2951 PoE Abilities
Patrick McHenry
Level 4
Level 4
To run a PoE switch module on the 2951, am I going to need more than the standard one power supply? The documentation is a little fuzzy on this.
Router#sh ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.2(1)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 19-Feb-12 01:53 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
Router uptime is 23 minutes
System returned to ROM by reload at 09:48:33 $time_z Fri Aug 3 2012
System restarted at 13:50:24 UTC Fri Aug 3 2012
System image file is "flash0:c2951-universalk9-mz.SPA.152-1.T2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
compliance with U.S. and local country laws. B
Aug  3 14:13:46.944: %SYS-5-CONFIG_I: Configured from console by consoley using this product you
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 481280K/43008K bytes of memory.
Processor board ID FTX1630AHPX
3 Gigabit Ethernet interfaces
2 terminal lines
2 Virtual Private Network (VPN) Modules
1 cisco ISM Crypto Engine(s)
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FTX1630AHPX
Technology Package License Information for Module:'c2951'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
Thanks, Pat.
paolo bevilacqua
Yes, you need
PWR-2921-51-POE
