3745 Router Problem
a.hajhamad
Level 4
Level 4
I have a cisco 3745 router with Ethernet switch module, my problem that every few months the SVI interface for the router will be stuck , that it will loose logically all the connectivity with other neighbors routers and switches but the interface physically and the protocol is up , I try to see the logs but it doesn't show where is the problem, the only way that can solve the problem by reload the router. So kindly your help
Abd Alqader
paolo bevilacqua
Which exact IOS are you running ?
Hello my friend,
I'm using IOS (tm) 3700 Software (C3745-JK9S-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Suggest you upgrade to latest 12.3(25) that has many bugs fixed and chances are the problem will go away.
