2811 Router
mel.farhat
looking for command line to format the compact flash on a 2811. perform format flash: - volume ID ?
Amit Singh
You have to first check whether the Compact Flash is a Type B or Type C file system and use the command " erase flash:" or "format flash:". Please see the link below for identifying and formatting the flash:
http://www.cisco.com/en/US/products/ps5854/prod_troubleshooting_guide09186a00802c35d3.html#wp38723
HTH,Please rate if it does.
-amit singh
