OSPF, iBGP, EBGP across datacenters
cjsattler
Community Member
I have two datacenters with two leased fibers running between them.  Currently one datacenter is just a slave off the main site with layer 3 switches connected by OSPF to routed interfaces.  The fibers themselves hook up to stacked 3750gs one each side with OSPF running between them.  The OSPF cost tells it what fiber to use as primarily.  The default-route is currently learned by OSPF from the core router at site A
Site A has 2 providers with full tables with ebgp and site B will have two providers with full routes and ebgp.  I would like to share internet routes by ibgp between both routers and i would like to also keep the fibers plugged into the stacked 3750s for redundnacy and not have the fibers plugged into the backbone routers.
The problem i am having is when a packet comes in from the internet destined for a provider on site B, router A sends it to the switches at side A and it gets in a routing loop since the destination isnt on the layer 3 switch (only ospf with internal network routes) and sends it back to router A.
I know i can just plug the fibers into the backbone routers to fix this but i really want it on the stacked 3750s since the likelihood i have to take down a single router is greater then both switches that have a port-channel to the access layer.
I was thinking of also doing a l2tpv3 pseudowire between both core routers to allow them to have layer two between them but i'd rather not have the added overhead and complexity.
Here are the questions i have and id love to hear people's recommendations:
A) Is there any way to do this other then a pseudowire or plugging the fibers into the 6500s?
B) When i do get this working, should both sites have default-route originate by ospf or would it be better to set one preference higher?
19 Replies 19
Talha Ansari
Level 5
Level 5
I assume your gateway router must be doing NAT. so the the packet reaching your l3 switches must contain your local ip address in the destination field of the packet header. If your internal OSPF routing is perfect then there should be no reason for the packet to get looped. Since, the destinations lying on the site B might be advertised from site B in OSPF and destinations lying on site A must be advertised in site A OSPF process.
Can you explain with an example and configuration of your devices about what is exactly happening?
Talha
Hi!,
The network is not running NAT.  We have a /19, /20 and /23 being announced from our 6500s to our upstreams with ebgp.  The problem with the loop is that OSPF doesnt have all the internal routes from EBGP so when someone on the inside wants to hit a site on the internet that Router B says is a better path, the path follows from access layer switches, to the 3750g's , follows their default gateway to Router A, router A says it should be on router B and sends it back down to the 3750 switches they connect to.  Since Router B doesnt have the external route (would kill the memory of the 3750s to have all the internet routes), it sends it back up its default gateway to Router A and then it sends it back
This is what it showed when i did a sho ip route on a destination i couldnt get to:
Router A#sho ip route 168.215.5.209
Routing entry for 168.215.0.0/19
  Known via "bgp XXXX", distance 200, metric 0
  Tag 4323, type internal
  Redistributing via ospf XXXX
  Last update from ROUTERB 00:04:52 ago
  Routing Descriptor Blocks:
  * ROUTERB, from loopback0, 00:04:52 ago
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 4323
      MPLS label: none
      MPLS Flags: NSF
and if i did a traceroute it bounced back and forth.
heres my bgp, ospf configs:
router bgp XXXX
no synchronization
bgp router-id X.X.X.X
no bgp fast-external-fallover
bgp log-neighbor-changes
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
bgp maxas-limit 50
bgp dampening
network X.X.X.X mask 255.255.240.0
network X.X.X.X mask 255.255.224.0
network X.X.X.X mask 255.255.254.0
neighbor X.X.X.X remote-as INTERNAL
neighbor X.X.X.X update-source Loopback0
neighbor PROVIDER1 remote-as XXXX
neighbor PROVIDER1 description PROVIDER1
neighbor PROVIDER1 version 4
neighbor PROVIDER1 send-community
neighbor PROVIDER1 prefix-list INTERNALFILTER out
neighbor PROVIDER1 maximum-prefix 500000 90
neighbor PROVIDER2 remote-as XXXXX
neighbor PROVIDER2 description PROVIDER2
neighbor PROVIDER2 password 7
neighbor PROVIDER2 version 4
neighbor PROVIDER2 send-community
neighbor PROVIDER2 prefix-list XXXXX out
neighbor PROVIDER2 maximum-prefix 500000 90
no auto-summary
router ospf XXXXX
router-id XXXX
log-adjacency-changes
no auto-cost
max-lsa 8000
area 0 authentication
area 1 authentication
area 10 authentication
redistribute static subnets
redistribute bgp XXXX subnets route-map BGP_OSPF_REDIST  (for failover for some customers but limits everything except a few subnets)
network XXXX XXXXX area 0
default-information originate
So what it sounds like is that my only solutions are really plug the fibers directly into the 6500s or create a tunnel.  I just wanted to make sure i'm not missing anything as im fairly new to ibgp.
Im probably leaning towards just plugging them into the 6500s since the tunneling will have overhead and the links are already running at about 500mb and the tunneling will add some overhead.
Hi ,
If I understand this correctly, From the output you pasted here Router B is advertising /19 to Router A.via iBGP so Router B should forward the packet to where it learned that /19 from and not resort to the default route. Can you post the sh ip bgp 168.215.5.209 on Router B and also sh ip route 168.215.5.209 as well
Kishore
Both routers are advertising the /19 and connecting to the switches by connected interfaces (switches only running ospf with internal /19).  Here is the output, however i am not currently running ibgp between them because of the loop and only accepting incoming traffic from router B, there is no default-originate on router B anywhere.
A>sho ip route 168.215.5.209
  Known via "bgp XXXX", distance 20, metric 0
  Tag 22773, type external
  Last update from X.X.18.193 1d17h ago
  * X.X.X.193, from X.X.18.193, 1d17h ago
      AS Hops 2
      Route tag 22773
      MPLS label: none
      MPLS Flags: NSF
RouterB>sho ip route 168.215.5.209
  Tag 4323, type external
  Last update from X.X.132.149 1d17h ago
  * X.X.132.149, from X.X.132.149, 1d17h ago
      AS Hops 1
      Route tag 4323
      MPLS label: none
      MPLS Flags: NSF
I did think of one way to get redundnacy across everything without needing to resort to layer 2 spanning tree or anything.  If i plug one fiber into the core routers directly and then the other fibers create a trunk on the switches and carve out a vlan for the 6500s to communicate with, that should allow me to survive a single router failure and talk across datacenters without the complexities and overhead of tunneling.
Any opinions on that?
cjasttler,
Here is the lab results just for you.  I just used a diff ip addressing.
+++++ WIth GRE
R1#sh ip bgp
BGP table version is 2, local router ID is 22.22.22.22
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i33.33.0.0/16     1.1.1.2                  0    100      0 i
R1#traceroute 33.33.33.33
Tracing the route to 33.33.33.33
1 1.1.1.2 72 msec *  60 msec                 <<<<  Trace succesful
R1#sh ip route 1.1.1.2
Routing entry for 1.1.1.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  * directly connected, via Tunnel0
+++++ Without GRE
R1#sh ip bgp
BGP table version is 4, local router ID is 22.22.22.22
*>i33.33.0.0/16     2.2.2.2                  0    100      0 i
  1 192.168.1.3 40 msec 36 msec 24 msec
  2 192.168.1.1 32 msec 16 msec 24 msec
*Dec  7 20:16:59.151: ICMP: time exceeded rcvd from 192.168.1.3
*Dec  7 20:16:59.191: ICMP: time exceeded rcvd from 192.168.1.3
*Dec  7 20:16:59.215: ICMP: time exceeded rcvd from 192.168.1.3
*Dec  7 20:16:59.235: ICMP: bogus redirect from 192.168.1.3 - for 33.33.33.33 use gw 192.168.1.1
*Dec  7 20:16:59.235:       gateway address is one of our addresses
So, just use a GRE Tunnel between both the Routers and run iBGP between them
Kishore
Marwan ALshawi
You can enable mpls on the switches make it like a core with ospf igp only and run mp-bgp between the two sites routers full route exchange
For defual route it is up to your requirements which one is better but since you have full Internet routing the defaule route is more from igp to bgp path only
Hope this help
That would be a interesting solution but the 3750s cant do mpls (the metro ethernet can but i dont have those)
thanks
You can run a gre tunnel between the routers with MPLs enabled over the tunnels and using the igp for tunnels reachability
On top of that you run MP-BGP
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_gre.html
maayre
Level 3
Level 3
Well if you use a GRE tunnel you will no longer need MPLS to tunnel as you're doing that with GRE
I vote for MPLS but as you said not supported so tunnel it "ipip" or "ip gre".
With the defaults I would just make sure that the devices at each site use their local exit point (if that is desirable). The two defaults can easily coexist if the cost between sites us high.
If you use tunneling without MPLs/mp-bgp a full routing has to be redistributed onto the igp and this is not recommended or best practice !
The concept same as pe-to-pe tunneling in the above link
Not sure if I've missed something but my response is;
- No redistribution required, iBGP is advertising routes with a next-hop routed over the tunnel
- MP-BGP not sure why you need new address-families in this setup. MP-BGP by definition means you are adding some other address-family besides IPv4, this isn't required
Marwan,
You suggested a very good idea of GRE but using MP-BGP or something is an overkill. All that needs to be done is to hide the destination from the internal network which can be done by GRE and should be enough. I  dont believe that you need any BGP sAFI's here. Also as Matt suggested no redis is required between the BGP and IGP.
The problem  the poster is having is that the switches (IGP) dont know the destination address for eg : 168.215.5.0/19
and hence when Router A tries to route via the 3750's the switches send the packets back to the Router A because of the default route.
Talha,
I see what you are saying . However I would say its suboptimal routing to go out to the internet and then come back from Router A to Router B.  The network has a backdoor fibre link and it would make sense to route those destinations internally via iBGP.
cjsattle,
I will definetly recommend to use GRE. I have tested this for you just in case you want some assurance. I will paste the results in the following post.
Kishore
Agree mp-bgp not required unless multiple vrf routes needed
Again GRE will form the bgp over the tunnels and make sure to use the tunnels as the bgp session source and the tunnel IPs are reachable via igp not bgp to avoid recursive lookup
Hope this help
