vEdge on MPLS PE router
p.hruby
Level 4
Level 4
Is it possible to configure WAN edge on a router which is also configured as a MPLS PE towards internal (LAN) network? Several MPLS/VPNs are configured on this router (in separate VRFs). Networks from these VRFs must be accessible from remote locations. Each remote location needs access to different set of VRFs/VPNs. Some VRFs/VPNs are intended for certain remote sites only. Other VPNs/VRFs are spread among more (all) remote sites. Currently we are using DMVPN for this purpose and we are considering Cisco SD-WAN.
p.hruby
Level 4
Level 4
If MPLS/PE is not supported on vEdge, is the mentioned design possible when VRF-lite is used on vEdge instead of MPLS/PE? I mean that vEdge will be connected by trunk to MPLS/PE (in corporate LAN core) and each subinterface (Vlan) will be configured in separate VRF on vEdge.
