NAT Configuration
Ahmed Malik
Level 3
Level 3
So i been studying NAT configuration and i do know that there is Static NAT and Dynamic AT. But when it comes to configuring NAT on a router this is where i get confused.
Below you will see the image i am using for NAT configuration..
And here are the commands i have been studying for NAT configuration.
Router>enable
Router#configure terminal
Router(config)#interface fastethernet0/1
Router(config-if)#ip address 172.16.1.1 255.255.255.0
Router(config-if)#ip nat inside
Router(config-if)#exit
Router(config)#interface fastethernet0/0
Router(config-if)#ip address 10.1.6.199 255.255.252.0
Router(config-if)#ip nat outside
Now after this, the next part i don't understand especially where prefix and access list commands are involved
Router(config)#ip nat pool no-overload 10.1.6.100 10.1.6.198 prefix 22
Router(config)#ip nat inside source list 10 pool no-overload
Router(config)#access-list 10 permit 172.16.0.0 0.0.0.254
Router(config)#exit
So if anyone can help me out here please.
Ahmed
5 Replies 5
shehinpm1
Level 4
Level 4
Hi Ahmed,
u will have to put this command to make it working "ip nat inside source list 10 pool no-overload overload
to translate u r 172.16.0.0 private subnet to that perticular pool of ips.
Ok, but what i dont understand is that, what does prefix 22 mean? does it always have to be Prefix 22 or it can be prefix 24 or any other number and can you tell me what do "source list 10" and "access-list 10" stand for?
Hi Ahmed
Make the prefix same as the subnet mask of the outside interface
Example if the masknof the outside interface is 255.255.255.0 then the prefix has to be 24
And I am not sure about yor LAN subnet but ibthink your acl 10 wildcard
Is wrong
Make is 0.0.0.255 if the LAN is /24
If helpful rate
HI Ahmed,
i hope u got the concepts of subnet mask and prefix-length from the above post,
here are some more information
in case of class a 10.10.10.1 255.0.0.0 the prefix length will be /8,if u r doing 8 bit subneting with class a it will be
10.10.10.1 255.255.0.0 prefix will be /16.
suppose if u got the public ip pool 91.224.2.16/28,  mask 255.255.255.240
in nat configuration it will be "ip nat pool no-overload 91.224.2.17 91.224.2.30 prefix-length 28"
To do nat overload you can define your public ip you want to nat to with a 1 IP pool:
-ip nat pool overload_pool 172.16.1.1 172.16.1.1 prefix-length 24 or
-ip nat pool overload_pool 172.16.1.1 172.16.1.1 255.255.255.0
then ip nat inside source list 10 overload_pool overload
or you can use the IP address of your public facing interface
ip nat inside source list 10 interface x/x  note: no need to specify overload because in this case IOS will add it in the running
the prefix notation is a shorter way of specifying subnet mask
source list 10 references the ACL 10 which specifies which addresses should be natted
Regards.
Alain.
