Recommendations for a Network Monitoring Solution for Cisco SD-WAN and
Ajay Viswam
Community Member
Hello Team,
I am new to the community and looking for recommendations on the best network monitoring solution to effectively monitor Cisco SD-WAN and Cisco ACI environments.
Below are the key requirements that the solution should support:
  • Detailed application monitoring to ensure visibility into network performance and application behavior.
  • SNMP monitoring for device health tracking and proactive issue detection.
  • NetFlow and application-based traffic performance monitoring to analyze network usage and optimize performance.
  • Cisco SD-WAN monitoring with comprehensive feature sets to manage and troubleshoot SD-WAN environments.
  • Cisco data center (ACI, APIC, Spine, Leaf, and Catalyst series) monitoring to maintain visibility across critical infrastructure components.
  • Integration with scripting and automation platforms for streamlined operations and advanced network configurations.
  • Preferred: Support for internet availability monitoring, including ping tests to public IPs or more advanced capabilities.
I would appreciate any insights or recommendations on solutions that effectively fulfill these requirements. Looking forward to valuable suggestions from the community!
Best Regards,
Given your detailed requirements for monitoring both Cisco SD-WAN and Cisco ACI, along with deep application visibility, SNMP, NetFlow, and automation support, here are the top monitoring solutions that align well with your needs:
1. Cisco ThousandEyes + AppDynamics (Cisco Full Stack Observability)
Best for: End-to-end visibility, application performance, SD-WAN + ACI + cloud paths
Cisco SD-WAN Integration: Native integration provides hop-by-hop performance metrics, WAN health, path visualizations
Cisco ACI Monitoring: AppD agent visibility inside ACI fabric, and overlay correlation with APIC
Internet Monitoring: Synthetic transactions, BGP route visibility, DNS health, public endpoint ping tests
NetFlow / SNMP: Not primary focus, but can integrate with other tools like Stealthwatch
App Telemetry: Tracks transaction latency across tiers (e.g., app server → DB)
Automation: APIs and webhook integration with Ansible, Terraform, ServiceNow, etc.
This is Cisco's recommended full-stack observability suite—particularly strong if you're invested in Cisco infrastructure.
2. SolarWinds Hybrid Cloud Observability
Best for: Comprehensive SNMP, NetFlow, and Cisco visibility
Cisco SD-WAN Support: Monitors vManage, vEdge, WAN health, tunnels, SLA
ACI Support: Integration with APIC for topology, health scores, tenant metrics
SNMP & NetFlow: Best-in-class SNMP polling and NetFlow traffic analytics (NTA module)
Application Monitoring: AppInsight provides deep metrics for databases, VMs, and services
Scripting/Automation: REST APIs and PowerShell support
Internet Monitoring: ICMP, HTTP, TCP checks with historical trend views
Great if you want deep SNMP, NetFlow, and are managing large hybrid networks.
3. LogicMonitor
Best for: SaaS-based ease, ACI/SD-WAN visibility with modern dashboards
Cisco ACI Support: Monitors spine/leaf, APIC, tenant health, EPG status
Cisco SD-WAN: Templates for vManage, WAN edges, application route stats
SNMP & NetFlow: Built-in collectors and auto-discovery
Cloud & App Monitoring: Azure/AWS/GCP plus app stack metrics
Internet Monitoring: Pings, traceroutes, and service checks from global nodes
Automation: Native support for Terraform, APIs, and alert webhooks
Ideal for multi-vendor/cloud environments with modern UI and minimal setup time.
4. Paessler PRTG Network Monitor
Best for: Simplicity, strong SNMP and flow monitoring, affordable
Cisco SD-WAN: Via SNMP and custom sensors/scripts
ACI Support: Limited, but can be customized with REST APIs
SNMP & NetFlow: Excellent support for flows, IPFIX, and SNMP traps
App Monitoring: Includes sensors for HTTP, SMTP, FTP, etc.
Internet Monitoring: Built-in ping and latency sensors
Automation: REST API, scripting with PowerShell and Python
Budget-friendly option for small to mid-sized networks.
5. ManageEngine OpManager Plus
Best for: Feature-rich monitoring with SD-WAN/AIOps focus
Cisco SD-WAN: Templates for vManage, vSmart, vEdge with tunnel health
ACI Monitoring: Supports APIC and leaf/spine node metrics
NetFlow Analyzer: Built-in for traffic flows, bandwidth usage
App Monitoring: Monitors app response times and service availability
Internet Monitoring: Ping, HTTP, and DNS monitors
Automation: Workflow automation and REST API
Solid all-in-one solution with good UI and built-in reporting.
Summary Table
Solution SD-WAN ACI SNMP NetFlow App Monitoring Internet Tests Automation
Cisco ThousandEyes + AppD Native Native ⚠️ Limited ⚠️ Limited Deep APM Global agents APIs
SolarWinds Strong Moderate Best-in-class Full NTA
LogicMonitor
PRTG ⚠️ Basic ⚠️ Custom ⚠️ Basic
OpManager Plus
Recommendation
If you are:
Cisco-heavy (SD-WAN, ACI, Umbrella, AppD): go with Cisco Full Stack Observability (ThousandEyes + AppDynamics)
Need SNMP/NetFlow-heavy insights: use SolarWinds or ManageEngine
Want ease of use with fast deployment: consider LogicMonitor
