2651 Clock source question
ckeithjones
I have a 2651 with a 4 port serial card. I cannot get any commands to work which might set the clock source. Is there another place in the IOS where I can set this?
FEIDATAR#show hard
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(20), RELEASE SOFTWARE (fc2)
cisco 2651 (MPC860P) processor (revision 0x200) with 28672K/4096K bytes of memory.
Processor board ID JAB05200C4C (4276647583)
M860 processor: part number 5, mask 1
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
FEIDATAR(config-if)#clock ?
  rate  Configure serial interface clock speed
Interface Serial0/1
Hardware is PowerQUICC MPC860
DTE V.35 TX and RX clocks detected.
idb at 0x815B81D8, driver data structure at 0x815BFFAC
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0300, Mask [SCCM]=0x001F, Status [SCCS]=0x03
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00008C04
Mask   [CIMR]=0x48204002, In-srv  [CISR]=0x00000000
Command register [CR]=0x6C0
Port A [PADIR]=0x4000, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0x29FE
Port B [PBDIR]=0x0FF0F, [PBPAR]=0x0600E
       [PBODR]=0x00000, [PBDAT]=0x3631D
Port C [PCDIR]=0x00C, [PCPAR]=0x000
       [PCSO]=0xBA0,  [PCDAT]=0xFC0, [PCINT]=0x00F
Receive Ring
        rmd(68012A70): status 9000 length 60C address 1DCD604
        rmd(68012A78): status 9000 length 60C address 1DC8804
        rmd(68012A80): status 9000 length 60C address 1DCDC84
        rmd(68012A88): status 9000 length 60C address 1DD0A04
        rmd(68012A90): status 9000 length 60C address 1DD2A84
        rmd(68012A98): status 9000 length 60C address 1DD3784
        rmd(68012AA0): status 9000 length 60C address 1DCE984
        rmd(68012AA8): status 9000 length 60C address 1DC9B84
        rmd(68012AB0): status 9000 length 60C address 1DD1704
        rmd(68012AB8): status 9000 length 60C address 1DD3104
        rmd(68012AC0): status 9000 length 60C address 1DD0384
        rmd(68012AC8): status 9000 length 60C address 1DC9504
        rmd(68012AD0): status 9000 length 60C address 1DCF684
        rmd(68012AD8): status 9000 length 60C address 1DCF004
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0x68013F00)
Rx BD Base [RBASE]=0x2A70, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x2B30, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x2A70
Tx State [TSTATE]=0x0, BD Ptr [TBPTR]=0x2B30
SCC HDLC PARAMETER RAM (at 0x68013F38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=10945
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
153 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
328 aborted short frames
Giuseppe Larosa
Hello Ckeithjones,
clock rate can be set only on a serial interface connected to a DCE cable
in your case
Or you swap the cables or you configure the clock rate on the other side
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ckeithjones,
in your case
Hope to help
Giuseppe
