problem ospf ip route...
Emmanuel Vilela
Level 2
Level 2
Hello, i've i little problem with my PT.
i'm gonna configure ospf on my router (a basic ospf), just to see how ospf work
I want all pc communicate !
But after insert all of network connected to the network, all of my router do not create the ip route
password for all equipement : tech
The networks connected to the Router2 are:
172.18.0.0 0.0.63.255
172.18.64.64 0.0.0.63
172.18.64.128 0.0.0.63
172.18.64.192 0.0.0.63
3.0.0.0 0.255.255.255
192.168.0.0 0.0.0.255
The network connected to the Router0 are :
172.16.0.0 0.0.31.255
172.16.32.0 0.0.31.255
172.16.64.32 0.0.0.31
172.16.64.64 0.0.0.31
172.16.64.96 0.0.0.31
172.16.64.128 0.0.0.31
172.16.64.160 0.0.0.31
2.0.0.0 0.255.255.255
1.0.0.0 0.255.255.255
The network connected to the Router3 are :
172.17.0.0 0.0.63.255
172.17.64.64 0.0.0.63
  172.17.64.128 0.0.0.63
172.17.64.192 0.0.0.63
The network connected to the Router 4 are :
172.19.0.0 0.0.63.255
172.19.64.64 0.0.0.63
172.19.64.128 0.0.0.63
172.19.64.192 0.0.0.63
PT in attachment
Thanks or u help
2 Accepted Solutions
You are using same ip address on Fa0/0 interfaces on different routers, that ip address ospf used for process ID. You can not use same ospf ID, this cause the problem.
Try to reload router or ospf process. For me seams to working )
12 Replies 12
Rajesh Hirani
Level 2
Level 2
If it is a basic config and you just want to get ip route for ospf to show up then do couple of simply task:
make sure the 4 routers are able to ping each other's directly connected link and then configure ospf like:
router ospf 1
net 0.0.0.0 255.255.255.255 a 0
let me know how you get on!
Hello rhirani12,
thanks for u help !
So, i add this network with my other network or on my 4 routers i have just this rules on my ospf configuration ?
regards!
Indeed!
So,
i clear my ospf, and i recreate my ospf juste with net 0.0.0.0 255.255.255.255 a 0" but know just two router have the route. I feel, pt is time to time totally random...
Are all 4 routers able to ping each other?
Can you share you interface/ospf config ?
Yes my 4 router able to ping each other !
But it's very strange because, my router "paris" have the ip route from "lille" and "lille" have route from "paris", but marseille and lyon, havé nothing, just their route "connected"..
when u say : fa0/0, it's just the hsrp interface or the fa sub interface too ?
regards
I talk about interface address. Use "show ip ospf" command to look ospf proccess id.
OSPF chooses proccess id by:
1. Highest ip address of loopback;
2. Highest  ip address of physical interface.
Ok, i change the 192.168.0.0 network, to 192.168.0.0 for paris, 1.0 lille, 2.0, lyon and 3.0 marseille, but the problem stay the same.
i upload a the version of my PT
omg, work perfectly 😄
So i've another question but it's not about ospf but about the stp (i know i'm on the wan section but, i ask my question anyway :D)
on my PT, on my switch0, "spanning-tree vlan 1-8 priority 61440" and "spanning-tree vlan 1-8 root primary" with this all of pc port in portfast, it's sufficient for a correct spannin-tree ? (beginner)
Thanks a lot Kirill !
