2xWAN uplink with 2 VPN ipsec on each
Piotr Pawlowski
Dear all,
I have router wiht 2 WAN uplinks. On both of them I need to have VPN ipsec connection.
With one VPN everythings works correctly. After adding second VPN configuration problem started.
I fugred out, that problem is in default gateway.
When I do:
no ip route 0.0.0.0 0.0.0.0 $GW_IP_of_primary_uplink$
ip route 0.0.0.0 0.0.0.0 $GW_IP_of_secondary_uplink$
VPN on first interface is not able to connect while VPN on second interface starts working.
What I would like to achieve is to have both VPN operating on my router.
Thank you in advance for any help.
Piotr
2 Accepted Solutions
Can you try using the next hop ip addresses instead of the interfaces in all of your static routes?
It is very good advice to use a next hop address in the static route rather than just the outbound interface. A static route such as ip route 192.168.200.0 255.255.255.0 GigabitEthernet0/2 will cause the router to generate an ARP request for each remote destination (which causes much more work on your router) and is dependent on the next hop router enabling proxy arp (and many networks are disabling proxy arp - especially on external connections - because it is perceived as a security risk). So if the next hop router does not enable proxy arp then this static route will not work at all.
Piotr says that 192.168.220.0 is unreachable. It is possible that this is because of the format of the static route. Please change the static route to use a next hop address and tell us if the problem improves.
Rick
Rick
12 Replies 12
Richard Burts
Piotr
You have given us a little informaiton but not enough for us to give you very good answers. From what you have given us it sounds like the "interesting traffic" that will bring up a VPN follows the default route. So perhaps the answer might be that you need some routing for the destinations used for the first VPN that is different from the routing used for destinations in the other VPN. Perhaps if you post the configuration it would help us to give you better advice.
Rick
Rick
Hi Richard,
Thank you for your post.
Below you can find my config. I removed some sensitive/unused information from it.
version 15.2
ip cef
redundancy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key key_for_first_vpn address IP_of_first_VPN_peer
crypto isakmp key key_for_second_vpn address IP_of_second_VPN_peer
crypto ipsec transform-set GLIWICE esp-3des esp-md5-hmac
mode tunnel
crypto ipsec transform-set 1stCentral esp-3des esp-md5-hmac
mode tunnel
crypto map 1stCentral-map 2 ipsec-isakmp
set peer IP_of_second_VPN_peer
set transform-set 1stCentral
match address acl_access_to_1st_central
crypto map GLIWICE-MAP 1 ipsec-isakmp
set peer IP_of_first_VPN_peer
set transform-set GLIWICE
match address 190
interface GigabitEthernet0/0
description LAN
ip address 10.0.0.1 255.255.254.0
ip nat inside
ip virtual-reassembly in
ip policy route-map rm-to-1stCentral
duplex auto
speed auto
interface GigabitEthernet0/1
ip address IP_of_primary_uplink 255.255.255.252
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
service-policy output skype-policy-map
interface GigabitEthernet0/2
ip address IP_of_secondary_uplink 255.255.255.224
ip access-group 101 in
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GW_IP_of_secondary_uplink
ip route 0.0.0.0 0.0.0.0 GW_IP_of_primary_uplink
ip access-list extended acl-route-servers-traffic
permit ip host 10.0.0.6 any
ip access-list extended acl_access_to_1st_central
permit ip 10.0.0.0 0.0.1.255 192.168.220.0 0.0.0.255
ip access-list extended acl_access_to_1st_central2
permit ip host 10.0.1.12 any log
ip sla auto discovery
access-list 1 permit 10.0.0.0 0.0.1.255
access-list 10 permit 0.0.0.0 255.255.254.0
access-list 101 permit ip any any
access-list 102 permit ip any any
access-list 110 deny   ip 10.0.0.0 0.0.1.255 192.168.220.0 0.0.0.255
access-list 110 deny   ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255
access-list 110 permit ip 10.0.0.0 0.0.1.255 any
access-list 111 deny   ip 10.0.0.0 0.0.1.255 192.168.220.0 0.0.0.255
access-list 111 permit ip 10.0.0.0 0.0.1.255 any
access-list 190 permit ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255
route-map all_gdansk_network_via_limes permit 10
match ip address 1 acl_access_to_1st_central2
set ip next-hop GW_IP_of_secondary_uplink GW_IP_of_primary_uplink
route-map rm-haarlem-via-task permit 10
match ip address acl-route-servers-traffic
set ip next-hop verify-availability
route-map track_isp permit 10
match ip address 101
match interface GigabitEthernet0/1
route-map track_isp permit 20
match ip address 102
match interface GigabitEthernet0/2
set ip next-hop GW_IP_of_primary_uplink
route-map rm-to-1stCentral permit 10
match ip address acl_access_to_1st_central2
set ip default next-hop  GW_IP_of_primary_uplink
route-map nat_isp2 permit 10
match ip address 110
route-map nat_isp1 permit 10
match ip address 111
control-plane
scheduler allocate 20000 1000
end
Piotr
Thank you for the additional information. In your original post it looked like you were doing one default route at a time. In this config there are two default routes at the same time. You probably should decide whether you want to have a primary route and a backup route (one at a time) or do load sharing (use both at the same time).
But there are likely to be VPN issues with either of the approaches unless you provide some additional routing information. For 1stCentral-map VPN to work its traffic must exit on interface Gig0/1. And for GLIWICE-MAP VPN to work then its traffic must exit on interface Gig0/2. The default routes will not accomplish that. So I suggest that you configure a route that will specify that traffic for 192.168.220 will exit on Gig0/1. And that you configure a route that will specify that traffic for 10.0.100 will exit on Gig0/2.
Rick
Rick
What I pasted is a current config.
After more diging I came into situation where both VPN are up, both networks 'after' VPNs are available. I achieved it with following config:
ip route 0.0.0.0 0.0.0.0 GW_IP_of_primary_uplink 10
ip route 10.0.100.0 255.255.255.0 GigabitEthernet0/2
ip route 192.168.220.0 255.255.255.0 GigabitEthernet0/1
However, right now whole LAN traffic is going via secondary uplink, which I can not accept.
When I give:
ip route 0.0.0.0 0.0.0.0 GW_IP_of_secondary_uplink 10
192.168.220.0/24 network is unreachable.
What I am doing wrong?
Thanks in advance.
Hi Piotr,
Have you also tried adding a static route for the destination VPN gateways out of the respective interfaces? For example, if the peer IP address for crypro map 1stCentral-map is 1.1.1.1 and the peer IP address of crypto map GLIWICE-MAP is 2.2.2.2, you will have he following static routes. These will be needed to not only direct the interesting traffic out of the correct interfaces, but to direct the peer VPN gateways out of the correct interfaces as well.
ip route 1.1.1.1 255.255.255.255 GigabitEthernet0/1
ip route 2.2.2.2 255.255.255.255 GigabitEthernet0/2
Just added such configuration:
ip route first_VPN_router_IP 255.255.255.255 GigabitEthernet0/2
ip route second_VPN_router_IP 255.255.255.255 GigabitEthernet0/2
and this caused, that both VPN site-2-site can not be established...
I am confused...
Rick
Rick
Well, that is what I have now:
ip route 10.0.100.0 255.255.255.0 GW_IP_of_primary_uplink
ip route first_VPN_router_IP 255.255.255.255 GW_IP_of_primary_uplinks
ip route 192.168.220.0 255.255.255.0 GW_IP_of_secondary_uplink
ip route second_VPN_router_IP 255.255.255.255 GW_IP_of_secondary_uplink
Both VPN connections are establishe, as well as both VPN networks 'after' VPN are visible.
However, right now in show ip route I see, that gateway of last resort is my GW_IP_of_secondary_uplink . Some of the traffic is going via primary uplink, some goes via secondary.
Should I pllay wright now with PBR in order to specify which LAN hosts can access secondary uplink (and also secondary VPN )? In general I do not want to enable whole traffic via secondary uplink, because it is slower than primary one...
Thanks in advance.
Piotr
I am glad that changing the format of the static routes seems to have resolved the problem with VPN.
When you configure static default routes for both outbound interfaces, such as
then you are telling your router that there are two equal paths to outside and the router will load share on the links. I believe that this is the current behavior that you describe. If you do not want load share because the second uplink is slower then I suggest that you change your approach to the routing. One solution that should work would be to have a single static default route which uses the faster uplink and to have static routes for VPN pointing to the second uplink. You might also consider configuring a floating static default route to provide failover to the second uplink in case of failure of the primary uplink. (If you do this you should probably also consider configuring IP SLA to track the primary uplink and to aid in failover.) You might also consider configuring some Policy Based Routing to send some types of traffic (perhaps traffic from specific hosts or perhaps some types of traffic such as Email) out the secondary uplink. This would result in most traffic using the faster primary uplink and would allow some traffic to use the slower secondary uplink.
Rick
Rick
Piotr Pawlowski
Thank you Richard and willwetherman for your suport and effort in solving my problem.
I will now try to configure PBR, but this is totally different topic, so this case can be treated as solved.
Thanks once again!
Piotr
I am glad that the VPN part of your problem is resolved and that our suggestions were helpful. Thank you for using the rating system to mark this question as answered. This will help other readers of the forum to recognize that helpful information is in this discussion. Good luck with the PBR configuration. If you run into issues feel free to start another discussion on that topic.
Rick
Rick
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
