12-21-2006 09:42 PM - edited 03-03-2019 03:09 PM
I hv one 3640 i upload the IOS through rommon mode successfully.
now when i do the
Router#sh flash
System flash directory:
No files in System flash
[0 bytes used, 4194304 available, 4194304 total]
4096K bytes of processor board System flash (Read/Write)
it gives the above message about IOS
as wht i understand from above that if i reload the router now it definetly doesnt comes up.
Wht shall i hv to do to rectify the same.
12-21-2006 10:28 PM
Hi Parvinder
Do make use of TFTP copying to copy the required IOS code onto your flash.
Once you are done with that do define the boot loader(boot system command) statement pointing the ios code file saved in your flash.
After doing the same make sure you have both the ios code in flash as well as your boot system command appears in your config.
Also make sure that you have correct config register value set in your config..
regds
12-21-2006 11:42 PM
can you share "show version" of this router with us?
12-22-2006 12:40 AM
Router#sh ver
IOS (tm) 3600 Software (C3640-I-M), Version 12.2(17a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 11:25 by pwade
Image text-base: 0x60008930, data-base: 0x60A36000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
Router uptime is 3 hours, 6 minutes
Running default software
cisco 3640 (R4700) processor (revision 0x00) with 28672K/4096K bytes of memory.
Processor board ID 12906756
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
Configuration register is 0x3922
12-22-2006 01:15 AM
The loaded IOS image is running from RAM
Current boot field value is 0010 (default).
This causes the system to boot the image from default boot filename "cisco2-3600" if boot from flash fails, in your case there is no IOS inflash:
Enabling the boot system command override the default filename for booting over the network from a TFTP server.
As mentioned in earlier post, you need to upload IOS in flash from TFTP and then set the boot system command to allow router to boot from flash:
hope it helps .... rate if it does ...
