3640 IOS problem
meerz
I up loaded a wrong IOS on my 3640 router and it is not showing ATM module in IOS. IOS installed is Version 12.3(19), RELEASE SOFTWARE (fc2). I have NM-1A-OC3MM module. Can someone tell me correct IOS.
Meer
Hi Meer ,
can you paste show diag of the router.
Your router has 64Mb DRAM and 10Mb flash.
You can load following ios.
1.c3640-jk2s-mz.121-5.YD6
Min DRAM -64 M and flash - 16M
2.c3640-jk2s-mz.121-5.XM7
3.c3640-jk2s-mz.121-3a.XI8
satish
5 Replies 5
smothuku
Level 7
Level 7
Hi Meer ,
How many modules are installed in router and what are those .which ios you are using in router.
Are you going to install only NM-1A-OC3MM in router.What is the flash and RAM capacity of the router.
I can help you after getting the above info.
You can load the following ios which supports NM-1A-OC3MM module.
1.c3640-jk9s-mz.123-14.T7
Min.DRAM - 128 M and flash - 32M
2.c3640-jk9s-mz.122-2.XT3
Min.DRAM - 100 M and flash - 32M
Hope it helps you.Plz rate it.
satish
Hi Satish,
Thanks for your reply. I have one NM-1A-OC3MM and a ethernet card and few serial interfaces on one module. Below is sh version.
cisco 3640 (R4700) processor (revision 0x00) with 49152K/16384K bytes of memory.
Processor board ID 26735267
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
8 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Meer
Hi Meer ,
satish
Slot 0:
Sync/Async Port adapter, 8 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.0 Board revision C0
Serial number 26538240 Part number 800-01225-03
FRU Part Number: NM-8A/S=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 25 01 00 01 94 F1 00 50 04 C9 03 00 00 00 00
0x10: 60 77 7A 00 01 12 04 17 FF FF FF FF FF FF FF FF
Slot 1:
Ethernet Port adapter, 1 port
Hardware revision 1.1 Board revision F0
Serial number 27265389 Part number 800-02026-03
FRU Part Number: NM-1E=
0x00: 01 43 01 01 01 A0 09 6D 50 07 EA 03 00 00 00 00
0x10: 78 00 00 00 01 11 28 00 FF FF FF FF FF FF FF FF
Slot 2:
Unknown (type 154) Port adapter
Port adapter is disabled
Hardware revision 1.0 Board revision H0
Serial number 26620286 Part number 800-03700-02
FRU Part Number: NM-1A-OC3MM=
0x00: 01 9A 01 00 01 96 31 7E 50 0E 74 02 00 00 00 00
0x10: 88 00 00 00 01 11 06 17 FF FF FF FF FF FF FF FF
It was working good. It happened after IOS upgrade.
Meer
Hi Meer ,
You can load any one of the ios, it supports all the modules.
These IOS requires only 64 Mb DRAM and 16Mb flash.
IP PLUS feature set :
1.c3640-is-mz.122-2.XT3
2.c3640-is-mz.122-2.XN
3.c3640-is-mz.122-8.T5
4.c3640-is-mz.121-5.YD6
5.c3640-is-mz.121-3.XQ3
Enterprise feature set:
1.c3640-js-mz.122-6c.M1
2.c3640-js-mz.122-31
3.c3640-js-mz.121-5.YD6
If you need any info update the query.
All the best :)
satish
