3- Ethernet Port Routing
dharmesh
Which cisco router will supports 3 ethernet port with routing facility?
Dharmesh
Pavel Bykov
Level 5
Level 5
Depends on how you want to use the ports. If you need ROUTED ports, you can for example buy 1841 router and buy a module HWIC-1FE. You will have 3 ports total
