I have a Cisco 1841 router which stops functioning sporadically. You have to manually go do hard reboot on the router before it starts working properly.
When it goes down, you cannot ping its internal interface (from the LAN side) not its public interface, it seems to go down quite regularly.
Where do i start to diagnose, is it hardware failure, or config issue. Nothing has changed as far a the config goes lately.
Please advise. Thanks
