3500 XL switch
zathura43
Is there an easier way to find the commands so I can disable or enable ex:telnet or ssh.
9 Replies 9
Roberto Salazar
Level 8
Level 8
For a switch running IOS, it is the same as in routers. If you do not configure "login" or "transport input none" under the line vty x x, it will not allow telnet. or if you want to be able to telnet to the switch:
line vty 0 4
login
tranport input all
conf t
enable password
This platform does not support SSH.
Please rate helpful posts.
how should I disable telnet.
you just need to use command
rememer to rate this post if it helps
regards
Devang
to disalbe telnet use this command
regards
Devang
hope it works..
senthil
devang_etcom
Level 7
Level 7
hi for telnet you can have...
line vty 0 4
login
transport input all
exec-timeout 5 0 (its good task to configure exec time out)
remember to configer the enable password...
regards
Devang
Once I use "transport input none" command this will disable telnet, so others can't telnet into the switch, where as when I connect directly into the switch I should be able to use HyperTerminal to access the configuration am I correct.
yes you are right...when you enter the command transport input none under the line vty 0 4 then it will not allow any protocol enter into line vty...
hope this helps you
regards
Devang
yes, you are correct, Hyperterminal will work with out any problem.
Remember you are giveing "transport input none" in vty interface, it will not affect your console login.
Thanks.
Senthil Kumar,C
