Showing results forĀ
Search instead forĀ
Did you mean:Ā
ip sla icmp set df bit
adnane dakna
Level 3
Level 3
I want to set a mechanism to control reachbility between two nodes using ip sla ,but I can't find  any way setting df bit for ip sla icmp packets , Is there any ideas to do that ?
Best regards.
int f1/0
no ip policy route-map df
exit
ip local policy route-map df
Regards.
Alain
cadet alain
use a local PBR for ip sla ping packets which sets the df bit to zero.
Regards.
Alain
I do that but it dosen't work , access list match trafic but  the route-map match nothing.
route-map df, permit, sequence 10
  Match clauses:
    ip address (access-lists): 1
  Set clauses:
    ip df 1
  Policy routing matches: 0 packets, 0 bytes
my architecure is basic  R1<------->R3
Config R1:
version 12.3
service timestamps log datetime localtime
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
ip domain name lab.local
no ip dhcp use vrf connected
!no ip ips deny-action ips-interface
ip sla monitor logging traps
ip sla monitor 1
type echo protocol ipIcmpEcho 20.20.20.2
request-data-size 1500
frequency 5
!ip sla monitor reaction-configuration 1 react timeout threshold-type immediate action-type trapOnly
!ip sla monitor schedule 1 life forever start-time now
no ftp-server write-enable
!track 1 rtr 1 reachability
no crypto isakmp ccm
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 20.20.20.1 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip classless
logging 10.10.10.1
access-list 1 permit 20.20.20.0 0.0.0.3
route-map df permit 10
match ip address 1
set ip df 1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Config R3:
version 12.3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
ip address 20.20.20.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip http server
ip classless
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
int f1/0
exit
Regards.
Alain
Thanks alain , now  its works for me .
