2600 router bot able to boot normaly
att-sgcops
Very time I reload the router, it always gives the prompts:
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 4K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
C2600 platform with 40960 Kbytes of main memory
rommon 1 >
And according to the cisco sugrestion as mentioned as
http://64.233.167.104/search?q=cache:IOzwo0nqkcUJ:www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml+load+IOS+2600&hl=zh-CN&lr=lang_zh-CN|lang_zh-TW|lang_en
I changed:
rommon 2 > confreg
Configuration Summary
enabled are:
diagnostic mode
load rom after netboot fails
ignore system config info
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C2600
do you wish to change the configuration? y/n [n]: y
disable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
disable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
disable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]: 3 <----changed to 3
enabled are:
diagnostic mode
console baud: 9600
or default to: cisco3-C2600
rommon 4 > dir flash:
File size Checksum File name
11405172 bytes (0xae0774) 0xebf9 c2600-js56i-mz.121-3.T.bin <--------Can see the IOS on the router
But After I did that, I am still not able to boot the router normaliy, can some one tell what is the problem?
6 Replies 6
stomasko
Level 4
Level 4
Try just setting it with the command:
confreg 0x2102
then reset
If not do you see any errors during the boot sequence?
Hope this helps.
Steve
not helpful.
Do I ned to write memnory after I change the confreg oX2102?
Do u hve a copy of the exisiting IOS code so that you can remove the current one and upload afresh using either tftpdnld or xmodem...
regds
If you enter it in ROMMON mode you don't need to save it if you enter it in ENABLE mode you do.
Can you boot the IOS using the BOOT command from ROMMON mode?
lanbrown
Can you manually boot the IOS code from the ROMMON prompt? If so, just add a line to the IOS config with the path of the image. For help, do boot ?
As the guys above have mentioned...enter the following at the rommon prompt.
rommon 2 > boot flash:c2600-js56i-mz.121-3.T.bin
Cheers
Sarb
