Hub-and-Spoke Topology Question
Joel0748363
Frequent Visitor
Frequent Visitor
Hi All
I'm working on a SD-WAN Hub-and-Spoke Topology, but i want to avoid traffic flow between spoke to spoke, for example : the DC site using VPN 100, and the branch A using VPN 10, branch B using VPN 20, in this circumstances i need to route-leaking between 100-10、100-20, but now the routing table on VPN 100 will allow traffic from 10 forward to 20
Because of the default route advertise from the DC site, branch can easily route through anyway via VPN 100, because VPN 100 need to have every VPN's route in the fabric
Is there any way that i can prevent traffic between 10 and 20 without using SD-WAN ZBFW ?
thanks for answering
2 Accepted Solutions
since you receive default route toward hub then we can not prevent spoke to spoke traffic without ACL
you need to use Local Data Policy in both Spoke
https://www.networkacademy.io/ccie-enterprise/sdwan/explicit-access-control-list-acl
MHM
Kanan Huseynli
I don't know how many sites you have. But one option could be to list remote branches and in centralized data policy you select drop action.
There is no way to filter this without manually written access-list.
HTH,
9 Replies 9
What I get you want to make traffic via Hub only ? Or something else
MHM
Yes, even though i am using hub and spoke topology, but i need to avoid any traffic from spoke to spoke via Hub
MHM
Torbjørn
You can solve this with a centralised policy that prevents spoke originated TLOC and OMP routes to be advertised to other spokes combined with a centralized data policy that restricts spoke-spoke traffic through the hub.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Yes I am using centralized policy to make sure there was no TLOC and Route exchange between spoke-spoke, but because of the default route that learn from the DC site, spoke-spoke can still communicate via DC
hi sir
Could you please explain specific which function to use in control policy ?
Joel0748363
Frequent Visitor
Frequent Visitor
Kanan Huseynli
HTH,
