05-30-2012 06:09 PM - edited 03-04-2019 04:31 PM
Hi all,
I have a 1841 router plugged into a 100M Comcast ethernet connection. My router cpu is really high and users download speed isn't as high as before.
Can a 1841 handle 100M circuit with 100 users on it? What would cause the router's cpu to be high? I don't think there are any viruses or malware on the lan.
#sh proc cpu his
r2.leaguecity-toy-startoy 06:06:26 PM Wednesday May 30 2012 PST
111 1 1 1 111 24 1 1 1 1
400369232222544222330359645223283294332688334452308404382236
100
90
80
70
60
50
40 *
30 *
20 * ** ** *
10 *##** * * * *** * # * *##*## #* ** * * #
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
438455339843 11423643653343 1 1 136346767584627
325952930008922225232611080609697827887864667630020933071108732332232342
100
90 * *
80 * ** * *
70 * ** * * ** * * *
60 * * ** * ** * ****** * *
50 **** ** * ** * ****** * *
40 * ***** **** * ********* * ********* *
30 ************ ************ **************
20 ************ ************ * **************
10 *#########*** * ****##########***************#########**
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
05-30-2012 06:20 PM
Hello Russell,
Why you consider your CPU to be High?
1 hour graph showing it to be very low - around 10%. 72 hour graph showing baseline (#) also close to 10% - there are only just few spikes seen those can be related to some routing updates, spikes in traffic or telnet/ssh session done to router, etc.
I don't see any point to worry now unless you see it consistently. If it is possible - please capture "shwo proc cpu sort" during the spike to see what it is driven by.
Nik
