2901 WAN concurrent users
cg100668
We are quoting for a 2901 Cisco router with a SHDSL card for a customer who require 200 concurrent connections through the SHDSL line. Could you please advise if the Cisco 2901 router is suitable to support the 200 concurrent users? Is there any data sheet supporting this statement?
Please advise.
Chandra
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Routers and switches generally don't "care" about number of users, they "care" about traffic volume.
If you can precisely answer how much bandwidth your 200 users will use, you can be pretty precise in selecting a device.
For a 4 Mbps link, a 2901 will easily handle that.  If fact, a 800 series would work fine too.  However, if the 2901 was also going to be used for routing on the LAN side, it could be totally inadequate.
PS:
Cisco recommends a 2901 for up to 25 Mbps of WAN bandwidth, but this is a very conservative.
7 Replies 7
Marwan ALshawi
200 concurrent connection dose not reflect how much bandwidth required
What is the wan link bandwidth ? Is there any other requirement like VoIP, security, VPN ?
Marwanshawi,
Thanks for the reply. In fact the site is connected using a 4 Mbps link. The remote sites will also be connected using SHDSL lines. Since the server is situated at the main site, remote users access the main site for database access, the customer wishes to know if 200 concurrent users can access the servers simultaneously.
Chandra
Well 4Mbps is not high 2901 or 2921 can work
Marwanshawi,
Can 200 concurrent users access the router simultaneously. Can the router support the 200 concurrent access? Do we have any kind of data sheet mentioning the above?
Chandra
The users would not access the router but yes the 2901 can handle 4 Mbps of traffic
Wether 4 Mbps is enough for 200 users is a different question
Joseph W. Doherty
Disclaimer
Posting
PS:
Joseph,
Thanks for the reply. It is very helpful in formulating the reply to the customer.
Chandra
