Showing results forĀ
Search instead forĀ
Did you mean:Ā
2 Catalyst 6500 ; 2 problems
Free Bird
I have depoloyed 2 catalyst 65k as a single entity VSS ; m getting the following error when saving the configration on the primary/local player.
Dec  4 23:15:16.971: %PFREDUN-SW1-4-BOOTSTRING_INVALID: The bootfile s2t54-ipse
rvicesk9-mz.SPA.151-2.SY2.bin is present on the active supervisor but not on the
 standby
the bootfile reside on the standyby as well with the exact same name and version , but this error pops up everytime upon saving the config.
2nd problem is regarding the VSS redundancy :
I am testing the standby part taking over as active player.
for verifying this I took out the VSL links from the active switch. (switchA).
the switchB takes place as active but the SwitchA goes into RECOVERY and when i see '.'show virtual switch role' on SwitchB ; it shows  both switches in ACTIVE state.
after a while i reloaded SwitchA and ran ''show virtual switch role' on SwitchB then it showed switchA as HOT STANDBY..
the bottomline is that I want to make the SwitchA go directly into HOT STANDBY mode when I plug out the VSL link.
kindly suggest what to do.
P.S. : (total 4 ports working as fast-hello , 2VSL ones ; and 2 2-gig ones.) I only took out the VSL links.
Vinit Jain
Could you please check the boot statement on both the switches. Please share the below outputs:
- show run | in boot
- show version | in image
- show redundancy
Vinit
--Vinit
HERE GOES YOUR REQUESTED OUTPUTS!!
show run | in boot
boot-start-marker
boot bootstrap tftp s2t54-ipservicesk9-mz.SPA.151-2.SY2.bin 255.255.255.255
boot system flash s2t54-ipservicesk9-mz.SPA.151-2.SY2.bin
boot-end-marker
diagnostic bootup level minimal
System image file is "bootdisk:s2t54-ipservicesk9-mz.SPA.151-2.SY2.bin"
show redundancy
Redundant System Information :
       Available system uptime = 1 week, 1 day, 23 hours, 19 minutes
Switchovers system experienced = 2
              Standby failures = 0
        Last switchover reason = active unit removed
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Down      Reason: Failure
Current Processor Information :
               Active Location = slot 1/7
        Current Software state = ACTIVE
       Uptime in current state = 17 hours, 22 minutes
                 Image Version = Cisco IOS Software, s2t54 Software (s2t54-IPSER
VICESK9-M), Version 15.1(2)SY2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 26-Feb-14 16:03 by prod_rel_team
                          BOOT = s2t54-ipservicesk9-mz.SPA.151-2.SY2.bin,1;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED
' state
