05-10-2023 11:48 PM
i am trying to upgrade my vedge viptela image using the following command and i am getting the following error:
vedge# request software install reboot viptela-20.4.1.2-mips64.tar.gz
ls: cannot access 'viptela-20.4.1.2-mips64.tar.gz': No such file or directory
usage: /usr/bin/sw install <image>
vedge#
05-11-2023 12:00 AM
Why you looking to upgrade from command level ? is this vEdge managed by Vmanage ? why not use vManage to upgrade ?
05-11-2023 12:14 AM
not managed by vmanage
05-11-2023 12:01 AM
vedge# file show viptela-20.4.1.2-mips64.tar.gz
cat: viptela-20.4.1.2-mips64.tar.gz: No such file or directory
05-12-2023 05:24 AM - edited 05-12-2023 05:25 AM
did you added file to local disk? If yes, use below command:
request software install-image [file-name]
Don't forget to activate after "request software activate now [version]" command.
file show - command is for text files (alternative for cat in vshell), use file list command.
01-29-2024 09:01 PM
SAME PROBLEM
no vManage .getting this message ERROR: install: Kernel image not found
01-08-2026 09:31 AM
A colleague had the same error message when trying to upgrade a ISR-1100-6G (Gnutella), the issue was that the incorrect Viptela OS image was being used, is easy to mistake the vEdge1000 with the ISR-1100-6G inside the cisco software download center as the GNutellas images are linked with the vBond upgrade images.
