2 internet lines active/active use
Hello Everyone.
I need some clarifications from experts.
Client has two internet lines from different ISP's (DNS is different for both internet lines) and wants use both the internet lines as active/active. For active/passive i belive SLA will be helpful but for active what should be used (is it PBR?)
Right now only single internet line is functional and second internet line need to be connected in the network.
Furthermore, ASA firewall need to be deployed between core switch and internet router.
Do i need to connect second internet line on the same router or i have to use use another router. Kindly advise.
Please advice.
Many Thanks.
5 Replies 5
Ruben Cocheno
both providers will give diferent public IPs, so that means you will need use PBR on router based on source address and do NAT on Firewall
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Many Thanks for the reply rcochenos.
Could you please elaborate your answer if possible with simple configuration example. I am using the 192.168.X.X and 10.10.X.X subnets.
On core switch there one default route pointing to router. One router if i do the below configuration where 192.168.x.x traffic is forwarded on ISP A and 10.10.x.x traffic is forwarded ISP B. Will it work
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip 10.10.0.0 0.0.255.255 any
route-map test permit 10
match ip address 101
set interface fa0/0
exit
route-map test permit 20
match ip address 102
set interface fa0/1
exit
route-map test permit 30
ip local policy route-map test
Usually we do the PAT on router where public IP is terminating in order to allow internet access to all the users.
I did not get why you advised to do nat on router.
Additionally customer asks if ISP A is down then traffic should be forwarded be ISP B and vice versa.
Any replies in the above regard will be helpful
hi
try use set ip next-hop next_hop1 next_hop2 next_hopx instead of interface, using interface require more lookups unless the IP of that particular interface is dynamic. You need to apply the policy on interface inbound.  the ip local policy is to use PBR for traffic generate by router itself.
if you have the public IPs on the router in that case the best place to do NAT is on the router.
Thanks for reply rcochenos.
Could you please have a look on the below summarized points.
1. When the traffic will come for subnet 192.168.x.x on router it will be forwarded to ISP 1 using PBR.
2. When the traffic will come for subnet 10.10.x.x on router it will be forwarded to ISP 2 using PBR.
3. Topology will be like this
        ISP1-------->Internet
LAN ------->Core Switch------>Firewall ------------>Router---|
        ISP2-------->Internet
4.Solution Configuration
interface FastEthernet1/0
description LAN interface
ip address 172.16.1.254 255.255.255.0
ip nat inside
ip policy route-map PBR    ---- this is for policy based routing
interface FastEthernet1/1
description To ISP 1
ip address <public IP1> 255.255.255.252
ip nat outside
interface FastEthernet2/0
description To ISP 2
ip address <public IP 2> 255.255.255.252
ip nat outside
exit
PBR Configuration.
set ip next-hop <ISP1 Public IP>
exit
set ip next-hop <ISP2 Public IP>
exit
Routing
ip route 0.0.0.0 0.0.0.0 ISP1-Next-Hop-IP
ip route 0.0.0.0 0.0.0.0 ISP2-Next-Hop-IP
Natting
access-list 10 permit 10.10.0.0 0.0.255.255
access-list 20 permit 192.168.0.0 0.0.255.255
route-map ISP1 permit 10
match ip address 20
match interface FastEthernet1/1
route-map ISP2 permit 10
match ip address 10
match interface FastEthernet2/0
ip nat inside source route-map ISP1 interface FastEthernet1/1 overload
ip nat inside source route-map ISP2 interface FastEthernet2/0 overload
I can see on disadvantage in the above configuration i.e. there is not failover when ISP1 is down 192.168.x.x traffic is not switching to ISP2 and vice versa for 10.10.x.x. Additionally how can i assign dns ip address on router or clients as there are different for ISP1 and ISP2. (is it like this ip name-server x.x.x.x x.x.x.x x.x.x.x x.x.x.x).
Do i need to use IP SLA tracking with static router and PBR.
Is the above solution will work perfectly if i dont need any failover and send 192.168.x.x traffic to ISP1 and 10.10.x.x traffic to ISP2
Thanks for your continues support.
Please reply.
You don't need match the interface on route-maps
match ip address 20
no match interface FastEthernet1/1
match ip address 10
no match interface FastEthernet2/0
the failover is doing by using ip next-hop for both ISP or leave one like you are doing and if next-hop is not available the router will use the routing table to route the packet
failover scenarios
1)If interface fail the next-hop disappear and PBR use the routing table to forwarding
2)for some reason if next-hop stop responding and your router interface stay up you can use IP SLA + Track to Speed up
Leave the clients doing DNS queries to both ISPs
