12-08-2011 02:16 PM - edited 03-04-2019 02:34 PM
Hello.
I want to upgrade IOS on 1811 from 12.4(11)T3 to 12.4(15)T16.
As a standard CF size in the 1811 is 32 M, so I have to free some space.
Here the strange things starts.
dir issued on the router shows thet ther is no image on the flash!
dir
Directory of flash:/
No files in directory
31940608 bytes total (12771328 bytes free)
sh ver shows that
uptime is 19 weeks, 2 days, 9 hours, 22 minutes
System restarted at 15:21:30 EEST Tue Jul 26 2011
System image file is "flash:c181x-advipservicesk9-mz.124-11.T3.bin"
The other strange thing is that some space is allocated for something!
(flash size) 3194060 - 12771328 (free) = 19169280 (space allocated to ???)
Just now router is running IOS c181x-advipservicesk9-mz.124-11.T3.bin
The size of this IOS is 19 155 816, that is approximately equal to the size that allocated to something invisible.
fsck flash and format flash doesn't help.
Bug Toolkit doesn't show any bugs similar to my issue.
How can I free space on the flash?
12-08-2011 02:26 PM
Don't know if this is going to help, but try "squeeze".
12-08-2011 02:42 PM
Thank you for reply, but 1811 has class C file system. squeeze is not supported on class C.
12-08-2011 02:49 PM
Then you got a faulty CF. You can replace it the right way or the "that's about right" way.
12-08-2011 02:59 PM
And if you are going to buy a new flash card, you may as well get a 128Mb one, so you don't have to run out of space anytime soon.
