1941 ISR with 15.3M5 IOS - Pseudowire
crawford.j
All,
  I have a 1941 ISR that will be replacing an 1841 ISR, due to the high CPU utilization being caused by virtual packet reassembly .  The biggest problem I'm running into is that IOS 15 doesn't seem to support Pseudowire Xconnect.  Has this command depreciated or disappeared?  Will the 1941 ISR support a 12.4 code?  I can't seem to find any supporting documentation.  I know that the 1941 will support l2tp-tunneling and MPLS pseudowire, but nothing for xconnects under the sub-interfaces.
acampbell
Hi.
I think your issue is liable to be the license that you have on your 1941.
By default you will have a an IP-Base license but to run the complex protocols like MPLS etc you need a DATA license
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
On which IOS versions - A 1941 is part of the ISR-G2 family - They start at IOS ver 15.0 - No support in ver 12 at all.
Alex
Regards, Alex. Please rate useful posts.
