SD-WAN dual stack (IPv4 IPv6)
jgeralsky
Level 2
Level 2
Is there any case study or documentation about migration (data plane) from IPv4 to IPv6 (via dual stack) in SD-WAN environment ?
I want to understand the behavior, once I will enable IPv6 on cEdges.
Many thanks,
Jan
Kanan Huseynli
I haven't seen IPv6 deployment/ design guide for SD-WAN, but there is document about IPv6 functionality on Edge routers in SD-WAN:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/ipv6-functionality.html
Since, IPv4 and IPv6 is different stack protocols, they basically work independent i.e dual-stack is supported in SD-WAN which is good for migration and to think how to do migration. Also, you may need NAT64 options depending on your requirements.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/nat/nat-book-xe-sdwan/configure-nat64.html
HTH,
jgeralsky
Level 2
Level 2
It's a pity , there is no IPv6 deployment/ design guide for SD-WAN. There are a lot hidden details in migration from IPv4 to IPv6.
There is nobody, who made migration (data plane) from IPv4 to IPv6 (via dual stack) in SD-WAN ?
