MSTP configuration help
bobbydazzler
Level 2
Level 2
I have a question regarding MSTP implementation. We are in the migration process to replace a standalone 6509 by two Nexus 9K switches.
We used to have MSTP running between the 6509 (root) site A and the nexus SFP site B. All others switches are in pvst. We have dedicated fibers connecting the switches with different vlan for each client. I was using MSTP in order to do that, but there might be a better solution ?
Attached is the layer 2 topology of the current situation, partly migrated some fibers to the Nexus and mstp in a messy state. I would like to migrate the final fibers of client C (in green) to the top Nexus and switch on the link between the 6509 and the Nexus (link in blue).
Could I configure MSTP only between the Nexus SFP of site A/B ? And keep the 6509 in pvst ? Which one of the Nexus should be root ?
Looking forward to any advice.
Hello
Based on your topology, as stated site B C9K1 would be the most applicable for the CIST root running MST
see attached file for possible solution.
Kind Regards
Paul
17 Replies 17
why you dont need to  run MST in c6K ?
run multi STP modes , hmm it not optimal
MHM
Should I run mstp on all the switches?
MHM
MHM
Hello @MHM Cisco World
PVST+ simulation is something you do need to be aware of however it will NOT negate having mst/pvst+ stp domain, they will indeed work together you just need to be aware of the "gotchas" doing so.
Kind Regards
Paul
MHM
Hello
@MHM Cisco World wrote:
friend please check Link I share, I know what I talking about mix PVST+MST can lead to pvst_inc and BLK port.
PVST+ simulation isnt something you enable, its something you need to be aware of and negate from happening when you have to connect pvst+ stp domains to mst stp domains
Which means you CAN connect these two stp domains together
Kind Regards
Paul
Which means you CAN connect these two stp domains together <<- did I mention different in my previous comment ?
I mention he must be careful never mention he can not mix
and again I suggest use same STP mode if he can
MHM
Thank you for taking the time to help out.
The issue running MST in all SW is that the RJ45 Nk9 in site A have loads of VLANs that are not needed on other sites.
If I run MST + PVST, how would you configure MST ? MST on Nk9 SFP on site A and B and all other switches on PVST ?
the MST is config with two  instance only no need more
each instance contain half of VLAN available in SW even VLAN not use new but can use in feature.
MST dont send like PVST using VLAN tag so it dont matter if the VLAN is use in one SW and dont use in other SW
anyway to help you I run lab and show you case
using MST
using mix MST + PVST
MHM
Hello
If you want to run mst & pvst domains then have the Nk9 in site B to be the root for the whole STP estate, just make sure on the PVST+ switches  the stp priority's for all vlans are higher(less preferred) then the MST domain.
Kind Regards
Paul
Thank you for taking the time to help out on my case.
Should I configure the Nk9 Site B and Site A on MST ? and the others swtiches can stay in pvst ?
The problem running mst on all the swiches is that few vlans are used between sites but each site has quite a lot of VLANs, especially the Nk9 on site A and B.
Georg Pauwen
I have not followed the entire thread, but I am just thinking why not simply use MST on all switches, and then manually prune the Vlans you don't need ?
Hello
MST is per instance not per vlan as such vlans, you should not be pruning any vlans off any trunks
Kind Regards
Paul
