Site to Public Cloud SDWAN Connection
fatalXerror
Level 7
Level 7
Hi Guys,
Sorry for this but I am really new into SDWAN. I would like to know how can I connect my site(hq/br) to the public cloud(AWS/Azure) via SDWAN? What devices do I need to deploy to have an SDWAN connectivity? Thank you so much.
inderdeeps
Level 9
Level 9
Hi Buddy the solution is simple, you need to have Cisco SD-WAN virtual appliances on AWS Marketplace. SD-WAN Cloud OnRamp for IaaS (virtual appliances automatically provisioned in the cloud and AWS VPC resources mapped to existing network network VPN segments)
Hosting SD-WAN controller components e.g. vManage, vSmart,etc.Enterprise branch connectivity to AWS (an indirect but critical benefit) which results in improved performance & reliability to AWS cloud plus quicker enterprise network migrations. Go to the below video helps you to understand. If you like dont forget to click on helpful button.
https://youtu.be/jbVJtqehqNw
Inderdeep
www.thenetworkdna.com
Hi @inderdeeps thanks for the feedback. So I can manage these virtualized vEdge routers in AWS or Azure using my existing vManage? Then as my transport, I can use either the internet or the express route or direct connect method? Thanks
Yes buddy you can do that.. Let me know if any further assistance required, Happy to help !
Kanan Huseynli
cloud on-ramp for IaaS feature will help you. See below:
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/sd-wan/white-paper-c11-742817.html
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/cloudonramp/vedge-20-x/cloud-onramp-book-vedge/m-cloud-onramp-iaas.html
HTH,
HTH,
