3745 Router modules hot swappable?
gokada
I would like to insert a 2FE2W module into a 3745 router into a vacant module slot. Are the modules hot-swappable or "OIR" Online insertion and removable capable? Please help!
according to the data sheet (see link below), OIR is supported on the 3745:
Online Insertion and Removal-capable (3745 only)
--> Allows network modules to be swapped or serviced with minimal impact to network availability
Check this link to the data sheet and scroll down to Table 1:
Cisco 3700 Series Multiservice Access Routers
Data Sheet
http://www.cisco.com/en/US/products/hw/routers/ps282/products_data_sheet09186a008009203f.html
HTH,
GP
Data Sheet
HTH,
GP
Many many thanks! I looked everywhere for a document that stated it was or wasn't OIR capable but to no avail until you responded. I appreciate your help greatly and I'm grateful for your quick response.
GO
Hi, Just want to confirm if the same applys for a 3845? I am sure this is OIR capable.
Yavuz
Yavuz,
OIR is supported on almost all NMs across 3660, 3745 and 3845
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a00801de926.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
