Highlighted
Beginner
3 T1's Bound to a Multilink
I want to remove a policy from a multilink and 3 T1's.  What would be the best practice/commands to use to shut them down make changes and then start them back up to test before writing the config?  Would the following work/be the safest/best practice?
#Shut multilink1
#Shut serial1
#Shut serial2
#Shut serial3
Make config Changes
#No shut serial1
#No shut serial2
#No shut serial3
#No shut multilink1
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Mentor
You don't need to shut down your WAN links to remove the service-policy command.
You simply go into configuration mode -> sub-interface mode -> copy the service-policy command and append a no to it.
Highlighted
show log will contain all the information you need.
Since you rebooted it the router, that information is now gone.
14 REPLIES 14
Highlighted
Advisor
What type of policies are you changing?
HTH, John *** Please rate all useful posts ***
Highlighted
These are the changes that I want to make.
#config t
(config)#interface Multilink1
(config-if)#no max-reserved-bandwidth 100
(config-if)#no service-policy output 25_74
(config-if)#exit
(config)#interface serial 0/1/0:1
(config-if)#fair-queue
(config-if)#exit
(config)#interface serial 0/0/1:1
(config-if)#exit
(config)#interface serial 0/0/0:1
(config-if)#exit
Highlighted
In addition to what Edison said, I don’t believe you’ll need fair-queue on the physical interface if you’re queuing in your policy on the MLP interface. But you don’t need to shut your interface down to make these changes.
HTH,
John
Highlighted
Hi John,
Hope you are doing well!
This is part II from a long thread
https://supportforums.cisco.com/thread/2133115?tstart=0
He is removing QoS from this router because it wasn't configured properly. I told him the only thing his previous QoS config was doing was changing the queuing from FIFO to FQ for class class-default. He wants to mimic that section w/o having a service-policy.
FQ is often recommended for slow speed links such as T1s.
Highlighted
Hi Edison! ☺ I hope you’re doing well!
Ah, I see what he’s doing now….
Thanks!
Highlighted
Hall of Fame Mentor
Highlighted
I did that and the whole Multilink came down, it was during production so I just restarted the router to get the previous running config back, because I had 8 remote locations calling me.
Highlighted
Please post the 'show version' output. There are some bugs floating around that can crash the router while removing a service-policy.
Highlighted
That shouldn’t have happened…what router and IOS version are you on? I did that one time on a 3745 to remove netflow on an interface and it locked the router up. I had to update the IOS because of a known problem.
Highlighted
MPLS#show version
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:10 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
KamcoMPLS uptime is 20 hours, 3 minutes
System restarted at 15:41:44 EST Wed Feb 22 2012
System image file is "flash:c2800nm-ipbase-mz.124-15.T9.bin"
Cisco 2821 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FTX1333AJ6X
2 Gigabit Ethernet interfaces
3 Serial interfaces
4 Channelized T1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Highlighted
Want to make sure I understand you correctly, the multilink came down but the router didn't crash, correct?
I couldn't find any bugs with router crashing due to service-policy removal with that particular IOS version.
If the multilink came down, what errors did you see in the log?
Are you sure you didn't remove any ppp related commands under the serial interfaces?
One best practice learning experience from here, 'do not make configuration changes in a router during production'.
Highlighted
Correct the router didn't crash, because I was still connected to it when the calls started coming in, at that point I just went to the server room and power cycled it.  I didn't do any other commands then the ones posted earlier.  Which loggs should I look at to see what happened?  Good advice to adhere to.
Highlighted
Highlighted
Edison
ok, it is not showing anything from yesterday at 16:00 EST`.
So I am getting our service provider engineer involved so that we can get all these polices matching on the edge, backbone and remote routers.  So when I am applying the correct policies and if it drops again, I'll be sure it is night time and to check the logs and not power the router off.
Thanks again for the crash course in QOS,
Dan
