05-28-2005 11:24 PM - edited 03-03-2019 09:42 AM
I have a 2651XM router which has shipped with a 128 MB RAM. I want to upgrade this to 256 MB.
I have a 15-8693-01 memory card already present on the router . I inserted the 128 DRAM card got from cisco , but have some issues here... when the router boots up, it shows
C2600 platform with 262144 Kbytes of main memory
but after booting , the show version command shows,
cisco 2651XM (MPC860P) processor (revision 0x400) with 111616K/19456K
bytes of memory.
Both the memory cards are fine, as they work as standalone 128 MB cards, but when put together, shows only 128 MB on show version.
What exactly is the issue here.. am sure the 2651 supports 256 MB DRAM.
Please lemme know..
Solved! Go to Solution.
05-29-2005 07:45 AM
Raj,
I think the problem is due to DDTS CSCeg14149
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCeg14149
Here is the associated field notice.
05-29-2005 07:45 AM
Raj,
05-29-2005 10:26 PM
Bulls eye... thanks a lot shanky...
