RV340 with German Telekom IPTV and Multi-WAN - some questions ahead
Patrick_de
Community Member
Hey,
I own a small business and got a 2nd ISP.
I have a RV340 up and running:
WAN1 - VDSL (modem in bridge mode) PPPoE (175mb/s)
WAN2 - Cable with static IP (1000mb/s)
Load-balancing is set to WAN2 80%, WAN1 20%
I added VLAN11 on eth3 for IPTV with dhcp server 192.168.11.0/24
I want WAN1 to get all incoming and outgoing traffic from VLAN11 and since the streams are
multicast, I have to setup the IGMP proxy right. I tried the policy based routing but I can't find
the right settings.
Is the RV340 capable of IGMPv3?
Anybody care to help?
Patrick
Georg Pauwen
Hello Patrick,
I don't think the RV340 supports IGMPv3, there is no option to select any IGMP version. The RV340 has only a few commands available through the CLI. You need a router with a full IOS in order to configure IGMP version 3...
