1941 Router
Joe Lee
The 1941 router has USB ports, Will it support a USB celluar data card? Please advise.
Joe
5 Replies 5
paolo bevilacqua
No, it will not.
You need to buy a specific HWIC card for 3G data access.
Hi Paolo,
Can you please provide me the name of the HWIC card? or the link will be helpfull.
Joe
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
This lists the modules supported on the ISR G2 routers. You want to look at the section on 'Wireless WAN modules' on page 6.
The USB for nextGen use i don’t think it can be used anyways
thomasanthony
