3750 ME traffic shaping down stream traffic
James Robertson
I am trying to come up with the best way to traffic shape traffic with 3750 Me switches.  the traffic will be coming from a 6504 Sup-7203b downstream and going out the wan.  Core---L3---->6504--intvlan80--trunkport to--->3750Me---g/1/1/1-trunkport to---MetroE network--->int f0/0.80--branch router.  The idea is to use the 3750 to traffic shape the traffic going towards the wan/branch to 500 to match the contracted rate and then to use qos on shaped rate.  I tried to apply it to g1/1/1 using port based policies but it did not shape the traffic.  I changed everything to IP interfaces and it worked.  I need to break up the metroe into different vlans so I can bring branch offices in on different vlans.
Jamie
Marwan ALshawi
Hi Jamie
Cisco
cisoc 3750 Metro Series switches with the Hierarchical
Queuing Framework features on the Enhanced Service ports is
able to deliver traffic shaping, 2 rates 3 colors policers, and other
advance QoS features on its 8000 queues. With the set of rich
features and flexibility, the Service Providers will be able to
offers differentiated services to multiple customers serviced by a
Catalyst 3750 Metro Series switch.
class-map match-all custAvlan10 --- identify Customer A
match vlan 10
class-map match-all custAipprec5 -- Customer A’s priority traffic
match ip precedence 5
class-map match-all custAipprec0 -- Customer A’s Internet traffic
match ip precedence 0
class-map match-all custAipprec3 -- Customer A’s VPN traffic
match ip precedence 3
class-map match-all custBvlan15 -- identify Customer B
match vlan 15
match vlan inner 2
match vlan inner 100
class-map match-all custBipdscp32 --- Customer B’s VPN traffic
match ip dscp 32
class-map match-all custBipdscp8 -- Customer B’s data traffic
match ip dscp 8
policy-map custAclasspolicy -- policy for Customer A’s class queues
class custAipprec5
priority -- assign strict priority to this queue
class custAipprec3
bandwidth percent 60
random-detect
random-detect precedence 3 200 400 3000
class custAipprec0
bandwidth percent 20
policy-map custBclasspolicy -- policy for Customer B’s class queues
class custBipdscp32
bandwidth percent 70
class custBipdscp8
class class-default
shape average 10000000
policy-map vlanpolicy -- logical level policy ataching class level policies
class custAvlan10
shape average 150000000
service-policy custAclasspolicy
class custBvlan15
police cir 75000000 bc 8192 pir 100000000 be 8192
service-policy custBclasspolicy
policy-map ES1 -- physical level policy attaching logical level policy
class class-default
shape average 500000000
service-policy vlanpolicy
interfaces gi1/1/1 --- atach the HQF policy to the interface
service-policy output ES1
if helpful Rate
Will traffic shaping with the vlan still work if the vlan interfaces are on the 6504 not the 3750me.  The 6504 will peer with the branch offices not the 3750me.  The traffic will traverse the 3750me and egress to the wan and hopefully it will shape the traffic.
again
|core|---L3----->|wan6504(intvlan80)|---L2trunk--->|g1/0/1-3750me--g1/1/1(SP)|---L2trunk------>METROE
Jamie
Marwan ALshawi
Only the 3750ME can do shaping
Shape same to the example then u can shape per vlan on the wan edge 3750
If helpful rate
