1750 and SDM
aamaral
Hi, anybody knows if the Cisco1750 supported SDM ? . If yes, what the last 1750 IOS version that supported it ?
TIA
Alexandre
royalblues
Level 10
Level 10
Hi alex,
THe SDM is supported on the 1751 from Cisco IOS Software Release 12.2(13)ZH, 12.2(13)T3, or 12.3(1)M
check out this link for more details
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_data_sheet0900aecd800fd118.html
HTH, rate if it does
Narayan
Dear Narayan,
Thank you for your help, but is a 1750 issue.
Do you have any information ?
once more tks !!!
Alexandre
hi Alex,
I ma not clear with your post regarding 1750 being an issue.
If you want SDM support on your router, the device should be running the code mentioned in the doc
Narayan
