 03F82800 03800000 6A000000 00110000 00900000 50330000 7F0A2000
layer 3 data: 45000058 00004000 3911F48C 670E5033 482C4D9B B4CA275E
00440000 800435ED 1AE91190 74121170 246D9585 0A6D591F
FA36E608 AE4FDE55 000003F8 00000101 00000380 7AC9
F8000400 03FB0000 01000000 8A000000 0011C694 6912670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.105.18
udp src 59166, dst 34032 len 100 checksum 0x0
00020000 03F82800 03800000 8A000000 00110000 20100000 50330000 7F0A2000
layer 3 data: 45000078 00004000 39115A8D 670E5033 C6946912 E71E84F0
00640000 80080104 1AE91280 730E166C F919C965 15F1E266
F0D07CE8 14F3964E 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 9296, dst 11058 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 24502B32
00280000 801219A2 1AE91230 3BDC5EBE 37400937 816DF1A0
C9394742 88C4C69E 000003F8 00000101 00000380 7AC7
10000400 03FB0000 01000000 4E000000 0011BC8A 30BD670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.48.189
udp src 7912, dst 7678 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119D28 670E5033 BC8A30BD 1EE81DFE
00280000 80120499 1AE91230 1669730B 783A80A0 00FAC200
07D678FA 40A000FA 000003F8 00000101 00000380 7AC5
18000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 46916, dst 33762 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 B74483E2
00280000 8012604C 1AE91230 2CBD49DF 788F79FE 8D3A566A
9814780F CED921C2 000003F8 00000101 00000380 7AC9
20000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
udp src 61544, dst 10098 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 F0682772
00280000 80127FDE 648166C0 7D121870 FCF84CE7 30DBED2D
56CE15A3 66C5C58A 000003F8 00000101 00000380 7AC7
28000400 03FB0000 01000000 4E000000 0011D12C 6C78670E 50330000 7F0A2000
udp src 27742, dst 6942 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114CCB 670E5033 D12C6C78 6C5E1B1E
00280000 80125BD0 648166C0 287D4D1F 10CBA517 BE32C147
7C92F533 52BCB78B 000003F8 00000101 00000380 7AC6
30000400 03FB0000 01000000 4E000000 0011642A 408A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.64.138
udp src 49300, dst 11438 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 642A408A C0942CAE
00280000 8012499C 648166C0 11157477 D4A7814E 40A36542
2C72D487 8112D7F3 000003F8 00000101 00000380 7AC6
38000400 03FB0000 01000000 4E000000 00116CA6 C0A6670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.192.166
udp src 6056, dst 12262 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 80A00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115D23 670E5033 6CA6C0A6 17A82FE6
00280000 80121193 648166C0 52AC37CE F65A0622 5C67F2BA
006FF4F7 067B4397 000003F8 00000101 00000380 7AC7
48000400 03FB0000 01000000 4E000000 00114A56 4752670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.86.71.82
udp src 63128, dst 7870 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 00500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F8C7 670E5033 4A564752 F6981EBE
00280000 8012ACE7 648166C0 71DB14B9 30F6F414 CB424314
A31A5263 8BC90542 000003F8 00000101 00000380 7AC6
50000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
udp src 55806, dst 45424 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 D9FEB170
00280000 80128F42 648166C0 138776E5 79C2FF2D 1EE242DD
814E7946 2732EEA9 000003F8 00000101 00000380 7AC7
58000400 03FB0000 01000000 4E000000 0011C694 72B2670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.114.178
udp src 41130, dst 9158 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115129 670E5033 C69472B2 A0AA23C6
00280000 80126B2F 648166C0 02A867CA D2DFF627 BD2B0B65
085B10BE C14FB66A 000003F8 00000101 00000380 7AC8
68000400 03FB0000 01000000 4E000000 00114298 AC6C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.172.108
udp src 51260, dst 9858 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 A0600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119B6B 670E5033 4298AC6C C83C2682
00280000 80120081 648166C0 58283D4A 783B40A0 00FAC200
07D678AE 80A000FA 000003F8 00000101 00000380 7AC9
70000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 65080, dst 37324 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FE3891CC
00280000 8012A350 64816710 7F7E1A1C 3860F187 DE92123A
0B10F8FA FAA7A48A 000003F8 00000101 00000380 7AC7
78000400 03FB0000 01000000 4E000000 00114657 DD2C670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.44
udp src 41488, dst 56616 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166EC 670E5033 4657DD2C A210DD28
00280000 8012050E 648166C0 58173D75 745B7442 729A5B06
5A9A6867 661143B2 000003F8 00000101 00000380 7AC8
88000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
udp src 51126, dst 16490 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C7B6406A
00280000 801229B2 648166C0 5E973BF5 3AD6CEC0 4B40CD12
73DC3734 4D01EE88 000003F8 00000101 00000380 7AC7
90000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
udp src 54266, dst 10186 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA D3FA27CA
00280000 80122989 648166C0 39A55CC7 96D24935 D2065242
28F71D65 88C06F91 000003F8 00000101 00000380 7AC8
udp src 21730, dst 59452 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 54E2E83C
00640000 80085B26 64816760 638406E6 56D55457 D65455D4
5455D5D4 54D55556 000003F8 00000101 00000380 7AC9
A0000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.36
udp src 30122, dst 10798 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 75AA2A2E
00280000 8012E163 648166C0 13F47696 656B1641 929D309B
D1EB23D7 959652ED 000003F8 00000101 00000380 7AC6
udp src 36592, dst 16912 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 8EF04210
00640000 800858B6 64816760 65560034 D5D55656 5753D4D7
D1D0D7D1 D5D4D451 000003F8 00000101 00000380 7AC6
B0000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.208.29
udp src 12746, dst 10342 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 90100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D 31CA2866
00280000 80121B43 648166C0 01476425 7EF24454 0CC7F198
44A815F7 C4857975 000003F8 00000101 00000380 7AC8
B8000400 03FB0000 01000000 4E000000 0011BC8A 68D3670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.104.211
udp src 42784, dst 11674 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116512 670E5033 BC8A68D3 A7202D9A
00280000 8012338F 648166C0 11AA74C8 21DBC624 F8AB1A6B
5471E1F3 5769C8E8 000003F8 00000101 00000380 7AC6
C8000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.123.87.2
udp src 36554, dst 9786 len 40 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
00020000 03F82800 03800000 4E000000 00110000 10000000 50330000 7F0A2000
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 8ECA263A
00280000 80121C1A 648166C0 77D412B6 40728E98 8E2A58E0
AB5F7478 1958BD72 000003F8 00000101 00000380 7AC5
------- dump of incoming inband packet -------
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
E0000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
udp src 18622, dst 6254 len 40 checksum 0x0
------- dump of outgoing inband packet -------
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A 48BE186E
00280000 8012CC69 64816710 6DD908BB D57505B7 25BB10FF
6EAD92D5 C06D6DE5 000003F8 00000101 00000380 7AC6
E8000400 03FB0000 01000000 4E000000 0011ADEC 2D3A670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.236.45.58
udp src 15184, dst 6246 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 20300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911AF49 670E5033 ADEC2D3A 3B501866
00280000 80128227 648166C0 171B7279 782BAB7A 8FCB5C52
CA144093 F241D953 000003F8 00000101 00000380 7AC6
F0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
udp src 36774, dst 24272 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 8FA65ED0
00280000 80122F34 648166C0 069D63FF F5DBFA29 F282D040
B9B064F2 7FE4E672 000003F8 00000101 00000380 7AC8
08000400 03FB0000 01000000 4E000000 001143D4 5091670E 50330000 7F0A2000
df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.145
udp src 42606, dst 35026 len 40 checksum 0x0
00020000 03F82800 03800000 4E000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F60A 670E5033 43D45091 A66E88D2
00280000 80120F04 648166C0 1F057A67 09A39FC3 41930C45
9F4E6736 60896043 000003F8 00000101 00000380 7AC6
18000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
udp src 36392, dst 9522 len 40 checksum 0x0
show ip route 70.87.221.51 3
RTLSGR1#show ip route 70.87.221.51
Routing entry for 70.84.0.0/14
Known via "bgp 58636", distance 20, metric 0
Tag 132337, type external
Last update from 103.12.212.129 1d20h ago
Routing Descriptor Blocks:
* 103.12.212.129, from 103.12.212.129, 1d20h ago
Route metric is 0, traffic share count is 1
AS Hops 5
Route tag 132337
MPLS label: none
RTLSGR1#
show ip route 209.44.127.36
RTLSGR1#show ip route 209.44.127.36
Routing entry for 209.44.96.0/19, supernet
AS Hops 4
Route tag 132337
MPLS label: none
show mls rate
RTLSGR1#sh mls rate
Sharing Codes: S - static, D - dynamic
Codes dynamic sharing: H - owner (head) of the group, g - guest of the group
Rate Limiter Type Status Packets/s Burst Sharing
MCAST NON RPF Off - - -
MCAST DFLT ADJ Off - - -
MCAST DIRECT CON Off - - -
ACL BRIDGED IN Off - - -
ACL BRIDGED OUT Off - - -
IP FEATURES Off - - -
ACL VACL LOG Off - - -
CEF RECEIVE Off - - -
CEF GLEAN Off - - -
MCAST PARTIAL SC Off - - -
IP RPF FAILURE Off - - -
TTL FAILURE Off - - -
ICMP UNREAC. NO-ROUTE Off - - -
ICMP UNREAC. ACL-DROP Off - - -
ICMP REDIRECT Off - - -
MTU FAILURE Off - - -
MCAST IP OPTION Off - - -
UCAST IP OPTION Off - - -
LAYER_2 PDU Off - - -
LAYER_2 PT Off - - -
DHCP Snooping IN Off - - -
DHCP Snooping OUT Off - - -
ARP Inspection Off - - -
LAYER_2 PORTSEC Off - - -
LAYER_2 MiniProto Off - - -
IP ERRORS Off - - -
CAPTURE PKT Off - - -
MCAST IGMP Off - - -
MCAST IPv6 DIRECT CON Off - - -
MCAST IPv6 ROUTE CNTL Off - - -
MCAST IPv6 *G M BRIDG Off - - -
MCAST IPv6 SG BRIDGE Off - - -
MCAST IPv6 DFLT DROP Off - - -
MCAST IPv6 SECOND. DR Off - - -
MCAST IPv6 *G BRIDGE Off - - -
MCAST IPv6 MLD Off - - -
IP ADMIS. ON L2 PORT Off - - -
UCAST IP TINY FRAG Off - - -
MCAST IP TINY FRAG Off - - -
LAYER_2 MACSEC Off - - -
MCAST IPv4 PIM Off - - -
RTLSGR1#
show mls rate usage
RTLSGR1#sh mls rate usage
Rate Limiter Type Packets/s Burst
Layer3 Rate Limiters:
RL# 0: Free - - -
RL# 1: Free - - -
RL# 2: Free - - -
RL# 3: Free - - -
RL# 4: Free - - -
RL# 5: Free - - -
RL# 6: Free - - -
RL# 7: Free - - -
RL# 8: Rsvd for capture - - -
Layer2 Rate Limiters:
RL# 9: Reserved
RL#10: Reserved
RL#11: Free - - -
RL#12: Free - - -
RTLSGR1#
10-01-2012 04:53 AM
Hi Rajs,
Did u find any thing? Pls help----------------------------
10-01-2012 08:09 AM
I have looked at the capture. Majority of the CPU procssed packets are coming from 103.14.80.51
These packets are not getting hardware switched. We need to check if there is any issues with mls cef or if there is some checksum errors
Please get me the following outputs
1. Show mls stat
2. show mls cef summary
3. Show mls cef exception status
4.show mls cef 70.84.0.0 detail
10-01-2012 11:58 AM
1. Show mls stat
RTLSGR1#sh mls stat
Statistics for Earl in Module 5
L2 Forwarding Engine
Total packets Switched : 68764457147
L3 Forwarding Engine
Total packets Processed : 68764353970 @ 171291 pps
Total packets L3 Switched : 38802051540 @ 85921 pps
Total Packets Bridged : 14925491788
Total Packets FIB Switched : 38802051540
Total Packets ACL Routed : 0
Total Packets Netflow Switched : 0
Total Mcast Packets Switched/Routed : 137672
Total ip packets with TOS changed : 2
Total ip packets with COS changed : 2
Total non ip packets COS changed : 0
Total packets dropped by ACL : 154738
Total packets dropped by Policing : 0
Total packets exceeding CIR : 0
Total packets exceeding PIR : 0
Errors
MAC/IP length inconsistencies : 0
Short IP packets received : 0
IP header checksum errors : 0
No-route packet drops : 2149902356
TTL failures : 378
MTU failures : 4389
Total packets L3 Processed by all Modules: 68764353970 @ 171291 pps
RTLSGR1#
RTLSGR1#show mls cef summary
Total routes: 196324
IPv4 unicast routes: 194270
IPv4 Multicast routes: 4
MPLS routes: 2048
IPv6 unicast routes: 2
IPv6 multicast routes: 3
EoM routes: 0
RTLSGR1#
RTLSGR1#Show mls cef exception status
Current IPv4 FIB exception state = TRUE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
RTLSGR1#
RTLSGR1#show mls cef 70.84.0.0 detail
Codes: M - mask entry, V - value entry, A - adjacency index, P - priority bit
D - full don't switch, m - load balancing modnumber, B - BGP Bucket sel
V0 - Vlan 0,C0 - don't comp bit 0,V1 - Vlan 1,C1 - don't comp bit 1
RVTEN - RPF Vlan table enable, RVTSEL - RPF Vlan table select
***** FIB is in exception state for IPv4 unicast *****
Format: IPV4_DA - (8 | xtag vpn pi cr recirc tos prefix)
Format: IPV4_SA - (9 | xtag vpn pi cr recirc prefix)
RTLSGR1#
