02-18-2017 06:55 PM - edited 03-05-2019 08:03 AM
Hi all Cisco Experts,
Good day! i just need help on implementing redundancy and load balancing on our two (Frame relay/ISP) network from our branches.
I want to now what are the devices capable of redundancy and load balancing and also its required software. Thank you.
Harley
Solved! Go to Solution.
02-18-2017 08:04 PM
For load balancing and redundancy, you can run a routing protocol. A basic cisco router supports routing protocols. 17xx and 2600 are end of sale. They work, but you'd probably better go with newer versions in case of supporting new features.
Masoud
02-18-2017 07:24 PM
Cisco 1800 series with serial modules(for frame relay) would be a good choice. IP base IOS supports redundancy and load balancing if you do need any other feature such as encryption.
Please take a look at the link below:
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-packaging/product_bulletin_c25-557276.html
Masoud
02-18-2017 07:54 PM
Hi Masoud,
Thank you for answering my query, I think this is one of the solution, but another problem is the ISp has a multiplexer thing that its output is already a Fastethernet ports.
I have options: Cisco routers 17xx, 19xx, 26xx but i dont know if it is capabale of load balancing & automatic swithching.
harley
02-18-2017 08:04 PM
Masoud
02-18-2017 08:16 PM
Thank you so much sir masoud, I appreciate so much your support. I will now look for a newer versions of cisco routers that can cater both redundancy and load balancing protocols. But ill try first to utilize our existing 1921 router if will work. :D Thanks again Masoud
Harley
02-18-2017 08:22 PM
You are most welcome. 1921 is a better option than others you suggested. As I said, others also work, but they are not supported anymore.
Masoud
