2811 ROUTER - REBOOT PROBLEM
Hi guys,
I've implemented dual internet on my cisco 2811 router, everything is working properly and after a period of time the router gives the below message thousand of times and reboots
%SYS-2-INTSCHED: 'suspend' at level 3 -Process= "IP NAT Ager
Please see below my configuration and let me know if i have something wrong
Current configuration : 19481 bytes
version 12.4
service password-encryption
hostname test
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 32568
aaa new-model
aaa session-id common
clock timezone EEDT 2
clock summer-time EEDT recurring last Sun Mar 3:00 last Sun Oct 4:00
dot11 syslog
ip source-route
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip cef
ip domain name neocleous.com
ip inspect tcp reassembly queue length 756
ip inspect name CBAC tcp
ip inspect name CBAC udp
ip inspect name CBAC icmp
ip inspect name CBAC ftp
ip inspect name CBAC http
ip inspect name CBAC imap
ip inspect name CBAC imap3
no ipv6 cef
voice dsp waitstate 0
voice-card 0
no dspfarm
track 1 ip sla 1 reachability
delay down 1 up 1
track 2 ip sla 2 reachability
delay down 1 up 1
interface FastEthernet0/0
description PRIMETEL
bandwidth 8000
ip address [public ip] 255.255.255.240
ip access-group CBAC-OUT-NEW in
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
description INSIDE-TO-LAN
ip address 192.168.100.x 255.255.255.240
ip nat inside
ip inspect CBAC in
ip policy route-map PBR
duplex full
speed 100
interface FastEthernet0/0/0
description CYTA
ip address [public ip 2] 255.255.255.248
ip nat outside
duplex full
speed 100
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 [gateway public ip] track 1
ip route 0.0.0.0 0.0.0.0 [gateway public ip 2] track 2
no ip http server
no ip http secure-server
ip nat inside source route-map CYTA interface FastEthernet0/0/0 overload
ip nat inside source route-map PRIMETEL interface FastEthernet0/0 overload
ip nat inside source static 192.168.100.13 [an ip in the range of public ip 2] route-map CYTA-STATIC-NAT
ip nat inside source static 192.168.3.23 [an ip in the range of public ip 2] route-map CYTA-STATIC-NAT
ip nat inside source static 192.168.100.13 [an ip in the range of public ip] route-map PRIMETEL-STATIC-NAT
ip nat inside source static 192.168.3.23 [an ip in the range of public ip] route-map PRIMETEL-STATIC-NAT
ip access-list extended ALLOW-EVERYWHEREACCESS
permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended ALLOW-WEB
permit tcp 192.168.0.0 0.0.255.255 any eq www
permit tcp 192.168.0.0 0.0.255.255 any eq 443
permit tcp 192.168.0.0 0.0.255.255 any eq smtp
ip access-list extended CBAC-OUT-NEW
permit ip host 192.168.20.1 any
ip access-list extended PBR-NOFILTER
ip access-list extended STATIC-NAT
permit ip host 192.168.100.x any
permit ip host 192.168.3.x any
ip access-list extended WEBFILTERING
permit ip 192.168.101.0 0.0.0.255 any
permit ip 192.168.100.0 0.0.0.255 any
deny   tcp any any eq 443
permit ip any any
ip sla 1
icmp-echo [gateway public ip]
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
logging 192.168.3.x
snmp-server community key RO
snmp-server location Internet Router 2
snmp-server contact x
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal change
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps license
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps firewall serverstatus
snmp-server enable traps ipmobile
snmp-server enable traps rf
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps mpls vpn
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host 192.168.3.x version 2c key
route-map CYTA permit 10
match ip address NATacl-NEW
match interface FastEthernet0/0/0
route-map PRIMETEL permit 10
route-map PBR permit 10
match ip address ALLOW-WEB
set ip next-hop verify-availability [gateway public ip ] 1 track 10
route-map PBR permit 30
match ip address ALLOW-EVERYWHEREACCESS
set ip next-hop verify-availability [gateway public ip 2] 2 track 20
route-map CYTA-STATIC-NAT permit 10
match ip address STATIC-NAT
route-map PRIMETEL-STATIC-NAT permit 10
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
2 Accepted Solutions
HI,
May be You're hitting this bug: CSCed28542.
http://www.cisco.com/en/US/docs/ios/12_3t/release/notes/123tcavs.html
you need to Upgrade your IOS.
Dont forget to rate helpful posts.
Richard Burts
You may not be hitting that specific bug, but the trace back indicates that you are hitting some software problem. A different version of IOS is probably your best alternative.
Rick
Rick
7 Replies 7
Richard Burts
I do not see any obvious issues in the configuration that you posted. So I have a few questions which may help us to give you some advice:
- when the problem occurs are there other console messages (especially anything like traceback) or is the message you refer to the only console message that is generated?
- has this router been running for a while with out issue? Or is this a fairly new router and the problem started immediately?
- am I correct in understanding that adding a second Internet was a recent change? Or were both Internet connections done at the same time?
- is this router covered by a maintenance contract?
This error message indicates a problem with the scheduler process in IOS. It is most likely a software bug. If the router is covered by a maintenance contract then opening a case with Cisco TAC is probably the best thing to do since they have better tools to diagnose the specific problem.
Rick
Rick
This router was kept offline us a backup (it's not a new router, we have it 4 years) and it has about the same configuration with the online router except ip sla,tracking and PBR
(We were requested to implement PBR, and have the primary internet line which is 24mbps to allow users to access the internet using www and ssl, and the other internet line to take care for any other traffic)
This router is located in the H.Q and handles around 100 of users also vpn is passing through from other remote offices.
(Total of 150 users)
During launch time when 10-20 users are working i don't see any problem and everything is working properly.
After launch time, the routers works fine for 15-30 minutes and then it reboots.
As far as i am concerned no it's not under maintenance contract.
I received a traceback please see below all output and advise
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x40086950 0x43EE0BAC 0x42057CA8 0x4207BBC0 0x4207247C 0x42043FC8 0x41ECD4FC 0x41ECD680 0x41EB90F4 0x41EB9B44 0x41EB9FB4 0x41EBA070 0x41EBA2B8
$0 : 00000000, AT : 46B00000, v0 : 47150000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 47F9A8D8
t0 : 46ED0000, t1 : 3400E101, t2 : 461B0000, t3 : 00000005
t4 : 00000008, t5 : 461B0000, t6 : 0209B4A0, t7 : 0000000A
s0 : 42057CA0, s1 : 49131E88, s2 : 0B0D0B0D, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 04000000, t9 : 00000332, k0 : 3040A801, k1 : A000F000
gp : 46B0BCD0, sp : 47F9A230, s8 : 46B00000, ra : 40086950
EPC  : 40086950, ErrorEPC : BFC0900C, SREG     : 3400E103
MDLO : 00000006, MDHI     : 00000000, BadVaddr : 0B0D0AF9
DATA_START : 0x43F4AAB0
Cause 00000010 (Code 0x4): Address Error (load or instruction fetch) exception
=== Start of Crashinfo Collection (13:37:01 EEDT Tue Nov 26 2013) ===
For image:
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(20)YA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 29-Aug-08 04:20 by prod_rel_team
HI,
I don't think  that i am hitting above mentioned bug since my IOS is 12.4(20) Y which is not included in "Known affected releases". listed in that hyperlink.
See below
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(20)Y        A1, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Which upgrade paths do i have for the current IOS, in order to exclude the possibility that it might be a software bug? i have 256 MB OF DRAM
Richard Burts
Rick
Rick
After upgrading to a newer version the rebooting problem has been resolved.
However i am still facing a problem with nat translation.
I will open a new discussion please reply if you can assist.
Thanks both of you for your helpful answer
I am glad that our suggestions helped you to achieve a solution for this problem. Thank you for using the rating system to mark this question as answered.
Opening a new thread for a different problem on the router was the right approach. I have posted some suggestions in your new thread. I hope they will be helpful.
Rick
Rick
