02-16-2012 06:34 AM - edited 03-04-2019 03:17 PM
In france, currently we're requesting to our Internet provider (Orange : France Telecom) to update our
access with optical fiber (replacing copper wires).
In a few words, we're using VPN and Orange boxes to remote connect on customer newtorks to give them some support.
My 2 questions are :
- can we add a SFP port (optical fiber) on a Cisco router ?
- Is there any adsl Cisco modems supporting the optical fiber ?
I hope I could correctly express my demand,
thanks a lot in advance,
best regards,
Laurent
Solved! Go to Solution.
02-16-2012 07:44 AM
- can we add a SFP port (optical fiber) on a Cisco router ? High end routers, (ASR, 76xx,GSR....newer ISRs sucha as some models of 3900 and 2900 series )
What model router are you particularly interested in ?
- Is there any adsl Cisco modems supporting the optical fiber ? - None that I could find.
02-16-2012 08:01 AM
Well, the Pix is actually a security device (firewall). It has been end of sale for quite some time.
I would suggest looking at the ASA series if you want to keep the same topology.
02-16-2012 07:44 AM
02-16-2012 07:54 AM
Thanks a lot vmiller,
The model router is a PIX 515E
02-16-2012 08:01 AM
02-16-2012 08:13 AM
Ok, so you mean that replacing my 515E by a ASA serie I could have the same utility (firewall)
and I will be able to plug SFP modules on it ?
Thx again
02-16-2012 08:40 AM
Yes & No. You would get the same security functionality, but according to the data sheet you would need the 5580 to
get SFP compatability. You might consider a small, sfp capable switch to terminate your link, and then connect the
firewall to the switch.
Bon Chance...
02-19-2012 11:51 PM
Thanks a lot !
