Community Helping Community
2423
Beginner
1941 ADSL failover to 3G HWIC with IPSEC VPN - DDNS -- IP SLA
The setup is a S2S VPN with failover to 3G HWIC in a Cisco 1941 however the IPSEC tunnel needs to remain up through 3G if ADSL fails.
The failover works ok, however when plugging ADSL back in, the - "sh crypto session" shows both dialer 0, and dialer 1 with the crypto map session to the other side of the VPN and either side is now not pingable.
The NoIP DDNS updater client runs on a server in the network and all IP resolution to host1,host2 works ok
(other side of VPN is Cisco 1921 with ADSL HWIC and 3G HWIC)
Any assistance would be greatly appreciated-
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname LAB
boot-start-marker
boot-end-marker
logging buffered 16000
no aaa new-model
memory-size iomem 10
no ipv6 cef
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.20.1
ip dhcp pool LAN_POOL
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.1
   dns-server  8.8.8.8
no ip bootp server
ip domain name host1.hopto.org
ip name-server 8.8.8.8
chat-script extranet "" ATDT*98*1#" TIMEOUT 30 CONNECT
username xxxxxxxx privilege 15 secret xxxxxxxxxxx
redundancy
ip ssh version 2
track 234 ip sla 1 reachability
delay down 5 up 5
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxx hostname host2.hopto.org
crypto isakmp profile IPSEC_PROFILE
   keyring default
   self-identity fqdn host1.hopto.org
   match identity host host2.hopto.org
   initiate mode aggressive
crypto ipsec transform-set site2site esp-3des esp-sha-hmac
crypto map VPN-Network 1 ipsec-isakmp
description Tunnel to xxxxx
set peer host2.hopto.org dynamic
set transform-set site2site
set isakmp-profile IPSEC_PROFILE
match address 100
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface ATM0/0/0
bandwidth 20000
no ip address
load-interval 30
no atm ilmi-keepalive
hold-queue 224 in
interface ATM0/0/0.1 point-to-point
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 2
interface Cellular0/1/0
no ip address
ip nat outside
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 1
async mode interactive
no fair-queue
interface Dialer0
description Primary ADSL Link
ip address negotiated
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
no ip route-cache cef
dialer pool 2
ppp authentication chap callin
ppp chap hostname xxxxxxx
ppp chap password xxxxxxx
no cdp enable
interface Dialer1
description 3G BACKUP LINK
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string extranet
dialer persistent
no fair-queue
no cdp enable
ip local policy route-map track-primary-if
ip forward-protocol nd
ip http server
ip http access-class 22
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source route-map nat2cell interface Dialer1 overload
ip nat inside source route-map nat2dsl interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 track 234
ip route 0.0.0.0 0.0.0.0 Dialer1 200
ip sla 1
icmp-echo 1.1.1.1 source-interface Dialer0
frequency 5
ip sla schedule 1 life forever start-time now
access-list 22 permit 10.10.10.0 0.0.0.255
access-list 100 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 remark IPSec Rule
access-list 101 deny   ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 permit ip 10.10.20.0 0.0.0.255 any
access-list 110 permit icmp any host 1.1.1.1
no cdp run
route-map track-primary-if permit 10
match ip address 110
set interface Dialer0
route-map nat2dsl permit 10
match ip address 101
route-map nat2cell permit 10
match interface Dialer1
snmp-server community xxxxx RO
control-plane
banner login ^C
* Access to this computer system is limited to authorised users only. *
* Unauthorised users may be subject to prosecution under the Crimes   *
*                       Act or State legislation                      *
* Please note, ALL CUSTOMER DETAILS are confidential and must         *
*                         not be disclosed.                           *
^C
line con 0
transport output all
line aux 0
line 0/1/0
exec-timeout 20 0
script dialer extranet
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 2000000
line vty 0 2
access-class 22 in
exec-timeout 20 0
login local
transport input telnet
line vty 3 4
exec-timeout 20 0
login local
transport input ssh
scheduler max-task-time 5000
scheduler allocate 20000 1000
event manager applet pri_back
event track 234 state any
action 2.0 cli command "clear ip nat trans forced"
end
5 REPLIES 5
Advisor
Is this a typo ?
Regards.
Alain.
Beginner
Gee, I hope that was all it was, I'll test and let you know. I think you're referring to the "route-map nat2cell permit 10" and not the "route-map nat2dsl permit 10" however? The "match" is incorrect.
Beginner
On second thoughts,  which logic is correct?
match interface Dialer0
or
Advisor
if the route-map is used for NAT then the correct statement is match because the set command is use for example in PBR.
Alain
Beginner
Right!
Ok that part, ie the 3G failover appears ok however, even what applying Dynamic DNS config to the router, the best I can time is a 3 minute failover before the VPN tunnel kicks back in if either side drops.
DDNS added as follows (names changed)-
ip ddns update method mymethod
HTTP
  add http://USER:PASSWORD@dynupdate.no-ip.com/nic/update?hostname=HOST1.HOPTO.ORG&myip=PASSWORD@dynupdate.no-ip.com/nic/update?hostname=HOST1.HOPTO.ORG&myip=
interval maximum 2 0 0 0
int d0
ip ddns update hostname host1.hopto.org
ip ddns update mymethod
int d1
When failover to 3G occurs and when host1.hopto.org is then pingable again from the internet (using 3G), the VPN tunnel still takes a long time to re-establish, however it does work.
Can the IPSEC timers be set more aggressively?
"keepalive 10 retry 2" has already been added under "crypto iakmp profile IPVAS_PROFILE"
"clearing crypto session" on BOTH sides solves problem immediately and VPN comes up but otherwise it will take around 3-3.5 mins.
Any help will be appreciated.
Content for Community-Ad
FusionCharts will render here
