07-01-2019 02:18 PM
Does anyone know if there are third party SFP DAC cables that work with the 2921 router? The 10gtek SFP+ cables claim to work with Cisco, I just dont want to buy something that wont work in the SFP port on my router.
THANKS!
Solved! Go to Solution.
07-01-2019 03:08 PM
if you refer to this cable:
I wouldn't know why it shouldn't work. The Cisco manufactured one costs you about 100 dollars, this one only about 20. If for some reason it doesn't work, you can always return it, obviously...
07-01-2019 03:08 PM
07-01-2019 03:42 PM
Thanks! I was worried because I have some SFP+ LC/LC transceivers from 10gtek running multi-mode 1 meter fiber cables that I tried in the slot and they weren't recognized. For that price on that DAC cable I think I will have to give it a try :-)
08-30-2019 03:27 AM
10Gtek SFP DAC cable can work with the 2921 router because the 10Gtek SFP DAC cable I bought works well with it. It's pretty cost-efficient!
