How can i add extra Gbe Module to 2911 Router or cant i do this ?
Thanks for in advance.
balaji.bandi
2911 -EOL I do not believe you get officially, but you may try with refurbished if you keen to buy.
you can add Ethernet switch modules :
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
BB
for the 2911, you can add a service module, an EHWIC, or an ISM (see the link below, scroll down to Table 3):
Joseph W. Doherty
Assuming you can, do keep in mind Cisco recommends the 2911 for up to 35 Mbps, duplex.  (NB: the 2911 can often do more than 35 Mbps, but capacity varies greatly based on traffic mix and router features being used.)
