2GE-CU-SFP ports showing down
datamodule
We have cisco ISR 4321 router and installed 2GE-CU-SFP module.Router detected ports on the router but they are showing the status as follows
GigabitEthernet0/1/0 unassigned YES manual down down
GigabitEthernet0/1/1 unassigned YES NVRAM down down
Module shows working
show hw-module subslot 0/1 oir
Module Model Operational Status
subslot 0/1 NIM-2GE-CU-SFP ok
Not sure we have to do anything else.I am trying to connect WAN link to RJ 45 port.
Thanks for your help
Hello @datamodule ,
if you are not using SFP optics and you want to use RJ45 try
interface gi0/1/0
media-type rj45
! this should tell the router you want to use the RJ45 port
Hope to help
Giuseppe
12 Replies 12
datamodule
IOS XE version running Version 16.3.5, RELEASE SOFTWARE (fc1)
marce1000
 - The ports may be shutdown in defaulted mode ; check this link for Basic Interface Configuration (example) :
 https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/cfgGENIMs.html#pgfId-1062600
 M.
Thanks for your reply.I have tried that before posting here.I have cconfigured IP address,no shut and saved cconfig  but still shows as down/down.Which is why i am getting confused.
 - Issue show logging after the port(s) have been configured and or especially after the no shut command has been given, check if any additional info and or errors are provided in the output.
 M.
After i entered no shut immediately port went down with the following message
%LINK-3-UPDOWN: Interface GigabitEthernet0/1/0, changed state to down
what is the output of:
show hw-module subslot 1/0 transceiver 0 idprom
Have you tired to stop/start the module with:
hw-module subslot slot / subslot [reload | stop | start]
sh hw-module subslot 0/1 transceiver 0 idprom
Output shows nothing  because we don't have any SFP on that port.We have connected WAN connetion to RJ45 port.
Tried stopping and starting of the module without suess.
--> sh hw-module subslot 0/1 transceiver 0 idprom
I think your subslot is 1/0
sh hw-module subslot 1/0 transceiver 0 idprom
My subslot is definitely 0/1 and the ports detected as 0/1/0 and 0/1/1
GigabitEthernet0/1/0 172.16.10.10 YES manual down down
is it an option to try and upgrade to one of the recommended releases below and check if that makes a difference ?
Gibraltar 16.12.3(MD)
Fuji 16.9.5(MD)
Hello @datamodule ,
interface gi0/1/0
media-type rj45
Hope to help
Giuseppe
Finally found the issue with carrier and module is working fine.
