07-07-2017 07:54 AM - edited 03-05-2019 08:49 AM
Need help connecting cisco to ADSL router to obtain Internet connection. Please assume ADSL modem doesn't have any other functionalities than just simply getting the internet service.
ADSL router contains username and password to connect to ISP via PPoE
1) ADSL router
ADSL WAN IP x.x.x.x/32
ADSL Router's gateway 192.168.1.254
DHCP enabled - 192.168.1.0/24
2) Cisco 1921 - No HWIC's
DHCP enabled - 10.10.10.0/24
No Vlans at present
(Thinking about creating a router on a stick 802.1Q trunking by adding a seperate subnet for voice in the future)
gi0/0 - ip address 192.168.1.250/24
ip nat outside
gi0/1 - ip address 10.10.10.254/24
ip nat inside
gi0/1 - Switch
Switch to end user devices.
access-list 10 to allow 10.10.10.0/24 & 172.16.0.0/24
ip route 0.0.0.0 0.0.0.0 192.168.1.254 (Next hop being the ISP router)
ip nat inside source list 10 int gi0/0 overload
Does this setup work ?
07-07-2017 08:15 AM
you have two options:
1. Put the ADSL router in bridge mode, the interface on the 1921 (GigabitEthernet0/0) will be assigned the public IP address, and you can configure it as the Internet edge device doing the NAT
2. Leave the ADSL router as it is, and add the networks on the 1921 (10.10.10.0/24 and 172.16.0.0/24) to the networks to be translated. This needs to be done in the ADSL router. Simply point the default route on the 1921 to either the next hop address on the ADSL (ip route 0.0.0.0 0.0.0.0 192.168.1.254) or out the connecting interface (ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0).
The second is probably the easier option. If you opt for the first, post the configuration of the 1921, and we can add the necessary bits and pieces...
07-07-2017 09:31 PM
With reference to option 1, after putting the ADSL router on bridge mode, did you mean that I create a ppp dialer on dialer interface?
Option 2, might not be always feasible because there are some adsl routers out in the world which doesn't support what we need :)
My orginal way of setup worked well
07-07-2017 11:36 PM
option 1 indeed includes a dialer interface. As Paul suggested, double NAT works fine, the only thing is, you cannot access any of your devices from the outside. You are fine if that is not a requirement.
As to option 2, what type and brand is your ADSL modem ? I'll check if you can configure it for bridge mode.
07-08-2017 04:49 AM
With reference to double natting and port forwarding to access devices from outside, I know for the fact that I can setup a port forward on the ISP's Edge ADSL router for port 22 to be forwarded to cisco's gi0/0's ip so that we can ssh into the Cisco from outside.
Please assume that I have a security camera connected to the cisco router and its IP is 10.10.10.100/24 and it uses port 8000.
For me to be able to access the security camera from outside what If I double port forward? i,e., port forwad tcp 8000 on the ISP router to cisco's IP which is 192.168.1.250 and in the cisco
ip nat inside source static tcp 10.10.10.100 8000 int gi0/0 8000
Will this setup work ?
I have got option 2 working as well. I didn't mean about bridge mode when I said that some ADSL modem's might not have that option. A s a matter of fact, most of the ADSL routers can be set to bridge mode, PPPoEthernet or PPPoATM. My statement was pertinent to adding the subnet from cisco into the ADSL router.
07-08-2017 05:38 AM
double NAT and port forwarding (from the 1921 in your case) won't work (at least I have never seen it work). That is why I suggested the bridge mode...
07-08-2017 06:06 AM
Thats fine. I'll test on Monday.
07-08-2017 08:50 AM
Hello
Yes you can static nat to a host on your internal network of the 1921 rtr, it is possible but will you need to configure not only a static nat entry on that rtr but also on the xDSL rtr.
res
Paul
07-08-2017 04:31 PM
Hello
I had some time thought i would lab this up for double nat translation:
Public-router .4 <10.1.14.0--> .1 ADSL 1. <10.1.12.0--> .2 1921 .2<10.1.23.0->.3 host .101
1) Public router
interface Loopback0
ip address 8.8.8.8 255.0.0.0
2) adsl
ip nat inside source static tcp 10.1.12.2 80 interface FastEthernet0/1 80
Pro Inside global Inside local Outside local Outside global
tcp 10.1.14.1:80 10.1.12.2:80 --- ---
3)1921
ip nat inside source static tcp 10.1.23.101 80 interface FastEthernet0/0 80
tcp 10.1.12.2:80 10.1.23.101:80 --- ---
4) host
sh ip route
Default gateway is 10.1.23.2
SH IP HTtp Server status | in port
HTTP server port: 80
HTTP secure server port: 443
TEST:
pubilc-router#
telnet 10.1.14.1 80 /source-interface loopback 0
Trying 10.1.14.1, 80 ... Open
ADSL#
sh ip nat translations
tcp 10.1.14.1:80 10.1.12.2:80 8.8.8.8:47642 8.8.8.8:47642
1921
#sh ip nat translations
tcp 10.1.12.2:80 10.1.23.101:80 8.8.8.8:47642 8.8.8.8:47642
res
Paul
07-09-2017 05:47 PM
Well done. What is ADSL router's model number?
07-10-2017 05:22 AM
Hello
It wasn't on any xDSL router but the concept of double nat was produced just so you would understand it can work.
res
paul
07-07-2017 11:18 AM
Hello
I see no issues with your double natting - simplistic option
your need to have dhcp somewhere to see in your lan environment for your lan hosts have the 1921 as the hosts default-gateway - lasty have a default route pointing to the SP
If you need sample config im sure others will be happy to provide it- at present im not in position to do so myself as I'm in transit
res
paul
07-07-2017 12:00 PM
I actually try to avoid double NAT as much as possible, if only because I cannot get to anything from the outside anymore then. If OP doesn't need outside to inside access, I guess it is a viable option...
07-07-2017 09:29 PM
Double nating worked. Provided 2 way data flow.
07-07-2017 05:24 PM
Can someone please provide me a sample config?
