03-23-2010 12:54 AM - edited 03-04-2019 07:53 AM
Hi all.
I am wondering if anyone is able to comment on the maximum number of NM-1A-E3's you can get into a 3745.
Documentation suggests the "maximum recommended" is 2, but I am wondering if it is possible to install 3 and whether the router will identify all of them and let you use them all?
Has anyone attempted this before that can share their experience?
Worst case scenario is that I will have to install two routers but it would be nice to get away with just one.
Tom
Solved! Go to Solution.
03-23-2010 03:14 AM
Hello Tom,
someone has done this test : one of the three NM is kept in shut down
I remember a thread about this.
you should not be able to use more then two network modules on a single device
Hope to help
Giuseppe
03-23-2010 03:14 AM
Hello Tom,
Hope to help
Giuseppe
03-23-2010 03:18 AM
Hi Giuseppe.
Thanks very much. At least I know where I stand now, and I'll have to put 2 routers at that site.
(Unfortunately I dont have the budget to afford a 7200VXR at this stage)
Tom
