I cannot seem to get my DNS setup working.
GOAL
Every device inside the LAN should only have 1 DNS server (the 1861 Router)
If that router doesn't know the answer the DNS request should be forwarded to the ISP.
ROUTER
1861 IOS 15.1.3T3 (adv.ent.k9) - DNS server for LAN. ISP provides DNS for public servers
NOTE: that the domain name used internally 'mydomain.com' also exists on the public internet
PROBLEM
The router cannot ping the ISP DNS server, except when using VLAN1 as the source
Devices on the LAN can ping the router and the ISP's DNS servers
ip domain timeout 2
ip domain name mydomain.com
ip host mydomain.com ns ns.mydomain.com
ip host ns.mydomain.com 10.1.1.10
ip host www.mydomain.com 62.19.22.133ip host home-wifi.mydomain.com 10.1.1.7
ip host home-iphone.mydomain.com 10.1.1.3
ip host home-router.mydomain.com 10.1.1.10
interface FastEthernet0/0
description ---- FW_OUTSIDE
mac-address 0010.a0a0.a0a0
ip address dhcp client-id FastEthernet0/0
ip access-group 10 in
ip access-group 10 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ntp broadcast client
no cdp enable
no mop enabled
interface Vlan1
description ---- FW_INSIDE
ip address 10.1.1.10 255.255.255.0
no ip redirects
no ip unreachables
ip dns view-group default-list
ip nat inside
ntp broadcast
no mop enabled
ip dns view default
domain timeout 2
domain name-server 112.34.60.35
domain name-server interface FastEthernet0/0
domain round-robin
dns forwarder 112.34.60.35
dns forwarder 112.34.40.35
dns forwarding source-interface FastEthernet0/0
ip dns view-list default-list
view default 10
ip dns server
ip nat translation timeout 180
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static
access-list 10 deny 181.122.46.156 (Just an IP I want to block)
access-list 10 deny 181.133.20.188 (Just an IP I want to block)
access-list 10 permit any
Any ideas? Feel like I'm overlooking something 'simple' ;-)
My guess is that the problem involves this statement in the config
in the config that you have posted there is no access-list 1. I suggest that you create access-list 1 and tell us whether the behavior changes or not.
Rick
